[QGIS Commit] r14979 - in trunk/qgis/src: app core/composer
svn_qgis at osgeo.org
Tue Dec 28 11:30:49 EST 2010
Author: jef
Date: 2010-12-28 08:30:49 -0800 (Tue, 28 Dec 2010)
New Revision: 14979
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/composer/qgscomposerpicture.cpp
trunk/qgis/src/core/composer/qgslegendmodel.cpp
fix #3363
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-12-27 21:27:01 UTC (rev 14978)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-12-28 16:30:49 UTC (rev 14979)
@@ -34,7 +34,6 @@
#include "qgscontrastenhancement.h"
#include "qgsrastertransparency.h"
#include <QTableWidgetItem>
#include <QHeaderView>
@@ -72,18 +71,7 @@
mGrayMinimumMaximumEstimated = true;
mRGBMinimumMaximumEstimated = true;
- if ( mRasterLayer->dataProvider() == 0 )
- // This is a GDAL-based layer
- mRasterLayerIsGdal = true;
- mRasterLayerIsWms = false;
- else if ( mRasterLayer->dataProvider()->name() == "wms" )
- // This is a WMS-based layer
- mRasterLayerIsWms = true;
- mRasterLayerIsGdal = false;
+ mRasterLayerIsInternal = mRasterLayer->dataProvider() == 0;
setupUi( this );
connect( buttonBox, SIGNAL( accepted() ), this, SLOT( accept() ) );
@@ -230,7 +218,7 @@
// Only do pyramids if dealing directly with GDAL.
- if ( mRasterLayerIsGdal )
+ if ( mRasterLayerIsInternal )
QgsRasterLayer::RasterPyramidList myPyramidList = mRasterLayer->buildPyramidList();
QgsRasterLayer::RasterPyramidList::iterator myRasterPyramidIterator;
@@ -253,7 +241,7 @@
- else if ( mRasterLayerIsWms )
+ else
// disable Pyramids tab completely
tabPagePyramids->setEnabled( false );
@@ -529,7 +517,7 @@
break;
- if ( mRasterLayerIsWms )
+ if ( !mRasterLayerIsInternal )
delete tabPageSymbology;
delete tabPageColormap;
@@ -592,119 +580,98 @@
cboxColorMap->setCurrentIndex( cboxColorMap->findText( tr( "User Defined" ) ) );
- else if ( !mRasterLayerIsWms )
+ else if ( mRasterLayerIsInternal )
cboxColorMap->setCurrentIndex( cboxColorMap->findText( tr( "Grayscale" ) ) );
- if ( !mRasterLayerIsWms )
- //set whether the layer histogram should be inverted
- if ( mRasterLayer->invertHistogram() )
+ if ( rbtnThreeBand->isChecked() )
- cboxInvertColorMap->setChecked( true );
- else
- cboxInvertColorMap->setChecked( false );
- //set the combos to the correct values
- cboRed->setCurrentIndex( cboRed->findText( mRasterLayer->redBandName() ) );
- cboGreen->setCurrentIndex( cboGreen->findText( mRasterLayer->greenBandName() ) );
- cboBlue->setCurrentIndex( cboBlue->findText( mRasterLayer->blueBandName() ) );
- cboGray->setCurrentIndex( cboGray->findText( mRasterLayer->grayBandName() ) );
- //set the stdDevs and min max values
- mDefaultStandardDeviation = myQSettings.value( "/Raster/defaultStandardDeviation", 2.0 ).toDouble();
- if ( mRasterLayerIsGdal && rbtnThreeBand->isChecked() )
- mRGBMinimumMaximumEstimated = mRasterLayer->isRGBMinimumMaximumEstimated();
- if ( mRasterLayer->hasUserDefinedRGBMinimumMaximum() )
- sboxThreeBandStdDev->setValue( mDefaultStandardDeviation );
- rbtnThreeBandStdDev->setChecked( false );
- rbtnThreeBandMinMax->setChecked( true );
- else
- sboxThreeBandStdDev->setValue( mRasterLayer->standardDeviations() );
- if ( mRasterLayer->standardDeviations() == 0.0 )
+ mRGBMinimumMaximumEstimated = mRasterLayer->isRGBMinimumMaximumEstimated();
+ if ( mRasterLayer->hasUserDefinedRGBMinimumMaximum() )
+ rbtnThreeBandMinMax->setChecked( true );
else
- rbtnThreeBandStdDev->setChecked( true );
+ sboxThreeBandStdDev->setValue( mRasterLayer->standardDeviations() );
+ if ( mRasterLayer->standardDeviations() == 0.0 )
+ sboxThreeBandStdDev->setValue( mDefaultStandardDeviation );
+ rbtnThreeBandStdDev->setChecked( false );
+ else
+ rbtnThreeBandStdDev->setChecked( true );
+ rbtnThreeBandMinMax->setChecked( false );
- rbtnThreeBandMinMax->setChecked( false );
- if ( QgsRasterLayer::PalettedColor != mRasterLayer->drawingStyle() &&
- QgsRasterLayer::PalettedSingleBandGray != mRasterLayer->drawingStyle() &&
- QgsRasterLayer::PalettedSingleBandPseudoColor != mRasterLayer->drawingStyle() &&
- QgsRasterLayer::PalettedMultiBandColor != mRasterLayer->drawingStyle() )
- if ( mRasterLayer->redBandName() != TRSTRING_NOT_SET )
+ if ( QgsRasterLayer::PalettedColor != mRasterLayer->drawingStyle() &&
+ QgsRasterLayer::PalettedSingleBandGray != mRasterLayer->drawingStyle() &&
+ QgsRasterLayer::PalettedSingleBandPseudoColor != mRasterLayer->drawingStyle() &&
+ QgsRasterLayer::PalettedMultiBandColor != mRasterLayer->drawingStyle() )
- leRedMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->redBandName() ) ) );
- leRedMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->redBandName() ) ) );
+ if ( mRasterLayer->redBandName() != TRSTRING_NOT_SET )
+ leRedMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->redBandName() ) ) );
+ leRedMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->redBandName() ) ) );
+ if ( mRasterLayer->greenBandName() != TRSTRING_NOT_SET )
+ leGreenMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->greenBandName() ) ) );
+ leGreenMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->greenBandName() ) ) );
+ if ( mRasterLayer->blueBandName() != TRSTRING_NOT_SET )
+ leBlueMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->blueBandName() ) ) );
+ leBlueMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->blueBandName() ) ) );
+ setMinimumMaximumEstimateWarning();
- if ( mRasterLayer->greenBandName() != TRSTRING_NOT_SET )
- leGreenMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->greenBandName() ) ) );
- leGreenMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->greenBandName() ) ) );
- if ( mRasterLayer->blueBandName() != TRSTRING_NOT_SET )
- leBlueMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->blueBandName() ) ) );
- leBlueMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->blueBandName() ) ) );
- setMinimumMaximumEstimateWarning();
- else if ( mRasterLayerIsGdal )
- mGrayMinimumMaximumEstimated = mRasterLayer->isGrayMinimumMaximumEstimated();
- if ( mRasterLayer->hasUserDefinedGrayMinimumMaximum() )
- sboxSingleBandStdDev->setValue( mDefaultStandardDeviation );
- rbtnSingleBandStdDev->setChecked( false );
- rbtnSingleBandMinMax->setChecked( true );
else
- sboxSingleBandStdDev->setValue( mRasterLayer->standardDeviations() );
+ mGrayMinimumMaximumEstimated = mRasterLayer->isGrayMinimumMaximumEstimated();
+ if ( mRasterLayer->hasUserDefinedGrayMinimumMaximum() )
+ rbtnSingleBandMinMax->setChecked( true );
else
- rbtnSingleBandStdDev->setChecked( true );
+ sboxSingleBandStdDev->setValue( mRasterLayer->standardDeviations() );
+ sboxSingleBandStdDev->setValue( mDefaultStandardDeviation );
+ rbtnSingleBandStdDev->setChecked( false );
+ else
+ rbtnSingleBandStdDev->setChecked( true );
+ rbtnSingleBandMinMax->setChecked( false );
- rbtnSingleBandMinMax->setChecked( false );
- if ( mRasterLayer->grayBandName() != TRSTRING_NOT_SET )
- leGrayMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->grayBandName() ) ) );
- leGrayMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->grayBandName() ) ) );
+ if ( mRasterLayer->grayBandName() != TRSTRING_NOT_SET )
+ leGrayMin->setText( QString::number( mRasterLayer->minimumValue( mRasterLayer->grayBandName() ) ) );
+ leGrayMax->setText( QString::number( mRasterLayer->maximumValue( mRasterLayer->grayBandName() ) ) );
//set color scaling algorithm
if ( QgsContrastEnhancement::StretchToMinimumMaximum == mRasterLayer->contrastEnhancementAlgorithm() )
@@ -798,7 +765,7 @@
leDisplayName->setText( mRasterLayer->name() );
//display the raster dimensions and no data value
lblColumns->setText( tr( "Columns: %1" ).arg( mRasterLayer->width() ) );
lblRows->setText( tr( "Rows: %1" ).arg( mRasterLayer->height() ) );
@@ -811,7 +778,7 @@
lblNoData->setText( tr( "No-Data Value: Not Set" ) );
+ else
// TODO: Account for fixedWidth and fixedHeight WMS layers
lblColumns->setText( tr( "Columns: " ) + tr( "n/a" ) );
@@ -848,7 +815,7 @@
void QgsRasterLayerProperties::syncColormapTab()
QgsDebugMsg( "populate color ramp tab" );
- if ( !mRasterLayerIsGdal )
return;
@@ -945,7 +912,7 @@
void QgsRasterLayerProperties::apply()
QgsDebugMsg( "apply processing symbology tab" );
@@ -1045,14 +1012,7 @@
- if ( cboxInvertColorMap->isChecked() )
- mRasterLayer->setInvertHistogram( true );
- else
- mRasterLayer->setInvertHistogram( false );
+ mRasterLayer->setInvertHistogram( cboxInvertColorMap->isChecked() );
//now set the color -> band mapping combos to the correct values
mRasterLayer->setRedBandName( cboRed->currentText() );
@@ -1442,7 +1402,7 @@
mRasterLayer->triggerRepaint();
//Because Min Max values can be set during the redraw if a strech is requested we need to resync after apply
if ( QgsContrastEnhancement::NoEnhancement != mRasterLayer->contrastEnhancementAlgorithm() )
@@ -1525,15 +1485,8 @@
for ( int myCounterInt = 0; myCounterInt < lbxPyramidResolutions->count(); myCounterInt++ )
QListWidgetItem *myItem = lbxPyramidResolutions->item( myCounterInt );
- if ( myItem->isSelected() || myPyramidList[myCounterInt].exists )
- //mark to be pyramided
- myPyramidList[myCounterInt].build = true;
- else
- myPyramidList[myCounterInt].build = false;
+ //mark to be pyramided
+ myPyramidList[myCounterInt].build = myItem->isSelected() || myPyramidList[myCounterInt].exists;
// Ask raster layer to build the pyramids
@@ -1619,7 +1572,7 @@
void QgsRasterLayerProperties::on_cboBlue_currentIndexChanged( const QString& theText )
- if ( mRasterLayerIsGdal && TRSTRING_NOT_SET != theText )
+ if ( mRasterLayerIsInternal && TRSTRING_NOT_SET != theText )
leBlueMin->setText( QString::number( mRasterLayer->minimumValue( theText ) ) );
leBlueMax->setText( QString::number( mRasterLayer->maximumValue( theText ) ) );
@@ -1628,7 +1581,7 @@
void QgsRasterLayerProperties::on_cboGray_currentIndexChanged( const QString& theText )
leGrayMin->setText( QString::number( mRasterLayer->minimumValue( theText ) ) );
leGrayMax->setText( QString::number( mRasterLayer->maximumValue( theText ) ) );
@@ -1637,7 +1590,7 @@
void QgsRasterLayerProperties::on_cboGreen_currentIndexChanged( const QString& theText )
leGreenMin->setText( QString::number( mRasterLayer->minimumValue( theText ) ) );
leGreenMax->setText( QString::number( mRasterLayer->maximumValue( theText ) ) );
@@ -1646,7 +1599,7 @@
void QgsRasterLayerProperties::on_cboRed_currentIndexChanged( const QString& theText )
leRedMin->setText( QString::number( mRasterLayer->minimumValue( theText ) ) );
leRedMax->setText( QString::number( mRasterLayer->maximumValue( theText ) ) );
@@ -1691,7 +1644,10 @@
void QgsRasterLayerProperties::on_cboxColorMap_currentIndexChanged( const QString& theText )
- if ( mRasterLayerIsGdal && ( theText == tr( "Pseudocolor" ) || theText == tr( "Freak Out" ) ) )
+ return;
+ if ( theText == tr( "Pseudocolor" ) || theText == tr( "Freak Out" ) )
tabPageColormap->setEnabled( false );
rbtnSingleBandMinMax->setEnabled( false );
@@ -1701,7 +1657,7 @@
cboxContrastEnhancementAlgorithm->setEnabled( false );
labelContrastEnhancement->setEnabled( false );
- else if ( mRasterLayerIsGdal && theText == tr( "Colormap" ) )
+ else if ( theText == tr( "Colormap" ) )
tabPageColormap->setEnabled( true );
@@ -1711,7 +1667,7 @@
- else if ( mRasterLayerIsGdal && theText == tr( "User Defined" ) )
+ else if ( theText == tr( "User Defined" ) )
rbtnSingleBandMinMax->setEnabled( true );
@@ -1721,7 +1677,7 @@
+ else
@@ -1739,7 +1695,6 @@
@@ -2604,7 +2559,10 @@
void QgsRasterLayerProperties::on_pbtnLoadMinMax_clicked()
- if ( mRasterLayerIsGdal && ( mRasterLayer->drawingStyle() == QgsRasterLayer::SingleBandGray || mRasterLayer->drawingStyle() == QgsRasterLayer::MultiBandSingleBandGray || mRasterLayer->drawingStyle() == QgsRasterLayer::MultiBandColor ) )
+ ( mRasterLayer->drawingStyle() == QgsRasterLayer::SingleBandGray
+ || mRasterLayer->drawingStyle() == QgsRasterLayer::MultiBandSingleBandGray
+ || mRasterLayer->drawingStyle() == QgsRasterLayer::MultiBandColor ) )
QgsRasterBandStats myRasterBandStats;
double myMinimumMaximum[2];
@@ -3025,7 +2983,7 @@
void QgsRasterLayerProperties::on_btnResetNull_clicked( )
//If reset NoDataValue is checked do this first, will ignore what ever is in the LineEdit
mRasterLayer->resetNoDataValue();
if ( mRasterLayer->isNoDataValueValid() )
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-12-27 21:27:01 UTC (rev 14978)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-12-28 16:30:49 UTC (rev 14979)
@@ -180,20 +180,13 @@
/** \brief Pointer to the raster layer that this property dilog changes the behaviour of. */
QgsRasterLayer * mRasterLayer;
- /** \brief If the underlying raster layer is of GDAL type (i.e. non-provider)
+ /** \brief If the underlying raster layer doesn't have a provider
This variable is used to determine if various parts of the Properties UI are
included or not
- bool mRasterLayerIsGdal;
+ bool mRasterLayerIsInternal;
- /** \brief If the underlying raster layer is of WMS type (i.e. WMS data provider)
- This variable is used to determine if various parts of the Properties UI are
- included or not
- bool mRasterLayerIsWms;
/** \brief Clear current color map table and population with values from new list */
void populateColorMapTable( const QList<QgsColorRampShader::ColorRampItem>& );
Modified: trunk/qgis/src/core/composer/qgscomposerpicture.cpp
--- trunk/qgis/src/core/composer/qgscomposerpicture.cpp 2010-12-27 21:27:01 UTC (rev 14978)
+++ trunk/qgis/src/core/composer/qgscomposerpicture.cpp 2010-12-28 16:30:49 UTC (rev 14979)
@@ -71,8 +71,6 @@
double boundRectWidthMM = boundRect.width() / newDpi * 25.4;
double boundRectHeightMM = boundRect.height() / newDpi * 25.4;
- double boundImageWidth = boundRect.width();
- double boundImageHeight = boundRect.height();
painter->save();
painter->translate( rect().width() / 2.0, rect().height() / 2.0 );
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp 2010-12-27 21:27:01 UTC (rev 14978)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp 2010-12-28 16:30:49 UTC (rev 14979)
@@ -312,8 +312,6 @@
void QgsLegendModel::removeLayer( const QString& layerId )
- QStandardItem* currentLayerItem = 0;
int numRootItems = rowCount();
for ( int i = 0; i < numRootItems ; ++i )
