[QGIS Commit] r14010 - in trunk/qgis: python/core src/app src/app/attributetable src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Aug 4 12:57:52 EDT 2010
Author: jef
Date: 2010-08-04 16:57:52 +0000 (Wed, 04 Aug 2010)
New Revision: 14010
   trunk/qgis/python/core/qgsattributeaction.sip
   trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsidentifyresults.cpp
   trunk/qgis/src/core/qgsattributeaction.cpp
   trunk/qgis/src/core/qgsattributeaction.h
add QgsAttributeAction::doAction to python bindings
Modified: trunk/qgis/python/core/qgsattributeaction.sip
--- trunk/qgis/python/core/qgsattributeaction.sip	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/python/core/qgsattributeaction.sip	2010-08-04 16:57:52 UTC (rev 14010)
@@ -49,13 +49,12 @@
     // dialog box.
     void addAction( QgsAction::ActionType type, QString name, QString action, bool capture = false );
     //! Does the action using the given values. defaultValueIndex is an
     // index into values which indicates which value in the values vector
     // is to be used if the action has a default placeholder.
+    // @note added to python API in 1.6 (without executePython parameter)
     void doAction( int index, const QList< QPair<QString, QString> > &values,
-                   int defaultValueIndex = 0, void *executePython = 0 );
+                   int defaultValueIndex = 0 );
     //! Removes all actions
     void clearActions();
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp	2010-08-04 16:57:52 UTC (rev 14010)
@@ -497,11 +497,6 @@
   emit layoutAboutToBeChanged();
-static void _runPythonString( const QString &expr )
-  QgisApp::instance()->runPythonString( expr );
 void QgsAttributeTableModel::executeAction( int action, const QModelIndex &idx ) const
   QList< QPair<QString, QString> > attributes;
@@ -514,5 +509,5 @@
-  mLayer->actions()->doAction( action, attributes, fieldIdx( idx.column() ), _runPythonString );
+  mLayer->actions()->doAction( action, attributes, fieldIdx( idx.column() ) );
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-08-04 16:57:52 UTC (rev 14010)
@@ -159,6 +159,7 @@
 #include "qgscredentialdialog.h"
 #include "qgstilescalewidget.h"
 #include "qgsquerybuilder.h"
+#include "qgsattributeaction.h"
 #ifdef HAVE_QWT
 #include "qgsgpsinformationwidget.h"
@@ -4939,6 +4940,11 @@
+static void _runPythonString( const QString &expr )
+  QgisApp::instance()->runPythonString( expr );
 void QgisApp::loadPythonSupport()
   QString pythonlibName( "qgispython" );
@@ -4983,6 +4989,7 @@
   if ( mPythonUtils && mPythonUtils->isEnabled() )
     QgsPluginRegistry::instance()->setPythonUtils( mPythonUtils );
+    QgsAttributeAction::setPythonExecute( _runPythonString );
     mActionShowPythonDialog = new QAction( tr( "Python Console" ), this );
     QgsShortcutsManager::instance()->registerAction( mActionShowPythonDialog );
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp	2010-08-04 16:57:52 UTC (rev 14010)
@@ -44,11 +44,6 @@
 #include "qgslogger.h"
 QgsFeatureAction::QgsFeatureAction( const QString &name, QgsIdentifyResults *results, QgsVectorLayer *vl, int action, QTreeWidgetItem *featItem )
     : QAction( name, results )
     , mLayer( vl )
@@ -60,7 +55,7 @@
 void QgsFeatureAction::execute()
-  mLayer->actions()->doAction( mAction, mAttributes, mIdx, _runPythonString );
+  mLayer->actions()->doAction( mAction, mAttributes, mIdx );
 class QgsIdentifyResultsDock : public QDockWidget
Modified: trunk/qgis/src/core/qgsattributeaction.cpp
--- trunk/qgis/src/core/qgsattributeaction.cpp	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/src/core/qgsattributeaction.cpp	2010-08-04 16:57:52 UTC (rev 14010)
@@ -68,6 +68,10 @@
       executePython( expandedAction );
+    else if ( smPythonExecute )
+      smPythonExecute( expandedAction );
   else
@@ -151,3 +155,9 @@
   return true;
+void ( *QgsAttributeAction::smPythonExecute )( const QString & ) = 0;
+void QgsAttributeAction::setPythonExecute( void ( *runPython )( const QString & ) )
+  smPythonExecute = runPython;
Modified: trunk/qgis/src/core/qgsattributeaction.h
--- trunk/qgis/src/core/qgsattributeaction.h	2010-08-04 15:45:39 UTC (rev 14009)
+++ trunk/qgis/src/core/qgsattributeaction.h	2010-08-04 16:57:52 UTC (rev 14010)
@@ -32,6 +32,7 @@
 class QDomNode;
 class QDomDocument;
+class QgsPythonUtils;
 /** \ingroup core
  * Utility class that encapsulates an action based on vector attributes.
@@ -109,6 +110,7 @@
+    // @note parameter executePython deprecated (and missing in python binding)
                    int defaultValueIndex = 0, void ( *executePython )( const QString & ) = 0 );
@@ -130,8 +132,11 @@
     QgsAction &at( int idx ) { return mActions[idx]; }
     QgsAction &operator[]( int idx ) { return mActions[idx]; }
+    static void setPythonExecute( void ( * )( const QString & ) );
   private:
     QList<QgsAction> mActions;
+    static void ( *smPythonExecute )( const QString & );
 #endif
More information about the QGIS-commit mailing list
