[QGIS Commit] r13367 - trunk/qgis/src/plugins/spatialquery
svn_qgis at osgeo.org
Sat Apr 24 14:11:41 EDT 2010
Author: jef
Date: 2010-04-24 14:11:40 -0400 (Sat, 24 Apr 2010)
New Revision: 13367
Removed:
trunk/qgis/src/plugins/spatialquery/ts/
trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
spatial query plugin: port to new QgsGeometry operators, gui cleanup
Modified: trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
--- trunk/qgis/src/plugins/spatialquery/CMakeLists.txt 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/CMakeLists.txt 2010-04-24 18:11:40 UTC (rev 13367)
@@ -41,13 +41,11 @@
../../core/symbology
../../gui
- ${GEOS_INCLUDE_DIR}
TARGET_LINK_LIBRARIES(spatialqueryplugin
qgis_core
qgis_gui
- ${GEOS_LIBRARY}
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp 2010-04-24 18:11:40 UTC (rev 13367)
@@ -55,7 +55,7 @@
setQuery( lyrTarget, lyrReference );
// Create Spatial index for Reference - Set mIndexReference
- mPb->setFormat( "Processing 1/2 - %p%" );
+ mPb->setFormat( QObject::tr( "Processing 1/2 - %p%" ) );
int totalStep = mUseReferenceSelection
? mLayerReference->selectedFeatureCount()
: ( int )( mLayerReference->featureCount() );
@@ -63,7 +63,7 @@
setSpatialIndexReference(); // Need set mLayerReference before
// Make Query
- mPb->setFormat( "Processing 2/2 - %p%" );
+ mPb->setFormat( QObject::tr( "Processing 2/2 - %p%" ) );
totalStep = mUseTargetSelection
? mLayerTarget->selectedFeatureCount()
: ( int )( mLayerTarget->featureCount() );
@@ -181,9 +181,7 @@
return false;
- GEOSGeometry *geomGeos = geom->asGeos();
- if ( GEOSisEmpty( geomGeos ) || 1 != GEOSisValid( geomGeos ) )
+ if ( geom->isGeosEmpty() || !geom->isGeosValid() )
return false;
@@ -218,33 +216,32 @@
void QgsSpatialQuery::execQuery( QSet<int> & qsetIndexResult, int relation )
- // Set GEOS function
- char( *operation )( const GEOSGeometry *, const GEOSGeometry* );
+ bool ( QgsGeometry::* operation )( QgsGeometry * );
switch ( relation )
case Disjoint:
- operation = &GEOSDisjoint;
+ operation = &QgsGeometry::disjoint;
break;
case Equals:
- operation = &GEOSEquals;
+ operation = &QgsGeometry::equals;
break;
case Touches:
- operation = &GEOSTouches;
+ operation = &QgsGeometry::touches;
break;
case Overlaps:
- operation = &GEOSOverlaps;
+ operation = &QgsGeometry::overlaps;
break;
case Within:
- operation = &GEOSWithin;
+ operation = &QgsGeometry::within;
break;
case Contains:
- operation = &GEOSContains;
+ operation = &QgsGeometry::contains;
break;
case Crosses:
- operation = &GEOSCrosses;
+ operation = &QgsGeometry::crosses;
break;
case Intersects:
- operation = &GEOSIntersects;
+ operation = &QgsGeometry::intersects;
break;
@@ -253,9 +250,7 @@
coordinateTransform->setCoordinateTransform( mLayerTarget, mLayerReference );
// Set function for populate result
- void ( QgsSpatialQuery::* funcPopulateIndexResult )
- ( QSet<int> &, int, QgsGeometry *,
- char( * )( const GEOSGeometry *, const GEOSGeometry * ) );
+ void ( QgsSpatialQuery::* funcPopulateIndexResult )( QSet<int> &, int, QgsGeometry *, bool ( QgsGeometry::* )( QgsGeometry * ) );
funcPopulateIndexResult = ( relation == Disjoint )
? &QgsSpatialQuery::populateIndexResultDisjoint
: &QgsSpatialQuery::populateIndexResult;
@@ -263,10 +258,8 @@
QgsFeature featureTarget;
QgsGeometry * geomTarget;
int step = 1;
- while ( true )
+ while ( mReaderFeaturesTarget->nextFeature( featureTarget ) )
- if ( ! mReaderFeaturesTarget->nextFeature( featureTarget ) ) break;
mPb->step( step++ );
if ( ! hasValidGeometry( featureTarget ) )
@@ -285,7 +278,7 @@
void QgsSpatialQuery::populateIndexResult(
QSet<int> &qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
- char( *operation )( const GEOSGeometry *, const GEOSGeometry * ) )
+ bool ( QgsGeometry::* op )( QgsGeometry * ) )
QList<int> listIdReference;
listIdReference = mIndexReference.intersects( geomTarget->boundingBox() );
@@ -293,7 +286,6 @@
return;
- GEOSGeometry * geosTarget = geomTarget->asGeos();
QgsFeature featureReference;
QgsGeometry * geomReference;
QList<int>::iterator iterIdReference = listIdReference.begin();
@@ -301,7 +293,7 @@
mLayerReference->featureAtId( *iterIdReference, featureReference );
geomReference = featureReference.geometry();
- if (( *operation )( geosTarget, geomReference->asGeos() ) == 1 )
+ if (( geomTarget->*op )( geomReference ) == 1 )
qsetIndexResult.insert( idTarget );
break;
@@ -312,7 +304,7 @@
void QgsSpatialQuery::populateIndexResultDisjoint(
@@ -321,7 +313,6 @@
return;
@@ -330,7 +321,7 @@
- if (( *operation )( geosTarget, geomReference->asGeos() ) == 0 )
+ if (( geomTarget->*op )( geomTarget ) == 0 )
addIndex = false;
break;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.h 2010-04-24 18:11:40 UTC (rev 13367)
@@ -19,8 +19,6 @@
#ifndef SPATIALQUERY_H
#define SPATIALQUERY_H
-#include <geos_c.h>
#include <qgsvectorlayer.h>
#include <qgsspatialindex.h>
@@ -137,7 +135,7 @@
void populateIndexResult(
QSet<int> & qsetIndexResult, int idTarget, QgsGeometry * geomTarget,
- char( *operation )( const GEOSGeometry *, const GEOSGeometry * ) );
+ bool ( QgsGeometry::* operation )( QgsGeometry * ) );
* \brief Populate index Result Disjoint
* \param qsetIndexResult Reference to QSet contains the result query
@@ -147,7 +145,7 @@
void populateIndexResultDisjoint(
MngProgressBar *mPb;
bool mUseReferenceSelection;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2010-04-24 18:11:40 UTC (rev 13367)
@@ -152,7 +152,7 @@
checkbox->setChecked( isCheckBoxValid );
checkbox->setEnabled( isCheckBoxValid );
QString textCheckBox = isCheckBoxValid
- ? QString::number( selectedCount ) + " " + tr( "Selected geometries" )
+ ? tr( "%n selected geometries", "selected geometries", selectedCount )
: tr( "Selected geometries" );
checkbox->setText( textCheckBox );
@@ -185,30 +185,37 @@
buttonBox->setEnabled( true );
grpResults->show();
- grpInputs->hide();
+ setInputsVisible( false );
progressBarStatus->hide();
buttonBox->button( QDialogButtonBox::Close )->show();
buttonBox->button( QDialogButtonBox::Cancel )->hide();
buttonBox->button( QDialogButtonBox::Ok )->hide();
} // void QgsSpatialQueryDialog::runQuery()
+void QgsSpatialQueryDialog::setInputsVisible( bool show )
+ grpTargetGroupBox->setVisible( show );
+ grpReferenceGroupBox->setVisible( show );
+ grpOperationGroupBox->setVisible( show );
void QgsSpatialQueryDialog::showLogProcessing( bool hasShow )
static int heightDialogNoStatus = 0;
hasShow ? textEditStatus->show() : textEditStatus->hide();
- this->adjustSize();
+ adjustSize();
if ( ! hasShow )
if ( heightDialogNoStatus == 0 )
- heightDialogNoStatus = this->geometry().height();
+ heightDialogNoStatus = geometry().height();
else
- this->setGeometry( this->geometry().x(), this->geometry().y(),
- this->geometry().width(), heightDialogNoStatus );
+ setGeometry( geometry().x(), geometry().y(),
+ geometry().width(), heightDialogNoStatus );
@@ -613,18 +620,18 @@
mRubberSelectId->reset();
selectedFeatureListWidget->setEnabled( false );
- QCursor cursor;
- cursor.setShape( Qt::WaitCursor );
- Qt::CursorShape shapeCurrent = this->cursor().shape();
- this->setCursor( cursor );
- cursor.setShape( shapeCurrent );
+ QCursor c;
+ c.setShape( Qt::WaitCursor );
+ Qt::CursorShape shapeCurrent = cursor().shape();
+ setCursor( c );
+ c.setShape( shapeCurrent );
bool ok;
int Id = currentText.toInt( &ok );
mRubberSelectId->addFeature( mLayerTarget, Id );
selectedFeatureListWidget->setEnabled( true );
+ setCursor( c );
selectedFeatureListWidget->setFocus();
mRubberSelectId->show();
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h 2010-04-24 18:11:40 UTC (rev 13367)
@@ -122,10 +122,13 @@
//! Rubber band for features result
QgsRubberSelectId* mRubberSelectId;
- // Menssage
+ // Message
QString mMsgLayersLessTwo;
void MsgDEBUG( QString sMSg );
+ //! show/hide target, reference and operation group box
+ void setInputsVisible( bool show );
#endif // SPATIALQUERYDIALOG_H
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui 2010-04-24 18:07:59 UTC (rev 13366)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui 2010-04-24 18:11:40 UTC (rev 13367)
@@ -9,8 +9,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>543</width>
- <height>459</height>
+ <width>532</width>
+ <height>680</height>
</rect>
</property>
<property name="minimumSize">
@@ -35,215 +35,39 @@
<locale language="English" country="UnitedKingdom"/>
</property>
<layout class="QGridLayout" name="gridLayout_3">
- <item row="0" column="0">
- <widget class="QGroupBox" name="grpInputs">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="minimumSize">
- <size>
- <width>230</width>
- <height>285</height>
- </size>
- </property>
+ <item row="8" column="0" colspan="2">
+ <widget class="QDialogButtonBox" name="buttonBox">
<property name="maximumSize">
<size>
<width>16777215</width>
<height>16777215</height>
</size>
</property>
- <property name="title">
- <string>Layers</string>
+ <property name="contextMenuPolicy">
+ <enum>Qt::DefaultContextMenu</enum>
</property>
- <layout class="QGridLayout" name="gridLayout_2">
- <widget class="QGroupBox" name="targetGroupBox">
- <property name="toolTip">
- <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><meta name="qrichtext" content="1" /><style type="text/css">
-p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'MS Shell Dlg 2'; font-size:8.25pt; font-weight:400; font-style:normal;">
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-size:8pt;">Layer where yours </span><span style=" font-size:8pt;">geometrys</span><span style=" font-size:8pt;"> will be selected by topological operation</span></p></body></html></string>
- </property>
- <string>Target layer</string>
- </property>
- <widget class="QCheckBox" name="usingSelectedTargetCheckBox">
- <property name="geometry">
- <rect>
- <x>1</x>
- <y>50</y>
- <width>201</width>
- <height>18</height>
- </rect>
- </property>
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-size:8pt;">When mark the operation will be only selected geometry of target</span></p></body></html></string>
- </property>
- <property name="text">
- <string>Selected feature(s) only</string>
- </property>
- </widget>
- <widget class="QComboBox" name="targetLayerComboBox">
- <rect>
- <x>1</x>
- <y>18</y>
- <width>211</width>
- <height>26</height>
- </rect>
- </property>
- <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
- </sizepolicy>
- </property>
- <size>
- <width>206</width>
- </size>
- </property>
- <property name="maximumSize">
- <size>
- <width>16777215</width>
- <height>16777215</height>
- </size>
- </property>
- <string>Select the target layer</string>
- </property>
- </widget>
- </widget>
- </item>
- <item row="1" column="0">
- <widget class="QGroupBox" name="OperationGroupBox">
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-size:8pt;">Topological operations between layers of target and reference</span></p></body></html></string>
- </property>
- <string>Topological operation</string>
- </property>
- <widget class="QComboBox" name="operantionComboBox">
- <rect>
- <x>1</x>
- <y>18</y>
- </rect>
- </property>
- <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
- <horstretch>10</horstretch>
- <verstretch>116</verstretch>
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- <size>
- </size>
- </property>
- <string>Select the topological operation</string>
- </property>
- </widget>
- </widget>
- </item>
- <item row="2" column="0">
- <widget class="QGroupBox" name="ReferenceGroupBox">
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-size:8pt;">Layer where yours geometrys will be used how reference by topological operation</span></p></body></html></string>
- </property>
- <string>Reference layer</string>
- </property>
- <widget class="QCheckBox" name="usingSelectedReferenceCheckBox">
- <rect>
- <x>1</x>
- <y>50</y>
- </rect>
- </property>
- <size>
- </size>
- </property>
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-size:8pt;">When mark the operation will be only selected geometry of reference</span></p></body></html></string>
- </property>
- </property>
- </widget>
- <widget class="QComboBox" name="referenceLayerComboBox">
- <rect>
- <x>1</x>
- <y>18</y>
- </rect>
- </property>
- </sizepolicy>
- </property>
- <size>
- </size>
- </property>
- <size>
- </size>
- </property>
- <string>Select the reference layer</string>
- </property>
- </widget>
- </widget>
- </item>
- </layout>
+ <property name="toolTip">
+ <string>Run query or close the window</string>
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
+ </property>
</widget>
</item>
- <item row="0" column="1" rowspan="2">
+ <item row="6" column="0" colspan="2">
+ <widget class="QProgressBar" name="progressBarStatus">
+ <property name="value">
+ <number>0</number>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignCenter</set>
+ </property>
+ <property name="textVisible">
+ <bool>false</bool>
+ </property>
+ </widget>
+ </item>
+ <item row="7" column="0">
<widget class="QGroupBox" name="grpResults">
@@ -254,8 +78,8 @@
<string>Results (click to highlight on map)</string>
</property>
- <layout class="QGridLayout" name="gridLayout">
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
<widget class="QListWidget" name="selectedFeatureListWidget">
<sizepolicy hsizetype="Preferred" vsizetype="Fixed">
@@ -280,7 +104,17 @@
</property>
</widget>
</item>
+ <item>
+ <widget class="QCheckBox" name="showLogProcessingCheckBox">
+ <string>Check to show log processing of query</string>
+ </property>
+ <property name="text">
+ <string>Show log messages</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QTextEdit" name="textEditStatus">
<property name="enabled">
<bool>true</bool>
@@ -290,7 +124,7 @@
</property>
</widget>
</item>
- <item row="3" column="0">
+ <item>
<widget class="QLabel" name="countSelectedFeats">
<size>
@@ -312,49 +146,154 @@
</property>
</widget>
</item>
- <widget class="QCheckBox" name="showLogProcessingCheckBox">
+ </layout>
+ </widget>
+ </item>
+ <item row="0" column="0">
+ <widget class="QGroupBox" name="grpTargetGroupBox">
+ <string>Layer on which the topological operation will select geometries</string>
+ </property>
+ <property name="title">
+ <string>Target layer</string>
+ </property>
+ <layout class="QVBoxLayout" name="verticalLayout_3">
+ <item>
+ <widget class="QComboBox" name="targetLayerComboBox">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="minimumSize">
+ <size>
+ <width>206</width>
+ <height>26</height>
+ </size>
+ </property>
+ <property name="maximumSize">
+ <size>
+ <width>16777215</width>
+ <height>16777215</height>
+ </size>
+ </property>
- <string>Mark to show log processing of query</string>
+ <string>Select the target layer</string>
</property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="usingSelectedTargetCheckBox">
+ <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'MS Shell Dlg 2'; font-size:8pt;">When checked the operation will only consider selected geometries of the target layer</span></p></body></html></string>
+ </property>
- <string>Show log messages</string>
+ <string>Selected feature(s) only</string>
</property>
</widget>
</item>
</layout>
+ <zorder>usingSelectedTargetCheckBox</zorder>
+ <zorder>targetLayerComboBox</zorder>
</widget>
</item>
- <widget class="QProgressBar" name="progressBarStatus">
- <property name="value">
- <number>0</number>
+ <widget class="QGroupBox" name="grpReferenceGroupBox">
+ <string>Layer whose geometries will be used as reference by the topological operation</string>
</property>
- <property name="alignment">
- <set>Qt::AlignCenter</set>
+ <string>Reference layer</string>
</property>
- <property name="textVisible">
- <bool>false</bool>
- </property>
+ <layout class="QVBoxLayout" name="verticalLayout_4">
+ <item>
+ <widget class="QComboBox" name="referenceLayerComboBox">
+ <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ <size>
+ </size>
+ </property>
+ <string>Select the reference layer</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="usingSelectedReferenceCheckBox">
+ <size>
+ <height>18</height>
+ </size>
+ </property>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'MS Shell Dlg 2'; font-size:8pt;">When checked the operation will be only consider selected geometries of the reference layer</span></p></body></html></string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
</widget>
</item>
- <item row="2" column="0" colspan="2">
- <widget class="QDialogButtonBox" name="buttonBox">
- <size>
- </size>
- </property>
- <property name="contextMenuPolicy">
- <enum>Qt::DefaultContextMenu</enum>
- </property>
+ <item row="5" column="0">
+ <widget class="QGroupBox" name="grpOperationGroupBox">
- <string>Run query or close the window</string>
+ <string>Topological operations between layers of target and reference</string>
</property>
- <property name="standardButtons">
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
+ <string>Topological operation</string>
</property>
+ <layout class="QVBoxLayout" name="verticalLayout_5">
+ <item>
+ <widget class="QComboBox" name="operantionComboBox">
+ <horstretch>10</horstretch>
+ <verstretch>116</verstretch>
+ </sizepolicy>
+ </property>
+ <size>
+ </size>
+ </property>
+ <size>
+ </size>
+ </property>
+ <string>Select the topological operation</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
</widget>
</item>
</layout>
