[QGIS Commit] r13406 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Wed Apr 28 06:32:58 EDT 2010
Author: jef
Date: 2010-04-28 06:32:56 -0400 (Wed, 28 Apr 2010)
New Revision: 13406
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
fix #2681
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-27 21:17:34 UTC (rev 13405)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2010-04-28 10:32:56 UTC (rev 13406)
@@ -3003,27 +3003,67 @@
Result result;
QString sql;
- if ( !isQuery )
+ QString schemaName = mSchemaName;
+ QString tableName = mTableName;
+ QString geomCol = geometryColumn;
+ if ( isQuery )
- sql = QString( "select type,srid from geometry_columns"
- " where f_table_name=%1 and f_geometry_column=%2 and f_table_schema=%3" )
- .arg( quotedValue( mTableName ) )
- .arg( quotedValue( geometryColumn ) )
- .arg( quotedValue( mSchemaName ) );
+ sql = QString( "select %1 from %2 limit 0" ).arg( quotedIdentifier( geometryColumn ) ).arg( mQuery );
QgsDebugMsg( "Getting geometry column: " + sql );
Result result = connectionRO->PQexec( sql );
+ if ( PGRES_TUPLES_OK == PQresultStatus( result ) )
+ Oid tableOid = PQftable( result, 0 );
+ int column = PQftablecol( result, 0 );
- QgsDebugMsg( "geometry column query returned " + QString::number( PQntuples( result ) ) );
+ result = connectionRO->PQexec( sql );
+ if ( tableOid >= 0 && PGRES_TUPLES_OK == PQresultStatus( result ) )
+ sql = QString( "SELECT pg_namespace.nspname,pg_class.relname FROM pg_class,pg_namespace WHERE pg_class.relnamespace=pg_namespace.oid AND pg_class.oid=%1" ).arg( tableOid );
- if ( PQntuples( result ) > 0 )
- fType = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
- srid = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
+ if ( PGRES_TUPLES_OK == PQresultStatus( result ) && 1 == PQntuples( result ) )
+ schemaName = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
+ tableName = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
+ sql = QString( "SELECT attname FROM pg_attribute WHERE attrelid=%1 AND attnum=%2" ).arg( tableOid ).arg( column );
+ geomCol = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
+ else
+ schemaName = mSchemaName;
+ tableName = mTableName;
+ sql = QString( "select type,srid from geometry_columns"
+ " where f_table_name=%1 and f_geometry_column=%2 and f_table_schema=%3" )
+ .arg( quotedValue( tableName ) )
+ .arg( quotedValue( geomCol ) )
+ .arg( quotedValue( schemaName ) );
+ QgsDebugMsg( "Getting geometry column: " + sql );
+ QgsDebugMsg( "geometry column query returned " + QString::number( PQntuples( result ) ) );
+ if ( PQntuples( result ) > 0 )
+ fType = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
+ srid = QString::fromUtf8( PQgetvalue( result, 0, 1 ) );
if ( srid.isEmpty() || fType.isEmpty() )
// Didn't find what we need in the geometry_columns table, so
