[QGIS Commit] r14070 - in docs/trunk/english_us/user_guide: .
plugins_decorations_images
svn_qgis at osgeo.org
Thu Aug 12 10:14:11 EDT 2010
Author: dassau
Date: 2010-08-12 14:14:11 +0000 (Thu, 12 Aug 2010)
New Revision: 14070
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/grass_integration.tex
docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
docs/trunk/english_us/user_guide/working_with_raster.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
minor changes
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-08-12 08:43:26 UTC (rev 14069)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-08-12 14:14:11 UTC (rev 14070)
@@ -793,9 +793,9 @@
means the layer will be added to the map, but its visibility checkbox in the
legend will be unchecked by default. To set this option, choose
menu option \mainmenuopt{Settings} > \dropmenuopt{Options} and click on the
-\tab{Rendering \& SVG} tab. Uncheck the \checkbox{By default new layers added
-to the map should be displayed} checkbox. Any layer added to the map will be
-off (invisible) by default.
+\tab{Rendering \& SVG} tab. Uncheck the \\
+\checkbox{By default new layers added to the map should be displayed} checkbox.
+Any layer added to the map will be off (invisible) by default.
%\minisec{Stopping Rendering}\index{rendering!halting}
%\label{label_stoprender}
@@ -888,7 +888,9 @@
Load saved projects into a QGIS session using
\mainmenuopt{File} > \dropmenuopttwo{mActionFileOpen}{Open Project}
-or \mainmenuopt{File} > \dropmenuopt{Open Recent Project}.
+or \mainmenuopt{File} > \\
+\dropmenuopt{Open Recent Project}.
If you wish to clear your session and start fresh, choose
\mainmenuopt{File} > \dropmenuopttwo{mActionFileNew}{New Project}.
Either of these menu options will prompt you to save the existing project
@@ -908,11 +910,10 @@
was updated several times compared to earlier QGIS versions. Project files
from older QGIS versions may not work properly anymore. To be made aware of this,
in the \tab{General} tab under \mainmenuopt{Settings} > \dropmenuopt{Options}
-you can select
+you can select: \\
\checkbox{Promt to save project changes when required} \\
-\checkbox{Warn when opening a project file saved with an older version of
-QGIS}.
+\checkbox{Warn when opening a project file saved with an older version of QGIS}
\minisec{Project Properties}
In the properties window for the project under \nix{\mainmenuopt{File} >
@@ -1165,8 +1166,8 @@
\subsection{Working with Bookmarks}
To use or manage bookmarks, select the menu
-option \mainmenuopt{View} > \dropmenuopt{Show Bookmarks}.
-The \dialog{Geospatial Bookmarks} dialog allows you to zoom to or delete a bookmark.
+option \mainmenuopt{View} > \dropmenuopt{Show Bookmarks}. The \\
+\dialog{Geospatial Bookmarks} dialog allows you to zoom to or delete a bookmark.
You can not edit the bookmark name or coordinates.
\subsection{Zooming to a Bookmark}
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2010-08-12 08:43:26 UTC (rev 14069)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2010-08-12 14:14:11 UTC (rev 14070)
@@ -710,8 +710,8 @@
\item Then click \classname{r.shaded.relief} to open
the module.
\item Change the \inputtext{azimuth angle}{270} to 315. Enter
-\usertext{gtopo30\_shade} for the \inputtext{Output shaded relief
-map}{gtopo30\_shade} new hillshade raster, and click \button{run}.
+\usertext{gtopo30\_shade} for the new hillshade raster, and click
+\button{run}.
\item When the process completes, add the hillshade raster to the map. You
should see it displayed in grayscale.
\item To view both the hill shading and the colors of the
@@ -790,15 +790,14 @@
and run the module.
\item Now load the \usertext{forest\_areas} vector and display the types of
forests - deciduous, evergreen, mixed - in different colors: In the layer
-\dropmenuopt{Properties} window, \tab{symbology} tab, choose
+\dropmenuopt{Properties} window, \tab{symbology} tab, choose \\
\selectstring{Legend type}{Unique value} and set the
\inputtext{Classification field}{VEGDESC} to VEGDESC. (Refer to the
explanation of the symbology tab \ref{sec:symbology} in the vector section).
\item Next reopen the GRASS toolbox and open Vector -> Vector update by other
maps.
-\item Click on the \classname{v.rast.stats} module. Enter \inputtext{Name of
-raster}{\usertext{gtopo30}}, and \inputtext{Name of vector
-polygon}{\usertext{forest\_areas}}.
+\item Click on the \classname{v.rast.stats} module. Enter \usertext{gtopo30},
+and \usertext{forest\_areas}.
\item Only one additional parameter is needed: Enter \inputtext{column
prefix}{\usertext{elev}}, and click \button{run}. This is a computationally
heavy operation which will run for a long time (probably up to two hours).
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_raster.tex
--- docs/trunk/english_us/user_guide/working_with_raster.tex 2010-08-12 08:43:26 UTC (rev 14069)
+++ docs/trunk/english_us/user_guide/working_with_raster.tex 2010-08-12 14:14:11 UTC (rev 14070)
@@ -52,7 +52,7 @@
Raster layers are loaded either by clicking on the
\toolbtntwo{mActionAddRasterLayer}{Load Raster} icon or by
-selecting the \mainmenuopt{View}>\dropmenuopttwo{mActionAddRasterLayer}{Add Raster Layer}
+selecting the \mainmenuopt{View} > \dropmenuopttwo{mActionAddRasterLayer}{Add Raster Layer}
menu option. More than one layer can be loaded at the same time by holding down the
\keystroke{Control} or \keystroke{Shift} key and clicking on multiple items
in the dialog \dialog{Open a GDAL Supported Raster Data Source}.\index{raster layers!loading}
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-12 08:43:26 UTC (rev 14069)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2010-08-12 14:14:11 UTC (rev 14070)
@@ -192,9 +192,9 @@
open the \dialog{Add Vector Layer} dialog and select \radiobuttonon{Database}.
The \dialog{Add PostGIS Table(s)} dialog will
be displayed. To access the connection manager\index{PostgreSQL!connection
-manager}, click on the \button{New} button to display the \dialog{Create a New
-PostGIS Connection} dialog. The parameters required for a connection are shown
-in table \ref{tab:postgis_connection_parms}.
+manager}, click on the \button{New} button to display the \\
+\dialog{Create a New PostGIS Connection} dialog. The parameters required for
+a connection are shown in table \ref{tab:postgis_connection_parms}.
\begin{table}[ht]\index{PostgreSQL!connection parameters}
\centering
@@ -351,7 +351,7 @@
icon will be added to the plugin toolbar\index{PostGIS!SPIT!loading}.
To import a shapefile, click on the \toolbtntwo{spiticon}{SPIT} tool in the
-toolbar to open the
+toolbar to open the \\
\dialog{SPIT - Shapefile to PostGIS Import Tool} dialog. Select the PostGIS database
you want to connect to and click on \button{Connect}. Now you can add one or more
files to the queue by clicking on the \button{Add} button. To process the files,
@@ -1490,6 +1490,7 @@
the new feature. Figure \ref{fig:vector_digitising} shows setting attributes
for a fictitious new river in Alaska. In the \tab{Digitising} tab under the
\mainmenuopt{Settings} >\dropmenuopt{Options} menu, you can also activate the
\checkbox{Suppress attributes pop-up windows after each created feature}.
\begin{figure}[ht]
