[QGIS Commit] r14877 - trunk/qgis/src/app
svn_qgis at osgeo.org
Thu Dec 9 11:07:27 EST 2010
Author: mhugent
Date: 2010-12-09 08:07:27 -0800 (Thu, 09 Dec 2010)
New Revision: 14877
trunk/qgis/src/app/qgsmaptoollabel.cpp
trunk/qgis/src/app/qgsmaptoollabel.h
trunk/qgis/src/app/qgsmaptoolmovelabel.cpp
trunk/qgis/src/app/qgsmaptoolmovelabel.h
trunk/qgis/src/app/qgsmaptoolrotatelabel.cpp
trunk/qgis/src/app/qgsmaptoolrotatelabel.h
Little improvement for label preview (box), better handling of situations where rotation is not possible
Modified: trunk/qgis/src/app/qgsmaptoollabel.cpp
--- trunk/qgis/src/app/qgsmaptoollabel.cpp 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoollabel.cpp 2010-12-09 16:07:27 UTC (rev 14877)
@@ -345,3 +345,66 @@
return true;
+bool QgsMapToolLabel::dataDefinedPosition( QgsVectorLayer* vlayer, int featureId, double& x, bool& xSuccess, double& y, bool& ySuccess, int& xCol, int& yCol ) const
+ xSuccess = false;
+ ySuccess = false;
+ if ( !vlayer )
+ return false;
+ if ( !layerIsMoveable( vlayer, xCol, yCol ) )
+ return false;
+ QgsFeature f;
+ if ( !vlayer->featureAtId( featureId, f, false, true ) )
+ return false;
+ QgsAttributeMap attributes = f.attributeMap();
+ x = attributes[xCol].toDouble( &xSuccess );
+ y = attributes[yCol].toDouble( &ySuccess );
+ return true;
+bool QgsMapToolLabel::layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const
+ const QgsVectorLayer* vlayer = dynamic_cast<const QgsVectorLayer*>( ml );
+ if ( !vlayer || !vlayer->isEditable() )
+ return false;
+ bool xColOk, yColOk;
+ QVariant xColumn = ml->customProperty( "labeling/dataDefinedProperty9" );
+ if ( !xColumn.isValid() )
+ return false;
+ xCol = xColumn.toInt( &xColOk );
+ if ( !xColOk )
+ return false;
+ QVariant yColumn = ml->customProperty( "labeling/dataDefinedProperty10" );
+ if ( !yColumn.isValid() )
+ return false;
+ yCol = yColumn.toInt( &yColOk );
+ if ( !yColOk )
+ return false;
+ return true;
Modified: trunk/qgis/src/app/qgsmaptoollabel.h
--- trunk/qgis/src/app/qgsmaptoollabel.h 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoollabel.h 2010-12-09 16:07:27 UTC (rev 14877)
@@ -31,6 +31,12 @@
QgsMapToolLabel( QgsMapCanvas* canvas );
~QgsMapToolLabel();
+ /**Returns true if layer move can be applied to a layer
+ @param xCol out: index of the attribute for data defined x coordinate
+ @param yCol out: index of the attribute for data defined y coordinate
+ @return true if labels of layer can be moved*/
+ bool layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const;
protected:
QgsRubberBand* mLabelRubberBand;
QgsRubberBand* mFeatureRubberBand;
@@ -73,6 +79,17 @@
/**Returns the font for the current feature (considering default font and data defined properties*/
QFont labelFontCurrentFeature();
+ /**Get data defined position of a feature
+ @param layerId layer identification string
+ @param x out: data defined x-coordinate
+ @param xSuccess out: false if attribute value is NULL
+ @param y out: data defined y-coordinate
+ @param ySuccess out: false if attribute value is NULL
+ @param xCol out: index of the x position column
+ @param yCol out: index of the y position column
+ @return false if layer does not have data defined label position enabled*/
+ bool dataDefinedPosition( QgsVectorLayer* vlayer, int featureId, double& x, bool& xSuccess, double& y, bool& ySuccess, int& xCol, int& yCol ) const;
private:
QgsPalLayerSettings mInvalidLabelSettings;
Modified: trunk/qgis/src/app/qgsmaptoolmovelabel.cpp
--- trunk/qgis/src/app/qgsmaptoolmovelabel.cpp 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoolmovelabel.cpp 2010-12-09 16:07:27 UTC (rev 14877)
@@ -116,8 +116,6 @@
xPosNew = releaseCoords.x() - mClickOffsetX;
yPosNew = releaseCoords.y() - mClickOffsetY;
- //todo: consider hali/vali if there
else
@@ -133,68 +131,5 @@
mCanvas->refresh();
-bool QgsMapToolMoveLabel::dataDefinedPosition( QgsVectorLayer* vlayer, int featureId, double& x, bool& xSuccess, double& y, bool& ySuccess, int& xCol, int& yCol ) const
- xSuccess = false;
- ySuccess = false;
- if ( !vlayer )
- return false;
- if ( !layerIsMoveable( vlayer, xCol, yCol ) )
- return false;
- QgsFeature f;
- if ( !vlayer->featureAtId( featureId, f, false, true ) )
- return false;
- QgsAttributeMap attributes = f.attributeMap();
- x = attributes[xCol].toDouble( &xSuccess );
- y = attributes[yCol].toDouble( &ySuccess );
- return true;
-bool QgsMapToolMoveLabel::layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const
- const QgsVectorLayer* vlayer = dynamic_cast<const QgsVectorLayer*>( ml );
- if ( !vlayer || !vlayer->isEditable() )
- return false;
- bool xColOk, yColOk;
- QVariant xColumn = ml->customProperty( "labeling/dataDefinedProperty9" );
- if ( !xColumn.isValid() )
- return false;
- xCol = xColumn.toInt( &xColOk );
- if ( !xColOk )
- return false;
- QVariant yColumn = ml->customProperty( "labeling/dataDefinedProperty10" );
- if ( !yColumn.isValid() )
- return false;
- yCol = yColumn.toInt( &yColOk );
- if ( !yColOk )
- return false;
- return true;
Modified: trunk/qgis/src/app/qgsmaptoolmovelabel.h
--- trunk/qgis/src/app/qgsmaptoolmovelabel.h 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoolmovelabel.h 2010-12-09 16:07:27 UTC (rev 14877)
@@ -35,23 +35,7 @@
virtual void canvasReleaseEvent( QMouseEvent * e );
- /**Returns true if layer move can be applied to a layer
- @param xCol out: index of the attribute for data defined x coordinate
- @param yCol out: index of the attribute for data defined y coordinate
- @return true if labels of layer can be moved*/
- bool layerIsMoveable( const QgsMapLayer* ml, int& xCol, int& yCol ) const;
protected:
- /**Get data defined position of a feature
- @param layerId layer identification string
- @param x out: data defined x-coordinate
- @param xSuccess out: false if attribute value is NULL
- @param y out: data defined y-coordinate
- @param ySuccess out: false if attribute value is NULL
- @param xCol out: index of the x position column
- @param yCol out: index of the y position column
- @return false if layer does not have data defined label position enabled*/
- bool dataDefinedPosition( QgsVectorLayer* vlayer, int featureId, double& x, bool& xSuccess, double& y, bool& ySuccess, int& xCol, int& yCol ) const;
/**Start point of the move in map coordinates*/
QgsPoint mStartPointMapCoords;
Modified: trunk/qgis/src/app/qgsmaptoolrotatelabel.cpp
--- trunk/qgis/src/app/qgsmaptoolrotatelabel.cpp 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoolrotatelabel.cpp 2010-12-09 16:07:27 UTC (rev 14877)
@@ -26,13 +26,14 @@
#include "qgisapp.h"
-QgsMapToolRotateLabel::QgsMapToolRotateLabel( QgsMapCanvas* canvas ): QgsMapToolLabel( canvas ), mRotationItem( 0 )
+QgsMapToolRotateLabel::QgsMapToolRotateLabel( QgsMapCanvas* canvas ): QgsMapToolLabel( canvas ), mRotationItem( 0 ), mRotationPreviewBox( 0 )
QgsMapToolRotateLabel::~QgsMapToolRotateLabel()
delete mRotationItem;
+ delete mRotationPreviewBox;
void QgsMapToolRotateLabel::canvasPressEvent( QMouseEvent * e )
@@ -68,8 +69,11 @@
mCurrentRotation = 0;
+ mStartRotation = mCurrentRotation;
createRubberBands();
+ mRotationPreviewBox = createRotationPreviewBox();
mRotationItem = new QgsPointRotationItem( mCanvas );
mRotationItem->setOrientation( QgsPointRotationItem::Counterclockwise );
mRotationItem->setSymbol( QgisApp::instance()->getThemePixmap( "mActionRotatePointSymbols.png" ).toImage() );
@@ -110,6 +114,7 @@
if ( mRotationItem )
mRotationItem->setSymbolRotation( displayValue );
+ setRotationPreviewBox( displayValue - mStartRotation );
mRotationItem->update();
@@ -117,9 +122,16 @@
void QgsMapToolRotateLabel::canvasReleaseEvent( QMouseEvent * e )
+ if ( !mLabelRubberBand ) //no rubber band created (most likely because the current label cannot be rotated )
+ return;
deleteRubberBands();
mRotationItem = 0;
+ mRotationPreviewBox = 0;
QgsMapLayer* layer = QgsMapLayerRegistry::instance()->mapLayer( mCurrentLabelPos.layerID );
if ( !layer )
@@ -140,6 +152,10 @@
double rotation = mCtrlPressed ? roundTo15Degrees( mCurrentRotation ) : mCurrentRotation;
+ if ( rotation == mStartRotation ) //mouse button pressed / released, but no rotation
+ return;
vlayer->beginEditCommand( tr( "Label rotated" ) );
vlayer->changeAttributeValue( mCurrentLabelPos.featureId, rotationCol, rotation, false );
@@ -191,6 +207,16 @@
+ //test, if data defined x- and y- values are not null. Otherwise, the position is determined by PAL and the rotation cannot be fixed
+ int xCol, yCol;
+ double x, y;
+ bool xSuccess, ySuccess;
+ if ( !dataDefinedPosition( vlayer, featureId, x, xSuccess, y, ySuccess, xCol, yCol ) || !xSuccess || !ySuccess )
+ return false;
rotation = attributes[rotationCol].toDouble( &rotationSuccess );
return true;
@@ -205,3 +231,53 @@
return ( a > 0 ? 360 - a : -a );
+QgsRubberBand* QgsMapToolRotateLabel::createRotationPreviewBox()
+ QVector< QgsPoint > boxPoints = mCurrentLabelPos.cornerPoints;
+ if ( boxPoints.size() < 1 )
+ return 0;
+ mRotationPreviewBox = new QgsRubberBand( mCanvas, false );
+ mRotationPreviewBox->setColor( Qt::blue );
+ mRotationPreviewBox->setWidth( 3 );
+ setRotationPreviewBox( mCurrentRotation - mStartRotation );
+ return mRotationPreviewBox;
+void QgsMapToolRotateLabel::setRotationPreviewBox( double rotation )
+ if ( !mRotationPreviewBox )
+ return;
+ mRotationPreviewBox->reset();
+ return;
+ for ( int i = 0; i < boxPoints.size(); ++i )
+ mRotationPreviewBox->addPoint( rotatePointCounterClockwise( boxPoints.at( i ), mRotationPoint, rotation ) );
+ mRotationPreviewBox->addPoint( rotatePointCounterClockwise( boxPoints.at( 0 ), mRotationPoint, rotation ) );
+ mRotationPreviewBox->show();
+QgsPoint QgsMapToolRotateLabel::rotatePointCounterClockwise( const QgsPoint& input, const QgsPoint& centerPoint, double degrees )
+ double rad = degrees / 180 * M_PI;
+ double v1x = input.x() - centerPoint.x();
+ double v1y = input.y() - centerPoint.y();
+ double v2x = cos( rad ) * v1x - sin( rad ) * v1y;
+ double v2y = sin( rad ) * v1x + cos( rad ) * v1y;
+ return QgsPoint( centerPoint.x() + v2x, centerPoint.y() + v2y );
Modified: trunk/qgis/src/app/qgsmaptoolrotatelabel.h
--- trunk/qgis/src/app/qgsmaptoolrotatelabel.h 2010-12-09 15:31:53 UTC (rev 14876)
+++ trunk/qgis/src/app/qgsmaptoolrotatelabel.h 2010-12-09 16:07:27 UTC (rev 14877)
@@ -49,11 +49,18 @@
/**Converts azimuth value to counterclockwise 0 - 360*/
static double azimuthToCCW( double a );
+ QgsRubberBand* createRotationPreviewBox();
+ void setRotationPreviewBox( double rotation );
+ /**Rotates input point counterclockwise around centerPoint*/
+ QgsPoint rotatePointCounterClockwise( const QgsPoint& input, const QgsPoint& centerPoint, double degrees );
+ double mStartRotation; //rotation value prior to start rotating
double mCurrentRotation;
double mCurrentMouseAzimuth;
QgsPoint mRotationPoint;
QgsPointRotationItem* mRotationItem;
+ QgsRubberBand* mRotationPreviewBox;
/**True if ctrl was pressed during the last mouse move event*/
bool mCtrlPressed;
