[QGIS Commit] r12737 - trunk/qgis/src/core/gps/qextserialport
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jan 11 16:16:26 EST 2010
Author: jef
Date: 2010-01-11 16:16:25 -0500 (Mon, 11 Jan 2010)
New Revision: 12737
Removed:
   trunk/qgis/src/core/gps/qextserialport/ChangeLog
   trunk/qgis/src/core/gps/qextserialport/Doxyfile
   trunk/qgis/src/core/gps/qextserialport/doc/
   trunk/qgis/src/core/gps/qextserialport/examples/
   trunk/qgis/src/core/gps/qextserialport/html/
   trunk/qgis/src/core/gps/qextserialport/qextserialport.pro
remove unused files from qextserialport
Deleted: trunk/qgis/src/core/gps/qextserialport/ChangeLog
--- trunk/qgis/src/core/gps/qextserialport/ChangeLog	2010-01-11 19:23:55 UTC (rev 12736)
+++ trunk/qgis/src/core/gps/qextserialport/ChangeLog	2010-01-11 21:16:25 UTC (rev 12737)
@@ -1,245 +0,0 @@
-Change history for QextSerialPort (formerly QwSerialPort):
-(Lines beginning with + represent new functionality, * represent changed or
-fixed functionality, - represent removed or deprecated functionality)
-Current CVS (Michal Policht)
-  + Added QextSerialEnumerator pre-alpha. Works under W2k and later versions of Windows.
-  + Event driven mechanism (alternative to polling) is now available on Windows.
-  - Removed default (=0) parameter from open() functions.
-  * Fixed bug #1714917 in Win_QextSerialPort::close() method (by Kurt).
-  * Fixed problem with lack of proper blocking in readData() on win32 (by Brandon Fosdick).
-  * Removed QT_THREAD_SUPPORT option. Now QextSerialPort must be always compiled with threads support.
-  * Mutexes are not static.
-  * setTimeout() now accepts only one parameter.
-  * bytesAvailable() on POSIX now shows 0 bytes instead of -1 when no bytes are available.
-  * bytesAvailable() is const.
-  * native POSIX file descriptors instead of QFile->handle() calls
-  + POSIX: Save and restore original termios when opening and closing the device
-  * POSIX: Only disable special characters on systems that support it
-  * POSIX: Use cfmakeraw(3) to get a non-canonical termios
-  + POSIX: Call close(2) in close() to actually close the device
-Version 1.1 (official release)
-Version 1.0.1
-  * Minor changes (mostly in test application)
-Version 1.0.0e (by Micha³ Policht)
-  * Fixed bytesAvailable(). Includes buffered bytes to the result.
-  + Added isSequential() method.
-  + Provided test application
-Version 1.0.0d ( changes by Micha³ Policht )
-  - Removed isOpen() overriden declaration/implementation from qextserialport's classes. isOpen() relies on QIODevice now.
-  - Removed bool portOpen variable. Replaced by internal QIODevice.openMode.
-  - Removed getChar(), putChar() overriden declaration/implementation. QIODevice can handle this.
-  * Calling open() with specified OpenMode invokes QIODevice::open() which result in proper openMode setting.
-  * readData(), writeData() are protected as in QIODevice declaration.
-  * QIODevice:: read() and write() function are working now (use them instead of readData() writeData()).
-  * readData(), writeData() don't check if port is open any more (read() and write() assures that). The same behaviour can be found in QFile for example.
-  * Fixed readLine().
-  * Fixed randomly crash on deletion bug on Windows ( by Stuart Nixon )
-  http://lists.trolltech.com/qt-interest/2007-02/thread00340-0.html#msg00351
-Version 0.9 (March 3, 2005) Stefan Sander <stefan-sander at users.sf.net>:
-  + Added a new precompiler constant, _TTY_FREEBSD_
-    to support FreeBSD port names.
-  + Added _TTY_WIN_ constant in qextserialport.pro win32:DEFINES
-    to have Windows port names as default when compiling on it.
-  - Removed construct() call from QextSerialBase constructors,
-    it is called indirectly through Win_QextSerialPort::construct()
-    and Posix_QextSerialPort::construct().
-  + Added construct() call to Win_QextSerialPort constructors.
-  + Added setTimeout(0, 500) call to Win_QextSerialPort::construct().
-  - Removed setTimeout(0, 500) call from Win_QextSerialPort(const char* name).
-  * Fixed Posix_QextSerialPort::open(int) control flow, now the port settings
-    are only applied if the associated file could be opened.
-  * Fixed masking CR to NL, in Posix_CommConfig.c_iflag
-Version 0.8 (, 2003) (Alpha release):
-  * Added code to set the port timeouts in Win_QextSerialPort's default
-    constructor.
-  * Fixed Posix_QextSerialPort::construct() to set up the port correctly.
-  * Fixed syntax errors in 2 ioctl() calls in posix_QextSerialPort.
-  * lastError is now initialized to E_NO_ERROR in the QextSerialBase
-    constructor.
-  * The select() call in posix_QextSerialPort::bytesWaiting() is now
-    properly coded.  Previously it would always time out.
-  * Fixed runtime errors in the ioctl() calls for
-    Posix_QextSerialPort::setDtr() and Posix_QextSerialPort::setRts().
-    Thanks to Marc Pignat.
-Version 0.7 (June 15, 2002) <Bugfix release>:
-  (0.61 - unofficial release)
-  * Fixed a small bug in the initializations of the static members when
-    QT_THREAD_SUPPORT was defined.
-  * Fixed a  bug that caused Borland's compiler to choke on Windows platforms
-    (which perversely actually stemmed from a shortcoming of Visual C++ that
-    Borland doesn't have).
-  (0.62 - unofficial release)
-  * Fixed a bug that gave Q_LONG the wrong typedef for QT versions prior to
-    3.0.
-  (0.63 - unofficial release)
-  * Fixed 2 incorrect references to Posix_Comm_Config.
-  * Fixed scoping of Posix_QextSerialPort::operator=().
-  * Posix_QextSerialPort::construct should now be coded correctly.
-  * Fixed return type for Posix_QextSerialPort::size().
-  (0.64 - unofficial release)
-  * Fixed all the port settings functions to work properly when opening the
-    port for the first time - previously none of the settings were being
-    applied when the port was opened.
-  * Fixed an oversight in Win_QextSerialPort::open() that caused the setting
-    of port parameters to fail on NT and 2000 systems.
-  (0.7 - official release)
-  * Fixed some calls to QextSerialBase constructors that no longer exist on
-    the POSIX side.
-  * Fixed the bad memcpy()'s in the POSIX copy constructor.
-  * Fixed the Offset scoping problem under gcc 2.95.
-  * The CBAUD flag has been deprecated on some POSIX systems.  Fixed
-    Posix_QextSerialPort::setBaudRate() to reflect this.
-  * Added construct() calls to all of the Posix_QextSerialPort constructors.
-  * Fixed double (and conflicting) typedefs of Offset when using QT versions
-    prior to 3.0
-  * Changed the call to CreateFile() to CreateFileA() in
-    Win_QextSerialPort.cpp.  This should get rid of problems for those using
-    Unicode or other multibyte character sets for their string literals.
-  * A few tweaks to the documentation.
-  - Removed the protected Posix_Handle variable from Posix_QextSerialPort.
-Version 0.6 (March 11, 2002) <Bugfix release>:
-  + Added a new precompiler constant, QTVER_PRE_30.  QT3 changed the return
-    types of some QIODevice functions. Therefore, if compiling on versions
-    of QT prior to 3.0, you should always define QTVER_PRE_30 in your project.
-    Also had to add some preprocessor blocks to support both 3.0 and earlier
-    versions of QT.
-  + Added implementations of 2 of the new constructors added in 0.5 to both
-    Win_QextSerialPort and Posix_QextSerialPort.
-  * The scoping of the enums used in the PortSettings struct has been fixed.
-  * QObject inheritance has been removed.  This should not affect the
-    functionality of the classes.
-  * Replaced a few stray references to mutex->unlock() with UNLOCK_MUTEX() in
-    the Windows code.
-  * Fixed several runtime errors caused by calling nonexistent members of
-    QextSerialBase.
-  * Fixed a whole bunch of little things that were causing MSVC to choke when
-    compiling for Windows.
-Version 0.5 (February 15, 2002):
-  + There are 4 new macros (LOCK_MUTEX, UNLOCK_MUTEX, TTY_WARNING, and
-    TTY_PORTABILITY_WARNING) that replace most of those ugly #ifdef blocks in
-    the code.
-  + In place of the old namingConvention stuff, there is a new function,
-    setName().  It is used to set the name of the device to be associated with
-    the object.  The new name() function can be used to retrieve the device
-    name, which is stored in the new member variable portName.
-  + There is a new version of open() that takes a const char* as a parameter.
-    It can be used to specify the name of the device when it is opened rather
-    than at construction time.
-  * 3 constructors have been removed and 3 more added.  There is now a copy
-    constructor (and operator=()) as well as a constructor that takes a
-    PortSettings structure as a parameter, and another that takes both a
-    device name and a PortSettings structure.  As a result of these changes
-    the PortSettings structure declaration is no longer local to the
-    QextSerialBase class.  All of the removed constructors had to do with
-    the setNamingConvention() system.
-  * The static mutex member should now be reference-counted and only deleted
-    when it is no longer referenced.
-  * Most of the object construction duties have been pushed back into
-    QextSerialBase
-  * Fixed a couple resource leaks, mostly to do with unlocking the mutex
-    properly
-  - Removed the setNamingConvention() nonsense.
-  - Removed all QStrings and calls to sprintf() for thread compatibility.
-  - Removed setNumber() functions as well as the portNumber member variable,
-    as they were only necessary under the setNamingConvention() system.
-  I am grateful to Jorg Preiss (Preisz?  Sorry, American keyboards don't have
-  an ess-tset character ;)) for his invaluable input on most of the changes
-  that went into this version.
-Version 0.4 (March 20, 2001):
-  + All of the classes now derive from QObject as well as QIODevice.  This
-    is pretty much useless at the moment - signals and slots may be used
-    to implement asynchronous communications in a future version
-  + Added configurable timeouts via the setTimeout() function.  The default
-    timeout for read and write operations is now 500 milliseconds
-  + There is now a functional .pro file for the library (thanks to
-    Gunnstein Lye)
-  + The prefixes for all of the classes have changed from Qw to Qext, in
-    compliance with the qt-addons project standard
-  * Fixed a bug that caused port settings to be restored incorrectly when
-    switching ports with setNumber()
-  * Minor changes to QextSerialBase::setNumber().  Functionality should now
-    reflect the documentation, which has also been updated to reflect the
-    changes that went in on version 0.3.
-  * Some fixes to the documentation.  The Posix_QextSerialPort and
-    Win_QextSerialPort classes should no longer have any unnecessary
-    references to inapplicable platforms, and the documentation for open() has
-    been updated.
-  * Should now compile without QT_THREAD_SUPPORT defined (ie, in single-
-    threaded environments), although it will require slight changes to the
-    makefile (tmake "CONFIG-=thread" should work)
-  * Fixed a few compilation issues, especially on the POSIX side (should
-    compile under Linux now :))
-  * POSIX code is a little cleaner and more efficient
-  * Various small fixes to the documentation
-  * Constants now follow a consistent naming convention, with underscores at
-    the beginning and end of each.  For example TTY_POSIX has become
-    _TTY_POSIX_
-Version 0.3 (Feb. 14, 2001):
-  + Added a warning that appears when QwSerialPort is compiled on a POSIX
-    platform that does not implement 76800 baud operation.  In this situation
-    QwSerialPort will also switch to 57600 baud.
-  + Major code reorganization - there are now 4 classes instead of 1.  This
-    should remove a lot of the #ifdef...#else...#endif constructs and
-    hopefully make the code easier to read.  Including the class in your
-    project is still done by including QwSerialPort.h and instantiating a
-    QwSerialPort object.
-  * The serial port associated with a QwSerialPort object is no longer
-    opened on construction, or upon calling the setNumber() function.  You
-    must now explicitly call open() to open the port.
-Version 0.2 (Jan. 3, 2001):
-  + Added lastError() function with rudimentary error codes
-  + Better documentation
-  + Added ability to examine the empty/not empty state of a port's input
-    buffer with atEnd()
-  + Added ability to retrieve the number of bytes in a port's input buffer
-    with size() (thanks to Olivier Tubach)
-  + Added ability to turn off portability warnings by defining
-    TTY_NOWARN_PORT in your project
-  + Added ability to turn off all warning messages by defining TTY_NOWARN
-    in your project
-  + Added ability to select POSIX serial functions in Windows NT/2000 by
-    defining TTY_POSIX in your project (untested)
-  + Added control over RTS and DTR lines with setRts() and setDtr()
-    respectively
-  + Added ability to query line status using lineStatus().
-  + Added readLine() functionality (thanks to Olivier Tubach)
-  + Added bytesWaiting(), a non-const/thread-safe version of size()
-  + The class should now be thread-safe through the use of a recursive
-    QMutex (untested)
-  * Fixed a bug that could cause hardware flow control not to work on some
-    POSIX systems
-  * Put in a few missing fileno() calls in the POSIX code
-  * Fixed a few syntax errors that caused compilation to fail on POSIX systems
-  - BAUD0 is no longer a valid baud rate setting - to drop the DTR line,
-    call setDtr(FALSE)
-Version 0.1 (Dec. 11, 2000):
-  Initial public release.
Deleted: trunk/qgis/src/core/gps/qextserialport/Doxyfile
--- trunk/qgis/src/core/gps/qextserialport/Doxyfile	2010-01-11 19:23:55 UTC (rev 12736)
+++ trunk/qgis/src/core/gps/qextserialport/Doxyfile	2010-01-11 21:16:25 UTC (rev 12737)
@@ -1,1514 +0,0 @@
-# Doxyfile 1.6.0
-# This file describes the settings to be used by the documentation system
-# doxygen (www.doxygen.org) for a project
-# All text after a hash (#) is considered a comment and will be ignored
-# The format is:
-#       TAG = value [value, ...]
-# For lists items can also be appended using:
-#       TAG += value [value, ...]
-# Values that contain spaces should be placed between quotes (" ")
-# Project related configuration options
-# This tag specifies the encoding used for all characters in the config file
-# that follow. The default is UTF-8 which is also the encoding used for all
-# text before the first occurrence of this tag. Doxygen uses libiconv (or the
-# iconv built into libc) for the transcoding. See
-# http://www.gnu.org/software/libiconv for the list of possible encodings.
-DOXYFILE_ENCODING      = UTF-8
-# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
-# by quotes) that should identify the project.
-PROJECT_NAME           = QextSerialPort
-# The PROJECT_NUMBER tag can be used to enter a project or revision number.
-# This could be handy for archiving the generated documentation or
-# if some version control system is used.
-PROJECT_NUMBER         = "1.2 beta"
-# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
-# base path where the generated documentation will be put.
-# If a relative path is entered, it will be relative to the location
-# where doxygen was started. If left blank the current directory will be used.
-OUTPUT_DIRECTORY       =
-# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
-# 4096 sub-directories (in 2 levels) under the output directory of each output
-# format and will distribute the generated files over these directories.
-# Enabling this option can be useful when feeding doxygen a huge amount of
-# source files, where putting all generated files in the same directory would
-# otherwise cause performance problems for the file system.
-CREATE_SUBDIRS         = NO
-# The OUTPUT_LANGUAGE tag is used to specify the language in which all
-# documentation generated by doxygen is written. Doxygen will use this
-# information to generate all constant output in the proper language.
-# The default language is English, other supported languages are:
-# Afrikaans, Arabic, Brazilian, Catalan, Chinese, Chinese-Traditional,
-# Croatian, Czech, Danish, Dutch, Esperanto, Farsi, Finnish, French, German,
-# Greek, Hungarian, Italian, Japanese, Japanese-en (Japanese with English
-# messages), Korean, Korean-en, Lithuanian, Norwegian, Macedonian, Persian,
-# Polish, Portuguese, Romanian, Russian, Serbian, Serbian-Cyrilic, Slovak,
-# Slovene, Spanish, Swedish, Ukrainian, and Vietnamese.
-OUTPUT_LANGUAGE        = English
-# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
-# include brief member descriptions after the members that are listed in
-# the file and class documentation (similar to JavaDoc).
-# Set to NO to disable this.
-BRIEF_MEMBER_DESC      = YES
-# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
-# the brief description of a member or function before the detailed description.
-# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
-# brief descriptions will be completely suppressed.
-REPEAT_BRIEF           = YES
-# This tag implements a quasi-intelligent brief description abbreviator
-# that is used to form the text in various listings. Each string
-# in this list, if found as the leading text of the brief description, will be
-# stripped from the text and the result after processing the whole list, is
-# used as the annotated text. Otherwise, the brief description is used as-is.
-# If left blank, the following values are used ("$name" is automatically
-# replaced with the name of the entity): "The $name class" "The $name widget"
-# "The $name file" "is" "provides" "specifies" "contains"
-# "represents" "a" "an" "the"
-ABBREVIATE_BRIEF       =
-# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
-# Doxygen will generate a detailed section even if there is only a brief
-# description.
-ALWAYS_DETAILED_SEC    = NO
-# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
-# inherited members of a class in the documentation of that class as if those
-# members were ordinary class members. Constructors, destructors and assignment
-# operators of the base classes will not be shown.
-INLINE_INHERITED_MEMB  = YES
-# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
-# path before files name in the file list and in the header files. If set
-# to NO the shortest path that makes the file name unique will be used.
-FULL_PATH_NAMES        = YES
-# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
-# can be used to strip a user-defined part of the path. Stripping is
-# only done if one of the specified strings matches the left-hand part of
-# the path. The tag can be used to show relative paths in the file list.
-# If left blank the directory from which doxygen is run is used as the
-# path to strip.
-STRIP_FROM_PATH        =
-# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
-# the path mentioned in the documentation of a class, which tells
-# the reader which header file to include in order to use a class.
-# If left blank only the name of the header file containing the class
-# definition is used. Otherwise one should specify the include paths that
-# are normally passed to the compiler using the -I flag.
-STRIP_FROM_INC_PATH    =
-# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
-# (but less readable) file names. This can be useful is your file systems
-# doesn't support long names like on DOS, Mac, or CD-ROM.
-SHORT_NAMES            = NO
-# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
-# will interpret the first line (until the first dot) of a JavaDoc-style
-# comment as the brief description. If set to NO, the JavaDoc
-# comments will behave just like regular Qt-style comments
-# (thus requiring an explicit @brief command for a brief description.)
-JAVADOC_AUTOBRIEF      = NO
-# If the QT_AUTOBRIEF tag is set to YES then Doxygen will
-# interpret the first line (until the first dot) of a Qt-style
-# comment as the brief description. If set to NO, the comments
-# will behave just like regular Qt-style comments (thus requiring
-# an explicit \brief command for a brief description.)
-QT_AUTOBRIEF           = NO
-# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
-# treat a multi-line C++ special comment block (i.e. a block of //! or ///
-# comments) as a brief description. This used to be the default behaviour.
-# The new default is to treat a multi-line C++ comment block as a detailed
-# description. Set this tag to YES if you prefer the old behaviour instead.
-MULTILINE_CPP_IS_BRIEF = NO
-# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
-# member inherits the documentation from any documented member that it
-# re-implements.
-INHERIT_DOCS           = YES
-# If the SEPARATE_MEMBER_PAGES tag is set to YES, then doxygen will produce
-# a new page for each member. If set to NO, the documentation of a member will
-# be part of the file/class/namespace that contains it.
-SEPARATE_MEMBER_PAGES  = NO
-# The TAB_SIZE tag can be used to set the number of spaces in a tab.
-# Doxygen uses this value to replace tabs by spaces in code fragments.
-TAB_SIZE               = 4
-# This tag can be used to specify a number of aliases that acts
-# as commands in the documentation. An alias has the form "name=value".
-# For example adding "sideeffect=\par Side Effects:\n" will allow you to
-# put the command \sideeffect (or @sideeffect) in the documentation, which
-# will result in a user-defined paragraph with heading "Side Effects:".
-# You can put \n's in the value part of an alias to insert newlines.
-ALIASES                =
-# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C
-# sources only. Doxygen will then generate output that is more tailored for C.
-# For instance, some of the names that are used will be different. The list
-# of all members will be omitted, etc.
-OPTIMIZE_OUTPUT_FOR_C  = NO
-# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java
-# Java. For instance, namespaces will be presented as packages, qualified
-# scopes will look different, etc.
-OPTIMIZE_OUTPUT_JAVA   = NO
-# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
-# Fortran.
-OPTIMIZE_FOR_FORTRAN   = NO
-# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
-# sources. Doxygen will then generate output that is tailored for
-# VHDL.
-OPTIMIZE_OUTPUT_VHDL   = NO
-# Doxygen selects the parser to use depending on the extension of the files it parses.
-# With this tag you can assign which parser to use for a given extension.
-# Doxygen has a built-in mapping, but you can override or extend it using this tag.
-# The format is ext=language, where ext is a file extension, and language is one of
-# the parsers supported by doxygen: IDL, Java, Javascript, C#, C, C++, D, PHP,
-# Objective-C, Python, Fortran, VHDL, C, C++. For instance to make doxygen treat
-# .inc files as Fortran files (default is PHP), and .f files as C (default is Fortran),
-# use: inc=Fortran f=C. Note that for custom extensions you also need to set
-# FILE_PATTERNS otherwise the files are not read by doxygen.
-EXTENSION_MAPPING      =
-# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
-# to include (a tag file for) the STL sources as input, then you should
-# set this tag to YES in order to let doxygen match functions declarations and
-# definitions whose arguments contain STL classes (e.g. func(std::string); v.s.
-# func(std::string) {}). This also make the inheritance and collaboration
-# diagrams that involve STL classes more complete and accurate.
-BUILTIN_STL_SUPPORT    = NO
-# If you use Microsoft's C++/CLI language, you should set this option to YES to
-# enable parsing support.
-CPP_CLI_SUPPORT        = NO
-# Set the SIP_SUPPORT tag to YES if your project consists of sip sources only.
-# Doxygen will parse them like normal C++ but will assume all classes use public
-# instead of private inheritance when no explicit protection keyword is present.
-SIP_SUPPORT            = NO
-# For Microsoft's IDL there are propget and propput attributes to indicate getter
-# and setter methods for a property. Setting this option to YES (the default)
-# will make doxygen to replace the get and set methods by a property in the
-# documentation. This will only work if the methods are indeed getting or
-# setting a simple type. If this is not the case, or you want to show the
-# methods anyway, you should set this option to NO.
-IDL_PROPERTY_SUPPORT   = YES
-# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
-# tag is set to YES, then doxygen will reuse the documentation of the first
-# member in the group (if any) for the other members of the group. By default
-# all members of a group must be documented explicitly.
-DISTRIBUTE_GROUP_DOC   = NO
-# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
-# the same type (for instance a group of public functions) to be put as a
-# subgroup of that type (e.g. under the Public Functions section). Set it to
-# NO to prevent subgrouping. Alternatively, this can be done per class using
-# the \nosubgrouping command.
-SUBGROUPING            = YES
-# When TYPEDEF_HIDES_STRUCT is enabled, a typedef of a struct, union, or enum
-# is documented as struct, union, or enum with the name of the typedef. So
-# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
-# with name TypeT. When disabled the typedef will appear as a member of a file,
-# namespace, or class. And the struct will be named TypeS. This can typically
-# be useful for C code in case the coding convention dictates that all compound
-# types are typedef'ed and only the typedef is referenced, never the tag name.
-TYPEDEF_HIDES_STRUCT   = NO
-# The SYMBOL_CACHE_SIZE determines the size of the internal cache use to
-# determine which symbols to keep in memory and which to flush to disk.
-# When the cache is full, less often used symbols will be written to disk.
-# For small to medium size projects (<1000 input files) the default value is
-# probably good enough. For larger projects a too small cache size can cause
-# doxygen to be busy swapping symbols to and from disk most of the time
-# causing a significant performance penality.
-# If the system has enough physical memory increasing the cache will improve the
-# performance by keeping more symbols in memory. Note that the value works on
-# a logarithmic scale so increasing the size by one will rougly double the
-# memory usage. The cache size is given by this formula:
-# 2^(16+SYMBOL_CACHE_SIZE). The valid range is 0..9, the default is 0,
-# corresponding to a cache size of 2^16 = 65536 symbols
-SYMBOL_CACHE_SIZE      = 0
-# Build related configuration options
-# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
-# documentation are documented, even if no documentation was available.
-# Private class members and static file members will be hidden unless
-# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
-EXTRACT_ALL            = NO
-# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
-# will be included in the documentation.
-EXTRACT_PRIVATE        = NO
-# If the EXTRACT_STATIC tag is set to YES all static members of a file
-EXTRACT_STATIC         = NO
-# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
-# defined locally in source files will be included in the documentation.
-# If set to NO only classes defined in header files are included.
-EXTRACT_LOCAL_CLASSES  = YES
-# This flag is only useful for Objective-C code. When set to YES local
-# methods, which are defined in the implementation section but not in
-# the interface are included in the documentation.
-# If set to NO (the default) only methods in the interface are included.
-EXTRACT_LOCAL_METHODS  = NO
-# If this flag is set to YES, the members of anonymous namespaces will be
-# extracted and appear in the documentation as a namespace called
-# 'anonymous_namespace{file}', where file will be replaced with the base
-# name of the file that contains the anonymous namespace. By default
-# anonymous namespace are hidden.
-EXTRACT_ANON_NSPACES   = NO
-# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
-# undocumented members of documented classes, files or namespaces.
-# If set to NO (the default) these members will be included in the
-# various overviews, but no documentation section is generated.
-# This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_MEMBERS     = NO
-# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
-# undocumented classes that are normally visible in the class hierarchy.
-# If set to NO (the default) these classes will be included in the various
-# overviews. This option has no effect if EXTRACT_ALL is enabled.
-HIDE_UNDOC_CLASSES     = NO
-# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
-# friend (class|struct|union) declarations.
-# If set to NO (the default) these declarations will be included in the
-# documentation.
-HIDE_FRIEND_COMPOUNDS  = NO
-# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
-# documentation blocks found inside the body of a function.
-# If set to NO (the default) these blocks will be appended to the
-# function's detailed documentation block.
-HIDE_IN_BODY_DOCS      = NO
-# The INTERNAL_DOCS tag determines if documentation
-# that is typed after a \internal command is included. If the tag is set
-# to NO (the default) then the documentation will be excluded.
-# Set it to YES to include the internal documentation.
-INTERNAL_DOCS          = NO
-# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
-# file names in lower-case letters. If set to YES upper-case letters are also
-# allowed. This is useful if you have classes or files whose names only differ
-# in case and if your file system supports case sensitive file names. Windows
-# and Mac users are advised to set this option to NO.
-CASE_SENSE_NAMES       = NO
-# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
-# will show members with their full class and namespace scopes in the
-# documentation. If set to YES the scope will be hidden.
-HIDE_SCOPE_NAMES       = NO
-# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
-# will put a list of the files that are included by a file in the documentation
-# of that file.
-SHOW_INCLUDE_FILES     = YES
-# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
-# is inserted in the documentation for inline members.
-INLINE_INFO            = YES
-# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
-# will sort the (detailed) documentation of file and class members
-# alphabetically by member name. If set to NO the members will appear in
-# declaration order.
-SORT_MEMBER_DOCS       = YES
-# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
-# brief documentation of file, namespace and class members alphabetically
-# by member name. If set to NO (the default) the members will appear in
-SORT_BRIEF_DOCS        = NO
-# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen
-# will sort the (brief and detailed) documentation of class members so that
-# constructors and destructors are listed first. If set to NO (the default)
-# the constructors will appear in the respective orders defined by
-# SORT_MEMBER_DOCS and SORT_BRIEF_DOCS.
-# This tag will be ignored for brief docs if SORT_BRIEF_DOCS is set to NO
-# and ignored for detailed docs if SORT_MEMBER_DOCS is set to NO.
-SORT_MEMBERS_CTORS_1ST = YES
-# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the
-# hierarchy of group names into alphabetical order. If set to NO (the default)
-# the group names will appear in their defined order.
-SORT_GROUP_NAMES       = NO
-# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
-# sorted by fully-qualified names, including namespaces. If set to
-# NO (the default), the class list will be sorted only by class name,
-# not including the namespace part.
-# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
-# Note: This option applies only to the class list, not to the
-# alphabetical list.
-SORT_BY_SCOPE_NAME     = NO
-# The GENERATE_TODOLIST tag can be used to enable (YES) or
-# disable (NO) the todo list. This list is created by putting \todo
-# commands in the documentation.
-GENERATE_TODOLIST      = YES
-# The GENERATE_TESTLIST tag can be used to enable (YES) or
-# disable (NO) the test list. This list is created by putting \test
-GENERATE_TESTLIST      = YES
-# The GENERATE_BUGLIST tag can be used to enable (YES) or
-# disable (NO) the bug list. This list is created by putting \bug
-GENERATE_BUGLIST       = YES
-# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
-# disable (NO) the deprecated list. This list is created by putting
-# \deprecated commands in the documentation.
-GENERATE_DEPRECATEDLIST= YES
-# The ENABLED_SECTIONS tag can be used to enable conditional
-# documentation sections, marked by \if sectionname ... \endif.
-ENABLED_SECTIONS       =
-# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
-# the initial value of a variable or define consists of for it to appear in
-# the documentation. If the initializer consists of more lines than specified
-# here it will be hidden. Use a value of 0 to hide initializers completely.
-# The appearance of the initializer of individual variables and defines in the
-# documentation can be controlled using \showinitializer or \hideinitializer
-# command in the documentation regardless of this setting.
-MAX_INITIALIZER_LINES  = 30
-# If the sources in your project are distributed over multiple directories
-# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
-# in the documentation. The default is NO.
-SHOW_DIRECTORIES       = NO
-# Set the SHOW_FILES tag to NO to disable the generation of the Files page.
-# This will remove the Files entry from the Quick Index and from the
-# Folder Tree View (if specified). The default is YES.
-SHOW_FILES             = YES
-# Set the SHOW_NAMESPACES tag to NO to disable the generation of the
-# Namespaces page.  This will remove the Namespaces entry from the Quick Index
-# and from the Folder Tree View (if specified). The default is YES.
-SHOW_NAMESPACES        = YES
-# The FILE_VERSION_FILTER tag can be used to specify a program or script that
-# doxygen should invoke to get the current version for each file (typically from
-# the version control system). Doxygen will invoke the program by executing (via
-# popen()) the command <command> <input-file>, where <command> is the value of
-# the FILE_VERSION_FILTER tag, and <input-file> is the name of an input file
-# provided by doxygen. Whatever the program writes to standard output
-# is used as the file version. See the manual for examples.
-FILE_VERSION_FILTER    =
-# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed by
-# doxygen. The layout file controls the global structure of the generated output files
-# in an output format independent way. The create the layout file that represents
-# doxygen's defaults, run doxygen with the -l option. You can optionally specify a
-# file name after the option, if omitted DoxygenLayout.xml will be used as the name
-# of the layout file.
-LAYOUT_FILE            =
-# configuration options related to warning and progress messages
-# The QUIET tag can be used to turn on/off the messages that are generated
-# by doxygen. Possible values are YES and NO. If left blank NO is used.
-QUIET                  = NO
-# The WARNINGS tag can be used to turn on/off the warning messages that are
-# generated by doxygen. Possible values are YES and NO. If left blank
-# NO is used.
-WARNINGS               = YES
-# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
-# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
-# automatically be disabled.
-WARN_IF_UNDOCUMENTED   = YES
-# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
-# potential errors in the documentation, such as not documenting some
-# parameters in a documented function, or documenting parameters that
-# don't exist or using markup commands wrongly.
-WARN_IF_DOC_ERROR      = YES
-# This WARN_NO_PARAMDOC option can be abled to get warnings for
-# functions that are documented, but have no documentation for their parameters
-# or return value. If set to NO (the default) doxygen will only warn about
-# wrong or incomplete parameter documentation, but not about the absence of
-# documentation.
-WARN_NO_PARAMDOC       = NO
-# The WARN_FORMAT tag determines the format of the warning messages that
-# doxygen can produce. The string should contain the $file, $line, and $text
-# tags, which will be replaced by the file and line number from which the
-# warning originated and the warning text. Optionally the format may contain
-# $version, which will be replaced by the version of the file (if it could
-# be obtained via FILE_VERSION_FILTER)
-WARN_FORMAT            = "$file:$line: $text"
-# The WARN_LOGFILE tag can be used to specify a file to which warning
-# and error messages should be written. If left blank the output is written
-# to stderr.
-WARN_LOGFILE           =
-# configuration options related to the input files
-# The INPUT tag can be used to specify the files and/or directories that contain
-# documented source files. You may enter file names like "myfile.cpp" or
-# directories like "/usr/src/myproject". Separate the files or directories
-# with spaces.
-INPUT                  = doc \
-# This tag can be used to specify the character encoding of the source files
-# that doxygen parses. Internally doxygen uses the UTF-8 encoding, which is
-# also the default input encoding. Doxygen uses libiconv (or the iconv built
-# into libc) for the transcoding. See http://www.gnu.org/software/libiconv for
-# the list of possible encodings.
-INPUT_ENCODING         = UTF-8
-# If the value of the INPUT tag contains directories, you can use the
-# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# and *.h) to filter out the source-files in the directories. If left
-# blank the following patterns are tested:
-# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx
-# *.hpp *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm *.py *.f90
-FILE_PATTERNS          = *.h \
-                         *.cpp \
-                         *.dox
-# The RECURSIVE tag can be used to turn specify whether or not subdirectories
-# should be searched for input files as well. Possible values are YES and NO.
-# If left blank NO is used.
-RECURSIVE              = NO
-# The EXCLUDE tag can be used to specify files and/or directories that should
-# excluded from the INPUT source files. This way you can easily exclude a
-# subdirectory from a directory tree whose root is specified with the INPUT tag.
-EXCLUDE                =
-# The EXCLUDE_SYMLINKS tag can be used select whether or not files or
-# directories that are symbolic links (a Unix filesystem feature) are excluded
-# from the input.
-EXCLUDE_SYMLINKS       = NO
-# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
-# certain files from those directories. Note that the wildcards are matched
-# against the file with absolute path, so to exclude all test directories
-# for example use the pattern */test/*
-EXCLUDE_PATTERNS       =
-# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
-# (namespaces, classes, functions, etc.) that should be excluded from the
-# output. The symbol name can be a fully qualified name, a word, or if the
-# wildcard * is used, a substring. Examples: ANamespace, AClass,
-# AClass::ANamespace, ANamespace::*Test
-EXCLUDE_SYMBOLS        =
-# The EXAMPLE_PATH tag can be used to specify one or more files or
-# directories that contain example code fragments that are included (see
-# the \include command).
-EXAMPLE_PATH           =
-# If the value of the EXAMPLE_PATH tag contains directories, you can use the
-# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
-# blank all files are included.
-EXAMPLE_PATTERNS       =
-# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
-# searched for input files to be used with the \include or \dontinclude
-# commands irrespective of the value of the RECURSIVE tag.
-# Possible values are YES and NO. If left blank NO is used.
-EXAMPLE_RECURSIVE      = NO
-# The IMAGE_PATH tag can be used to specify one or more files or
-# directories that contain image that are included in the documentation (see
-# the \image command).
-IMAGE_PATH             =
-# The INPUT_FILTER tag can be used to specify a program that doxygen should
-# invoke to filter for each input file. Doxygen will invoke the filter program
-# by executing (via popen()) the command <filter> <input-file>, where <filter>
-# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
-# input file. Doxygen will then use the output that the filter program writes
-# to standard output.  If FILTER_PATTERNS is specified, this tag will be
-# ignored.
-INPUT_FILTER           =
-# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
-# basis.  Doxygen will compare the file name with each pattern and apply the
-# filter if there is a match.  The filters are a list of the form:
-# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
-# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
-# is applied to all files.
-FILTER_PATTERNS        =
-# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
-# INPUT_FILTER) will be used to filter the input files when producing source
-# files to browse (i.e. when SOURCE_BROWSER is set to YES).
-FILTER_SOURCE_FILES    = NO
-# configuration options related to source browsing
-# If the SOURCE_BROWSER tag is set to YES then a list of source files will
-# be generated. Documented entities will be cross-referenced with these sources.
-# Note: To get rid of all source code in the generated output, make sure also
-# VERBATIM_HEADERS is set to NO.
-SOURCE_BROWSER         = YES
-# Setting the INLINE_SOURCES tag to YES will include the body
-# of functions and classes directly in the documentation.
-INLINE_SOURCES         = NO
-# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
-# doxygen to hide any special comment blocks from generated source code
-# fragments. Normal C and C++ comments will always remain visible.
-STRIP_CODE_COMMENTS    = YES
-# If the REFERENCED_BY_RELATION tag is set to YES
-# then for each documented function all documented
-# functions referencing it will be listed.
-REFERENCED_BY_RELATION = NO
-# If the REFERENCES_RELATION tag is set to YES
-# then for each documented function all documented entities
-# called/used by that function will be listed.
-REFERENCES_RELATION    = NO
-# If the REFERENCES_LINK_SOURCE tag is set to YES (the default)
-# and SOURCE_BROWSER tag is set to YES, then the hyperlinks from
-# functions in REFERENCES_RELATION and REFERENCED_BY_RELATION lists will
-# link to the source code.  Otherwise they will link to the documentation.
-REFERENCES_LINK_SOURCE = YES
-# If the USE_HTAGS tag is set to YES then the references to source code
-# will point to the HTML generated by the htags(1) tool instead of doxygen
-# built-in source browser. The htags tool is part of GNU's global source
-# tagging system (see http://www.gnu.org/software/global/global.html). You
-# will need version 4.8.6 or higher.
-USE_HTAGS              = NO
-# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
-# will generate a verbatim copy of the header file for each class for
-# which an include is specified. Set to NO to disable this.
-VERBATIM_HEADERS       = YES
-# configuration options related to the alphabetical class index
-# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
-# of all compounds will be generated. Enable this if the project
-# contains a lot of classes, structs, unions or interfaces.
-ALPHABETICAL_INDEX     = YES
-# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
-# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
-# in which this list will be split (can be a number in the range [1..20])
-COLS_IN_ALPHA_INDEX    = 5
-# In case all classes in a project start with a common prefix, all
-# classes will be put under the same header in the alphabetical index.
-# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
-# should be ignored while generating the index headers.
-IGNORE_PREFIX          =
-# configuration options related to the HTML output
-# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
-# generate HTML output.
-GENERATE_HTML          = YES
-# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
-# If a relative path is entered the value of OUTPUT_DIRECTORY will be
-# put in front of it. If left blank `html' will be used as the default path.
-HTML_OUTPUT            = html
-# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
-# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
-# doxygen will generate files with .html extension.
-HTML_FILE_EXTENSION    = .html
-# The HTML_HEADER tag can be used to specify a personal HTML header for
-# each generated HTML page. If it is left blank doxygen will generate a
-# standard header.
-HTML_HEADER            =
-# The HTML_FOOTER tag can be used to specify a personal HTML footer for
-# standard footer.
-HTML_FOOTER            =
-# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
-# style sheet that is used by each HTML page. It can be used to
-# fine-tune the look of the HTML output. If the tag is left blank doxygen
-# will generate a default style sheet. Note that doxygen will try to copy
-# the style sheet file to the HTML output directory, so don't put your own
-# stylesheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET        =
-# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
-# files or namespaces will be aligned in HTML using tables. If set to
-# NO a bullet list will be used.
-HTML_ALIGN_MEMBERS     = YES
-# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
-# documentation will contain sections that can be hidden and shown after the
-# page has loaded. For this to work a browser that supports
-# JavaScript and DHTML is required (for instance Mozilla 1.0+, Firefox
-# Netscape 6.0+, Internet explorer 5.0+, Konqueror, or Safari).
-HTML_DYNAMIC_SECTIONS  = NO
-# If the GENERATE_DOCSET tag is set to YES, additional index files
-# will be generated that can be used as input for Apple's Xcode 3
-# integrated development environment, introduced with OSX 10.5 (Leopard).
-# To create a documentation set, doxygen will generate a Makefile in the
-# HTML output directory. Running make will produce the docset in that
-# directory and running "make install" will install the docset in
-# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find
-# it at startup.
-# See http://developer.apple.com/tools/creatingdocsetswithdoxygen.html for more information.
-GENERATE_DOCSET        = NO
-# When GENERATE_DOCSET tag is set to YES, this tag determines the name of the
-# feed. A documentation feed provides an umbrella under which multiple
-# documentation sets from a single provider (such as a company or product suite)
-# can be grouped.
-DOCSET_FEEDNAME        = "Doxygen generated docs"
-# When GENERATE_DOCSET tag is set to YES, this tag specifies a string that
-# should uniquely identify the documentation set bundle. This should be a
-# reverse domain-name style string, e.g. com.mycompany.MyDocSet. Doxygen
-# will append .docset to the name.
-DOCSET_BUNDLE_ID       = org.doxygen.Project
-# If the GENERATE_HTMLHELP tag is set to YES, additional index files
-# will be generated that can be used as input for tools like the
-# Microsoft HTML help workshop to generate a compiled HTML help file (.chm)
-# of the generated HTML documentation.
-GENERATE_HTMLHELP      = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
-# be used to specify the file name of the resulting .chm file. You
-# can add a path in front of the file if the result should not be
-# written to the html output directory.
-CHM_FILE               =
-# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
-# be used to specify the location (absolute path including file name) of
-# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
-# the HTML help compiler on the generated index.hhp.
-HHC_LOCATION           =
-# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
-# controls if a separate .chi index file is generated (YES) or that
-# it should be included in the master .chm file (NO).
-GENERATE_CHI           = NO
-# If the GENERATE_HTMLHELP tag is set to YES, the CHM_INDEX_ENCODING
-# is used to encode HtmlHelp index (hhk), content (hhc) and project file
-# content.
-CHM_INDEX_ENCODING     =
-# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
-# controls whether a binary table of contents is generated (YES) or a
-# normal table of contents (NO) in the .chm file.
-BINARY_TOC             = NO
-# The TOC_EXPAND flag can be set to YES to add extra items for group members
-# to the contents of the HTML help documentation and to the tree view.
-TOC_EXPAND             = NO
-# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and QHP_VIRTUAL_FOLDER
-# are set, an additional index file will be generated that can be used as input for
-# Qt's qhelpgenerator to generate a Qt Compressed Help (.qch) of the generated
-# HTML documentation.
-GENERATE_QHP           = NO
-# If the QHG_LOCATION tag is specified, the QCH_FILE tag can
-# be used to specify the file name of the resulting .qch file.
-# The path specified is relative to the HTML output folder.
-QCH_FILE               =
-# The QHP_NAMESPACE tag specifies the namespace to use when generating
-# Qt Help Project output. For more information please see
-# http://doc.trolltech.com/qthelpproject.html#namespace
-QHP_NAMESPACE          =
-# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating
-# http://doc.trolltech.com/qthelpproject.html#virtual-folders
-QHP_VIRTUAL_FOLDER     = doc
-# If QHP_CUST_FILTER_NAME is set, it specifies the name of a custom filter to add.
-# For more information please see
-# http://doc.trolltech.com/qthelpproject.html#custom-filters
-QHP_CUST_FILTER_NAME   =
-# The QHP_CUST_FILT_ATTRS tag specifies the list of the attributes of the custom filter to add.For more information please see
-# <a href="http://doc.trolltech.com/qthelpproject.html#custom-filters">Qt Help Project / Custom Filters</a>.
-QHP_CUST_FILTER_ATTRS  =
-# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this project's
-# filter section matches.
-# <a href="http://doc.trolltech.com/qthelpproject.html#filter-attributes">Qt Help Project / Filter Attributes</a>.
-QHP_SECT_FILTER_ATTRS  =
-# If the GENERATE_QHP tag is set to YES, the QHG_LOCATION tag can
-# be used to specify the location of Qt's qhelpgenerator.
-# If non-empty doxygen will try to run qhelpgenerator on the generated
-# .qhp file.
-QHG_LOCATION           =
-# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
-# top of each HTML page. The value NO (the default) enables the index and
-# the value YES disables it.
-DISABLE_INDEX          = NO
-# This tag can be used to set the number of enum values (range [1..20])
-# that doxygen will group on one line in the generated HTML documentation.
-ENUM_VALUES_PER_LINE   = 4
-# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
-# structure should be generated to display hierarchical information.
-# If the tag value is set to FRAME, a side panel will be generated
-# containing a tree-like index structure (just like the one that
-# is generated for HTML Help). For this to work a browser that supports
-# JavaScript, DHTML, CSS and frames is required (i.e. any modern browser).
-# Windows users are probably better off using the HTML help feature.
-GENERATE_TREEVIEW      = YES
-# By enabling USE_INLINE_TREES, doxygen will generate the Groups, Directories,
-# and Class Hierarchy pages using a tree view instead of an ordered list.
-USE_INLINE_TREES       = NO
-# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
-# used to set the initial width (in pixels) of the frame in which the tree
-# is shown.
-TREEVIEW_WIDTH         = 250
-# Use this tag to change the font size of Latex formulas included
-# as images in the HTML documentation. The default is 10. Note that
-# when you change the font size after a successful doxygen run you need
-# to manually remove any form_*.png images from the HTML output directory
-# to force them to be regenerated.
-FORMULA_FONTSIZE       = 10
-# When the SEARCHENGINE tag is enable doxygen will generate a search box
-# for the HTML output. The underlying search engine uses javascript
-# and DHTML and should work on any modern browser. Note that when using
-# HTML help (GENERATE_HTMLHELP) or Qt help (GENERATE_QHP)
-# there is already a search function so this one should typically
-# be disabled.
-SEARCHENGINE           = NO
-# configuration options related to the LaTeX output
-# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
-# generate Latex output.
-GENERATE_LATEX         = NO
-# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
-# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT           = latex
-# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
-# invoked. If left blank `latex' will be used as the default command name.
-LATEX_CMD_NAME         = latex
-# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
-# generate index for LaTeX. If left blank `makeindex' will be used as the
-# default command name.
-MAKEINDEX_CMD_NAME     = makeindex
-# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
-# LaTeX documents. This may be useful for small projects and may help to
-# save some trees in general.
-COMPACT_LATEX          = NO
-# The PAPER_TYPE tag can be used to set the paper type that is used
-# by the printer. Possible values are: a4, a4wide, letter, legal and
-# executive. If left blank a4wide will be used.
-PAPER_TYPE             = a4wide
-# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
-# packages that should be included in the LaTeX output.
-EXTRA_PACKAGES         =
-# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
-# the generated latex document. The header should contain everything until
-# the first chapter. If it is left blank doxygen will generate a
-# standard header. Notice: only use this tag if you know what you are doing!
-LATEX_HEADER           =
-# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
-# is prepared for conversion to pdf (using ps2pdf). The pdf file will
-# contain links (just like the HTML output) instead of page references
-# This makes the output suitable for online browsing using a pdf viewer.
-PDF_HYPERLINKS         = NO
-# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
-# plain latex in the generated Makefile. Set this option to YES to get a
-# higher quality PDF documentation.
-USE_PDFLATEX           = NO
-# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
-# command to the generated LaTeX files. This will instruct LaTeX to keep
-# running if errors occur, instead of asking the user for help.
-# This option is also used when generating formulas in HTML.
-LATEX_BATCHMODE        = NO
-# If LATEX_HIDE_INDICES is set to YES then doxygen will not
-# include the index chapters (such as File Index, Compound Index, etc.)
-# in the output.
-LATEX_HIDE_INDICES     = NO
-# If LATEX_SOURCE_CODE is set to YES then doxygen will include
-# source code with syntax highlighting in the LaTeX output.
-# Note that which sources are shown also depends on other settings
-# such as SOURCE_BROWSER.
-LATEX_SOURCE_CODE      = NO
-# configuration options related to the RTF output
-# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
-# The RTF output is optimized for Word 97 and may not look very pretty with
-# other RTF readers or editors.
-GENERATE_RTF           = NO
-# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
-# put in front of it. If left blank `rtf' will be used as the default path.
-RTF_OUTPUT             = rtf
-# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
-# RTF documents. This may be useful for small projects and may help to
-COMPACT_RTF            = NO
-# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
-# will contain hyperlink fields. The RTF file will
-# contain links (just like the HTML output) instead of page references.
-# This makes the output suitable for online browsing using WORD or other
-# programs which support those fields.
-# Note: wordpad (write) and others do not support links.
-RTF_HYPERLINKS         = NO
-# Load stylesheet definitions from file. Syntax is similar to doxygen's
-# config file, i.e. a series of assignments. You only have to provide
-# replacements, missing definitions are set to their default value.
-RTF_STYLESHEET_FILE    =
-# Set optional variables used in the generation of an rtf document.
-# Syntax is similar to doxygen's config file.
-RTF_EXTENSIONS_FILE    =
-# configuration options related to the man page output
-# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
-# generate man pages
-GENERATE_MAN           = NO
-# The MAN_OUTPUT tag is used to specify where the man pages will be put.
-# put in front of it. If left blank `man' will be used as the default path.
-MAN_OUTPUT             = man
-# The MAN_EXTENSION tag determines the extension that is added to
-# the generated man pages (default is the subroutine's section .3)
-MAN_EXTENSION          = .3
-# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
-# then it will generate one additional man file for each entity
-# documented in the real man page(s). These additional files
-# only source the real man page, but without them the man command
-# would be unable to find the correct page. The default is NO.
-MAN_LINKS              = NO
-# configuration options related to the XML output
-# If the GENERATE_XML tag is set to YES Doxygen will
-# generate an XML file that captures the structure of
-# the code including all documentation.
-GENERATE_XML           = NO
-# The XML_OUTPUT tag is used to specify where the XML pages will be put.
-# put in front of it. If left blank `xml' will be used as the default path.
-XML_OUTPUT             = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
-# syntax of the XML files.
-XML_SCHEMA             =
-# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD                =
-# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
-# dump the program listings (including syntax highlighting
-# and cross-referencing information) to the XML output. Note that
-# enabling this will significantly increase the size of the XML output.
-XML_PROGRAMLISTING     = YES
-# configuration options for the AutoGen Definitions output
-# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
-# generate an AutoGen Definitions (see autogen.sf.net) file
-# that captures the structure of the code including all
-# documentation. Note that this feature is still experimental
-# and incomplete at the moment.
-GENERATE_AUTOGEN_DEF   = NO
-# configuration options related to the Perl module output
-# If the GENERATE_PERLMOD tag is set to YES Doxygen will
-# generate a Perl module file that captures the structure of
-# the code including all documentation. Note that this
-# feature is still experimental and incomplete at the
-# moment.
-GENERATE_PERLMOD       = NO
-# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
-# the necessary Makefile rules, Perl scripts and LaTeX code to be able
-# to generate PDF and DVI output from the Perl module output.
-PERLMOD_LATEX          = NO
-# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
-# nicely formatted so it can be parsed by a human reader.  This is useful
-# if you want to understand what is going on.  On the other hand, if this
-# tag is set to NO the size of the Perl module output will be much smaller
-# and Perl will parse it just the same.
-PERLMOD_PRETTY         = YES
-# The names of the make variables in the generated doxyrules.make file
-# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
-# This is useful so different doxyrules.make files included by the same
-# Makefile don't overwrite each other's variables.
-PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
-# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
-# evaluate all C-preprocessor directives found in the sources and include
-# files.
-ENABLE_PREPROCESSING   = YES
-# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
-# names in the source code. If set to NO (the default) only conditional
-# compilation will be performed. Macro expansion can be done in a controlled
-# way by setting EXPAND_ONLY_PREDEF to YES.
-MACRO_EXPANSION        = YES
-# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
-# then the macro expansion is limited to the macros specified with the
-# PREDEFINED and EXPAND_AS_DEFINED tags.
-EXPAND_ONLY_PREDEF     = YES
-# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
-# in the INCLUDE_PATH (see below) will be search if a #include is found.
-SEARCH_INCLUDES        = YES
-# The INCLUDE_PATH tag can be used to specify one or more directories that
-# contain include files that are not input files but should be processed by
-# the preprocessor.
-INCLUDE_PATH           =
-# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
-# patterns (like *.h and *.hpp) to filter out the header-files in the
-# directories. If left blank, the patterns specified with FILE_PATTERNS will
-# be used.
-INCLUDE_FILE_PATTERNS  =
-# The PREDEFINED tag can be used to specify one or more macro names that
-# are defined before the preprocessor is started (similar to the -D option of
-# gcc). The argument of the tag is a list of macros of the form: name
-# or name=definition (no spaces). If the definition and the = are
-# omitted =1 is assumed. To prevent a macro definition from being
-# undefined via #undef or recursively expanded use the := operator
-# instead of the = operator.
-PREDEFINED             = "protected = private"
-# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
-# this tag can be used to specify a list of macro names that should be expanded.
-# The macro definition that is found in the sources will be used.
-# Use the PREDEFINED tag if you want to use a different macro definition.
-EXPAND_AS_DEFINED      =
-# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
-# doxygen's preprocessor will remove all function-like macros that are alone
-# on a line, have an all uppercase name, and do not end with a semicolon. Such
-# function macros are typically used for boiler-plate code, and will confuse
-# the parser if not removed.
-SKIP_FUNCTION_MACROS   = YES
-# Configuration::additions related to external references
-# The TAGFILES option can be used to specify one or more tagfiles.
-# Optionally an initial location of the external documentation
-# can be added for each tagfile. The format of a tag file without
-# this location is as follows:
-#   TAGFILES = file1 file2 ...
-# Adding location for the tag files is done as follows:
-#   TAGFILES = file1=loc1 "file2 = loc2" ...
-# where "loc1" and "loc2" can be relative or absolute paths or
-# URLs. If a location is present for each tag, the installdox tool
-# does not have to be run to correct the links.
-# Note that each tag file must have a unique name
-# (where the name does NOT include the path)
-# If a tag file is not located in the directory in which doxygen
-# is run, you must also specify the path to the tagfile here.
-TAGFILES               = doc/qiodevice.tag
-# When a file name is specified after GENERATE_TAGFILE, doxygen will create
-# a tag file that is based on the input files it reads.
-GENERATE_TAGFILE       =
-# If the ALLEXTERNALS tag is set to YES all external classes will be listed
-# in the class index. If set to NO only the inherited external classes
-# will be listed.
-ALLEXTERNALS           = NO
-# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
-# in the modules index. If set to NO, only the current project's groups will
-# be listed.
-EXTERNAL_GROUPS        = YES
-# The PERL_PATH should be the absolute path and name of the perl script
-# interpreter (i.e. the result of `which perl').
-PERL_PATH              = /usr/bin/perl
-# Configuration options related to the dot tool
-# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
-# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base
-# or super classes. Setting the tag to NO turns the diagrams off. Note that
-# this option is superseded by the HAVE_DOT option below. This is only a
-# fallback. It is recommended to install and use dot, since it yields more
-# powerful graphs.
-CLASS_DIAGRAMS         = NO
-# You can define message sequence charts within doxygen comments using the \msc
-# command. Doxygen will then run the mscgen tool (see
-# http://www.mcternan.me.uk/mscgen/) to produce the chart and insert it in the
-# documentation. The MSCGEN_PATH tag allows you to specify the directory where
-# the mscgen tool resides. If left empty the tool is assumed to be found in the
-# default search path.
-MSCGEN_PATH            =
-# If set to YES, the inheritance and collaboration graphs will hide
-# inheritance and usage relations if the target is undocumented
-# or is not a class.
-HIDE_UNDOC_RELATIONS   = YES
-# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
-# available from the path. This tool is part of Graphviz, a graph visualization
-# toolkit from AT&T and Lucent Bell Labs. The other options in this section
-# have no effect if this option is set to NO (the default)
-HAVE_DOT               = NO
-# By default doxygen will write a font called FreeSans.ttf to the output
-# directory and reference it in all dot files that doxygen generates. This
-# font does not include all possible unicode characters however, so when you need
-# these (or just want a differently looking font) you can specify the font name
-# using DOT_FONTNAME. You need need to make sure dot is able to find the font,
-# which can be done by putting it in a standard location or by setting the
-# DOTFONTPATH environment variable or by setting DOT_FONTPATH to the directory
-# containing the font.
-DOT_FONTNAME           = FreeSans
-# The DOT_FONTSIZE tag can be used to set the size of the font of dot graphs.
-# The default size is 10pt.
-DOT_FONTSIZE           = 10
-# By default doxygen will tell dot to use the output directory to look for the
-# FreeSans.ttf font (which doxygen will put there itself). If you specify a
-# different font using DOT_FONTNAME you can set the path where dot
-# can find it using this tag.
-DOT_FONTPATH           =
-# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for each documented class showing the direct and
-# indirect inheritance relations. Setting this tag to YES will force the
-# the CLASS_DIAGRAMS tag to NO.
-CLASS_GRAPH            = YES
-# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
-# indirect implementation dependencies (inheritance, containment, and
-# class references variables) of the class with other documented classes.
-COLLABORATION_GRAPH    = YES
-# If the GROUP_GRAPHS and HAVE_DOT tags are set to YES then doxygen
-# will generate a graph for groups, showing the direct groups dependencies
-GROUP_GRAPHS           = YES
-# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
-# collaboration diagrams in a style similar to the OMG's Unified Modeling
-# Language.
-UML_LOOK               = NO
-# If set to YES, the inheritance and collaboration graphs will show the
-# relations between templates and their instances.
-TEMPLATE_RELATIONS     = NO
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
-# tags are set to YES then doxygen will generate a graph for each documented
-# file showing the direct and indirect include dependencies of the file with
-# other documented files.
-INCLUDE_GRAPH          = YES
-# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
-# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
-# documented header file showing the documented files that directly or
-# indirectly include this file.
-INCLUDED_BY_GRAPH      = YES
-# If the CALL_GRAPH and HAVE_DOT options are set to YES then
-# doxygen will generate a call dependency graph for every global function
-# or class method. Note that enabling this option will significantly increase
-# the time of a run. So in most cases it will be better to enable call graphs
-# for selected functions only using the \callgraph command.
-CALL_GRAPH             = NO
-# If the CALLER_GRAPH and HAVE_DOT tags are set to YES then
-# doxygen will generate a caller dependency graph for every global function
-# the time of a run. So in most cases it will be better to enable caller
-# graphs for selected functions only using the \callergraph command.
-CALLER_GRAPH           = NO
-# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
-# will graphical hierarchy of all classes instead of a textual one.
-GRAPHICAL_HIERARCHY    = YES
-# If the DIRECTORY_GRAPH, SHOW_DIRECTORIES and HAVE_DOT tags are set to YES
-# then doxygen will show the dependencies a directory has on other directories
-# in a graphical way. The dependency relations are determined by the #include
-# relations between the files in the directories.
-DIRECTORY_GRAPH        = YES
-# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
-# generated by dot. Possible values are png, jpg, or gif
-# If left blank png will be used.
-DOT_IMAGE_FORMAT       = png
-# The tag DOT_PATH can be used to specify the path where the dot tool can be
-# found. If left blank, it is assumed the dot tool can be found in the path.
-DOT_PATH               =
-# The DOTFILE_DIRS tag can be used to specify one or more directories that
-# contain dot files that are included in the documentation (see the
-# \dotfile command).
-DOTFILE_DIRS           =
-# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of
-# nodes that will be shown in the graph. If the number of nodes in a graph
-# becomes larger than this value, doxygen will truncate the graph, which is
-# visualized by representing a node as a red box. Note that doxygen if the
-# number of direct children of the root node in a graph is already larger than
-# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note
-# that the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
-DOT_GRAPH_MAX_NODES    = 50
-# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
-# graphs generated by dot. A depth value of 3 means that only nodes reachable
-# from the root by following a path via at most 3 edges will be shown. Nodes
-# that lay further from the root node will be omitted. Note that setting this
-# option to 1 or 2 may greatly reduce the computation time needed for large
-# code bases. Also note that the size of a graph can be further restricted by
-# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
-MAX_DOT_GRAPH_DEPTH    = 0
-# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
-# background. This is disabled by default, because dot on Windows does not
-# seem to support this out of the box. Warning: Depending on the platform used,
-# enabling this option may lead to badly anti-aliased labels on the edges of
-# a graph (i.e. they become hard to read).
-DOT_TRANSPARENT        = NO
-# Set the DOT_MULTI_TARGETS tag to YES allow dot to generate multiple output
-# files in one run (i.e. multiple -o and -T options on the command line). This
-# makes dot run faster, but since only newer versions of dot (>1.8.10)
-# support this, this feature is disabled by default.
-DOT_MULTI_TARGETS      = NO
-# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
-# generate a legend page explaining the meaning of the various boxes and
-# arrows in the dot generated graphs.
-GENERATE_LEGEND        = YES
-# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
-# remove the intermediate dot files that are used to generate
-# the various graphs.
-DOT_CLEANUP            = YES
Deleted: trunk/qgis/src/core/gps/qextserialport/qextserialport.pro
--- trunk/qgis/src/core/gps/qextserialport/qextserialport.pro	2010-01-11 19:23:55 UTC (rev 12736)
+++ trunk/qgis/src/core/gps/qextserialport/qextserialport.pro	2010-01-11 21:16:25 UTC (rev 12737)
@@ -1,39 +0,0 @@
-PROJECT                 = qextserialport
-TEMPLATE                = lib
-CONFIG                 += qt warn_on thread debug_and_release
-CONFIG                  += dll
-#CONFIG                 += staticlib
-# event driven device enumeration on windows requires the gui module
-!win32:QT               -= gui
-OBJECTS_DIR             = build/obj
-MOC_DIR                 = build/moc
-DEPENDDIR               = .
-INCLUDEDIR              = .
-HEADERS                 = qextserialport.h \
-                          qextserialenumerator.h
-SOURCES                 = qextserialport.cpp \
-                          qextserialenumerator.cpp
-unix:SOURCES           += posix_qextserialport.cpp
-macx: LIBS             += -framework IOKit
-win32:SOURCES          += win_qextserialport.cpp
-win32:DEFINES          += WINVER=0x0501 # needed for mingw to pull in appropriate dbt business...probably a better way to do this
-win32:LIBS             += -lsetupapi
-DESTDIR                 = build
-#DESTDIR                = examples/enumerator/debug
-#DESTDIR                = examples/qespta/debug
-#DESTDIR                = examples/event/debug
-CONFIG(debug, debug|release) {
-    TARGET = qextserialportd
-} else {
-VERSION            = 1.2.0
More information about the QGIS-commit mailing list
