[QGIS Commit] r14155 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Aug 27 08:16:53 EDT 2010
Author: dassau
Date: 2010-08-27 12:16:53 +0000 (Fri, 27 Aug 2010)
New Revision: 14155
   docs/trunk/english_us/user_guide/help_and_support.tex
   docs/trunk/english_us/user_guide/plugins_table_manager.tex
   docs/trunk/english_us/user_guide/print_composer.tex
updates from Alexander Bruy
Modified: docs/trunk/english_us/user_guide/help_and_support.tex
--- docs/trunk/english_us/user_guide/help_and_support.tex	2010-08-27 11:37:20 UTC (rev 14154)
+++ docs/trunk/english_us/user_guide/help_and_support.tex	2010-08-27 12:16:53 UTC (rev 14155)
@@ -71,7 +71,7 @@
 \url{irc.freenode.net}. Please wait around for a response to your question as many
 folks on the channel are doing other things and it may take a while for them to
 notice your question. Commercial support for QGIS is also available.
-Check the website \url{http://qgis.org/content/view/90/91} for more information.
+Check the website \url{http://qgis.org/en/commercial-support.html} for more information.
 If you missed a discussion on IRC, not a problem! We log all discussion so you can
 easily catch up. Just go to \url{http://logs.qgis.org} and read the IRC-logs.
Modified: docs/trunk/english_us/user_guide/plugins_table_manager.tex
--- docs/trunk/english_us/user_guide/plugins_table_manager.tex	2010-08-27 11:37:20 UTC (rev 14154)
+++ docs/trunk/english_us/user_guide/plugins_table_manager.tex	2010-08-27 12:16:53 UTC (rev 14155)
@@ -20,4 +20,4 @@
 Therefore click the menu \mainmenuopt{Plugins} >
 \mainmenuopt{Manage Plugins}, select \dropmenuopt{Table Manager} and click
 \button{OK}. A new \toolbtntwo{tableManagerIcon}{Table Manager} icon occurs
-in the toolbar. icon appears in the toolbar menu.
+in the toolbar.
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex	2010-08-27 11:37:20 UTC (rev 14154)
+++ docs/trunk/english_us/user_guide/print_composer.tex	2010-08-27 12:16:53 UTC (rev 14155)
@@ -292,7 +292,7 @@
 \begin{itemize}[label=--]
 \item Here you can define color and outline width for the element frame, set
-a background color and opacity for the map canvas. The \button{Position}
+a background color and opacity for the label. The \button{Position}
 button opens the \dialog{Set items position} dialog and allows to set the map
 canvas position using reference points or coordinates. Furthermore you can
 select or unselect to display the element frame with the \checkbox{Show
@@ -338,7 +338,7 @@
+a background color and opacity for the picture. The \button{Position}
@@ -380,9 +380,9 @@
 \item The legend items window lists all legend items and allows to change
 item order, edit layer names, remove and restore items of the list. After
-changing the symbology in the QGIS main window you can click on update to
+changing the symbology in the QGIS main window you can click on \button{Update} to
 adapt the changes in the legend element of the print composer. The item oder
-can be changed using the Up and Down buttons or with Drag and Drop
+can be changed using the \button{Up} and \button{Down} buttons or with Drag and Drop
 functionality.
 \end{itemize}
@@ -393,7 +393,7 @@
+a background color and opacity for the legend. The \button{Position}
@@ -436,7 +436,7 @@
+a background color and opacity for the scalebar. The \button{Position}
@@ -448,7 +448,7 @@
 For map navigation the print composer provides 4 general tools:
-\item \toolbtntwo{mActionZoomOut}{Zoom in},
+\item \toolbtntwo{mActionZoomIn}{Zoom in},
 \item \toolbtntwo{mActionZoomOut}{Zoom out},
 \item \toolbtntwo{mActionZoomFullExtent}{Zoom to full extend} and
 \item \toolbtntwo{mActionDraw}{Refresh the view}, if you find the view in an
@@ -511,7 +511,7 @@
+a background color and opacity for the table. The \button{Position}
More information about the QGIS-commit mailing list
