[QGIS Commit] r14047 - in docs/trunk/english_us/user_guide: . features_at_a_glance_screenies working_with_vector_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Aug 10 16:31:28 EDT 2010
Author: dassau
Date: 2010-08-10 20:31:28 +0000 (Tue, 10 Aug 2010)
New Revision: 14047
Added:
   docs/trunk/english_us/user_guide/working_with_vector_screenies/rulesymbol_ng_line.png
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/annotation.png
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_angle.png
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_area.png
   docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_line.png
   docs/trunk/english_us/user_guide/working_with_vector.tex
   docs/trunk/english_us/user_guide/working_with_vector_screenies/addvectorlayerdialog.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/categorysymbol_ng_line.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_area.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_line.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_point.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties1.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/vectorLayerSymbology.png
started figure updates
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/annotation.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_angle.png
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_area.png
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/measure_line.png
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-08-10 20:26:07 UTC (rev 14046)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-08-10 20:31:28 UTC (rev 14047)
@@ -598,9 +598,12 @@
 if you make changes to the style that you are not happy with, use the \button{Restore
 Default Style} button to revert to your default style.
-\minisec{Vector transparency} \label{sec:vect_transparency} \index{vector layers!transparency}
+\minisec{Vector transparency} \label{sec:vect_transparency}
+\index{vector layers!transparency}
 \qg allows to set a transparency for every vector layer. This can be done with
-the slider \slider{Transparency}{0}{20mm} inside the \tab{symbology} tab (see
+the slider \\
+\slider{Transparency} inside the \tab{symbology} tab (see
 fig. \ref{subfig:single_symbol}). This is very useful for overlaying several
 vector layers.
@@ -650,7 +653,8 @@
 \end{itemize}
 Color ramps can be defined in the \dialog{Style Manager} dialog (see Section
-\ref{subsec:stylemanager}) by selecting \selectstring{Style item type:}{Color ramp} as style element type from the drop-down list, clicking on \button{Add item} button and then choosing a color ramp type.
+\ref{subsec:stylemanager}) by selecting \\
+\selectstring{Style item type:}{Color ramp} as style element type from the drop-down list, clicking on \button{Add item} button and then choosing a color ramp type.
 \minisec{Styles}
@@ -756,6 +760,24 @@
    \caption{New Graduated Symbolizing options \nixcaption}\label{fig:gradsymNG}
 \end{figure}
+\minisec{Rule-based rendering}
+The rule-based renderer is used to render all the features from a layer, using
+rule based symbols, whose color reflects the classification of a selected
+feature's attribute to a class.
+%%FIXME
+Add more text here
+The example in figure \ref{fig:rulesymNG} shows the rule-based rendering dialog
+for the rivers layer of the \qg sample dataset.
+\begin{figure}[ht]
+   \centering
+   \includegraphics[clip=true, width=10cm]{rulesymbol_ng_line}
+   \caption{New Rule-rBased Symbolizing options \nixcaption}\label{fig:rulesymNG}
+\end{figure}
 \minisec{Symbol Properties}
 The symbol properties dialog allows the user to specify different properties of
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/addvectorlayerdialog.png
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/categorysymbol_ng_line.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/rulesymbol_ng_line.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/rulesymbol_ng_line.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_area.png
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_line.png
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_point.png
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties1.png
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/vectorLayerSymbology.png
More information about the QGIS-commit mailing list
