[QGIS Commit] r12673 - trunk/qgis/src/app
svn_qgis at osgeo.org
Tue Jan 5 11:06:20 EST 2010
Author: mhugent
Date: 2010-01-05 11:06:18 -0500 (Tue, 05 Jan 2010)
New Revision: 12673
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
Show a message box if there was an error during the merge operation (instead of crashing). Fixes ticket #2342
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-01-05 14:09:31 UTC (rev 12672)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-01-05 16:06:18 UTC (rev 12673)
@@ -3635,8 +3635,9 @@
mMapCanvas->setMapTool( mMapTools.mDeletePart );
-QgsGeometry* QgisApp::unionGeometries( const QgsVectorLayer* vl, QgsFeatureList& featureList )
+QgsGeometry* QgisApp::unionGeometries( const QgsVectorLayer* vl, QgsFeatureList& featureList, bool& canceled )
+ canceled = false;
if ( !vl || featureList.size() < 2 )
return 0;
@@ -3660,6 +3661,7 @@
delete unionGeom;
QApplication::restoreOverrideCursor();
+ canceled = true;
return 0;
progress.setValue( i );
@@ -3668,6 +3670,12 @@
backupPtr = unionGeom;
unionGeom = unionGeom->combine( currentGeom );
+ if ( !unionGeom )
+ delete backupPtr;
+ QApplication::restoreOverrideCursor();
+ return 0;
if ( i > 1 ) //delete previous intermediate results
delete backupPtr;
@@ -3798,9 +3806,14 @@
//get initial selection (may be altered by attribute merge dialog later)
QgsFeatureList featureList = vl->selectedFeatures(); //get QList<QgsFeature>
- QgsGeometry* unionGeom = unionGeometries( vl, featureList );
+ bool canceled;
+ QgsGeometry* unionGeom = unionGeometries( vl, featureList, canceled );
if ( !unionGeom )
+ if ( !canceled )
+ QMessageBox::critical( 0, tr( "Merge failed" ), tr( "An error occured during the merge operation" ) );
return;
@@ -3835,9 +3848,14 @@
if ( featureList.size() != featureListAfter.size() )
delete unionGeom;
- unionGeom = unionGeometries( vl, featureListAfter );
+ bool canceled;
+ unionGeom = unionGeometries( vl, featureListAfter, canceled );
if ( !unionGeom )
+ if ( !canceled )
return;
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2010-01-05 14:09:31 UTC (rev 12672)
+++ trunk/qgis/src/app/qgisapp.h 2010-01-05 16:06:18 UTC (rev 12673)
@@ -710,8 +710,8 @@
//! check to see if file is dirty and if so, prompt the user th save it
bool saveDirty();
/** Helper function to union several geometries together (used in function mergeSelectedFeatures)
- @return 0 in case of error*/
- QgsGeometry* unionGeometries( const QgsVectorLayer* vl, QgsFeatureList& featureList );
+ @return 0 in case of error or if canceled*/
+ QgsGeometry* unionGeometries( const QgsVectorLayer* vl, QgsFeatureList& featureList, bool& canceled );
/**Deletes all the composer objects and clears mPrintComposers*/
void deletePrintComposers();
