[QGIS Commit] r12693 - trunk/qgis/src/app
svn_qgis at osgeo.org
Thu Jan 7 12:32:58 EST 2010
Author: timlinux
Date: 2010-01-07 12:32:58 -0500 (Thu, 07 Jan 2010)
New Revision: 12693
trunk/qgis/src/app/qgsmaptooladdfeature.h
[FEATURE] GPS Tracking widget added. This is a bug fix for a missing file that should have been updated in last commit
Modified: trunk/qgis/src/app/qgsmaptooladdfeature.h
--- trunk/qgis/src/app/qgsmaptooladdfeature.h 2010-01-07 17:06:16 UTC (rev 12692)
+++ trunk/qgis/src/app/qgsmaptooladdfeature.h 2010-01-07 17:32:58 UTC (rev 12693)
@@ -21,12 +21,15 @@
Q_OBJECT
public:
- QgsMapToolAddFeature( QgsMapCanvas* canvas, enum CaptureTool tool );
+ QgsMapToolAddFeature( QgsMapCanvas* canvas, enum CaptureMode tool );
virtual ~QgsMapToolAddFeature();
void canvasReleaseEvent( QMouseEvent * e );
- private:
/**Modifies geometry to avoid intersections with the layers specified in project properties
- @return 0 in case of success, 1 if geometry is not of polygon type, 2 if avoid intersection would change the geometry type, \
- 3 other error during intersection removal*/
- int avoidIntersectons( QgsGeometry* g );
+ @return 0 in case of success,
+ @return 1 if geometry is not of polygon type,
+ @return 2 if avoid intersection would change the geometry type, \
+ 3 other error during intersection removal
+ @note Consider moving this into analysis lib since it is now used by QgsGpsInformation too. */
+ static int avoidIntersectons( QgsGeometry* g );
