[QGIS Commit] r13403 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Apr 27 01:39:37 EDT 2010
Author: dassau
Date: 2010-04-27 01:39:35 -0400 (Tue, 27 Apr 2010)
New Revision: 13403
   docs/trunk/english_us/user_guide/working_with_vector.tex
fixed wrong description of simplify tool
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-04-27 01:48:22 UTC (rev 13402)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-04-27 05:39:35 UTC (rev 13403)
@@ -1661,10 +1661,11 @@
 The \toolbtntwo{mActionSimplify}{Simplify Feature} tool allows to reduce the
 number of vertices of a feature, as long as the geometry doesn't change. You
-need to select one or several features, they will be highlighted by a red
-rubber band and a slider appears. Moving the slider, the red rubber band is
-changing its shape to show how the feature is being simplified. Clicking \button{OK} the new, simplified geometry will be stored. If a feature cannot be
-simplified, a message shows up.
+need to select a feature, it will be highlighted by a red rubber band and a
+slider appears. Moving the slider, the red rubber band is changing its shape
+to show how the feature is being simplified. Clicking \button{OK} the new,
+simplified geometry will be stored. If a feature cannot be simplified (e.g.
+MultiPolygons), a message shows up.
 \minisec{Add Ring}
 \index{vector layers!add!ring}
More information about the QGIS-commit mailing list
