[QGIS Commit] r14057 -
docs/trunk/english_us/developer_cookbook/source
svn_qgis at osgeo.org
Wed Aug 11 07:22:37 EDT 2010
Author: wonder
Date: 2010-08-11 11:22:37 +0000 (Wed, 11 Aug 2010)
New Revision: 14057
Removed:
docs/trunk/english_us/developer_cookbook/source/todolist.rst
docs/trunk/english_us/developer_cookbook/source/canvas.rst
docs/trunk/english_us/developer_cookbook/source/composer.rst
docs/trunk/english_us/developer_cookbook/source/expressions.rst
docs/trunk/english_us/developer_cookbook/source/index.rst
docs/trunk/english_us/developer_cookbook/source/intro.rst
docs/trunk/english_us/developer_cookbook/source/loadlayer.rst
docs/trunk/english_us/developer_cookbook/source/measure.rst
docs/trunk/english_us/developer_cookbook/source/raster.rst
docs/trunk/english_us/developer_cookbook/source/vector.rst
Removed todo directives to make the document compatible with sphinx 0.4
Modified: docs/trunk/english_us/developer_cookbook/source/canvas.rst
--- docs/trunk/english_us/developer_cookbook/source/canvas.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/canvas.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -202,12 +202,12 @@
Writing Custom Map Tools
-.. todo:: how to create a map tool
+**TODO:** how to create a map tool
Writing Custom Map Canvas Items
-.. todo:: how to create a map canvas item
+**TODO:** how to create a map canvas item
Modified: docs/trunk/english_us/developer_cookbook/source/composer.rst
--- docs/trunk/english_us/developer_cookbook/source/composer.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/composer.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -93,7 +93,7 @@
image.save("out.png", "png")
-.. todo::
+**TODO:**
Output to PDF,
Loading/saving compositions,
More composer items (north arrow, scale, ...)
Modified: docs/trunk/english_us/developer_cookbook/source/expressions.rst
--- docs/trunk/english_us/developer_cookbook/source/expressions.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/expressions.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -49,7 +49,7 @@
-.. todo:: parsing, error handling
+**TODO:** parsing, error handling
@@ -61,7 +61,7 @@
>>> s.parserErrorMsg()
PyQt4.QtCore.QString(u'syntax error, unexpected $end')
-.. todo:: working with the tree, evaluation as a predicate, as a function, error handling
+**TODO:** working with the tree, evaluation as a predicate, as a function, error handling
Evaluating Expressions
Modified: docs/trunk/english_us/developer_cookbook/source/index.rst
--- docs/trunk/english_us/developer_cookbook/source/index.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/index.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -22,7 +22,6 @@
expressions
measure
plugins
- todolist
Indices and tables
Modified: docs/trunk/english_us/developer_cookbook/source/intro.rst
--- docs/trunk/english_us/developer_cookbook/source/intro.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/intro.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -13,7 +13,7 @@
QGIS code depends on Qt libraries. Python bindings for Qt (PyQt) are done also using SIP and this allows seamless integration of PyQGIS with PyQt.
-.. todo::
+**TODO:**
Getting PyQGIS to work (Manual compilation, Troubleshooting)
Modified: docs/trunk/english_us/developer_cookbook/source/loadlayer.rst
--- docs/trunk/english_us/developer_cookbook/source/loadlayer.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/loadlayer.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -97,5 +97,5 @@
QgsMapLayerRegistry.instance().removeMapLayer(layer_id)
-.. todo::
+**TODO:**
More about map layer registry?
Modified: docs/trunk/english_us/developer_cookbook/source/measure.rst
--- docs/trunk/english_us/developer_cookbook/source/measure.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/measure.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -13,4 +13,4 @@
print "distance in meters: ", d.measureLine(QgsPoint(10,10),QgsPoint(11,11))
-.. todo:: area, planar vs. ellipsoid
\ No newline at end of file
+**TODO:** area, planar vs. ellipsoid
Modified: docs/trunk/english_us/developer_cookbook/source/raster.rst
--- docs/trunk/english_us/developer_cookbook/source/raster.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/raster.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -60,7 +60,7 @@
The following sections explain how to query and modify the layer drawing style. After doing the changes, you might want to force update
of map canvas, see :ref:`refresh-layer`.
-.. todo:: contrast enhancements, transparency (no data), user defined min/max, band statistics
+**TODO:** contrast enhancements, transparency (no data), user defined min/max, band statistics
Single Band Rasters
Deleted: docs/trunk/english_us/developer_cookbook/source/todolist.rst
--- docs/trunk/english_us/developer_cookbook/source/todolist.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/todolist.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -1,7 +0,0 @@
-TODO list
-This section lists parts of the documentation which are missing some explanations, code samples etc.
-.. todolist::
Modified: docs/trunk/english_us/developer_cookbook/source/vector.rst
--- docs/trunk/english_us/developer_cookbook/source/vector.rst 2010-08-11 10:12:54 UTC (rev 14056)
+++ docs/trunk/english_us/developer_cookbook/source/vector.rst 2010-08-11 11:22:37 UTC (rev 14057)
@@ -6,7 +6,7 @@
This section summarizes various actions that can be done with vector layers.
-.. todo::
+**TODO:**
Editing, Layer vs. Data provider, ...
Iterating over Vector Layer
@@ -89,7 +89,7 @@
Using Spatial Index
-.. todo::
+**TODO:**
Intro to spatial indexing
1. create spatial index - the following code creates an empty index::
