[QGIS Commit] r13345 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org
Thu Apr 22 10:50:11 EDT 2010
Author: wonder
Date: 2010-04-22 10:50:10 -0400 (Thu, 22 Apr 2010)
New Revision: 13345
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.h
Fix calculation of feature count in OGR provider (FeatureCount function works with current spatial filter)
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2010-04-22 07:37:01 UTC (rev 13344)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2010-04-22 14:50:10 UTC (rev 13345)
@@ -271,7 +271,7 @@
// getting the total number of features in the layer
// TODO: This can be expensive, do we really need it!
- featuresCounted = OGR_L_GetFeatureCount( ogrLayer, TRUE );
+ recalculateFeatureCount();
// get the extent_ (envelope) of the layer
QgsDebugMsg( "Starting get extent" );
@@ -771,7 +771,6 @@
f.setFeatureId( OGR_F_GetFID( feature ) );
- ++featuresCounted;
OGR_F_Destroy( feature );
return returnValue;
@@ -792,7 +791,7 @@
returnvalue = false;
- featuresCounted = OGR_L_GetFeatureCount( ogrLayer, TRUE ); //new feature count
return returnvalue;
@@ -997,8 +996,9 @@
QString sql = QString( "REPACK %1" ).arg( layerName ); // don't quote the layer name as it works with spaces in the name and won't work if the name is quoted
QgsDebugMsg( QString( "SQL: %1" ).arg( sql ) );
OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, NULL );
OGR_L_GetExtent( ogrOrigLayer, ( OGREnvelope * ) extent_, TRUE );
return returnvalue;
@@ -1860,3 +1860,22 @@
return true;
+void QgsOgrProvider::recalculateFeatureCount()
+ OGRGeometryH filter = OGR_L_GetSpatialFilter( ogrLayer );
+ if ( filter )
+ filter = OGR_G_Clone( filter );
+ OGR_L_SetSpatialFilter( ogrLayer, 0 );
+ // feature count returns number of features within current spatial filter
+ // so we remove it if there's any and then put it back
+ featuresCounted = OGR_L_GetFeatureCount( ogrLayer, TRUE );
+ if ( filter )
+ OGR_L_SetSpatialFilter( ogrLayer, filter );
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.h
--- trunk/qgis/src/providers/ogr/qgsogrprovider.h 2010-04-22 07:37:01 UTC (rev 13344)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.h 2010-04-22 14:50:10 UTC (rev 13345)
@@ -245,8 +245,9 @@
/**Get an attribute associated with a feature*/
void getFeatureAttribute( OGRFeatureH ogrFet, QgsFeature & f, int attindex );
+ /** find out the number of features of the whole layer */
+ void recalculateFeatureCount();
private:
unsigned char *getGeometryPointer( OGRFeatureH fet );
QgsFieldMap mAttributeFields;
