[QGIS Commit] r13391 - in trunk/qgis: cmake scripts
src/analysis/vector src/core/symbology-ng
src/plugins/georeferencer src/providers/grass
svn_qgis at osgeo.org
Mon Apr 26 03:20:03 EDT 2010
Author: jef
Date: 2010-04-26 03:19:50 -0400 (Mon, 26 Apr 2010)
New Revision: 13391
trunk/qgis/cmake/SIPMacros.cmake
trunk/qgis/scripts/spelling.dat
trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgssymbolv2.h
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
fix common typos
Modified: trunk/qgis/cmake/SIPMacros.cmake
--- trunk/qgis/cmake/SIPMacros.cmake 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/cmake/SIPMacros.cmake 2010-04-26 07:19:50 UTC (rev 13391)
@@ -54,7 +54,7 @@
# We give this target a long logical target name.
# (This is to avoid having the library name clash with any already
- # install library names. If that happens then cmake dependancy
+ # install library names. If that happens then cmake dependency
# tracking get confused.)
STRING(REPLACE "." "_" _logical_name ${MODULE_NAME})
SET(_logical_name "python_module_${_logical_name}")
Modified: trunk/qgis/scripts/spelling.dat
--- trunk/qgis/scripts/spelling.dat 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/scripts/spelling.dat 2010-04-26 07:19:50 UTC (rev 13391)
@@ -443,6 +443,7 @@
useage:usage
aribitary:arbitrary
colour:color
+colours:colors
recommeneded:recommended
implementaed:implemented
containging:containing
Modified: trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp 2010-04-26 07:19:50 UTC (rev 13391)
@@ -285,7 +285,7 @@
pixelRectGeometry = QgsGeometry::fromRect( QgsRectangle( currentX - hCellSizeX, currentY - hCellSizeY, currentX + hCellSizeX, currentY + hCellSizeY ) );
if ( pixelRectGeometry )
- //intersecton
+ //intersection
intersectGeometry = pixelRectGeometry->intersection( poly );
if ( intersectGeometry )
Modified: trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2010-04-26 07:19:50 UTC (rev 13391)
@@ -169,8 +169,8 @@
p.end();
// Check that the selected version is different. If not, then re-render,
- // filling the background with the selection colour and using the normal
- // colours for the symbol .. could be ugly!
+ // filling the background with the selection color and using the normal
+ // colors for the symbol .. could be ugly!
if ( mSelCache == mCache )
Modified: trunk/qgis/src/core/symbology-ng/qgssymbolv2.h
--- trunk/qgis/src/core/symbology-ng/qgssymbolv2.h 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/src/core/symbology-ng/qgssymbolv2.h 2010-04-26 07:19:50 UTC (rev 13391)
@@ -137,8 +137,7 @@
//! @note added in 1.5
void setRenderHints( int hints ) { mRenderHints = hints; }
- // Colour used for selections
+ // Color used for selections
static QColor selectionColor();
double outputLineWidth( double width ) const;
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-04-26 07:19:50 UTC (rev 13391)
@@ -953,7 +953,7 @@
line = points.readLine();
QStringList ls;
- if ( line.contains( QRegExp( "," ) ) ) // in previous format "\t" is delemiter of points in new - ","
+ if ( line.contains( QRegExp( "," ) ) ) // in previous format "\t" is delimeter of points in new - ","
// points from new georeferencer
ls = line.split( "," );
Modified: trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2010-04-25 22:37:59 UTC (rev 13390)
+++ trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2010-04-26 07:19:50 UTC (rev 13391)
@@ -109,7 +109,7 @@
QMessageBox::warning( 0, QObject::tr( "Warning" ), QObject::tr( "Cannot draw raster" ) + "\n"
+ e.what() );
- // We dont set mValid to false, because the raster can be recreated and work next time
+ // We don't set mValid to false, because the raster can be recreated and work next time
return image;
QgsDebugMsg( QString("%1 bytes read from modules stdout").arg(data.size()) );
