[QGIS Commit] r12710 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jan 8 14:25:31 EST 2010
Author: jef
Date: 2010-01-08 14:25:30 -0500 (Fri, 08 Jan 2010)
New Revision: 12710
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgisapp.h
   trunk/qgis/src/app/qgsidentifyresults.cpp
fix runtime warning
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2010-01-08 16:30:10 UTC (rev 12709)
+++ trunk/qgis/src/app/qgisapp.cpp	2010-01-08 19:25:30 UTC (rev 12710)
@@ -1840,9 +1840,9 @@
   // Monitor change of project path
   connect( QgsProject::instance(), SIGNAL( readProject( const QDomDocument & ) ),
-           this, SLOT( projectChanged( const QDomDocument & ) ) );
+           this, SLOT( readProject( const QDomDocument & ) ) );
   connect( QgsProject::instance(), SIGNAL( writeProject( QDomDocument & ) ),
+           this, SLOT( writeProject( QDomDocument & ) ) );
 void QgisApp::createCanvas()
@@ -6067,3 +6067,13 @@
   runPythonString( expr );
+void QgisApp::writeProject( QDomDocument &doc )
+  projectChanged( doc );
+void QgisApp::readProject( const QDomDocument &doc )
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h	2010-01-08 16:30:10 UTC (rev 12709)
+++ trunk/qgis/src/app/qgisapp.h	2010-01-08 19:25:30 UTC (rev 12710)
@@ -386,6 +386,12 @@
     /**Deletes the selected attributes for the currently selected vector layer*/
     void deleteSelected( QgsMapLayer *layer = 0 );
+    //! project was written
+    void writeProject( QDomDocument & );
+    //! project was read
+    void readProject( const QDomDocument & );
   protected:
     //! Handle state changes (WindowTitleChange)
@@ -647,9 +653,6 @@
     void showStyleManagerV2();
-    //! project changed
-    void projectChanged( const QDomDocument & );
   signals:
     /** emitted when a key is pressed and we want non widget sublasses to be able
       to pick up on this (e.g. maplayer) */
@@ -1049,6 +1052,9 @@
     //! Persistent GPS toolbox
     QgsGPSInformationWidget * mpGpsWidget;
+    //! project changed
+    void projectChanged( const QDomDocument & );
 #endif
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp	2010-01-08 16:30:10 UTC (rev 12709)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp	2010-01-08 19:25:30 UTC (rev 12710)
@@ -293,7 +293,8 @@
 // (saves the current window size/position)
 void QgsIdentifyResults::close()
-  clearRubberbands();
+  clear();
   delete mActionPopup;
   mActionPopup = 0;
More information about the QGIS-commit mailing list
