[QGIS Commit] r14149 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org
Wed Aug 25 21:30:49 EDT 2010
Author: kyngchaos
Date: 2010-08-26 01:30:49 +0000 (Thu, 26 Aug 2010)
New Revision: 14149
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
remove old snow python 32/64bit hacks for pyuic (use pyqt 4.7+)
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-08-26 01:01:56 UTC (rev 14148)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-08-26 01:30:49 UTC (rev 14149)
@@ -17106,7 +17106,7 @@
runOnlyForDeploymentPostprocessing = 0;
shellPath = /bin/sh;
- shellScript = "plug=\"fTools\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# workaround for broken arch command on Snow - we need to run python 32bit (from pyuic4)\n\nif [ \"$SDKSYS\" = \"snow\" ] && [ \"$PYTHON_FORM\" = \"system\" ] ; then\n\texport PATH=\"$TARGET_TEMP_DIR/python/bin:$PATH\"\nfi\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\nRCR
C=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$targetdir/$rpy\" ] ; then\n\t\trm -f \"$targetdir/$rpy\"\n\t\techo \"$PYRCC4 -name $rpy -o \\\"$targetdir/$rpy\\\" $r\"\n\t\t$PYRCC4 -name $rpy -o \"$targetdir/$rpy\" $r\n\t#fi\ndone\n\n# generate tools ui py files\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug/tools\"\nmkdir -p \"$targetdir\"\ncd tools\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\nexit 0\n";
+ shellScript = "plug=\"fTools\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$targetdir/
showEnvVarsInLog = 0;
72DEE0FC11B95859004ED376 /* Script - ui+rc */ = {
@@ -17121,7 +17121,7 @@
- shellScript = "plug=\"osm\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug/ui_files\n\n# workaround for broken arch command on Snow - we need to run python 32bit (from pyuic4)\n\nif [ \"$SDKSYS\" = \"snow\" ] && [ \"$PYTHON_FORM\" = \"system\" ] ; then\n\texport PATH=\"$TARGET_TEMP_DIR/python/bin:$PATH\"\nfi\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\
n\ncd ..\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$targetdir/$rpy\" ] ; then\n\t\trm -f \"$targetdir/$rpy\"\n\t\techo \"$PYRCC4 -name $rpy -o \\\"$targetdir/$rpy\\\" $r\"\n\t\t$PYRCC4 -name $rpy -o \"$targetdir/$rpy\" $r\n\t#fi\ndone\n\nexit 0\n";
+ shellScript = "plug=\"osm\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug/ui_files\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\ncd ..\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt
72DEE19811B95920004ED376 /* Script - ui+rc */ = {
@@ -17136,7 +17136,7 @@
- shellScript = "plug=\"GdalTools\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# workaround for broken arch command on Snow - we need to run python 32bit (from pyuic4)\n\nif [ \"$SDKSYS\" = \"snow\" ] && [ \"$PYTHON_FORM\" = \"system\" ] ; then\n\texport PATH=\"$TARGET_TEMP_DIR/python/bin:$PATH\"\nfi\n\n# generate ui py files\n\n#UIUI=`ls *.ui`\n\n#for u in $UIUI\n#do\n#\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n#\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n#\t\trm -f \"$targetdir/$upy\"\n#\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n#\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n#\tfi\n#done\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if c
hanged\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$targetdir/$rpy\" ] ; then\n\t\trm -f \"$targetdir/$rpy\"\n\t\techo \"$PYRCC4 -name $rpy -o \\\"$targetdir/$rpy\\\" $r\"\n\t\t$PYRCC4 -name $rpy -o \"$targetdir/$rpy\" $r\n\t#fi\ndone\n\n# generate tools ui py files\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug/tools\"\nmkdir -p \"$targetdir\"\ncd tools\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\nexit 0\n";
+ shellScript = "plug=\"GdalTools\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# generate ui py files\n\n#UIUI=`ls *.ui`\n\n#for u in $UIUI\n#do\n#\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n#\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n#\t\trm -f \"$targetdir/$upy\"\n#\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n#\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n#\tfi\n#done\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt
72DEE24B11B95A01004ED376 /* Script - ui+rc */ = {
@@ -17151,7 +17151,7 @@
- shellScript = "plug=\"mapserver_export\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# workaround for broken arch command on Snow - we need to run python 32bit (from pyuic4)\n\nif [ \"$SDKSYS\" = \"snow\" ] && [ \"$PYTHON_FORM\" = \"system\" ] ; then\n\texport PATH=\"$TARGET_TEMP_DIR/python/bin:$PATH\"\nfi\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if chan
ged\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$targetdir/$rpy\" ] ; then\n\t\trm -f \"$targetdir/$rpy\"\n\t\techo \"$PYRCC4 -name $rpy -o \\\"$targetdir/$rpy\\\" $r\"\n\t\t$PYRCC4 -name $rpy -o \"$targetdir/$rpy\" $r\n\t#fi\ndone\n\nexit 0\n";
+ shellScript = "plug=\"mapserver_export\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$
72DEE27111B95AFF004ED376 /* Script - ui+rc */ = {
@@ -17166,7 +17166,7 @@
- shellScript = "plug=\"plugin_installer\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# workaround for broken arch command on Snow - we need to run python 32bit (from pyuic4)\n\nif [ \"$SDKSYS\" = \"snow\" ] && [ \"$PYTHON_FORM\" = \"system\" ] ; then\n\texport PATH=\"$TARGET_TEMP_DIR/python/bin:$PATH\"\nfi\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if chan
+ shellScript = "plug=\"plugin_installer\"\n\ntargetdir=\"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/plugins/$plug\"\nmkdir -p \"$targetdir\"\n\ncd ../../python/plugins/$plug\n\n# generate ui py files\n\nUIUI=`ls *.ui`\n\nfor u in $UIUI\ndo\n\tupy=\"ui_`echo $u | sed 's,\\.ui$,.py,'`\"\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\tif [ ! -f \"$targetdir/$upy\" ] || [ $u -nt \"$targetdir/$upy\" ] ; then\n\t\trm -f \"$targetdir/$upy\"\n\t\techo \"$PYUIC4 -o \\\"$targetdir/$upy\\\" $u\"\n\t\t$PYUIC4 -o \"$targetdir/$upy\" $u\n\tfi\ndone\n\n# generate rc py files\n# qrc may not change, but referenced resources might. for now, regenerate always.\n# TODO: need to list qrc resources and check them all if changed\n\nRCRC=`ls *.qrc`\n\nfor r in $RCRC\ndo\n\trpy=`echo $r | sed 's,\\.qrc$,_rc.py,'`\n\t# compare times because output files spec below doesn't seem to work with wildcards\n\t#if [ ! -f \"$targetdir/$rpy\" ] || [ $r -nt \"$
72E25B1E12070F9900E2895A /* Script - bundle Qt */ = {
