[QGIS Commit] r13372 - in trunk/qgis: python/core src/core src/plugins/spatialquery
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 24 15:08:53 EDT 2010
Author: jef
Date: 2010-04-24 15:08:49 -0400 (Sat, 24 Apr 2010)
New Revision: 13372
   trunk/qgis/python/core/qgsgeometry.sip
   trunk/qgis/src/core/qgsgeometry.h
   trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
missed python binding to additional GEOS operators
Modified: trunk/qgis/python/core/qgsgeometry.sip
--- trunk/qgis/python/core/qgsgeometry.sip	2010-04-24 18:49:03 UTC (rev 13371)
+++ trunk/qgis/python/core/qgsgeometry.sip	2010-04-24 19:08:49 UTC (rev 13372)
@@ -100,6 +100,11 @@
     bool isGeosValid();
+    /** check if geometry is empty using GEOS
+      @note added in 1.5
+    bool isGeosEmpty();
        Set the geometry, feeding in a geometry in GEOS format.
@@ -239,10 +244,34 @@
     /** Test for containment of a point (uses GEOS) */
     bool contains(QgsPoint* p);
-    /** Test for containment with a geometry (uses GEOS)
-    *  @note added in 1.5 */
+    /** Test for if geometry is contained in an other (uses GEOS)
+     *  @note added in 1.5 */
     bool contains( QgsGeometry* geometry );
+    /** Test for if geometry is disjoint of an other (uses GEOS)
+    bool disjoint( QgsGeometry* geometry );
+    /** Test for if geometry equals an other (uses GEOS)
+    bool equals( QgsGeometry* geometry );
+    /** Test for if geometry touch an other (uses GEOS)
+    bool touches( QgsGeometry* geometry );
+    /** Test for if geometry overlaps an other (uses GEOS)
+    bool overlaps( QgsGeometry* geometry );
+    /** Test for if geometry is within an other (uses GEOS)
+    bool within( QgsGeometry* geometry );
+    /** Test for if geometry crosses an other (uses GEOS)
+    bool crosses( QgsGeometry* geometry );
     /** Returns a buffer region around this geometry having the given width and with a specified number
         of segments used to approximate curves */
     QgsGeometry* buffer(double distance, int segments) /Factory/;
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h	2010-04-24 18:49:03 UTC (rev 13371)
+++ trunk/qgis/src/core/qgsgeometry.h	2010-04-24 19:08:49 UTC (rev 13372)
@@ -288,7 +288,7 @@
     bool contains( QgsPoint* p );
-    /** Test for if geometry is contain in an other (uses GEOS)
Modified: trunk/qgis/src/plugins/spatialquery/CMakeLists.txt
--- trunk/qgis/src/plugins/spatialquery/CMakeLists.txt	2010-04-24 18:49:03 UTC (rev 13371)
+++ trunk/qgis/src/plugins/spatialquery/CMakeLists.txt	2010-04-24 19:08:49 UTC (rev 13372)
@@ -41,6 +41,7 @@
      ../../core/symbology
      ../../gui
+     ${GEOS_INCLUDE_DIR}
 TARGET_LINK_LIBRARIES(spatialqueryplugin
More information about the QGIS-commit mailing list
