[QGIS Commit] r12920 - trunk/qgis/python
svn_qgis at osgeo.org
Wed Feb 10 14:03:28 EST 2010
Author: wonder
Date: 2010-02-10 14:03:27 -0500 (Wed, 10 Feb 2010)
New Revision: 12920
trunk/qgis/python/console.py
Python console: basic syntax highlighting (prompt, errors)
Modified: trunk/qgis/python/console.py
--- trunk/qgis/python/console.py 2010-02-10 15:35:46 UTC (rev 12919)
+++ trunk/qgis/python/console.py 2010-02-10 19:03:27 UTC (rev 12920)
@@ -18,7 +18,7 @@
TODO:
- configuration - init commands, font, ...
-- syntax highlighting
+- python code highlighting
@@ -92,6 +92,29 @@
QWidget.closeEvent(self, event)
+class ConsoleHighlighter(QSyntaxHighlighter):
+ EDIT_LINE, ERROR, OUTPUT, INIT = range(4)
+ def __init__(self, doc):
+ QSyntaxHighlighter.__init__(self,doc)
+ formats = { self.OUTPUT : Qt.black,
+ self.ERROR : Qt.red,
+ self.EDIT_LINE : Qt.darkGreen,
+ self.INIT : Qt.gray }
+ self.f = {}
+ for tag, color in formats.iteritems():
+ self.f[tag] = QTextCharFormat()
+ self.f[tag].setForeground(color)
+ def highlightBlock(self, txt):
+ size = txt.length()
+ state = self.currentBlockState()
+ if state == self.OUTPUT or state == self.ERROR or state == self.INIT:
+ self.setFormat(0,size, self.f[state])
+ # highlight prompt only
+ if state == self.EDIT_LINE:
+ self.setFormat(0,3, self.f[self.EDIT_LINE])
class PythonEdit(QTextEdit, code.InteractiveInterpreter):
def __init__(self,parent=None):
@@ -108,9 +131,9 @@
self.buffer = []
- self.insertPlainText("To access Quantum GIS environment from this console\n"
- "use qgis.utils.iface object (instance of QgisInterface class).\n"
- "\n")
+ self.insertTaggedText("To access Quantum GIS environment from this console\n"
+ "use qgis.utils.iface object (instance of QgisInterface class).\n"
+ "\n", ConsoleHighlighter.INIT)
for line in _init_commands:
self.runsource(line)
@@ -120,13 +143,12 @@
self.history = QStringList()
self.historyIndex = 0
- #from pythonhigh import PythonHighlighter
- #self.high = PythonHighlighter(self)
+ self.high = ConsoleHighlighter(self)
def displayPrompt(self, more=False):
self.currentPrompt = "... " if more else ">>> "
self.currentPromptLength = len(self.currentPrompt)
- self.insertPlainText(self.currentPrompt)
+ self.insertTaggedLine(self.currentPrompt, ConsoleHighlighter.EDIT_LINE)
self.moveCursor(QTextCursor.End, QTextCursor.MoveAnchor)
def isCursorInEditionZone(self):
@@ -240,6 +262,24 @@
self.setTextCursor(self.cursor)
self.runCommand( unicode(self.currentCommand()) )
+ def insertTaggedText(self, txt, tag):
+ if len(txt) > 0 and txt[-1] == '\n': # remove trailing newline to avoid one more empty line
+ txt = txt[0:-1]
+ c = self.textCursor()
+ for line in txt.split('\n'):
+ b = c.block()
+ b.setUserState(tag)
+ c.insertText(line)
+ c.insertBlock()
+ def insertTaggedLine(self, txt, tag):
+ b = c.block()
+ c.insertText(txt)
def runCommand(self, cmd):
self.updateHistory(cmd)
@@ -254,14 +294,13 @@
output = sys.stdout.get_and_clean_data()
if output:
- self.insertPlainText(output)
+ self.insertTaggedText(output, ConsoleHighlighter.OUTPUT)
self.displayPrompt(more)
def write(self, txt):
""" reimplementation from code.InteractiveInterpreter """
- self.insertPlainText(txt)
+ self.insertTaggedText(txt, ConsoleHighlighter.ERROR)
if __name__ == '__main__':
a = QApplication(sys.argv)
show_console()
