[QGIS Commit] r12661 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Fri Jan 1 22:15:20 EST 2010
Author: jef
Date: 2010-01-01 22:15:19 -0500 (Fri, 01 Jan 2010)
New Revision: 12661
trunk/qgis/src/app/qgslabeldialog.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/ui/qgslabeldialogbase.ui
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
allow entry of visibility scales in floating point
Modified: trunk/qgis/src/app/qgslabeldialog.cpp
--- trunk/qgis/src/app/qgslabeldialog.cpp 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/app/qgslabeldialog.cpp 2010-01-02 03:15:19 UTC (rev 12661)
@@ -14,15 +14,19 @@
/* $Id$ */
+#include <limits>
#include "qgslabeldialog.h"
#include "qgsfield.h"
#include "qgslabel.h"
#include "qgslabelattributes.h"
+#include "qgslogger.h"
#include <QColorDialog>
#include <QFontDialog>
#include <QTabWidget>
-#include "qgslogger.h"
+#include <QDoubleValidator>
const int PIXMAP_WIDTH = 200;
@@ -146,8 +150,10 @@
// set up the scale based layer visibility stuff....
chkUseScaleDependentRendering->setChecked( mLabel->scaleBasedVisibility() );
- spinMinimumScale->setValue(( int )mLabel->minScale() );
- spinMaximumScale->setValue(( int )mLabel->maxScale() );
+ leMinimumScale->setText( QString::number( mLabel->minScale(), 'f' ) );
+ leMinimumScale->setValidator( new QDoubleValidator( 0, std::numeric_limits<float>::max(), 1000, this ) );
+ leMaximumScale->setText( QString::number( mLabel->maxScale(), 'f' ) );
+ leMaximumScale->setValidator( new QDoubleValidator( 0, std::numeric_limits<float>::max(), 1000, this ) );
//set the non-databound fields up now
@@ -438,8 +444,8 @@
mLabel->setScaleBasedVisibility( chkUseScaleDependentRendering->isChecked() );
- mLabel->setMinScale( spinMinimumScale->value() );
- mLabel->setMaxScale( spinMaximumScale->value() );
+ mLabel->setMinScale( leMinimumScale->text().toFloat() );
+ mLabel->setMaxScale( leMaximumScale->text().toFloat() );
int QgsLabelDialog::fieldIndexFromName( QString name )
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-01-02 03:15:19 UTC (rev 12661)
@@ -15,7 +15,7 @@
-#include <QDebug>
+#include <limits>
#include "qgsapplication.h"
@@ -98,8 +98,10 @@
chkUseScaleDependentRendering->setChecked( lyr->hasScaleBasedVisibility() );
- spinMinimumScale->setValue(( int )lyr->minimumScale() );
- spinMaximumScale->setValue(( int )lyr->maximumScale() );
+ leMinimumScale->setText( QString::number( lyr->minimumScale(), 'f' ) );
+ leMaximumScale->setText( QString::number( lyr->maximumScale(), 'f' ) );
// build GUI components
cboxColorMap->addItem( tr( "Grayscale" ) );
@@ -1446,8 +1448,8 @@
mRasterLayer->toggleScaleBasedVisibility( chkUseScaleDependentRendering->isChecked() );
- mRasterLayer->setMinimumScale( spinMinimumScale->value() );
- mRasterLayer->setMaximumScale( spinMaximumScale->value() );
+ mRasterLayer->setMinimumScale( leMinimumScale->text().toFloat() );
+ mRasterLayer->setMaximumScale( leMaximumScale->text().toFloat() );
//update the legend pixmap
pixmapLegend->setPixmap( mRasterLayer->legendAsPixmap() );
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2010-01-02 03:15:19 UTC (rev 12661)
@@ -18,6 +18,7 @@
/* $Id$ */
#include <memory>
+#include <limits>
#include "qgisapp.h"
@@ -476,8 +477,10 @@
chkUseScaleDependentRendering->setChecked( layer->hasScaleBasedVisibility() );
- spinMinimumScale->setValue(( int )layer->minimumScale() );
- spinMaximumScale->setValue(( int )layer->maximumScale() );
+ leMinimumScale->setText( QString::number( layer->minimumScale(), 'f' ) );
+ leMaximumScale->setText( QString::number( layer->maximumScale(), 'f' ) );
// symbology initialization
if ( legendtypecombobox->count() == 0 )
@@ -570,8 +573,8 @@
layer->toggleScaleBasedVisibility( chkUseScaleDependentRendering->isChecked() );
- layer->setMinimumScale( spinMinimumScale->value() );
- layer->setMaximumScale( spinMaximumScale->value() );
+ layer->setMinimumScale( leMinimumScale->text().toFloat() );
+ layer->setMaximumScale( leMaximumScale->text().toFloat() );
// update the display field
layer->setDisplayField( displayFieldComboBox->currentText() );
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui 2010-01-02 03:15:19 UTC (rev 12661)
@@ -304,9 +304,6 @@
<property name="text">
<string>Maximum</string>
</property>
- <property name="buddy">
- <cstring>spinMaximumScale</cstring>
- </property>
</widget>
</item>
<item row="0" column="0">
@@ -314,36 +311,13 @@
<string>Minimum</string>
</property>
- <cstring>spinMinimumScale</cstring>
- </property>
</widget>
</item>
<item row="0" column="1">
- <widget class="QSpinBox" name="spinMinimumScale">
- <property name="toolTip">
- <string>Minimum scale at which this layer will be displayed. </string>
- </property>
- <property name="minimum">
- <number>1</number>
- </property>
- <property name="maximum">
- <number>100000000</number>
- </property>
- </widget>
+ <widget class="QLineEdit" name="leMinimumScale"/>
</item>
<item row="0" column="3">
- <widget class="QSpinBox" name="spinMaximumScale">
- <string>Maximum scale at which this layer will be displayed. </string>
- </property>
- </property>
- </property>
- </widget>
+ <widget class="QLineEdit" name="leMaximumScale"/>
</item>
</layout>
</widget>
@@ -947,8 +921,8 @@
<tabstop>radioBelowLeft</tabstop>
<tabstop>radioBelow</tabstop>
<tabstop>radioBelowRight</tabstop>
- <tabstop>spinMinimumScale</tabstop>
- <tabstop>spinMaximumScale</tabstop>
+ <tabstop>leMinimumScale</tabstop>
+ <tabstop>leMaximumScale</tabstop>
<tabstop>pbnDefaultBufferColor_2</tabstop>
<tabstop>spinBufferSize</tabstop>
<tabstop>radioBufferUnitsPoints</tabstop>
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-01-02 03:15:19 UTC (rev 12661)
@@ -1569,46 +1569,32 @@
<property name="margin">
<number>11</number>
</property>
- <item row="0" column="3">
- </property>
- </property>
- </property>
- </widget>
- </item>
<item row="0" column="2">
<widget class="QLabel" name="textLabel1_2_2_2">
+ <property name="layoutDirection">
+ <enum>Qt::RightToLeft</enum>
+ </property>
</property>
</widget>
</item>
- <item row="0" column="1">
- </property>
- </property>
- </property>
- </widget>
- </item>
<widget class="QLabel" name="textLabel1_3">
+ </property>
</property>
</widget>
</item>
+ <item row="0" column="3">
+ </item>
+ <item row="0" column="1">
+ </item>
</layout>
</widget>
</item>
@@ -1824,8 +1810,8 @@
<string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
<html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'DejaVu Sans'; font-size:10pt; font-weight:400; font-style:normal;">
-<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></string>
+</style></head><body style=" font-family:'Sans Serif'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p></body></html></string>
</property>
</widget>
</item>
@@ -2114,8 +2100,8 @@
<tabstop>tableTransparency</tabstop>
<tabstop>leDisplayName</tabstop>
<tabstop>leLayerSource</tabstop>
<tabstop>leSpatialRefSys</tabstop>
<tabstop>pbnChangeSpatialRefSys</tabstop>
<tabstop>tePyramidDescription</tabstop>
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2010-01-01 02:29:28 UTC (rev 12660)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2010-01-02 03:15:19 UTC (rev 12661)
@@ -142,7 +142,7 @@
<widget class="QStackedWidget" name="stackedWidget">
<property name="currentIndex">
- <number>0</number>
+ <number>3</number>
</property>
<widget class="QWidget" name="page_3">
<layout class="QGridLayout" name="gridLayout_4">
@@ -423,8 +423,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>401</width>
- <height>425</height>
+ <width>514</width>
+ <height>428</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_3">
@@ -548,9 +548,6 @@
</property>
- </property>
</widget>
</item>
@@ -558,36 +555,13 @@
</property>
- </property>
</widget>
</item>
- </property>
- </property>
- </property>
- </widget>
</item>
- </property>
- </property>
- </property>
- </widget>
</item>
</layout>
</widget>
@@ -732,8 +706,8 @@
<tabstop>displayFieldComboBox</tabstop>
<tabstop>pbnIndex</tabstop>
<tabstop>txtSubsetSQL</tabstop>
<tabstop>pbnQueryBuilder</tabstop>
<tabstop>buttonBox</tabstop>
