[QGIS Commit] r14828 - in trunk/qgis: i18n src/plugins/grass/modules-6.4
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Dec 2 12:27:46 EST 2010
Author: pcav
Date: 2010-12-02 09:27:46 -0800 (Thu, 02 Dec 2010)
New Revision: 14828
   trunk/qgis/i18n/qgis_it.ts
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Typos in IT GUI - thanks Rocco for spotting them
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts	2010-12-02 09:55:42 UTC (rev 14827)
+++ trunk/qgis/i18n/qgis_it.ts	2010-12-02 17:27:46 UTC (rev 14828)
@@ -6831,25 +6831,25 @@
         <location filename="../src/app/qgisapp.cpp" line="902"/>
         <location filename="../src/app/qgisapp.cpp" line="904"/>
         <source>Select features by rectangle</source>
-        <translation>Sleleziona elementi con un rettangolo</translation>
+        <translation>Seleziona elementi con un rettangolo</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="908"/>
         <location filename="../src/app/qgisapp.cpp" line="910"/>
         <source>Select features by polygon</source>
-        <translation>Sleleziona elementi con un poligono</translation>
+        <translation>Seleziona elementi con un poligono</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="914"/>
         <location filename="../src/app/qgisapp.cpp" line="916"/>
         <source>Select features by freehand</source>
-        <translation>Sleleziona elementi a mano libera</translation>
+        <translation>Seleziona elementi a mano libera</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="920"/>
         <location filename="../src/app/qgisapp.cpp" line="922"/>
         <source>Select features by radius</source>
-        <translation>Sleleziona elementi con un cerchio</translation>
+        <translation>Seleziona elementi con un cerchio</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="962"/>
@@ -7467,7 +7467,7 @@
         <location filename="../src/app/qgisapp.cpp" line="856"/>
         <location filename="../src/app/qgisapp.cpp" line="858"/>
         <source>Merge attributes of selected features</source>
-        <translation type="unfinished"></translation>
+        <translation>Unisci gli attributi dalle geometrie selezionate</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="868"/>
@@ -34614,7 +34614,7 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="364"/>
         <source>Remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed</source>
-        <translation>Rimuovi i vertici sotto una certa soglia di tolleranza da linee e contorni, il contorno viene tagliato solo se la topologia non è danneggiata (nuove intersezioni, attachement cambiato), il primo e l&apos;ultimo segmento del contorno non viene mai cambiato</translation>
+        <translation>Rimuovi i vertici sotto una certa soglia di tolleranza da linee e contorni, il contorno viene tagliato solo se la topologia non è danneggiata (nuove intersezioni, attachment cambiato), il primo e l&apos;ultimo segmento del contorno non viene mai cambiato</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="365"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2010-12-02 09:55:42 UTC (rev 14827)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2010-12-02 17:27:46 UTC (rev 14828)
@@ -12,7 +12,6 @@
 		<section label="Create new GRASS location from raster data">
 			<grass name="r.in.gdal.qgis.loc"/>
 			<grass name="r.in.gdal.qgis"/>
-			<grass name="r.external.qgis"/>
 		</section>
 		<section label="Create new GRASS location from vector data">
 			<grass name="v.in.ogr.qgis.loc"/>
More information about the QGIS-commit mailing list
