[QGIS Commit] r12961 - in trunk/qgis: . src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Feb 22 04:55:10 EST 2010
Author: wonder
Date: 2010-02-22 04:55:08 -0500 (Mon, 22 Feb 2010)
New Revision: 12961
   trunk/qgis/CONTRIBUTORS
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
Applied patch from #2461: add support for incremental rendering with symbology-ng.
Fixes $2409.
Contributed by Jeremy Palmer, thanks!
Modified: trunk/qgis/CONTRIBUTORS
--- trunk/qgis/CONTRIBUTORS	2010-02-21 19:23:01 UTC (rev 12960)
+++ trunk/qgis/CONTRIBUTORS	2010-02-22 09:55:08 UTC (rev 12961)
@@ -42,3 +42,4 @@
 Alexander Bruy
 Andres Manz
 Mark Baas
+Jeremy Palmer
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2010-02-21 19:23:01 UTC (rev 12960)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2010-02-22 09:55:08 UTC (rev 12961)
@@ -718,11 +718,35 @@
     selRenderer->startRender( rendererContext, this );
+#ifndef Q_WS_MAC
+  int totalFeatures = pendingFeatureCount();
+  int featureCount = 0;
+#endif //Q_WS_MAC
   QgsFeature fet;
   while ( nextFeature( fet ) )
     try
+      if ( rendererContext.renderingStopped() )
+        break;
+#ifndef Q_WS_MAC //MH: disable this on Mac for now to avoid problems with resizing
+      if ( mUpdateThreshold > 0 && 0 == featureCount % mUpdateThreshold )
+        emit screenUpdateRequested();
+        emit drawingProgress( featureCount, totalFeatures );
+        qApp->processEvents();
+      else if ( featureCount % 1000 == 0 )
+#endif //Q_WS_MAC
       bool sel = mSelectedFeatureIds.contains( fet.id() );
       bool drawMarker = ( mEditable && ( !vertexMarkerOnlyForSelection || sel ) );
@@ -749,15 +773,12 @@
       msg += cse.what();
       QgsLogger::warning( msg );
+#ifndef Q_WS_MAC
+    ++featureCount;
+#endif //Q_WS_MAC
-  mRendererV2->stopRender( rendererContext );
-  if ( selRenderer )
-    selRenderer->stopRender( rendererContext );
-    delete selRenderer;
+  stopRendererV2( rendererContext, selRenderer );
 void QgsVectorLayer::drawRendererV2Levels( QgsRenderContext& rendererContext, bool labeling )
@@ -781,8 +802,22 @@
   // 1. fetch features
   QgsFeature fet;
+#ifndef Q_WS_MAC
+#endif //Q_WS_MAC
+      return;
+#ifndef Q_WS_MAC
+    if ( featureCount % 1000 == 0 )
+#endif //Q_WS_MAC
     QgsSymbolV2* sym = mRendererV2->symbolForFeature( fet );
     if ( !features.contains( sym ) )
@@ -798,6 +833,9 @@
       // Cache this for the use of (e.g.) modifying the feature's uncommitted geometry.
       mCachedGeometries[fet.id()] = *fet.geometry();
+#ifndef Q_WS_MAC
+    ++featureCount;
+#endif //Q_WS_MAC
   // find out the order
@@ -831,8 +869,22 @@
       int layer = item.layer();
       QList<QgsFeature>& lst = features[item.symbol()];
       QList<QgsFeature>::iterator fit;
+#ifndef Q_WS_MAC
+      featureCount = 0;
+#endif //Q_WS_MAC
       for ( fit = lst.begin(); fit != lst.end(); ++fit )
+          return;
+#ifndef Q_WS_MAC
+#endif //Q_WS_MAC
         bool sel = mSelectedFeatureIds.contains( fit->id() );
         // maybe vertex markers should be drawn only during the last pass...
@@ -851,21 +903,22 @@
           msg += cse.what();
+#ifndef Q_WS_MAC
+        ++featureCount;
+#endif //Q_WS_MAC
 bool QgsVectorLayer::draw( QgsRenderContext& rendererContext )
+  //set update threshold before each draw to make sure the current setting is picked up
+  QSettings settings;
+  mUpdateThreshold = settings.value( "Map/updateThreshold", 0 ).toInt();
   if ( mUsingRendererV2 )
     if ( mRendererV2 == NULL )
@@ -916,9 +969,6 @@
     return TRUE;
-  //set update threshold before each draw to make sure the current setting is picked up
-  QSettings settings;
-  mUpdateThreshold = settings.value( "Map/updateThreshold", 0 ).toInt();
   //draw ( p, viewExtent, theMapToPixelTransform, ct, drawingToEditingCanvas, 1., 1.);
   if ( mRenderer )
@@ -4540,3 +4590,13 @@
   return -1;
+void QgsVectorLayer::stopRendererV2( QgsRenderContext& rendererContext, QgsSingleSymbolRendererV2* selRenderer )
+  mRendererV2->stopRender( rendererContext );
+  if ( selRenderer )
+    selRenderer->stopRender( rendererContext );
+    delete selRenderer;
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2010-02-21 19:23:01 UTC (rev 12960)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2010-02-22 09:55:08 UTC (rev 12961)
@@ -44,6 +44,7 @@
 class QgsUndoCommand;
 class QgsVectorDataProvider;
 class QgsVectorOverlay;
+class QgsSingleSymbolRendererV2;
 class QgsRectangle;
@@ -660,6 +661,8 @@
     /** Record changed attribute, store in active command (if any) */
     void editAttributeChange( int featureId, int field, QVariant value );
+    /** Stop version 2 renderer and selected renderer (if required) */
+    void stopRendererV2( QgsRenderContext& rendererContext, QgsSingleSymbolRendererV2* selRenderer );
   private:                       // Private attributes
More information about the QGIS-commit mailing list
