[QGIS Commit] r13381 - in trunk/qgis/src: gui plugins/spatialquery
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Apr 25 09:28:43 EDT 2010
Author: jef
Date: 2010-04-25 09:28:42 -0400 (Sun, 25 Apr 2010)
New Revision: 13381
   trunk/qgis/src/gui/qgsfiledropedit.cpp
   trunk/qgis/src/gui/qgsfiledropedit.h
   trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
   trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
fix spatialquery combobox resizing issue
Property changes on: trunk/qgis/src/gui/qgsfiledropedit.cpp
___________________________________________________________________
Modified: svn:keywords
   - "Author Date Id Revision"
   + Author Date Id Revision
Property changes on: trunk/qgis/src/gui/qgsfiledropedit.h
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2010-04-25 12:51:49 UTC (rev 13380)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2010-04-25 13:28:42 UTC (rev 13381)
@@ -287,7 +287,7 @@
            this, SLOT( signal_qgis_layerWasAdded( QgsMapLayer* ) ) ) ;
   connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString ) ),
            this, SLOT( signal_qgis_layerWillBeRemoved( QString ) ) );
-  connect( showLogProcessingCheckBox, SIGNAL( clicked() ),
+  connect( showLogProcessingCheckBox, SIGNAL( clicked( bool ) ),
            this, SLOT( on_showLogProcessingCheckBox_clicked( bool ) ) );
 } // QgsSpatialQueryDialog::connectAll()
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui	2010-04-25 12:51:49 UTC (rev 13380)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialogbase.ui	2010-04-25 13:28:42 UTC (rev 13381)
@@ -35,120 +35,6 @@
    <locale language="English" country="UnitedKingdom"/>
   </property>
   <layout class="QGridLayout" name="gridLayout_3">
-   <item row="8" column="0" colspan="2">
-    <widget class="QDialogButtonBox" name="buttonBox">
-     <property name="maximumSize">
-      <size>
-       <width>16777215</width>
-       <height>16777215</height>
-      </size>
-     </property>
-     <property name="contextMenuPolicy">
-      <enum>Qt::DefaultContextMenu</enum>
-     </property>
-     <property name="toolTip">
-      <string>Run query or close the window</string>
-     </property>
-     <property name="standardButtons">
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
-   <item row="6" column="0" colspan="2">
-    <widget class="QProgressBar" name="progressBarStatus">
-     <property name="value">
-      <number>0</number>
-     </property>
-     <property name="alignment">
-      <set>Qt::AlignCenter</set>
-     </property>
-     <property name="textVisible">
-      <bool>false</bool>
-     </property>
-    </widget>
-   </item>
-   <item row="7" column="0">
-    <widget class="QGroupBox" name="grpResults">
-     <property name="sizePolicy">
-      <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-     <property name="title">
-      <string>Results (click to highlight on map)</string>
-     </property>
-     <layout class="QVBoxLayout" name="verticalLayout">
-      <item>
-       <widget class="QListWidget" name="selectedFeatureListWidget">
-         <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
-         </sizepolicy>
-        </property>
-        <property name="minimumSize">
-         <size>
-          <width>136</width>
-          <height>135</height>
-         </size>
-        </property>
-         <size>
-         </size>
-        </property>
-         <string>Select item to identify geometry of feature</string>
-        </property>
-       </widget>
-      </item>
-      <item>
-       <widget class="QCheckBox" name="showLogProcessingCheckBox">
-         <string>Check to show log processing of query</string>
-        </property>
-        <property name="text">
-         <string>Show log messages</string>
-        </property>
-       </widget>
-      </item>
-      <item>
-       <widget class="QTextEdit" name="textEditStatus">
-        <property name="enabled">
-         <bool>true</bool>
-        </property>
-        <property name="textInteractionFlags">
-         <set>Qt::TextSelectableByKeyboard|Qt::TextSelectableByMouse</set>
-        </property>
-       </widget>
-      </item>
-      <item>
-       <widget class="QLabel" name="countSelectedFeats">
-         <size>
-          <width>18</width>
-          <height>20</height>
-         </size>
-        </property>
-         <size>
-          <height>30</height>
-         </size>
-        </property>
-         <string>Total of features from query</string>
-        </property>
-         <string> Total</string>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
    <item row="0" column="0">
     <widget class="QGroupBox" name="grpTargetGroupBox">
@@ -259,6 +145,25 @@
      </layout>
     </widget>
    </item>
+   <item row="10" column="0" colspan="2">
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="maximumSize">
+      <size>
+       <width>16777215</width>
+       <height>16777215</height>
+      </size>
+     </property>
+     <property name="contextMenuPolicy">
+      <enum>Qt::DefaultContextMenu</enum>
+     </property>
+     <property name="toolTip">
+      <string>Run query or close the window</string>
+     </property>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
    <item row="5" column="0">
     <widget class="QGroupBox" name="grpOperationGroupBox">
@@ -296,6 +201,117 @@
      </layout>
     </widget>
    </item>
+   <item row="9" column="0">
+    <widget class="QProgressBar" name="progressBarStatus">
+     <property name="value">
+      <number>0</number>
+     </property>
+     <property name="alignment">
+      <set>Qt::AlignCenter</set>
+     </property>
+     <property name="textVisible">
+      <bool>false</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="6" column="0">
+    <widget class="QGroupBox" name="grpResults">
+     <property name="enabled">
+      <bool>true</bool>
+     </property>
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+     <property name="title">
+      <string>Results (click to highlight on map)</string>
+     </property>
+     <layout class="QVBoxLayout" name="verticalLayout">
+      <item>
+       <widget class="QListWidget" name="selectedFeatureListWidget">
+         <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+         </sizepolicy>
+        </property>
+        <property name="minimumSize">
+         <size>
+          <width>136</width>
+          <height>135</height>
+         </size>
+        </property>
+         <size>
+         </size>
+        </property>
+         <string>Select item to identify geometry of feature</string>
+        </property>
+       </widget>
+      </item>
+      <item>
+       <widget class="QCheckBox" name="showLogProcessingCheckBox">
+         <string>Check to show log processing of query</string>
+        </property>
+        <property name="text">
+         <string>Show log messages</string>
+        </property>
+       </widget>
+      </item>
+      <item>
+       <widget class="QTextEdit" name="textEditStatus">
+         <bool>true</bool>
+        </property>
+        <property name="textInteractionFlags">
+         <set>Qt::TextSelectableByKeyboard|Qt::TextSelectableByMouse</set>
+        </property>
+       </widget>
+      </item>
+      <item>
+       <widget class="QLabel" name="countSelectedFeats">
+         <size>
+          <width>18</width>
+          <height>20</height>
+         </size>
+        </property>
+         <size>
+          <height>30</height>
+         </size>
+        </property>
+         <string>Total of features from query</string>
+        </property>
+         <string> Total</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="7" column="0">
+    <spacer name="verticalSpacer">
+     <property name="orientation">
+      <enum>Qt::Vertical</enum>
+     </property>
+     <property name="sizeHint" stdset="0">
+      <size>
+       <width>20</width>
+       <height>40</height>
+      </size>
+     </property>
+    </spacer>
+   </item>
   </layout>
  </widget>
  <resources/>
More information about the QGIS-commit mailing list
