[QGIS Commit] r13360 - in trunk/qgis: debian src/plugins/spatialquery
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 24 05:00:27 EDT 2010
Author: jef
Date: 2010-04-24 05:00:25 -0400 (Sat, 24 Apr 2010)
New Revision: 13360
   trunk/qgis/debian/changelog
   trunk/qgis/debian/qgis.install
   trunk/qgis/debian/rules
   trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
   trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.cpp
   trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.h
   trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.cpp
   trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.h
   trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.cpp
   trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.h
   trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.cpp
   trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.h
   trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
   trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h
   trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
   trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
   trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
   trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.h
spatial query plugin: fix warnings, reindent, include in debian package
Modified: trunk/qgis/debian/changelog
--- trunk/qgis/debian/changelog	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/debian/changelog	2010-04-24 09:00:25 UTC (rev 13360)
@@ -5,8 +5,9 @@
   * require CMake >2.6 and Qt 4.4 for sid
   * remove circular dependencies
   * integrate new GRASS raster provider
+  * add spatialquery plugin
- -- Jürgen E. Fischer <jef at norbit.de>  Thu, 04 Feb 2010 23:20:29 +0100
+ -- Jürgen E. Fischer <jef at norbit.de>  Sat, 24 Apr 2010 10:57:21 +0200
 qgis (1.4.0) UNRELEASED; urgency=low
Modified: trunk/qgis/debian/qgis.install
--- trunk/qgis/debian/qgis.install	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/debian/qgis.install	2010-04-24 09:00:25 UTC (rev 13360)
@@ -26,6 +26,7 @@
 usr/lib/qgis/libosmprovider.so
 usr/lib/qgis/librasterterrainplugin.so
 usr/lib/qgis/liblabelingplugin.so
+usr/lib/qgis/libspatialqueryplugin.so
 usr/share/pixmaps/qgis-icon.xpm
 usr/share/pixmaps/qgis-mime-icon.png
 usr/share/pixmaps/qgis-mime-icon.png usr/share/icons/crystalsvg/128x128/mimetypes
Modified: trunk/qgis/debian/rules
--- trunk/qgis/debian/rules	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/debian/rules	2010-04-24 09:00:25 UTC (rev 13360)
@@ -10,7 +10,7 @@
 DEB_BUILD_GNU_TYPE  ?= $(shell dpkg-architecture -qDEB_BUILD_GNU_TYPE)
 DISTRIBUTION := $(shell dpkg-parsechangelog --format rfc822 | sed -ne "s/^Distribution: //p")
-ifneq ($(DISTRIBUTION),$(findstring $(DISTRIBUTION),"lenny hardy intrepid jaunty karmic"))
+ifneq ($(DISTRIBUTION),$(findstring $(DISTRIBUTION),"lenny hardy intrepid jaunty karmic lucid"))
 DISTRIBUTION := sid
 endif
Modified: trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
--- trunk/qgis/src/plugins/spatialquery/CMakeLists.txt	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/CMakeLists.txt	2010-04-24 09:00:25 UTC (rev 13360)
@@ -14,11 +14,6 @@
 SET (SPATIALQUERY_MOC_HDRS
-     qgsspatialquery.h
-     qgsreaderfeatures.h
-     qgsrubberselectid.h
-     qgsgeometrycoordinatetransform.h
-     qgsmngprogressbar.h
 SET( SPATIALQUERY_UIS qgsspatialquerydialogbase.ui)
Modified: trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -23,33 +23,33 @@
 QgsGeometryCoordinateTransform::~QgsGeometryCoordinateTransform()
-    delete mCoordTransform;
+  delete mCoordTransform;
 } // QgsGeometryCoordinateTransform::~QgsGeometryCoordinateTransform()
-void QgsGeometryCoordinateTransform::setCoordinateTransform(QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference)
+void QgsGeometryCoordinateTransform::setCoordinateTransform( QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference )
-    // Transform Forward: Target to Reference
-    // * Use srs() to use old versions QGis - will be deprecited in 2.0 (after use crs())
-    QgsCoordinateReferenceSystem srsTarget = lyrTarget->srs();
-    QgsCoordinateReferenceSystem srsReference = lyrReference->srs();
+  // Transform Forward: Target to Reference
+  // * Use srs() to use old versions QGis - will be deprecited in 2.0 (after use crs())
+  QgsCoordinateReferenceSystem srsTarget = lyrTarget->srs();
+  QgsCoordinateReferenceSystem srsReference = lyrReference->srs();
-    mCoordTransform = new QgsCoordinateTransform(srsTarget, srsReference);
+  mCoordTransform = new QgsCoordinateTransform( srsTarget, srsReference );
-    mFuncTransform = ( srsTarget != srsReference)
+  mFuncTransform = ( srsTarget != srsReference )
                    ? &QgsGeometryCoordinateTransform::setGeomTransform
                    : &QgsGeometryCoordinateTransform::setNoneGeomTransform;
 } // void QgsGeometryCoordinateTransform::setCoordinateTransform(QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference)
-void QgsGeometryCoordinateTransform::transform(QgsGeometry *geom)
+void QgsGeometryCoordinateTransform::transform( QgsGeometry *geom )
-    (this->*mFuncTransform)(geom);
+  ( this->*mFuncTransform )( geom );
 } // void QgsGeometryCoordinateTransform::transformCoordenate()
-void QgsGeometryCoordinateTransform::setGeomTransform(QgsGeometry *geom)
+void QgsGeometryCoordinateTransform::setGeomTransform( QgsGeometry *geom )
-    geom->transform(*mCoordTransform);
+  geom->transform( *mCoordTransform );
 } // void QgsGeometryCoordinateTransform::setGeomTransform(QgsGeometry *geom)
Modified: trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.h
--- trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsgeometrycoordinatetransform.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -29,44 +29,44 @@
 class QgsGeometryCoordinateTransform
-public:
+  public:
     * \brief Constructor for a Geometry Coordinate Transform.
-    QgsGeometryCoordinateTransform () {};
+    QgsGeometryCoordinateTransform() {};
     * \brief Destructor
-    ~QgsGeometryCoordinateTransform ();
+    ~QgsGeometryCoordinateTransform();
     * \brief Sets the coordinate reference system the target and reference layer
     * \param lyrTarget      target layer.
     * \param lyrReference   reference layer.
-    void setCoordinateTransform(QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference);
+    void setCoordinateTransform( QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference );
     * \brief Transform the coordinates reference system of the geometry, if target have the different system of reference
     * \param geom      Geometry
-    void transform(QgsGeometry *geom);
-private:
+    void transform( QgsGeometry *geom );
+  private:
     * \brief Transform the coordinates reference system of the geometry (use by transform)
-    void setGeomTransform(QgsGeometry *geom);
+    void setGeomTransform( QgsGeometry *geom );
     * \brief None transform the coordinates reference system of the geometry (use by transform)
-    void setNoneGeomTransform(QgsGeometry *geom) {};
+    void setNoneGeomTransform( QgsGeometry *geom ) {};
     QgsCoordinateTransform * mCoordTransform;
-    void (QgsGeometryCoordinateTransform::* mFuncTransform)(QgsGeometry *);
+    void ( QgsGeometryCoordinateTransform::* mFuncTransform )( QgsGeometry * );
 #endif // GEOMETRYCOORDINATETRANSFORM_H
Modified: trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -19,32 +19,32 @@
 #include "qgsmngprogressbar.h"
-MngProgressBar::MngProgressBar(QProgressBar *pb)
+MngProgressBar::MngProgressBar( QProgressBar *pb )
-    mPb = pb;
-    mPb->reset();
+  mPb = pb;
+  mPb->reset();
 } // MngProgressBar::MngProgressBar(QProgressBar *pb)
-void MngProgressBar::init(int minimum, int maximum)
+void MngProgressBar::init( int minimum, int maximum )
-    mPb->reset();
-    mPb->setRange(minimum, maximum);
+  mPb->reset();
+  mPb->setRange( minimum, maximum );
 } // void MngProgressBar::init(int minimum, int maximum)
-void MngProgressBar::setFormat(QString format)
+void MngProgressBar::setFormat( QString format )
 // special caracters:
 // %p - is replaced by the percentage completed.
 // %v - is replaced by the current value.
 // %m - is replaced by the total number of steps.
-    mPb->setFormat(format);
+  mPb->setFormat( format );
 } // void MngProgressBar::setFormat(QString format)
-void MngProgressBar::step(int step)
+void MngProgressBar::step( int step )
-        mPb->setValue(step);
-        mPb->repaint();
+  mPb->setValue( step );
+  mPb->repaint();
 } // void MngProgressBar::step()
Modified: trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.h
--- trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsmngprogressbar.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -27,39 +27,39 @@
 class MngProgressBar
-public:
+  public:
     * \brief Constructor for a MngProgressBar.
     * \param pb Pointer to the MngProgressBar object.
-    MngProgressBar(QProgressBar *pb);
+    MngProgressBar( QProgressBar *pb );
     * \brief Destructor
     ~MngProgressBar() { mPb->reset(); };
     * \brief Sets the progress bar's minimum and maximum values to minimum and maximum respectively
     * \param minimum minimun value.
     * \param maximum maximum value.
-    void init(int minimum, int maximum);
+    void init( int minimum, int maximum );
     * \brief Sets the format the current text.
     * \param format This property holds the string used to generate the current text.
-    void setFormat(QString format);
+    void setFormat( QString format );
     * \brief Sets current value progress bar's
     * \param step current value
-    void step(int step );
+    void step( int step );
-private:
+  private:
     QProgressBar * mPb;
 #endif // QGSMNGPROGRESSBAR_H
Modified: trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -1,88 +1,88 @@
-                          qgsreaderfeatures.cpp
-    begin                : Dec 29, 2009
-    copyright            : (C) 2009 by Diego Moreira And Luiz Motta
-    email                : moreira.geo at gmail.com And motta.luiz at gmail.com
- *   This program is free software; you can redistribute it and/or modify  *
- *   it under the terms of the GNU General Public License as published by  *
- *   the Free Software Foundation; either version 2 of the License, or     *
- *   (at your option) any later version.                                   *
-/*  $Id: $ */
-#include <qgsvectordataprovider.h>
-#include "qgsreaderfeatures.h"
-QgsReaderFeatures::QgsReaderFeatures(QgsVectorLayer *layer, bool useSelection)
-	mLayer = layer;
-	initReader(useSelection);
-} // QgsReaderFeatures::QgsReaderFeatures(QgsVectorLayer *layer, bool useSelection)
-QgsReaderFeatures::~QgsReaderFeatures()
-        if ( mListSelectedFeature.count() > 0 )
-            mListSelectedFeature.clear();
-} // QgsReaderFeatures::~QgsReaderFeatures()
-bool QgsReaderFeatures::nextFeature(QgsFeature & feature)
-        return (this->*mFuncNextFeature)(feature);
-} // bool QgsReaderFeatures::nextFeature(QgsFeature & feature)
-void QgsReaderFeatures::initReader(bool useSelection)
-        if ( useSelection )
-            mListSelectedFeature = mLayer->selectedFeatures();
-            mIterSelectedFeature = mListSelectedFeature.begin();
-            mFuncNextFeature = &QgsReaderFeatures::nextFeatureSelected;
-	else
-            QgsAttributeList attListGeom;
-            int idGeom = 0;
-            attListGeom.append(idGeom);
-            mLayer->select(attListGeom, mLayer->extent(), true, false);
-            mFuncNextFeature = &QgsReaderFeatures::nextFeatureTotal;
-} // void QgsReaderFeatures::initReader()
-bool QgsReaderFeatures::nextFeatureTotal ( QgsFeature & feature )
-    return mLayer->dataProvider()->nextFeature(feature);
-} // bool QgsReaderFeatures::nextFeatureTotal ( QgsFeature & feature )
-bool QgsReaderFeatures::nextFeatureSelected ( QgsFeature & feature )
-    bool bReturn = true;
-    if ( mIterSelectedFeature == mListSelectedFeature.end() )
-        bReturn = false;
-    else
-        feature = *mIterSelectedFeature;
-        mIterSelectedFeature++;
-    return bReturn;
-} // bool QgsReaderFeatures::nextFeatureSelected( QgsFeature &feature )
+                          qgsreaderfeatures.cpp
+    begin                : Dec 29, 2009
+    copyright            : (C) 2009 by Diego Moreira And Luiz Motta
+    email                : moreira.geo at gmail.com And motta.luiz at gmail.com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/*  $Id: $ */
+#include <qgsvectordataprovider.h>
+#include "qgsreaderfeatures.h"
+QgsReaderFeatures::QgsReaderFeatures( QgsVectorLayer *layer, bool useSelection )
+  mLayer = layer;
+  initReader( useSelection );
+} // QgsReaderFeatures::QgsReaderFeatures(QgsVectorLayer *layer, bool useSelection)
+QgsReaderFeatures::~QgsReaderFeatures()
+  if ( mListSelectedFeature.count() > 0 )
+    mListSelectedFeature.clear();
+} // QgsReaderFeatures::~QgsReaderFeatures()
+bool QgsReaderFeatures::nextFeature( QgsFeature & feature )
+  return ( this->*mFuncNextFeature )( feature );
+} // bool QgsReaderFeatures::nextFeature(QgsFeature & feature)
+void QgsReaderFeatures::initReader( bool useSelection )
+  if ( useSelection )
+    mListSelectedFeature = mLayer->selectedFeatures();
+    mIterSelectedFeature = mListSelectedFeature.begin();
+    mFuncNextFeature = &QgsReaderFeatures::nextFeatureSelected;
+  else
+    QgsAttributeList attListGeom;
+    int idGeom = 0;
+    attListGeom.append( idGeom );
+    mLayer->select( attListGeom, mLayer->extent(), true, false );
+    mFuncNextFeature = &QgsReaderFeatures::nextFeatureTotal;
+} // void QgsReaderFeatures::initReader()
+bool QgsReaderFeatures::nextFeatureTotal( QgsFeature & feature )
+  return mLayer->dataProvider()->nextFeature( feature );
+} // bool QgsReaderFeatures::nextFeatureTotal ( QgsFeature & feature )
+bool QgsReaderFeatures::nextFeatureSelected( QgsFeature & feature )
+  bool bReturn = true;
+  if ( mIterSelectedFeature == mListSelectedFeature.end() )
+    bReturn = false;
+  else
+    feature = *mIterSelectedFeature;
+    mIterSelectedFeature++;
+  return bReturn;
+} // bool QgsReaderFeatures::nextFeatureSelected( QgsFeature &feature )
Modified: trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.h
--- trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsreaderfeatures.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -1,78 +1,78 @@
-/*  $Id: $ */
-#ifndef READERFEATURES_H
-#define READERFEATURES_H
-#include <qgsvectorlayer.h>
-#include <qgsfeature.h>
-* \class QgsReaderFeatures
-* \brief Reader Features
-class QgsReaderFeatures
-public:
-    * \brief Constructor for a Reader Features.
-    * \param layer Pointer to the layer.
-    * \param useSelection Use or not use the features selected
-    QgsReaderFeatures(QgsVectorLayer *layer, bool useSelection);
-    * \brief Destructor
-    ~QgsReaderFeatures();
-    * \brief Next feature
-    * \param feature reference to next Feature.
-    * \returns True if has next feature.
-    bool nextFeature(QgsFeature & feature);
-private:
-    * \brief init Reader
-    void initReader(bool useSelection);
-    * \brief Next feature, not using the features selected
-    bool nextFeatureTotal(QgsFeature & feature);
-    * \brief Next feature, using the features selected
-    bool nextFeatureSelected(QgsFeature & feature);
-    QgsVectorLayer * mLayer;
-    QgsFeatureList   mListSelectedFeature;
-    QList<QgsFeature>::iterator mIterSelectedFeature;
-    bool (QgsReaderFeatures::* mFuncNextFeature) ( QgsFeature &);
-#endif // READERFEATURES_H
+                          qgsreaderfeatures.h
+/*  $Id: $ */
+#ifndef READERFEATURES_H
+#define READERFEATURES_H
+#include <qgsvectorlayer.h>
+#include <qgsfeature.h>
+* \class QgsReaderFeatures
+* \brief Reader Features
+class QgsReaderFeatures
+  public:
+    * \brief Constructor for a Reader Features.
+    * \param layer Pointer to the layer.
+    * \param useSelection Use or not use the features selected
+    QgsReaderFeatures( QgsVectorLayer *layer, bool useSelection );
+    * \brief Destructor
+    ~QgsReaderFeatures();
+    * \brief Next feature
+    * \param feature reference to next Feature.
+    * \returns True if has next feature.
+    bool nextFeature( QgsFeature & feature );
+  private:
+    * \brief init Reader
+    void initReader( bool useSelection );
+    * \brief Next feature, not using the features selected
+    bool nextFeatureTotal( QgsFeature & feature );
+    * \brief Next feature, using the features selected
+    bool nextFeatureSelected( QgsFeature & feature );
+    QgsVectorLayer * mLayer;
+    QgsFeatureList   mListSelectedFeature;
+    QList<QgsFeature>::iterator mIterSelectedFeature;
+    bool ( QgsReaderFeatures::* mFuncNextFeature )( QgsFeature & );
+#endif // READERFEATURES_H
Modified: trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -22,62 +22,62 @@
 #include "qgsfeature.h"
-QgsRubberSelectId::QgsRubberSelectId( QgsMapCanvas* mapCanvas)
+QgsRubberSelectId::QgsRubberSelectId( QgsMapCanvas* mapCanvas )
-    mIsPolygon = true;
-    mMapCanvas = mapCanvas;
-    mRubberBand = new QgsRubberBand( mMapCanvas, mIsPolygon );
+  mIsPolygon = true;
+  mMapCanvas = mapCanvas;
+  mRubberBand = new QgsRubberBand( mMapCanvas, mIsPolygon );
 } // QgsRubberSelectId::QgsRubberSelectId( QgsMapCanvas* mapCanvas, bool isPolygon = true )
 QgsRubberSelectId::~QgsRubberSelectId()
-    reset();
-    delete mRubberBand;
+  reset();
+  delete mRubberBand;
 } // QgsRubberSelectId::~QgsRubberSelectId()
-void QgsRubberSelectId::isGeometryNotPolygon(bool isPolygon = false)
+void QgsRubberSelectId::isGeometryNotPolygon( bool isPolygon = false )
-    reset();
-    mIsPolygon = isPolygon;
+  reset();
+  mIsPolygon = isPolygon;
 } // void QgsRubberSelectId::isGeometryNotPolygon(bool isPolygon)
 void QgsRubberSelectId::reset()
-    mRubberBand->reset( mIsPolygon );
+  mRubberBand->reset( mIsPolygon );
 } // void QgsRubberSelectId::reset()
-void QgsRubberSelectId::setColor(int colorRed, int colorGreen, int colorBlue, int width, float alfa = 0)
+void QgsRubberSelectId::setColor( int colorRed, int colorGreen, int colorBlue, int width, float alfa = 0 )
-    QColor color = QColor( colorRed, colorGreen, colorBlue );
-    color.setAlpha( alfa );
-    mRubberBand->setColor( color );
-    mRubberBand->setWidth( width );
+  QColor color = QColor( colorRed, colorGreen, colorBlue );
+  color.setAlpha( alfa );
+  mRubberBand->setColor( color );
+  mRubberBand->setWidth( width );
 } // void QgsRubberSelectId::setColor(int colorRed, int colorGreen, int colorBlue, float alfa, width)
 void QgsRubberSelectId::addFeature( QgsVectorLayer* mLayer, int fid )
-    QgsFeature feat;
-    if ( !mLayer->featureAtId( fid, feat, true, false ) )
-        return;
-    if ( !feat.geometry() )
-        return;
+  QgsFeature feat;
+  if ( !mLayer->featureAtId( fid, feat, true, false ) )
+    return;
+  if ( !feat.geometry() )
+    return;
-    mRubberBand->setToGeometry( feat.geometry(), mLayer );
+  mRubberBand->setToGeometry( feat.geometry(), mLayer );
 } // void QgsRubberSelectId::addFeature( QgsVectorLayer* mLayer, int Id )
 void QgsRubberSelectId::show()
-    mRubberBand->show();
+  mRubberBand->show();
 } // QgsRubberSelectId::show()
Modified: trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.h
--- trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsrubberselectid.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -30,12 +30,12 @@
 class QgsRubberSelectId
-public:
+  public:
     * Constructor for a class RubberSelectedId.
     * @param mapCanvas Pointer to the iface.mapCanvas().
-    QgsRubberSelectId( QgsMapCanvas* mapCanvas);
+    QgsRubberSelectId( QgsMapCanvas* mapCanvas );
     * \brief Destructor
@@ -45,7 +45,7 @@
     * \brief Set if is geometry polygon for rubber band
     * \param isPolygon   boolean for type geometry is polygon
-    void isGeometryNotPolygon(bool isPolygon);
+    void isGeometryNotPolygon( bool isPolygon );
     * \brief Reset rubber band
@@ -72,7 +72,7 @@
     * \brief Show rubber band
     void show();
-private:
+  private:
     //! RubberBand
     QgsRubberBand* mRubberBand;
     bool mIsPolygon;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -25,163 +25,166 @@
 #include "qgsgeometrycoordinatetransform.h"
 #include "qgsspatialquery.h"
-QgsSpatialQuery::QgsSpatialQuery(MngProgressBar *pb)
+QgsSpatialQuery::QgsSpatialQuery( MngProgressBar *pb )
-    mPb = pb;
-    mUseTargetSelection = mUseReferenceSelection = false;
+  mPb = pb;
+  mUseTargetSelection = mUseReferenceSelection = false;
 } // QgsSpatialQuery::QgsSpatialQuery(MngProgressBar *pb)
 QgsSpatialQuery::~QgsSpatialQuery()
-    delete mReaderFeaturesTarget;
+  delete mReaderFeaturesTarget;
 } // QgsSpatialQuery::~QgsSpatialQuery()
-void QgsSpatialQuery::setSelectedFeaturesTarget(bool useSelected)
+void QgsSpatialQuery::setSelectedFeaturesTarget( bool useSelected )
-    mUseTargetSelection = useSelected;
+  mUseTargetSelection = useSelected;
 } // void QgsSpatialQuery::setSelectedFeaturesTarget(bool useSelected)
-void QgsSpatialQuery::setSelectedFeaturesReference(bool useSelected)
+void QgsSpatialQuery::setSelectedFeaturesReference( bool useSelected )
-    mUseReferenceSelection = useSelected;
+  mUseReferenceSelection = useSelected;
 } // void QgsSpatialQuery::setSelectedFeaturesReference(bool useSelected)
 void QgsSpatialQuery::runQuery( QSet<int> & qsetIndexResult, int relation, QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference )
-    setQuery(lyrTarget, lyrReference);
+  setQuery( lyrTarget, lyrReference );
-    // Create Spatial index for Reference - Set mIndexReference
-    mPb->setFormat("Processing 1/2 - %p%");
-    int totalStep = mUseReferenceSelection
-                    ? mLayerReference->selectedFeatureCount()
-                    : (int) (mLayerReference->featureCount());
-    mPb->init(1, totalStep);
-    setSpatialIndexReference(); // Need set mLayerReference before
+  // Create Spatial index for Reference - Set mIndexReference
+  mPb->setFormat( "Processing 1/2 - %p%" );
+  int totalStep = mUseReferenceSelection
+                  ? mLayerReference->selectedFeatureCount()
+                  : ( int )( mLayerReference->featureCount() );
+  mPb->init( 1, totalStep );
+  setSpatialIndexReference(); // Need set mLayerReference before
-    // Make Query
-    mPb->setFormat("Processing 2/2 - %p%");
-    totalStep = mUseTargetSelection
-                ? mLayerTarget->selectedFeatureCount()
-                : (int) (mLayerTarget->featureCount());
+  // Make Query
+  mPb->setFormat( "Processing 2/2 - %p%" );
+  totalStep = mUseTargetSelection
+              ? mLayerTarget->selectedFeatureCount()
+              : ( int )( mLayerTarget->featureCount() );
-    execQuery(qsetIndexResult, relation);
+  execQuery( qsetIndexResult, relation );
 } // QSet<int> QgsSpatialQuery::runQuery( int relation)
-QMap<QString, int>* QgsSpatialQuery::getTypesOperations(QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference)
+QMap<QString, int>* QgsSpatialQuery::getTypesOperations( QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference )
-    /* Relations from OGC document (obtain in February 2010)
-       06-103r3_Candidate_Implementation_Specification_for_Geographic_Information_-_Simple_feature_access_-_Part_1_Common_Architecture_v1.2.0.pdf
+  /* Relations from OGC document (obtain in February 2010)
+     06-103r3_Candidate_Implementation_Specification_for_Geographic_Information_-_Simple_feature_access_-_Part_1_Common_Architecture_v1.2.0.pdf
-       (P)oint, (L)ine and (A)rea
-       Target Geometry(P,L,A) / Reference Geometry (P,L,A)
-       dim -> Dimension of geometry
-       Relations:
-        1) Intersects and Disjoint: All
-        2) Touches: P/L P/A L/L L/A A/A
-           dimReference  > dimTarget OR dimReference = dimTarget if dimReference > 0
-        3) Crosses: P/L P/A L/L L/A
-           dimReference  > dimTarget OR dimReference = dimTarget if dimReference = 1
-        4) Within: P/L P/A L/A A/A
-           dimReference  > dimTarget OR dimReference = dimTarget if dimReference = 2
-        5) Equals: P/P L/L A/A
-           dimReference = dimTarget
-        6) Overlaps: P/P L/L A/A
-        7) Contains: L/P A/P A/L A/A
-           dimReference  <  dimTarget OR dimReference = dimTarget if dimReference = 2
+     (P)oint, (L)ine and (A)rea
+     Target Geometry(P,L,A) / Reference Geometry (P,L,A)
+     dim -> Dimension of geometry
+     Relations:
+      1) Intersects and Disjoint: All
+      2) Touches: P/L P/A L/L L/A A/A
+         dimReference  > dimTarget OR dimReference = dimTarget if dimReference > 0
+      3) Crosses: P/L P/A L/L L/A
+         dimReference  > dimTarget OR dimReference = dimTarget if dimReference = 1
+      4) Within: P/L P/A L/A A/A
+         dimReference  > dimTarget OR dimReference = dimTarget if dimReference = 2
+      5) Equals: P/P L/L A/A
+         dimReference = dimTarget
+      6) Overlaps: P/P L/L A/A
+      7) Contains: L/P A/P A/L A/A
+         dimReference  <  dimTarget OR dimReference = dimTarget if dimReference = 2
-    QMap<QString, int> * operations = new QMap<QString, int>;
-    operations->insert(QObject::tr("Intersects"), Intersects);
-    operations->insert(QObject::tr("Disjoint"), Disjoint);
+  QMap<QString, int> * operations = new QMap<QString, int>;
+  operations->insert( QObject::tr( "Intersects" ), Intersects );
+  operations->insert( QObject::tr( "Disjoint" ), Disjoint );
-    short int dimTarget=0, dimReference=0;
-    dimTarget = dimensionGeometry(lyrTarget->geometryType());
-    dimReference = dimensionGeometry(lyrReference->geometryType());
+  short int dimTarget = 0, dimReference = 0;
+  dimTarget = dimensionGeometry( lyrTarget->geometryType() );
+  dimReference = dimensionGeometry( lyrReference->geometryType() );
-    if (dimReference > dimTarget)
+  if ( dimReference > dimTarget )
+    operations->insert( QObject::tr( "Touches" ), Touches );
+    operations->insert( QObject::tr( "Crosses" ), Crosses );
+    operations->insert( QObject::tr( "Within" ), Within );
+  else if ( dimReference < dimTarget )
+    operations->insert( QObject::tr( "Contains" ), Contains );
+  else // dimReference == dimTarget
+    operations->insert( QObject::tr( "Equals" ), Equals );
+    operations->insert( QObject::tr( "Overlaps" ), Overlaps );
+    switch ( dimReference )
-        operations->insert(QObject::tr("Touches"), Touches);
-        operations->insert(QObject::tr("Crosses"), Crosses);
-        operations->insert(QObject::tr("Within"), Within);
+      case 0:
+        break;
+      case 1:
+        break;
+      case 2:
-    else if (dimReference < dimTarget)
-        operations->insert(QObject::tr("Contains"), Contains);
-    else // dimReference == dimTarget
-        operations->insert(QObject::tr("Equals"), Equals);
-        operations->insert(QObject::tr("Overlaps"), Overlaps);
-        switch (dimReference)
-        case 0:
-            break;
-        case 1:
-            break;
-        case 2:
-    return operations;
+  return operations;
 } // QMap<QString, int>* QgsSpatialQuery::getTypesOperators(QgsVectorLayer* lyrTarget, QgsVectorLayer* lyrReference)
-short int QgsSpatialQuery::dimensionGeometry(QGis::GeometryType geomType)
+short int QgsSpatialQuery::dimensionGeometry( QGis::GeometryType geomType )
-    int dimGeom = 0;
-    switch (geomType)
+  int dimGeom = 0;
+  switch ( geomType )
     case QGis::Point:
-        dimGeom = 0;
-        break;
+      dimGeom = 0;
+      break;
     case QGis::Line:
-        dimGeom = 1;
-        break;
+      dimGeom = 1;
+      break;
     case QGis::Polygon:
-        dimGeom = 2;
-    return dimGeom;
+      dimGeom = 2;
+    default:
+      Q_ASSERT( 0 );
+      dimGeom = 0;
+  return dimGeom;
 } // int QgsSpatialQuery::dimensionGeometry(QGis::GeometryType geomType)
-void QgsSpatialQuery::setQuery (QgsVectorLayer *layerTarget, QgsVectorLayer *layerReference)
+void QgsSpatialQuery::setQuery( QgsVectorLayer *layerTarget, QgsVectorLayer *layerReference )
-    mLayerTarget = layerTarget;
-    mReaderFeaturesTarget = new QgsReaderFeatures(mLayerTarget, mUseTargetSelection);
-    mLayerReference = layerReference;
+  mLayerTarget = layerTarget;
+  mReaderFeaturesTarget = new QgsReaderFeatures( mLayerTarget, mUseTargetSelection );
+  mLayerReference = layerReference;
 } // void QgsSpatialQuery::setQuery (QgsVectorLayer *layerTarget, QgsVectorLayer *layerReference)
-bool QgsSpatialQuery::hasValidGeometry(QgsFeature &feature)
+bool QgsSpatialQuery::hasValidGeometry( QgsFeature &feature )
   if ( ! feature.isValid() )
-      return false;
+    return false;
   QgsGeometry *geom = feature.geometry();
   if ( NULL == geom )
-      return false;
+    return false;
   GEOSGeometry *geomGeos = geom->asGeos();
-  if ( GEOSisEmpty(geomGeos) || 1 !=  GEOSisValid(geomGeos))
+  if ( GEOSisEmpty( geomGeos ) || 1 !=  GEOSisValid( geomGeos ) )
-      return false;
+    return false;
   return true;
@@ -190,153 +193,153 @@
 void QgsSpatialQuery::setSpatialIndexReference()
-    QgsReaderFeatures * readerFeaturesReference = new QgsReaderFeatures(mLayerReference, mUseReferenceSelection);
-    QgsFeature feature;
-    int step = 1;
-    while ( true )
+  QgsReaderFeatures * readerFeaturesReference = new QgsReaderFeatures( mLayerReference, mUseReferenceSelection );
+  QgsFeature feature;
+  int step = 1;
+  while ( true )
+    if ( ! readerFeaturesReference->nextFeature( feature ) )
-        if ( ! readerFeaturesReference->nextFeature(feature) )
-            break;
-        mPb->step(step++);
+      break;
+    mPb->step( step++ );
-        if ( ! hasValidGeometry(feature) )
-            continue;
-        mIndexReference.insertFeature(feature);
+    if ( ! hasValidGeometry( feature ) )
+      continue;
-    delete readerFeaturesReference;
+    mIndexReference.insertFeature( feature );
+  delete readerFeaturesReference;
 } // void QgsSpatialQuery::setSpatialIndexReference()
-void QgsSpatialQuery::execQuery( QSet<int> & qsetIndexResult, int relation)
+void QgsSpatialQuery::execQuery( QSet<int> & qsetIndexResult, int relation )
-    // Set function GEOS
-    char(*operation)(const GEOSGeometry *, const GEOSGeometry*);
-    switch (relation)
+  // Set function GEOS
+  char( *operation )( const GEOSGeometry *, const GEOSGeometry* );
+  switch ( relation )
     case Disjoint:
-        operation = &GEOSDisjoint;
-        break;
+      operation = &GEOSDisjoint;
+      break;
     case Equals:
-        operation = &GEOSEquals;
-        break;
+      operation = &GEOSEquals;
+      break;
     case Touches:
-        operation = &GEOSTouches;
-        break;
+      operation = &GEOSTouches;
+      break;
     case Overlaps:
-        operation = &GEOSOverlaps;
-        break;
+      operation = &GEOSOverlaps;
+      break;
     case Within:
-        operation = &GEOSWithin;
-        break;
+      operation = &GEOSWithin;
+      break;
     case Contains:
-        operation = &GEOSContains;
-        break;
+      operation = &GEOSContains;
+      break;
     case Crosses:
-        operation = &GEOSCrosses;
-        break;
+      operation = &GEOSCrosses;
+      break;
     case Intersects:
-        operation = &GEOSIntersects;
-        break;
+      operation = &GEOSIntersects;
+      break;
-    // Transform referencer Target = Reference
-    QgsGeometryCoordinateTransform *coordinateTransform = new QgsGeometryCoordinateTransform();
-    coordinateTransform->setCoordinateTransform(mLayerTarget, mLayerReference);
+  // Transform referencer Target = Reference
+  QgsGeometryCoordinateTransform *coordinateTransform = new QgsGeometryCoordinateTransform();
+  coordinateTransform->setCoordinateTransform( mLayerTarget, mLayerReference );
-    // Set function for populate result
-    void (QgsSpatialQuery::* funcPopulateIndexResult)
-            (QSet<int> &, int, QgsGeometry *,
-             char(*)(const GEOSGeometry *, const GEOSGeometry *) );
-    funcPopulateIndexResult = ( relation == Disjoint )
-                              ? &QgsSpatialQuery::populateIndexResultDisjoint
-                              : &QgsSpatialQuery::populateIndexResult;
+  // Set function for populate result
+  void ( QgsSpatialQuery::* funcPopulateIndexResult )
+  ( QSet<int> &, int, QgsGeometry *,
+    char( * )( const GEOSGeometry *, const GEOSGeometry * ) );
+  funcPopulateIndexResult = ( relation == Disjoint )
+                            ? &QgsSpatialQuery::populateIndexResultDisjoint
+                            : &QgsSpatialQuery::populateIndexResult;
-    QgsFeature featureTarget;
-    QgsGeometry * geomTarget;
-    int step = 1;
-    while( true )
-        if ( ! mReaderFeaturesTarget->nextFeature(featureTarget) ) break;
+  QgsFeature featureTarget;
+  QgsGeometry * geomTarget;
+  int step = 1;
+  while ( true )
+    if ( ! mReaderFeaturesTarget->nextFeature( featureTarget ) ) break;
-        if ( ! hasValidGeometry(featureTarget) )
-            continue;
+    if ( ! hasValidGeometry( featureTarget ) )
+      continue;
-        geomTarget = featureTarget.geometry();
-        coordinateTransform->transform(geomTarget);
+    geomTarget = featureTarget.geometry();
+    coordinateTransform->transform( geomTarget );
-        (this->*funcPopulateIndexResult)
-              (qsetIndexResult, featureTarget.id(), geomTarget, operation);
-    delete coordinateTransform;
+    ( this->*funcPopulateIndexResult )
+    ( qsetIndexResult, featureTarget.id(), geomTarget, operation );
+  delete coordinateTransform;
 } // QSet<int> QgsSpatialQuery::execQuery( QSet<int> & qsetIndexResult, int relation)
 void QgsSpatialQuery::populateIndexResult(
-        QSet<int> &qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
-        char(*operation)(const GEOSGeometry *, const GEOSGeometry *) )
+  QSet<int> &qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
+  char( *operation )( const GEOSGeometry *, const GEOSGeometry * ) )
-    QList<int> listIdReference;
-    listIdReference = mIndexReference.intersects(geomTarget->boundingBox());
-    if ( listIdReference.count() == 0 )
+  QList<int> listIdReference;
+  listIdReference = mIndexReference.intersects( geomTarget->boundingBox() );
+  if ( listIdReference.count() == 0 )
+    return;
+  GEOSGeometry * geosTarget = geomTarget->asGeos();
+  QgsFeature featureReference;
+  QgsGeometry * geomReference;
+  QList<int>::iterator iterIdReference = listIdReference.begin();
+  for ( ; iterIdReference != listIdReference.end(); iterIdReference++ )
+    mLayerReference->featureAtId( *iterIdReference, featureReference );
+    geomReference = featureReference.geometry();
+    if (( *operation )( geosTarget, geomReference->asGeos() ) == 1 )
-        return;
+      qsetIndexResult.insert( idTarget );
+      break;
-    GEOSGeometry * geosTarget = geomTarget->asGeos();
-    QgsFeature featureReference;
-    QgsGeometry * geomReference;
-    QList<int>::iterator iterIdReference = listIdReference.begin();
-    for( ; iterIdReference != listIdReference.end(); iterIdReference++ )
-        mLayerReference->featureAtId(*iterIdReference, featureReference);
-        geomReference = featureReference.geometry();
-        if( (*operation)(geosTarget, geomReference->asGeos()) == 1 )
-            qsetIndexResult.insert(idTarget);
-            break;
 } // void QgsSpatialQuery::populateIndexResult(...
 void QgsSpatialQuery::populateIndexResultDisjoint(
+    return;
+  bool addIndex = true;
+    if (( *operation )( geosTarget, geomReference->asGeos() ) == 0 )
-        return;
+      addIndex = false;
+      break;
-    bool addIndex = true;
-        if( (*operation)(geosTarget, geomReference->asGeos()) == 0 )
-            addIndex = false;
-            break;
-    if ( addIndex )
+  if ( addIndex )
 } // void QgsSpatialQuery::populateIndexResultDisjoint( ...
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -35,14 +35,14 @@
 enum Topologic_Relation
-    Intersects,
-    Disjoint,
-    Touches,
-    Crosses,
-    Within,
-    Equals,
-    Overlaps,
-    Contains
+  Intersects,
+  Disjoint,
+  Touches,
+  Crosses,
+  Within,
+  Equals,
+  Overlaps,
+  Contains
@@ -53,12 +53,12 @@
 class QgsSpatialQuery
-public:
+  public:
     * \brief Constructor for a Spatial query.
-    QgsSpatialQuery(MngProgressBar *pb);
+    QgsSpatialQuery( MngProgressBar *pb );
     * \brief Destructor
@@ -69,13 +69,13 @@
     * \brief Sets if using selected features in Target layer
     * \param useSelected TRUE if use selected.
-    void setSelectedFeaturesTarget(bool useSelected);
+    void setSelectedFeaturesTarget( bool useSelected );
     * \brief Sets if using selected features in Reference layer
-    void setSelectedFeaturesReference(bool useSelected);
+    void setSelectedFeaturesReference( bool useSelected );
     * \brief Execute the query
@@ -99,9 +99,9 @@
     * \param geomType          Geometry Type
     * \returns short int       Topologic Dimension
-    static short int dimensionGeometry(QGis::GeometryType geomType);
+    static short int dimensionGeometry( QGis::GeometryType geomType );
-private:
+  private:
     * \brief Sets the target layer and reference layer
@@ -114,7 +114,7 @@
     * \brief Verify has valid Geometry in feature
     * \param QgsFeature       Feature
-    bool hasValidGeometry(QgsFeature &feature);
+    bool hasValidGeometry( QgsFeature &feature );
     * \brief Build the Spatial Index
@@ -126,7 +126,7 @@
     * \param qsetIndexResult    Reference to QSet contains the result query
     * \param relation           Enum Topologic Relation
-    void execQuery(QSet<int> & qsetIndexResult, int relation);
+    void execQuery( QSet<int> & qsetIndexResult, int relation );
     * \brief Populate index Result
@@ -136,8 +136,8 @@
     * \param operation          Pointer to function of GEOS operation
     void populateIndexResult(
-            QSet<int> & qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
-            char(*operation)(const GEOSGeometry *, const GEOSGeometry *) );
+      QSet<int> & qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
+      char( *operation )( const GEOSGeometry *, const GEOSGeometry * ) );
     * \brief Populate index Result Disjoint
@@ -146,8 +146,8 @@
     void populateIndexResultDisjoint(
     MngProgressBar *mPb;
     bool mUseReferenceSelection;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -34,679 +34,680 @@
 QgsSpatialQueryDialog::QgsSpatialQueryDialog( QWidget* parent, QgisInterface* iface ): QDialog( parent )
-    setupUi( this );
+  setupUi( this );
-    grpResults->hide();
-    mLayerReference = mLayerTarget = NULL;
+  grpResults->hide();
+  mLayerReference = mLayerTarget = NULL;
-    mIface = iface;
-    mRubberSelectId = new QgsRubberSelectId( iface->mapCanvas() );
-    setColorRubberSelectId();
+  mIface = iface;
+  mRubberSelectId = new QgsRubberSelectId( iface->mapCanvas() );
+  setColorRubberSelectId();
-    initGui();
-    connectAll();
+  initGui();
+  connectAll();
-    mMsgLayersLessTwo = tr("The spatial query requires at least two layers");
+  mMsgLayersLessTwo = tr( "The spatial query requires at least two layers" );
 } // QgsSpatialQueryDialog::QgsSpatialQueryDialog( QWidget* parent, QgisInterface* iface )
 QgsSpatialQueryDialog::~QgsSpatialQueryDialog()
-    disconnectAll();
-    delete mRubberSelectId;
-    mMapIdVectorLayers.clear();
-    mFeatureResult.clear();
+  disconnectAll();
+  delete mRubberSelectId;
+  mMapIdVectorLayers.clear();
+  mFeatureResult.clear();
 } // QgsSpatialQueryDialog::~QgsSpatialQueryDialog()
 void QgsSpatialQueryDialog::messageLayersLessTwo()
-    QString msgLayersLessTwo = tr("The spatial query requires at least two layers");
-    QMessageBox::warning(0, tr("Insufficient number of layers"), msgLayersLessTwo, QMessageBox::Ok);
+  QString msgLayersLessTwo = tr( "The spatial query requires at least two layers" );
+  QMessageBox::warning( 0, tr( "Insufficient number of layers" ), msgLayersLessTwo, QMessageBox::Ok );
 void QgsSpatialQueryDialog::disconnectQGis()
-    disconnectAll();
+  disconnectAll();
 } // void QgsSpatialQueryDialog::unload()
 void QgsSpatialQueryDialog::initGui()
-    showLogProcessing(false);
-    buttonBox->button(QDialogButtonBox::Close)->hide();
+  showLogProcessing( false );
+  buttonBox->button( QDialogButtonBox::Close )->hide();
-    populateTargetLayerComboBox();
-    if (targetLayerComboBox->count() > 1)
-        setLayer(true, 0);
-        evaluateCheckBox(true);
-        populateReferenceLayerComboBox();
-        setLayer(false, 0);
-        evaluateCheckBox(false);
-        populateOperationComboBox();
-    else
-        buttonBox->setEnabled(false);
-        textEditStatus->append(mMsgLayersLessTwo);
+  populateTargetLayerComboBox();
+  if ( targetLayerComboBox->count() > 1 )
+    setLayer( true, 0 );
+    evaluateCheckBox( true );
+    populateReferenceLayerComboBox();
+    setLayer( false, 0 );
+    evaluateCheckBox( false );
+    populateOperationComboBox();
+  else
+    buttonBox->setEnabled( false );
+    textEditStatus->append( mMsgLayersLessTwo );
 } // QgsSpatialQueryDialog::initGui()
 void QgsSpatialQueryDialog::setColorRubberSelectId()
-    int myRedInt, myGreenInt, myBlueInt;
-    myRedInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorRedPart", 255 );
-    myGreenInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorGreenPart", 255 );
-    myBlueInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorBluePart", 0 );
+  int myRedInt, myGreenInt, myBlueInt;
+  myRedInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorRedPart", 255 );
+  myGreenInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorGreenPart", 255 );
+  myBlueInt = QgsProject::instance()->readNumEntry( "Gui", "/SelectionColorBluePart", 0 );
-    mRubberSelectId->setColor(255-myRedInt, 255-myGreenInt, 255-myBlueInt, 0.5, 2);
+  mRubberSelectId->setColor( 255 - myRedInt, 255 - myGreenInt, 255 - myBlueInt, 0.5, 2 );
 } // void QgsSpatialQueryDialog::setColorRubberSelectId()
-void QgsSpatialQueryDialog::setLayer(bool isTarget, int index)
+void QgsSpatialQueryDialog::setLayer( bool isTarget, int index )
-    if (isTarget) {
-        if (mLayerTarget)
-            disconnect(mLayerTarget, SIGNAL( selectionChanged()),
-                this, SLOT( signal_layerTarget_selectionFeaturesChanged() ) );
-        mLayerTarget = getLayerFromCombobox(isTarget, index);
-        connect(mLayerTarget, SIGNAL( selectionChanged()),
+  if ( isTarget )
+    if ( mLayerTarget )
+      disconnect( mLayerTarget, SIGNAL( selectionChanged() ),
+                  this, SLOT( signal_layerTarget_selectionFeaturesChanged() ) );
-    else
+    mLayerTarget = getLayerFromCombobox( isTarget, index );
+    connect( mLayerTarget, SIGNAL( selectionChanged() ),
+  else
+    if ( mLayerReference )
-        if (mLayerReference)
-            disconnect(mLayerReference, SIGNAL( selectionChanged()),
-                this, SLOT( signal_layerReference_selectionFeaturesChanged() ) );
-        mLayerReference = getLayerFromCombobox(isTarget, index);
-        connect(mLayerReference, SIGNAL( selectionChanged()),
+      disconnect( mLayerReference, SIGNAL( selectionChanged() ),
+                  this, SLOT( signal_layerReference_selectionFeaturesChanged() ) );
+    mLayerReference = getLayerFromCombobox( isTarget, index );
+    connect( mLayerReference, SIGNAL( selectionChanged() ),
 } // void QgsSpatialQueryDialog::setLayer(bool isTarget, int index)
-void QgsSpatialQueryDialog::evaluateCheckBox(bool isTarget)
+void QgsSpatialQueryDialog::evaluateCheckBox( bool isTarget )
-    QgsVectorLayer* layer = NULL;
-    QCheckBox* checkbox = NULL;
-    if (isTarget)
-        layer = mLayerTarget;
-        checkbox = usingSelectedTargetCheckBox;
-    else
-        layer = mLayerReference;
-        checkbox = usingSelectedReferenceCheckBox;
-    int selectedCount = layer->selectedFeatureCount();
-    bool isCheckBoxValid = ( layer != NULL &&  selectedCount > 0 );
-    checkbox->setChecked(isCheckBoxValid);
-    checkbox->setEnabled(isCheckBoxValid);
-    QString textCheckBox  = isCheckBoxValid
-                          ? QString::number(selectedCount) + " " + tr("Selected geometries")
-                          : tr("Selected geometries");
-    checkbox->setText(textCheckBox);
+  QgsVectorLayer* layer = NULL;
+  QCheckBox* checkbox = NULL;
+  if ( isTarget )
+    layer = mLayerTarget;
+    checkbox = usingSelectedTargetCheckBox;
+  else
+    layer = mLayerReference;
+    checkbox = usingSelectedReferenceCheckBox;
+  int selectedCount = layer->selectedFeatureCount();
+  bool isCheckBoxValid = ( layer != NULL &&  selectedCount > 0 );
+  checkbox->setChecked( isCheckBoxValid );
+  checkbox->setEnabled( isCheckBoxValid );
+  QString textCheckBox  = isCheckBoxValid
+                          ? QString::number( selectedCount ) + " " + tr( "Selected geometries" )
+                          : tr( "Selected geometries" );
+  checkbox->setText( textCheckBox );
 } // void QgsSpatialQueryDialog::evaluateCheckBox(bool isTarget)
 void QgsSpatialQueryDialog::runQuery()
-    MngProgressBar* pb = new MngProgressBar(progressBarStatus);
-    QgsSpatialQuery* spatialQuery = new QgsSpatialQuery(pb);
-    if (usingSelectedTargetCheckBox->isChecked())
-        spatialQuery->setSelectedFeaturesTarget(true);
-    if (usingSelectedReferenceCheckBox->isChecked())
-        spatialQuery->setSelectedFeaturesReference(true);
-    progressBarStatus->setTextVisible(true);
+  MngProgressBar* pb = new MngProgressBar( progressBarStatus );
+  QgsSpatialQuery* spatialQuery = new QgsSpatialQuery( pb );
+  if ( usingSelectedTargetCheckBox->isChecked() )
+    spatialQuery->setSelectedFeaturesTarget( true );
+  if ( usingSelectedReferenceCheckBox->isChecked() )
+    spatialQuery->setSelectedFeaturesReference( true );
+  progressBarStatus->setTextVisible( true );
-    int currentItem = operantionComboBox->currentIndex();
-    bool isOk;
-    int operation = operantionComboBox->itemData(currentItem).toInt(&isOk);
-    spatialQuery->runQuery(mFeatureResult, operation, mLayerTarget, mLayerReference);
-    delete spatialQuery;
-    delete pb;
+  int currentItem = operantionComboBox->currentIndex();
+  bool isOk;
+  int operation = operantionComboBox->itemData( currentItem ).toInt( &isOk );
+  spatialQuery->runQuery( mFeatureResult, operation, mLayerTarget, mLayerReference );
+  delete spatialQuery;
+  delete pb;
-    progressBarStatus->setTextVisible(false);
-    buttonBox->setEnabled(true);
+  progressBarStatus->setTextVisible( false );
+  buttonBox->setEnabled( true );
-    grpResults->show();
-    grpInputs->hide();
-    progressBarStatus->hide();
-    buttonBox->button(QDialogButtonBox::Close)->show();
-    buttonBox->button(QDialogButtonBox::Cancel)->hide();
-    buttonBox->button(QDialogButtonBox::Ok)->hide();
+  grpResults->show();
+  grpInputs->hide();
+  progressBarStatus->hide();
+  buttonBox->button( QDialogButtonBox::Close )->show();
+  buttonBox->button( QDialogButtonBox::Cancel )->hide();
+  buttonBox->button( QDialogButtonBox::Ok )->hide();
 } // void QgsSpatialQueryDialog::runQuery()
-void QgsSpatialQueryDialog::showLogProcessing(bool hasShow)
+void QgsSpatialQueryDialog::showLogProcessing( bool hasShow )
-    static int heightDialogNoStatus = 0;
+  static int heightDialogNoStatus = 0;
-    hasShow ? textEditStatus->show() : textEditStatus->hide();
-    this->adjustSize();
+  hasShow ? textEditStatus->show() : textEditStatus->hide();
+  this->adjustSize();
-    if ( ! hasShow )
+  if ( ! hasShow )
+    if ( heightDialogNoStatus == 0 )
-        if ( heightDialogNoStatus == 0 )
-            heightDialogNoStatus = this->geometry().height();
-        else
-            this->setGeometry(this->geometry().x(), this->geometry().y(),
-                              this->geometry().width(), heightDialogNoStatus);
+      heightDialogNoStatus = this->geometry().height();
+    else
+      this->setGeometry( this->geometry().x(), this->geometry().y(),
+                         this->geometry().width(), heightDialogNoStatus );
 } // void QgsSpatialQueryDialog::showLogProcessing(bool hasShow)
-void QgsSpatialQueryDialog::showResultQuery(QDateTime *datetimeStart, QDateTime *datetimeEnd)
+void QgsSpatialQueryDialog::showResultQuery( QDateTime *datetimeStart, QDateTime *datetimeEnd )
-    selectedFeatureListWidget->clear();
-    countSelectedFeats->setText(tr("Total: %1").arg(mFeatureResult.size()));
+  selectedFeatureListWidget->clear();
+  countSelectedFeats->setText( tr( "Total: %1" ).arg( mFeatureResult.size() ) );
-    QString msg = tr("<<-- Begin at [%L1] --").arg(datetimeStart->toString());
-    textEditStatus->append(msg);
-    msg = tr("Query:");
-    msg = QString("- %1").arg(getDescriptionLayerShow(true));
-    msg = tr("< %1 >").arg(operantionComboBox->currentText());
-    msg = QString("- %1").arg(getDescriptionLayerShow(false));
-    msg = tr("Result: %1 features").arg(mFeatureResult.size());
-    double timeProcess = (double)datetimeStart->secsTo(*datetimeEnd) / 60.0;
-    msg = tr("-- Finish at [%L1] (processing time %L2 minutes) -->>").arg(datetimeEnd->toString()).arg(timeProcess, 0, 'f', 2);
+  QString msg = tr( "<<-- Begin at [%L1] --" ).arg( datetimeStart->toString() );
+  textEditStatus->append( msg );
+  msg = tr( "Query:" );
+  msg = QString( "- %1" ).arg( getDescriptionLayerShow( true ) );
+  msg = tr( "< %1 >" ).arg( operantionComboBox->currentText() );
+  msg = QString( "- %1" ).arg( getDescriptionLayerShow( false ) );
+  msg = tr( "Result: %1 features" ).arg( mFeatureResult.size() );
+  double timeProcess = ( double )datetimeStart->secsTo( *datetimeEnd ) / 60.0;
+  msg = tr( "-- Finish at [%L1] (processing time %L2 minutes) -->>" ).arg( datetimeEnd->toString() ).arg( timeProcess, 0, 'f', 2 );
-    if( mFeatureResult.size() > 0 )
-        populateQueryResult();
-        mLayerTarget->setSelectedFeatures(mFeatureResult);
+  if ( mFeatureResult.size() > 0 )
+    populateQueryResult();
+    mLayerTarget->setSelectedFeatures( mFeatureResult );
-        QString sIdFeat = selectedFeatureListWidget->currentItem()->text();
-        on_selectedFeatureListWidget_currentTextChanged(sIdFeat);
-    else
-        mRubberSelectId->reset();
+    QString sIdFeat = selectedFeatureListWidget->currentItem()->text();
+    on_selectedFeatureListWidget_currentTextChanged( sIdFeat );
+  else
+    mRubberSelectId->reset();
 } // void QgsSpatialQueryDialog::showResultQuery(QDateTime *datetimeStart, QDateTime *datetimeEnd)
-QString QgsSpatialQueryDialog::getDescriptionLayerShow(bool isTarget)
+QString QgsSpatialQueryDialog::getDescriptionLayerShow( bool isTarget )
-    QCheckBox * checkBox = NULL;
-    if (isTarget)
-        checkBox = usingSelectedTargetCheckBox;
-    else
-        checkBox = usingSelectedReferenceCheckBox;
+  QCheckBox * checkBox = NULL;
+  if ( isTarget )
+    checkBox = usingSelectedTargetCheckBox;
+  else
+    checkBox = usingSelectedReferenceCheckBox;
-    QString sDescFeatures = checkBox->isChecked()
-            ? tr("%1 of %2").arg(layer->selectedFeatureCount()).arg(layer->featureCount())
-            : tr("all = %1").arg(layer->featureCount());
+  QString sDescFeatures = checkBox->isChecked()
+                          ? tr( "%1 of %2" ).arg( layer->selectedFeatureCount() ).arg( layer->featureCount() )
+                          : tr( "all = %1" ).arg( layer->featureCount() );
-    return QString("%1 (%2)").arg(layer->name()).arg(sDescFeatures);
+  return QString( "%1 (%2)" ).arg( layer->name() ).arg( sDescFeatures );
 } // QString QgsSpatialQueryDialog::getDescriptionLayerShow(bool isTarget)
 void QgsSpatialQueryDialog::connectAll()
-    connect(QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded(QgsMapLayer*) ),
-             this, SLOT( signal_qgis_layerWasAdded(QgsMapLayer*) )) ;
-    connect(QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved(QString) ),
-             this, SLOT( signal_qgis_layerWillBeRemoved( QString ) ) );
-    connect(showLogProcessingCheckBox, SIGNAL ( clicked() ),
-             this, SLOT( on_showLogProcessingCheckBox_clicked(bool) ) );
+  connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded( QgsMapLayer* ) ),
+           this, SLOT( signal_qgis_layerWasAdded( QgsMapLayer* ) ) ) ;
+  connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString ) ),
+           this, SLOT( signal_qgis_layerWillBeRemoved( QString ) ) );
+  connect( showLogProcessingCheckBox, SIGNAL( clicked() ),
+           this, SLOT( on_showLogProcessingCheckBox_clicked( bool ) ) );
 } // QgsSpatialQueryDialog::connectAll()
 void QgsSpatialQueryDialog::disconnectAll()
-    disconnect(QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded(QgsMapLayer*)),
-    disconnect(QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString )),
+  disconnect( QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded( QgsMapLayer* ) ),
+  disconnect( QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString ) ),
-    if ( mLayerTarget )
-    if ( mLayerReference )
 } // QgsSpatialQueryDialog::disconnectAll()
 void QgsSpatialQueryDialog::reject()
-    disconnectAll();
+  disconnectAll();
-    mLayerTarget = mLayerReference = NULL;
+  mLayerTarget = mLayerReference = NULL;
-    QDialog::reject();
+  QDialog::reject();
 } // QgsSpatialQueryDialog::reject()
-QgsVectorLayer * QgsSpatialQueryDialog::getLayerFromCombobox(bool isTarget, int index)
+QgsVectorLayer * QgsSpatialQueryDialog::getLayerFromCombobox( bool isTarget, int index )
-    QVariant data = isTarget
-                  ? targetLayerComboBox->itemData(index)
-                  : referenceLayerComboBox->itemData(index);
-    QgsVectorLayer* lyr = static_cast<QgsVectorLayer*>( data.value<void *>() );
-    return lyr;
+  QVariant data = isTarget
+                  ? targetLayerComboBox->itemData( index )
+                  : referenceLayerComboBox->itemData( index );
+  QgsVectorLayer* lyr = static_cast<QgsVectorLayer*>( data.value<void *>() );
+  return lyr;
 } // QgsVectorLayer * QgsSpatialQueryDialog::getLayerFromCombobox(bool isTarget, int index)
-QIcon QgsSpatialQueryDialog::getIconTypeGeometry(QGis::GeometryType geomType)
+QIcon QgsSpatialQueryDialog::getIconTypeGeometry( QGis::GeometryType geomType )
-    QString theName;
-    if ( geomType == QGis::Point )
-        theName = "/mIconPointLayer.png";
-    else if ( geomType == QGis::Line )
-        theName = "/mIconLineLayer.png";
-    else // Polygon
-        theName = "/mIconPolygonLayer.png";
-    // Copy from qgisapp.cpp
-    QString myPreferredPath = QgsApplication::activeThemePath() + QDir::separator() + theName;
-    QString myDefaultPath = QgsApplication::defaultThemePath() + QDir::separator() + theName;
-    if ( QFile::exists( myPreferredPath ) )
+  QString theName;
+  if ( geomType == QGis::Point )
+    theName = "/mIconPointLayer.png";
+  else if ( geomType == QGis::Line )
+    theName = "/mIconLineLayer.png";
+  else // Polygon
+    theName = "/mIconPolygonLayer.png";
+  // Copy from qgisapp.cpp
+  QString myPreferredPath = QgsApplication::activeThemePath() + QDir::separator() + theName;
+  QString myDefaultPath = QgsApplication::defaultThemePath() + QDir::separator() + theName;
+  if ( QFile::exists( myPreferredPath ) )
     return QIcon( myPreferredPath );
-    else if ( QFile::exists( myDefaultPath ) )
+  else if ( QFile::exists( myDefaultPath ) )
     //could still return an empty icon if it
     //doesnt exist in the default theme either!
     return QIcon( myDefaultPath );
-    else
+  else
     return QIcon();
 } // QIcon QgsSpatialQueryDialog::getIconTypeGeometry(int typeGeometry)
-void QgsSpatialQueryDialog::addLayerCombobox(bool isTarget, QgsVectorLayer* vectorLayer)
+void QgsSpatialQueryDialog::addLayerCombobox( bool isTarget, QgsVectorLayer* vectorLayer )
-    QVariant item = QVariant::fromValue((void *)vectorLayer);
-    QComboBox * cmb = isTarget ? targetLayerComboBox : referenceLayerComboBox;
-    int idNew = cmb->count();
-    QIcon icon = getIconTypeGeometry(vectorLayer->geometryType());
-    cmb->addItem(icon, vectorLayer->name(), item);
-    cmb->setItemData(idNew, QVariant(vectorLayer->source()), Qt::ToolTipRole);
+  QVariant item = QVariant::fromValue(( void * )vectorLayer );
+  QComboBox * cmb = isTarget ? targetLayerComboBox : referenceLayerComboBox;
+  int idNew = cmb->count();
+  QIcon icon = getIconTypeGeometry( vectorLayer->geometryType() );
+  cmb->addItem( icon, vectorLayer->name(), item );
+  cmb->setItemData( idNew, QVariant( vectorLayer->source() ), Qt::ToolTipRole );
 } // void QgsSpatialQueryDialog::removeLayerCombobox(bool isTarget, QgsVectorLayer* vectorLayer)
-int QgsSpatialQueryDialog::getIndexLayerCombobox(bool isTarget, QgsVectorLayer* vectorLayer)
+int QgsSpatialQueryDialog::getIndexLayerCombobox( bool isTarget, QgsVectorLayer* vectorLayer )
-    return cmb->findData(item);
+  return cmb->findData( item );
-void QgsSpatialQueryDialog::removeLayer(bool isTarget, QgsVectorLayer* lyrRemove)
+void QgsSpatialQueryDialog::removeLayer( bool isTarget, QgsVectorLayer* lyrRemove )
-    cmb->blockSignals(true);
-    // Remove Combobox
-    int index = getIndexLayerCombobox(isTarget, lyrRemove);
-    if(index > -1)
+  cmb->blockSignals( true );
+  // Remove Combobox
+  int index = getIndexLayerCombobox( isTarget, lyrRemove );
+  if ( index > -1 )
+    cmb->removeItem( index );
+  else
+    return;
+  // Set Layers (Target or Reference)
+  QgsVectorLayer* lyrThis = mLayerTarget;
+  if ( !isTarget )
+    lyrThis = mLayerReference;
+  if ( lyrRemove == lyrThis )
+    lyrThis = NULL;
+    if ( cmb->count() > 0 )
-        cmb->removeItem(index);
+      cmb->setCurrentIndex( 0 );
+      setLayer( isTarget, 0 );
+      evaluateCheckBox( isTarget );
+      if ( isTarget )
+        selectedFeatureListWidget->blockSignals( true );
+        selectedFeatureListWidget->blockSignals( false );
+        countSelectedFeats->setText( tr( "Total" ) + ": 0" );
-    else
-        return;
-    // Set Layers (Target or Reference)
-    QgsVectorLayer* lyrThis = mLayerTarget;
-    if ( !isTarget )
-        lyrThis = mLayerReference;
-    if (lyrRemove == lyrThis)
-        lyrThis = NULL;
-        if( cmb->count() > 0 )
-            cmb->setCurrentIndex(0);
-            setLayer(isTarget, 0);
-            evaluateCheckBox(isTarget);
-            if (isTarget)
-                selectedFeatureListWidget->blockSignals(true);
-                selectedFeatureListWidget->blockSignals(false);
-                countSelectedFeats->setText(tr("Total") + ": 0");
-    cmb->blockSignals(false);
+  cmb->blockSignals( false );
 } // void QgsSpatialQueryDialog::removeLayer(bool isTarget, QgsVectorLayer* lyrRemove)
 void QgsSpatialQueryDialog::populateTargetLayerComboBox()
-    targetLayerComboBox->blockSignals(true);
+  targetLayerComboBox->blockSignals( true );
-    QMap <QString, QgsMapLayer*> map = QgsMapLayerRegistry::instance()->mapLayers();
-    QMapIterator <QString, QgsMapLayer*> item(map);
-    QgsMapLayer * mapLayer = NULL;
-    QgsVectorLayer * vectorLayer = NULL;
-    QString layerId;
-    while ( item.hasNext() )
+  QMap <QString, QgsMapLayer*> map = QgsMapLayerRegistry::instance()->mapLayers();
+  QMapIterator <QString, QgsMapLayer*> item( map );
+  QgsMapLayer * mapLayer = NULL;
+  QgsVectorLayer * vectorLayer = NULL;
+  QString layerId;
+  while ( item.hasNext() )
+    item.next();
+    mapLayer = item.value();
+    if ( mapLayer->type() != QgsMapLayer::VectorLayer )
-        item.next();
-        mapLayer = item.value();
-        if( mapLayer->type() != QgsMapLayer::VectorLayer )
-            continue;
-        vectorLayer = qobject_cast<QgsVectorLayer *>(mapLayer);
-        if (!vectorLayer)
-            continue;
-        addLayerCombobox(true, vectorLayer);
-        mMapIdVectorLayers.insert(vectorLayer->getLayerID(), vectorLayer);
+      continue;
-    targetLayerComboBox->setCurrentIndex(0);
-    targetLayerComboBox->blockSignals(false);
+    vectorLayer = qobject_cast<QgsVectorLayer *>( mapLayer );
+    if ( !vectorLayer )
+      continue;
+    addLayerCombobox( true, vectorLayer );
+    mMapIdVectorLayers.insert( vectorLayer->getLayerID(), vectorLayer );
+  targetLayerComboBox->setCurrentIndex( 0 );
+  targetLayerComboBox->blockSignals( false );
 } // void QgsSpatialQueryDialog::populateTargetLayerComboBox()
 void QgsSpatialQueryDialog::populateReferenceLayerComboBox()
-    referenceLayerComboBox->blockSignals(true);
-    referenceLayerComboBox->clear();
+  referenceLayerComboBox->blockSignals( true );
+  referenceLayerComboBox->clear();
-    // Populate new values and Set current item keeping the previous value
-    QString itemText;
-    QVariant itemData;
-    QIcon itemIcon;
-    QgsVectorLayer * itemLayer = NULL;
-    int idNew = 0;
-    for (int id = 0; id < targetLayerComboBox->count(); id++)
+  // Populate new values and Set current item keeping the previous value
+  QString itemText;
+  QVariant itemData;
+  QIcon itemIcon;
+  QgsVectorLayer * itemLayer = NULL;
+  int idNew = 0;
+  for ( int id = 0; id < targetLayerComboBox->count(); id++ )
+    itemText = targetLayerComboBox->itemText( id );
+    itemData = targetLayerComboBox->itemData( id );
+    itemIcon = targetLayerComboBox->itemIcon( id );
+    itemLayer = static_cast<QgsVectorLayer *>( itemData.value<void *>() );
+    if ( itemLayer == mLayerTarget )
-        itemText = targetLayerComboBox->itemText(id);
-        itemData = targetLayerComboBox->itemData(id);
-        itemIcon = targetLayerComboBox->itemIcon(id);
-        itemLayer = static_cast<QgsVectorLayer *>(itemData.value<void *>());
-        if (itemLayer == mLayerTarget)
-            continue;
-        referenceLayerComboBox->addItem(itemIcon, itemText, itemData);
-        referenceLayerComboBox->setItemData(idNew, QVariant(itemLayer->source()), Qt::ToolTipRole);
-        idNew++;
+      continue;
-    int idCurrent = getIndexLayerCombobox(false, mLayerReference);
-    if (idCurrent == -1)
-        idCurrent = 0;
-    referenceLayerComboBox->setCurrentIndex(idCurrent);
-    referenceLayerComboBox->blockSignals(false);
+    referenceLayerComboBox->addItem( itemIcon, itemText, itemData );
+    referenceLayerComboBox->setItemData( idNew, QVariant( itemLayer->source() ), Qt::ToolTipRole );
+    idNew++;
+  int idCurrent = getIndexLayerCombobox( false, mLayerReference );
+  if ( idCurrent == -1 )
+    idCurrent = 0;
+  referenceLayerComboBox->setCurrentIndex( idCurrent );
+  referenceLayerComboBox->blockSignals( false );
 } // QgsSpatialQueryDialog::populateReferenceLayerComboBox()
 void QgsSpatialQueryDialog::populateOperationComboBox()
-    operantionComboBox->blockSignals(true);
+  operantionComboBox->blockSignals( true );
-    if ( mLayerTarget == NULL || mLayerReference == NULL )
-        operantionComboBox->clear();
+  if ( mLayerTarget == NULL || mLayerReference == NULL )
+    operantionComboBox->clear();
-    QVariant currentValueItem;
-    bool isStartEmpty = false;
-    if (operantionComboBox->count() == 0)
-        isStartEmpty = true;
-    else
-        currentValueItem = operantionComboBox->itemData(operantionComboBox->currentIndex());
+  QVariant currentValueItem;
+  bool isStartEmpty = false;
+  if ( operantionComboBox->count() == 0 )
+    isStartEmpty = true;
+  else
+    currentValueItem = operantionComboBox->itemData( operantionComboBox->currentIndex() );
-    QMap<QString, int> * map = QgsSpatialQuery::getTypesOperations(mLayerTarget, mLayerReference);
-    QMapIterator <QString, int> item(*map);
-        item.next();
-        operantionComboBox->addItem(item.key(), QVariant(item.value()));
-    delete map;
+  QMap<QString, int> * map = QgsSpatialQuery::getTypesOperations( mLayerTarget, mLayerReference );
+  QMapIterator <QString, int> item( *map );
+    item.next();
+    operantionComboBox->addItem( item.key(), QVariant( item.value() ) );
+  delete map;
-    // Set current item keeping the previous value
-    int idCurrent = 0;
-    if (!isStartEmpty)
+  // Set current item keeping the previous value
+  int idCurrent = 0;
+  if ( !isStartEmpty )
+    idCurrent = operantionComboBox->findData( currentValueItem );
-        idCurrent = operantionComboBox->findData(currentValueItem);
-            idCurrent = 0;
+      idCurrent = 0;
-    operantionComboBox->setCurrentIndex(idCurrent);
-    operantionComboBox->blockSignals(false);
+  operantionComboBox->setCurrentIndex( idCurrent );
+  operantionComboBox->blockSignals( false );
 } // QgsSpatialQueryDialog::populateOperantionComboBox()
 void QgsSpatialQueryDialog::populateQueryResult()
-    selectedFeatureListWidget->setEnabled(false);
+  selectedFeatureListWidget->setEnabled( false );
-    QSetIterator <int>item(mFeatureResult);
-        selectedFeatureListWidget->addItem(QString::number(item.next()));
-    selectedFeatureListWidget->setEnabled(true);
-    selectedFeatureListWidget->setCurrentRow(0);
+  QSetIterator <int>item( mFeatureResult );
+    selectedFeatureListWidget->addItem( QString::number( item.next() ) );
+  selectedFeatureListWidget->setEnabled( true );
+  selectedFeatureListWidget->setCurrentRow( 0 );
 } // QgsSpatialQueryDialog::populateQueryResult()
 //! Slots for signs of Dialog
 void QgsSpatialQueryDialog::on_buttonBox_accepted()
-    if( ! mLayerReference )
-        QMessageBox::warning(0, tr("Missing reference layer"), tr("Select reference layer!"), QMessageBox::Ok);
-        return;
-    if( ! mLayerTarget )
-        QMessageBox::warning(0, tr("Missing target layer"), tr("Select target layer!"), QMessageBox::Ok);
-        return;
+  if ( ! mLayerReference )
+    QMessageBox::warning( 0, tr( "Missing reference layer" ), tr( "Select reference layer!" ), QMessageBox::Ok );
+    return;
+  if ( ! mLayerTarget )
+    QMessageBox::warning( 0, tr( "Missing target layer" ), tr( "Select target layer!" ), QMessageBox::Ok );
+    return;
-    QDateTime datetimeStart = QDateTime::currentDateTime();
-    runQuery();
-    QDateTime datetimeEnd = QDateTime::currentDateTime();
+  QDateTime datetimeStart = QDateTime::currentDateTime();
+  runQuery();
+  QDateTime datetimeEnd = QDateTime::currentDateTime();
-    showResultQuery(&datetimeStart, &datetimeEnd);
+  showResultQuery( &datetimeStart, &datetimeEnd );
 } // QgsSpatialQueryDialog::on_buttonBox_accepted()
 void QgsSpatialQueryDialog::on_buttonBox_rejected()
-    reject();
+  reject();
 } // void QgsSpatialQueryDialog::on_buttonBox_rejected()
- void QgsSpatialQueryDialog::on_targetLayerComboBox_currentIndexChanged(int index)
+void QgsSpatialQueryDialog::on_targetLayerComboBox_currentIndexChanged( int index )
-    // Add old target layer in reference combobox
-    addLayerCombobox(false, mLayerTarget);
+  // Add old target layer in reference combobox
+  addLayerCombobox( false, mLayerTarget );
-    // Set target layer
-    setLayer(true, index);
+  // Set target layer
+  setLayer( true, index );
-    // Remove new target layer in reference combobox
-    removeLayer(false, mLayerTarget);
+  // Remove new target layer in reference combobox
+  removeLayer( false, mLayerTarget );
 } // QgsSpatialQueryDialog::on_targetLayerComboBox_currentIndexChanged(int index)
-void QgsSpatialQueryDialog::on_referenceLayerComboBox_currentIndexChanged(int index)
+void QgsSpatialQueryDialog::on_referenceLayerComboBox_currentIndexChanged( int index )
-    setLayer(false, index);
+  setLayer( false, index );
 } // QgsSpatialQueryDialog::on_referenceLayerComboBox_currentIndexChanged(int index);
-void QgsSpatialQueryDialog::on_selectedFeatureListWidget_currentTextChanged(const QString& currentText)
+void QgsSpatialQueryDialog::on_selectedFeatureListWidget_currentTextChanged( const QString& currentText )
-    QCursor cursor;
-    cursor.setShape(Qt::WaitCursor);
-    Qt::CursorShape shapeCurrent = this->cursor().shape();
-    this->setCursor(cursor);
-    cursor.setShape(shapeCurrent);
+  QCursor cursor;
+  cursor.setShape( Qt::WaitCursor );
+  Qt::CursorShape shapeCurrent = this->cursor().shape();
+  this->setCursor( cursor );
+  cursor.setShape( shapeCurrent );
-    bool ok;
-    int Id = currentText.toInt(&ok);
-    mRubberSelectId->addFeature( mLayerTarget, Id);
+  bool ok;
+  int Id = currentText.toInt( &ok );
+  mRubberSelectId->addFeature( mLayerTarget, Id );
-    selectedFeatureListWidget->setFocus();
-    mRubberSelectId->show();
+  selectedFeatureListWidget->setFocus();
+  mRubberSelectId->show();
- } // QgsSpatialQueryDialog::on_selectedFeatureListWidget_currentTextChanged(const QString& currentText)
+} // QgsSpatialQueryDialog::on_selectedFeatureListWidget_currentTextChanged(const QString& currentText)
-void QgsSpatialQueryDialog::on_showLogProcessingCheckBox_clicked(bool checked)
+void QgsSpatialQueryDialog::on_showLogProcessingCheckBox_clicked( bool checked )
-    showLogProcessing(checked);
+  showLogProcessing( checked );
 } // void QgsSpatialQueryDialog::on_showLogProcessingCheckBox_clicked(bool checked)
 //! Slots for signs of QGIS
-void QgsSpatialQueryDialog::signal_qgis_layerWasAdded(QgsMapLayer* mapLayer)
+void QgsSpatialQueryDialog::signal_qgis_layerWasAdded( QgsMapLayer* mapLayer )
-        return;
-    QgsVectorLayer * vectorLayer = qobject_cast<QgsVectorLayer *>(mapLayer);
-    if (!vectorLayer)
-        return;
-    addLayerCombobox(false, vectorLayer);
+    return;
+  QgsVectorLayer * vectorLayer = qobject_cast<QgsVectorLayer *>( mapLayer );
+    return;
+  addLayerCombobox( false, vectorLayer );
-    // Verify is can enable buttonBox
-    if( buttonBox->button(QDialogButtonBox::Ok)->isEnabled() == false && targetLayerComboBox->count() > 1)
-        buttonBox->button(QDialogButtonBox::Ok)->setEnabled(true);
+  // Verify is can enable buttonBox
+  if ( buttonBox->button( QDialogButtonBox::Ok )->isEnabled() == false && targetLayerComboBox->count() > 1 )
+    buttonBox->button( QDialogButtonBox::Ok )->setEnabled( true );
 } // QgsSpatialQueryDialog::signal_qgis_layerWasAdded(QgsMapLayer* mapLayer)
-void QgsSpatialQueryDialog::signal_qgis_layerWillBeRemoved(QString idLayer)
+void QgsSpatialQueryDialog::signal_qgis_layerWillBeRemoved( QString idLayer )
-    // If Frozen: the QGis can be: Exit, Add Project, New Project
-    if ( mIface->mapCanvas()->isFrozen() )
-        reject();
-    // idLayer = QgsMapLayer::getLayerID()
-    // Get Pointer layer removed
-    QMap<QString, QgsVectorLayer *>::const_iterator i = mMapIdVectorLayers.find(idLayer);
-    if (i == mMapIdVectorLayers.end() )
-        return;
-    mMapIdVectorLayers.remove(idLayer);
-    QgsVectorLayer *vectorLayer = i.value();
-    removeLayer(true, vectorLayer); // set new target if need
-    removeLayer(false, vectorLayer); // set new reference if need
-    if ( mLayerTarget && getIndexLayerCombobox(referenceLayerComboBox, mLayerTarget) > -1)
+  // If Frozen: the QGis can be: Exit, Add Project, New Project
+  if ( mIface->mapCanvas()->isFrozen() )
+    reject();
+  // idLayer = QgsMapLayer::getLayerID()
+  // Get Pointer layer removed
+  QMap<QString, QgsVectorLayer *>::const_iterator i = mMapIdVectorLayers.find( idLayer );
+  if ( i == mMapIdVectorLayers.end() )
+    return;
+  mMapIdVectorLayers.remove( idLayer );
+  QgsVectorLayer *vectorLayer = i.value();
+  removeLayer( true, vectorLayer ); // set new target if need
+  removeLayer( false, vectorLayer ); // set new reference if need
+  if ( mLayerTarget && getIndexLayerCombobox( referenceLayerComboBox, mLayerTarget ) > -1 )
-   if( targetLayerComboBox->count() < 2 )
-       buttonBox->button(QDialogButtonBox::Ok)->setEnabled(false);
+  if ( targetLayerComboBox->count() < 2 )
+    buttonBox->button( QDialogButtonBox::Ok )->setEnabled( false );
 } // QgsSpatialQueryDialog::signal_qgis_layerWillBeRemoved(QString idLayer)
 //! Slots for signals of Layers (Target or Reference)
 void QgsSpatialQueryDialog::signal_layerTarget_selectionFeaturesChanged()
 } // void QgsSpatialQueryDialog::signal_layerTarget_selectionFeaturesChanged()
 void QgsSpatialQueryDialog::signal_layerReference_selectionFeaturesChanged()
 } // void QgsSpatialQueryDialog::signal_layerReference_selectionFeaturesChanged()
-void QgsSpatialQueryDialog::MsgDEBUG(QString sMSg)
+void QgsSpatialQueryDialog::MsgDEBUG( QString sMSg )
-    QMessageBox::warning(0, tr("DEBUG"), sMSg, QMessageBox::Ok);
+  QMessageBox::warning( 0, tr( "DEBUG" ), sMSg, QMessageBox::Ok );
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -34,13 +34,13 @@
 class QgsSpatialQueryDialog : public QDialog, private Ui::QgsSpatialQueryDialogBase
     Q_OBJECT
-public:
+  public:
     * Constructor for a dialog. The QgisInterface pointer is passed by
     * QGIS when it attempts to instantiate the plugin.
     * @param iface Pointer to the QgisInterface object.
-    QgsSpatialQueryDialog(QWidget *parent = 0, QgisInterface* iface = 0);
+    QgsSpatialQueryDialog( QWidget *parent = 0, QgisInterface* iface = 0 );
     //! Destructor
     ~QgsSpatialQueryDialog();
@@ -50,24 +50,24 @@
     //! Unload plugins by QGIS - Disconnect signal from QGIS
     void disconnectQGis();
-private slots:
+  private slots:
     void on_buttonBox_accepted();
     void on_buttonBox_rejected();
     void on_targetLayerComboBox_currentIndexChanged( int index );
     void on_referenceLayerComboBox_currentIndexChanged( int index );
-    void on_selectedFeatureListWidget_currentTextChanged ( const QString& currentText );
-    void on_showLogProcessingCheckBox_clicked(bool checked);
+    void on_selectedFeatureListWidget_currentTextChanged( const QString& currentText );
+    void on_showLogProcessingCheckBox_clicked( bool checked );
-    void signal_qgis_layerWasAdded ( QgsMapLayer* mapLayer );
-    void signal_qgis_layerWillBeRemoved ( QString idLayer );
+    void signal_qgis_layerWasAdded( QgsMapLayer* mapLayer );
+    void signal_qgis_layerWillBeRemoved( QString idLayer );
     //! Slots for signs of Layers (Target or Reference)
     void signal_layerTarget_selectionFeaturesChanged();
     void signal_layerReference_selectionFeaturesChanged();
- private:
+  private:
     //! Initialize the Gui
     void initGui();
     //! Set Color mRubberSelectId
@@ -79,11 +79,11 @@
     //! Run Query
     void runQuery();
     //! Show Log Processing
-    void showLogProcessing(bool hasShow);
+    void showLogProcessing( bool hasShow );
     //! Show result of query
-    void showResultQuery(QDateTime *datetimeStart, QDateTime *datetimeEnd);
+    void showResultQuery( QDateTime *datetimeStart, QDateTime *datetimeEnd );
     //! Get Description Layer to show result
-    QString getDescriptionLayerShow(bool isTarget);
+    QString getDescriptionLayerShow( bool isTarget );
     //! Connect all slots
     void connectAll();
     //! Disconnect all slots
@@ -91,15 +91,15 @@
     //! reject - override
     void reject();
     //! Get Vector layer from combobox
-    QgsVectorLayer * getLayerFromCombobox(bool isTarget, int index);
+    QgsVectorLayer * getLayerFromCombobox( bool isTarget, int index );
     //! Get Icon for vector layer
-    QIcon getIconTypeGeometry(QGis::GeometryType geomType);
+    QIcon getIconTypeGeometry( QGis::GeometryType geomType );
     //! Add layer in combobox (text, data and  tooltips)
-    void addLayerCombobox(bool isTarget, QgsVectorLayer* vectorLayer);
+    void addLayerCombobox( bool isTarget, QgsVectorLayer* vectorLayer );
     //! Find Layer in combobox
-    int getIndexLayerCombobox(bool isTarget, QgsVectorLayer* vectorLayer);
+    int getIndexLayerCombobox( bool isTarget, QgsVectorLayer* vectorLayer );
     //! Remove layer in combobox and setting GUI
-    void removeLayer(bool isTarget, QgsVectorLayer* lyrRemove);
+    void removeLayer( bool isTarget, QgsVectorLayer* lyrRemove );
     //! Populates targetLayerComboBox with all layers
     void populateTargetLayerComboBox();
     //! Populates referenceLayerComboBox with all layers except the current target layer
@@ -125,7 +125,7 @@
     // Menssage
     QString mMsgLayersLessTwo;
-    void MsgDEBUG(QString sMSg);
+    void MsgDEBUG( QString sMSg );
 #endif // SPATIALQUERYDIALOG_H
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp	2010-04-24 09:00:25 UTC (rev 13360)
@@ -57,83 +57,84 @@
 * @param qgis Pointer to the QGIS main window
 * @parma mIface Pointer to the QGIS interface object
-QgsSpatialQueryPlugin::QgsSpatialQueryPlugin(QgisInterface* iface)
-:QgisPlugin( name_, description_, version_, type_ ),
- mIface(iface)
+QgsSpatialQueryPlugin::QgsSpatialQueryPlugin( QgisInterface* iface )
+    : QgisPlugin( name_, description_, version_, type_ ),
+    mIface( iface )
-    mDialog = NULL;
+  mDialog = NULL;
 QgsSpatialQueryPlugin::~QgsSpatialQueryPlugin()
-    mIface = NULL;
-    delete mSpatialQueryAction;
-    delete mDialog;
+  mIface = NULL;
+  delete mSpatialQueryAction;
+  delete mDialog;
 * Initialize the GUI interface for the plugin
 void QgsSpatialQueryPlugin::initGui()
-    // Create the action for tool
-    mSpatialQueryAction = new QAction( QIcon(), tr("&Spatial Query"), this);
+  // Create the action for tool
+  mSpatialQueryAction = new QAction( QIcon(), tr( "&Spatial Query" ), this );
-    // Connect the action to the spatialQuery slot
-    connect(mSpatialQueryAction, SIGNAL(activated()), this, SLOT(run()));
+  // Connect the action to the spatialQuery slot
+  connect( mSpatialQueryAction, SIGNAL( activated() ), this, SLOT( run() ) );
-    setCurrentTheme( "" );
-    // this is called when the icon theme is changed
-    connect( mIface, SIGNAL( currentThemeChanged( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
+  setCurrentTheme( "" );
+  // this is called when the icon theme is changed
+  connect( mIface, SIGNAL( currentThemeChanged( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
-    // Add the icon to the toolbar and to the plugin menu
-    mIface->addToolBarIcon(mSpatialQueryAction);
-    mIface->addPluginToMenu(tr("&Spatial Query"), mSpatialQueryAction);
+  // Add the icon to the toolbar and to the plugin menu
+  mIface->addToolBarIcon( mSpatialQueryAction );
+  mIface->addPluginToMenu( tr( "&Spatial Query" ), mSpatialQueryAction );
 //Unload the plugin by cleaning up the GUI
 void QgsSpatialQueryPlugin::unload()
-    // remove the GUI
-    mIface->removeToolBarIcon(mSpatialQueryAction);
-    mIface->removePluginMenu(tr("&Spatial Query"), mSpatialQueryAction);
+  // remove the GUI
+  mIface->removeToolBarIcon( mSpatialQueryAction );
+  mIface->removePluginMenu( tr( "&Spatial Query" ), mSpatialQueryAction );
 void QgsSpatialQueryPlugin::run()
-    if (!mDialog){
-        if(QgsMapLayerRegistry::instance()->mapLayers().size() < 2)
-            QgsSpatialQueryDialog::messageLayersLessTwo();
-             return;
-        mDialog = new QgsSpatialQueryDialog(mIface->mainWindow(), mIface);
-        mDialog->setModal(false);
-        mDialog->show();
+  if ( !mDialog )
+    if ( QgsMapLayerRegistry::instance()->mapLayers().size() < 2 )
+      QgsSpatialQueryDialog::messageLayersLessTwo();
+      return;
+    mDialog = new QgsSpatialQueryDialog( mIface->mainWindow(), mIface );
+    mDialog->setModal( false );
+    mDialog->show();
+  else
+    if ( !mDialog->isVisible() )
+      delete mDialog;
+      mDialog = NULL;
+      run();
     else
-        if ( !mDialog->isVisible() )
-            delete mDialog;
-            mDialog = NULL;
-            run();
-        else
-            mDialog->activateWindow();
+      mDialog->activateWindow();
 //! Set icons to the current theme
 void QgsSpatialQueryPlugin::setCurrentTheme( QString )
-  mSpatialQueryAction->setIcon(getThemeIcon("/spatialquery.png"));
+  mSpatialQueryAction->setIcon( getThemeIcon( "/spatialquery.png" ) );
 QIcon QgsSpatialQueryPlugin::getThemeIcon( const QString &theName )
@@ -142,19 +143,19 @@
     return QIcon( QgsApplication::activeThemePath() + "/plugins" + theName );
-  else if (QFile::exists(QgsApplication::defaultThemePath() + "/plugins" + theName ))
+  else if ( QFile::exists( QgsApplication::defaultThemePath() + "/plugins" + theName ) )
     return QIcon( QgsApplication::defaultThemePath() + "/plugins" + theName );
   else
-    return QIcon(":/icons" + theName);
+    return QIcon( ":/icons" + theName );
-void QgsSpatialQueryPlugin::MsgDEBUG(QString sMSg)
+void QgsSpatialQueryPlugin::MsgDEBUG( QString sMSg )
@@ -164,9 +165,9 @@
 * of the plugin class
 // Class factory to return a new instance of the plugin class
-QGISEXTERN QgisPlugin* classFactory(QgisInterface* iface)
+QGISEXTERN QgisPlugin* classFactory( QgisInterface* iface )
-  return new QgsSpatialQueryPlugin(iface);
+  return new QgsSpatialQueryPlugin( iface );
 // Return the name of the plugin
@@ -194,7 +195,7 @@
 // Delete ourself
-QGISEXTERN void unload(QgisPlugin* theSpatialQueryPluginPointer)
+QGISEXTERN void unload( QgisPlugin* theSpatialQueryPluginPointer )
   delete theSpatialQueryPluginPointer;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.h	2010-04-24 08:28:07 UTC (rev 13359)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.h	2010-04-24 09:00:25 UTC (rev 13360)
@@ -45,17 +45,17 @@
 class QgsSpatialQueryPlugin: public QObject, public QgisPlugin
     Q_OBJECT
-    public:
+  public:
     * \brief Constructor for a plugin. The QgisInterface pointer is passed by
     * \param iface Pointer to the QgisInterface object.
-    QgsSpatialQueryPlugin(QgisInterface* iface);
+    QgsSpatialQueryPlugin( QgisInterface* iface );
     //! Destructor
     ~QgsSpatialQueryPlugin();
-    public slots:
+  public slots:
     //! init the gui
     void initGui();
     //! unload the plugin
@@ -66,7 +66,7 @@
     void setCurrentTheme( QString theThemeName );
     QIcon getThemeIcon( const QString &theThemeName );
-    private:
+  private:
     QgsSpatialQueryDialog  *mDialog;
     //! Pointer to the QgisInterface object
@@ -75,7 +75,7 @@
     QAction* mSpatialQueryAction;
 #endif
More information about the QGIS-commit mailing list
