[QGIS Commit] r14081 - trunk/qgis/scripts
svn_qgis at osgeo.org
Sat Aug 14 10:47:48 EDT 2010
Author: jef
Date: 2010-08-14 14:47:48 +0000 (Sat, 14 Aug 2010)
New Revision: 14081
trunk/qgis/scripts/create_new_ts.sh
trunk/qgis/scripts/update_ts_files.sh
fix create_new_ts.sh
Modified: trunk/qgis/scripts/create_new_ts.sh
--- trunk/qgis/scripts/create_new_ts.sh 2010-08-14 12:24:19 UTC (rev 14080)
+++ trunk/qgis/scripts/create_new_ts.sh 2010-08-14 14:47:48 UTC (rev 14081)
@@ -9,26 +9,4 @@
exit 0
fi
-# Create a new .ts file for a new translation in qgis
-# 1. create a clean Qt .pro file for the project
-# 2. run lupdate using the .pro file from step 1
-# 3. remove the .pro
-# update_ts_files.sh,v 1.3 2004/07/14 18:16:24 gsherman Exp
-#first tar the qt_xx.ts files in i18n folder such that lupdate does not
-#merge the qgis strings to them
-QTDIR=/usr/
-echo Creating qt_ts.tar
-tar -cvf i18n/qt_ts.tar i18n/qt_*.ts
-rm i18n/qt_*.ts
-echo Creating qmake project file
-$QTDIR/bin/qmake -project -o qgis_ts.pro
-#add our new translation to the pro file
-echo "Creating new translation entry for $1 in the pro file"
-echo "TRANSLATIONS += i18n/qgis_${1}.ts" >> qgis_ts.pro
-echo Updating translation files
-$QTDIR/bin/lupdate -verbose qgis_ts.pro
-echo Removing qmake project file
-rm qgis_ts.pro
-echo Unpacking qt_ts.tar
-tar -xvf i18n/qt_ts.tar
+$(dirname $0)/update_ts_files.sh -a $1
Modified: trunk/qgis/scripts/update_ts_files.sh
--- trunk/qgis/scripts/update_ts_files.sh 2010-08-14 12:24:19 UTC (rev 14080)
+++ trunk/qgis/scripts/update_ts_files.sh 2010-08-14 14:47:48 UTC (rev 14081)
@@ -51,14 +51,27 @@
tar --remove-files -cf i18n/qt_ts.tar i18n/qt_*.ts
exclude=
opts=
-for i in "$@"; do
- if [ -f "i18n/qgis_$i.ts" ]; then
- exclude="$exclude --exclude i18n/qgis_$i.ts"
+while (( $# > 0 )); do
+ arg=$1
+ shift
+ if [ "$arg" = "-a" ]; then
+ arg=$1
+ shift
+ if [ -f "i18n/qgis_$arg.ts" ]; then
+ echo "cannot add existing tranlation $arg"
+ exit 1
+ else
+ add="$add $arg"
+ fi
+ elif [ -f "i18n/qgis_$arg.ts" ]; then
+ exclude="$exclude --exclude i18n/qgis_$arg.ts"
else
- opts=" $i"
+ opts="$opts $arg"
fi
done
-if [ -n "$exclude" ]; then
+if [ -n "$exclude" -o -n "$add" ]; then
echo Saving excluded translations
tar --remove-files -cf i18n/qgis_ts.tar i18n/qgis_*.ts$exclude
fi
@@ -86,5 +99,22 @@
[ -f "$i" ] && mv "$i" "$i.save"
done
qmake -project -o qgis_ts.pro -nopwd src python i18n
+if [ -n "$add" ]; then
+ for i in $add; do
+ echo "Adding translation for $i"
+ echo "TRANSLATIONS += i18n/qgis_$i.ts" >> qgis_ts.pro
+ done
+fi
echo Updating translations
lupdate$opts -verbose qgis_ts.pro
+ for i in $add; do
+ if [ -f i18n/qgis_$i.ts ]; then
+ svn add i18n/qgis_$i.ts
+ else
+ echo "Translaiton for $i was not added"
+ exit 1
+ fi
+ done
+fi
