[QGIS Commit] r14026 - in docs/trunk/english_us/developer_cookbook:
. source
svn_qgis at osgeo.org
Sat Aug 7 18:05:59 EDT 2010
Author: wonder
Date: 2010-08-07 22:05:59 +0000 (Sat, 07 Aug 2010)
New Revision: 14026
docs/trunk/english_us/developer_cookbook/
docs/trunk/english_us/developer_cookbook/source/raster.rst
Added some text and code for raster layers
Property changes on: docs/trunk/english_us/developer_cookbook
___________________________________________________________________
Added: svn:ignore
+ build
Modified: docs/trunk/english_us/developer_cookbook/source/raster.rst
--- docs/trunk/english_us/developer_cookbook/source/raster.rst 2010-08-07 19:34:00 UTC (rev 14025)
+++ docs/trunk/english_us/developer_cookbook/source/raster.rst 2010-08-07 22:05:59 UTC (rev 14026)
@@ -6,6 +6,105 @@
This sections lists various operations you can do with raster layers.
+Layer Details
+A raster layer consists of one or more raster bands - it is referred to as either single band or multi band raster.
+One band represents a matrix of values. Usual color image (e.g. aerial photo) is a raster consisting of red, blue and green band.
+Single band layers typically represent either continuous variables (e.g. elevation) or discrete variables (e.g. land use).
+In some cases, a raster layer comes with a palette and raster values refer to colors stored in the palette.
+ >>> rlayer.width(), rlayer.height()
+ (812, 301)
+ >>> rlayer.extent().toString()
+ PyQt4.QtCore.QString(u'12.095833,48.552777 : 18.863888,51.056944')
+ >>> rlayer.rasterType()
+ 2 # 0 = GrayOrUndefined (single band), 1 = Palette (single band), 2 = Multiband
+ >>> rlayer.bandCount()
+ 3
+ >>> rlayer.metadata()
+ PyQt4.QtCore.QString(u'<p class="glossy">Driver:</p>...')
+ >>> rlayer.hasPyramids()
+ False
+Drawing Style
+When a raster layer is loaded, it gets a default drawing style based on its type. It can be altered either in raster layer properties or programmatically.
+The following drawing styles exist:
+Index Constant: QgsRasterLater.X Comment
+ 1 SingleBandGray Single band image drawn as a range of gray colors
+ 2 SingleBandPseudoColor Single band image drawn using a pseudocolor algorithm
+ 3 PalettedColor "Palette" image drawn using color table
+ 4 PalettedSingleBandGray "Palette" layer drawn in gray scale
+ 5 PalettedSingleBandPseudoColor "Palette" layerdrawn using a pseudocolor algorithm
+ 7 MultiBandSingleGandGray Layer containing 2 or more bands, but a single band drawn as a range of gray colors
+ 8 MultiBandSingleBandPseudoColor Layer containing 2 or more bands, but a single band drawn using a pseudocolor algorithm
+ 9 MultiBandColor Layer containing 2 or more bands, mapped to RGB color space.
+To query the current drawing style:
+ >>> rlayer.drawingStyle()
+ 9
+Single band raster layers can be drawn either in gray colors (low values = black, high values = white) or with a pseudocolor algorithm
+that assigns colors for values from the single band. Single band rasters with a palette can be additionally drawn using their palette.
+Multiband layers are typically drawn by mapping the bands to RGB colors. Other possibility is to use just one band for gray or pseudocolor
+drawing.
+.. todo:: contrast enhancements, transparency (no data), user defined min/max, band statistics
+Single Band Rasters
+They are rendered in gray colors by default. To change the drawing style to pseudocolor:
+ >>> rlayer.setDrawingStyle(QgsRasterLayer.SingleBandPseudoColor)
+ >>> rlayer.setColorShadingAlgorithm(QgsRasterLayer.PseudoColorShader)
+The ``PseudoColorShader`` is a basic shader that highlighs low values in blue and high values in red. Another, ``FreakOutShader`` uses
+more fancy colors and according to the documentation, it will frighten your granny and make your dogs howl.
+There is also ``ColorRampShader`` which maps the colors as specified by its color map. It has three modes of interpolation of values:
+* linear (``INTERPOLATED``): resulting color is linearly interpolated from the color map entries above and below the actual pixel value
+* discrete (``DISCRETE``): color is used from the color map entry with equal or higher value
+* exact (``EXACT``): color is not interpolated, only the pixels with value equal to color map entries are drawn
+To set an interpolated color ramp shader ranging from green to yellow color (for pixel values from 0 to 255)::
+ >>> rlayer.setColorShadingAlgorithm(QgsRasterLayer.ColorRampShader)
+ >>> lst = [ QgsColorRampShader.ColorRampItem(0, QColor(0,255,0)), QgsColorRampShader.ColorRampItem(255, QColor(255,255,0)) ]
+ >>> fcn = rlayer.rasterShader().rasterShaderFunction()
+ >>> fcn.setColorRampType(QgsColorRampShader.INTERPOLATED)
+ >>> fcn.setColorRampItemList(lst)
+To return back to default gray levels, use:
+ >>> rlayer.setDrawingStyle(QgsRasterLayer.SingleBandGray)
+Multi Band Rasters
+By default, QGIS maps the first three bands to red, green and blue values to create a color image (this is the ``MultiBandColor`` drawing style.
+In some cases you might want to override these setting. The following code interchanges red band (1) and green band (2):
+ >>> rlayer.setGreenBandName(rlayer.bandName(1))
+ >>> rlayer.setRedBandName(rlayer.bandName(2))
+In case only one band is necessary for visualization of the raster, single band drawing can be chosen - either gray levels or pseudocolor,
+see previous section::
+ >>> rlayer.setDrawingStyle(QgsRasterLayer.MultiBandSingleBandPseudoColor)
+ >>> rlayer.setGrayBandName(rlayer.bandName(1))
+ >>> # now set the shader
Query Values
