[QGIS Commit] r14092 - in branches/threading-branch/src/core: .
symbology-ng
svn_qgis at osgeo.org
Mon Aug 16 11:17:09 EDT 2010
Author: wonder
Date: 2010-08-16 15:17:09 +0000 (Mon, 16 Aug 2010)
New Revision: 14092
branches/threading-branch/src/core/qgsclipper.cpp
branches/threading-branch/src/core/qgsclipper.h
branches/threading-branch/src/core/symbology-ng/qgssymbollayerv2.cpp
Improved rendering speed of zoomed in polygons with holes.
Clipping is now done to get coordinates into range +/- 16000.
(This is to ensure that slow Qt clipping won't start with Qt >= 4.6)
Hopefully it will not affect printing from map composer.
Modified: branches/threading-branch/src/core/qgsclipper.cpp
--- branches/threading-branch/src/core/qgsclipper.cpp 2010-08-16 12:30:26 UTC (rev 14091)
+++ branches/threading-branch/src/core/qgsclipper.cpp 2010-08-16 15:17:09 UTC (rev 14092)
@@ -25,9 +25,14 @@
// But the static members must be initialised outside the class! (or GCC 4 dies)
-const double QgsClipper::MAX_X = 30000;
-const double QgsClipper::MIN_X = -30000;
-const double QgsClipper::MAX_Y = 30000;
-const double QgsClipper::MIN_Y = -30000;
+// Qt also does clipping when the coordinates go over +/- 32767
+// moreover from Qt 4.6, Qt clips also when the width/height of a painter path
+// is more than 32767. Since we want to avoid clipping by Qt (because it is slow)
+// we set coordinate limit to less than 32767 / 2
+static const double COORD_LIMIT = 16000;
+const double QgsClipper::MAX_X = COORD_LIMIT;
+const double QgsClipper::MIN_X = -COORD_LIMIT;
+const double QgsClipper::MAX_Y = COORD_LIMIT;
+const double QgsClipper::MIN_Y = -COORD_LIMIT;
const double QgsClipper::SMALL_NUM = 1e-12;
Modified: branches/threading-branch/src/core/qgsclipper.h
--- branches/threading-branch/src/core/qgsclipper.h 2010-08-16 12:30:26 UTC (rev 14091)
+++ branches/threading-branch/src/core/qgsclipper.h 2010-08-16 15:17:09 UTC (rev 14092)
@@ -27,6 +27,8 @@
#include <cmath>
#include <iostream>
+#include <QPolygonF>
/** \ingroup core
* A class to trim lines and polygons to within a rectangular region.
* The functions in this class are likely to be called from within a
@@ -77,6 +79,8 @@
std::vector<double>& y,
bool shapeOpen );
+ static void trimFeature( QPolygonF& pts, bool shapeOpen );
private:
// Used when testing for equivalance to 0.0
@@ -91,16 +95,27 @@
Boundary b,
bool shapeOpen );
+ static void trimFeatureToBoundary( const QPolygonF& inPts,
+ QPolygonF& outPts,
+ Boundary b,
+ bool shapeOpen );
// Determines if a point is inside or outside the given boundary
static bool inside( const double x, const double y, Boundary b );
+ static bool inside( const QPointF& pt, Boundary b );
// Calculates the intersection point between a line defined by a
// (x1, y1), and (x2, y2) and the given boundary
static QgsPoint intersect( const double x1, const double y1,
const double x2, const double y2,
Boundary b );
+ static QPointF intersect( const QPointF& pt1,
+ const QPointF& pt2,
+ Boundary b );
// The inline functions
// Trim the feature using Sutherland and Hodgman's
@@ -134,6 +149,36 @@
trimFeatureToBoundary( tmpX, tmpY, x, y, YMin, shapeOpen );
+inline void QgsClipper::trimFeature( QPolygonF& pts, bool shapeOpen )
+ bool needs_clipping = false;
+ const QPointF* ptsData = pts.constData();
+ for ( int i = 0; i < pts.count(); i++, ptsData++ )
+ if ( ptsData->x() < MIN_X || ptsData->x() > MAX_X
+ || ptsData->y() < MIN_Y || ptsData->y() > MAX_Y )
+ needs_clipping = true;
+ break;
+ if ( !needs_clipping )
+ return;
+ QPolygonF tmpPts;
+ tmpPts.reserve( pts.size() );
+ trimFeatureToBoundary( pts, tmpPts, XMax, shapeOpen );
+ pts.clear();
+ trimFeatureToBoundary( tmpPts, pts, YMax, shapeOpen );
+ tmpPts.clear();
+ trimFeatureToBoundary( pts, tmpPts, XMin, shapeOpen );
+ pts.clear();
+ trimFeatureToBoundary( tmpPts, pts, YMin, shapeOpen );
// An auxilary function that is part of the polygon trimming
// code. Will trim the given polygon to the given boundary and return
// the trimmed polygon in the out pointer. Uses Sutherland and
@@ -194,6 +239,53 @@
+inline void QgsClipper::trimFeatureToBoundary(
+ const QPolygonF& inPts, QPolygonF& outPts,
+ Boundary b, bool shapeOpen )
+ // The shapeOpen parameter selects whether this function treats the
+ // shape as open or closed. False is appropriate for polygons and
+ // true for polylines.
+ unsigned int i1 = inPts.size() - 1; // start with last point
+ // and compare to the first point initially.
+ for ( unsigned int i2 = 0; i2 < inPts.size() ; ++i2 )
+ { // look at each edge of the polygon in turn
+ if ( inside( inPts[i2], b ) ) // end point of edge is inside boundary
+ if ( inside( inPts[i1], b ) )
+ outPts.append( inPts[i2] );
+ else
+ // edge crosses into the boundary, so trim back to the boundary, and
+ // store both ends of the new edge
+ if ( !( i2 == 0 && shapeOpen ) )
+ outPts.append( intersect( inPts[i1], inPts[i2], b ) );
+ else // end point of edge is outside boundary
+ // start point is in boundary, so need to trim back
+ i1 = i2;
// An auxilary function to trimPolygonToBoundarY() that returns
// whether a point is inside or outside the given boundary.
@@ -221,7 +313,23 @@
return false;
+inline bool QgsClipper::inside( const QPointF& pt, Boundary b )
+ switch ( b )
+ case XMax: // x < MAX_X is inside
+ return ( pt.x() < MAX_X );
+ case XMin: // x > MIN_X is inside
+ return ( pt.x() > MIN_X );
+ case YMax: // y < MAX_Y is inside
+ return ( pt.y() < MAX_Y );
+ case YMin: // y > MIN_Y is inside
+ return ( pt.y() > MIN_Y );
+ return false;
// An auxilary function to trimPolygonToBoundarY() that calculates and
// returns the intersection of the line defined by the given points
// and the given boundary.
@@ -273,5 +381,50 @@
return p;
+inline QPointF QgsClipper::intersect( const QPointF& pt1,
+ Boundary b )
+ // This function assumes that the two given points (x1, y1), and
+ // (x2, y2) cross the given boundary. Making this assumption allows
+ // some optimisations.
+ double r_n = SMALL_NUM, r_d = SMALL_NUM;
+ const double x1 = pt1.x(), x2 = pt2.x();
+ const double y1 = pt1.y(), y2 = pt2.y();
+ switch ( b )
+ case XMax: // x = MAX_X boundary
+ r_n = -( x1 - MAX_X ) * ( MAX_Y - MIN_Y );
+ r_d = ( x2 - x1 ) * ( MAX_Y - MIN_Y );
+ break;
+ case XMin: // x = MIN_X boundary
+ r_n = -( x1 - MIN_X ) * ( MAX_Y - MIN_Y );
+ break;
+ case YMax: // y = MAX_Y boundary
+ r_n = ( y1 - MAX_Y ) * ( MAX_X - MIN_X );
+ r_d = -( y2 - y1 ) * ( MAX_X - MIN_X );
+ break;
+ case YMin: // y = MIN_Y boundary
+ r_n = ( y1 - MIN_Y ) * ( MAX_X - MIN_X );
+ break;
+ if ( std::abs( r_d ) > SMALL_NUM && std::abs( r_n ) > SMALL_NUM )
+ { // they cross
+ double r = r_n / r_d;
+ return QPointF( x1 + r*( x2 - x1 ), y1 + r*( y2 - y1 ) );
+ else
+ // Should never get here, but if we do for some reason, cause a
+ // clunk because something else is wrong if we do.
+ Q_ASSERT( std::abs( r_d ) > SMALL_NUM && std::abs( r_n ) > SMALL_NUM );
+ return QPointF();
#endif
Modified: branches/threading-branch/src/core/symbology-ng/qgssymbollayerv2.cpp
--- branches/threading-branch/src/core/symbology-ng/qgssymbollayerv2.cpp 2010-08-16 12:30:26 UTC (rev 14091)
+++ branches/threading-branch/src/core/symbology-ng/qgssymbollayerv2.cpp 2010-08-16 15:17:09 UTC (rev 14092)
@@ -3,6 +3,7 @@
#include "qgsrenderer.h"
#include "qgsrendercontext.h"
+#include "qgsclipper.h"
#include <QSize>
#include <QPainter>
@@ -87,12 +88,20 @@
QPainterPath path;
QPolygonF outer_ring( numPoints );
memcpy( outer_ring.data(), points, sizeof(QPointF) * numPoints );
+ // clip polygon rings! Qt (as of version 4.6) has a slow algorithm for
+ // clipping painter paths: we will clip the rings by ourselves, so
+ // the clipping in Qt will not be triggered.
+ QgsClipper::trimFeature( outer_ring, false );
path.addPolygon( outer_ring );
QList<QPolygonF>::const_iterator it = rings->constBegin();
for ( ; it != rings->constEnd(); ++it )
- path.addPolygon( *it );
+ QPolygonF ring = *it;
+ QgsClipper::trimFeature( ring, false );
+ path.addPolygon( ring );
p->drawPath( path );
