[QGIS Commit] r12754 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org
Wed Jan 13 12:00:21 EST 2010
Author: kyngchaos
Date: 2010-01-13 12:00:20 -0500 (Wed, 13 Jan 2010)
New Revision: 12754
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
restore app build of qgis_help
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-01-13 16:45:11 UTC (rev 12753)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-01-13 17:00:20 UTC (rev 12754)
@@ -55,7 +55,7 @@
dependencies = (
727E6B520FEABF4E00DF6F64 /* PBXTargetDependency */,
7256F1CD0F411CDD0022BE1F /* PBXTargetDependency */,
- 7249EBF310E7C0E200708435 /* PBXTargetDependency */,
+ 7217CEA410FE32330064D760 /* PBXTargetDependency */,
72E706FA0F42613A00142011 /* PBXTargetDependency */,
7256F1D10F411D080022BE1F /* PBXTargetDependency */,
@@ -2230,6 +2230,13 @@
remoteGlobalIDString = 721597EA1052B46D003D1610;
remoteInfo = qgis_analysis;
+ 7217CEA310FE32330064D760 /* PBXContainerItemProxy */ = {
+ isa = PBXContainerItemProxy;
+ containerPortal = 20286C28FDCF999611CA2CEA /* Project object */;
+ proxyType = 1;
+ remoteGlobalIDString = 729BBEFE0F40770B001BCB63 /* qgis_help app */;
+ remoteInfo = "qgis_help app";
7223B7A50F96AA6C00D905B4 /* PBXContainerItemProxy */ = {
@@ -2244,13 +2251,6 @@
remoteGlobalIDString = 7225EF1710B2265A00D23EA2;
remoteInfo = labelingplugin;
- 7249EBF210E7C0E200708435 /* PBXContainerItemProxy */ = {
- isa = PBXContainerItemProxy;
- containerPortal = 20286C28FDCF999611CA2CEA /* Project object */;
- proxyType = 1;
- remoteGlobalIDString = 7249EBD610E7BBEA00708435;
- remoteInfo = qgis_help;
7256F18F0F411B110022BE1F /* PBXContainerItemProxy */ = {
@@ -14444,7 +14444,7 @@
runOnlyForDeploymentPostprocessing = 0;
shellPath = /bin/sh;
- shellScript = "install_name_tool -change @executable_path/$QGIS_LIB_SUBDIR/libqgis_core.dylib @executable_path/../../../../$QGIS_LIB_SUBDIR/libqgis_core.dylib \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/MacOS/$PRODUCT_NAME\"\n\n# so Qt doesn't get confused with installed Qt, symlinks in qgis_help Frameworks\n# works better than @executable_paths all the way down to Qgis frameworks\n\nln -sfh ../../../../Frameworks $CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents\n\n#mkdir -p \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Frameworks\"\n\n#qtlist=\"QtCore QtGui QtNetwork QtSql QtSvg QtXml\"\n#for q in $qtlist\n#do\n#\tln -sfh ../../../../../Frameworks/$q.framework $CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Frameworks\n#done\n\n# and don't forget the qt.conf\n\nmkdir -p \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Resources\"\ntouch \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Resources/qt.conf\"\n\nexit 0\n";
+ shellScript = "install_name_tool -change @executable_path/$QGIS_LIB_SUBDIR/libqgis_core.dylib @executable_path/../../../../$QGIS_LIB_SUBDIR/libqgis_core.dylib \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/MacOS/$PRODUCT_NAME\"\n\n# so Qt doesn't get confused with installed Qt, symlink to Qgis Frameworks\n# works better than @executable_paths all the way down to Qgis frameworks\n\nln -sfh ../../../../Frameworks $CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents\n\n# and don't forget the qt.conf\n\nmkdir -p \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Resources\"\ntouch \"$CONFIGURATION_BUILD_DIR/$PRODUCT_NAME.app/Contents/Resources/qt.conf\"\n\nexit 0\n";
showEnvVarsInLog = 0;
72E70A950F427FC100142011 /* Script - bundle Qt */ = {
@@ -14459,7 +14459,7 @@
- shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"/Library/Frameworks/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tfi\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls *.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tqq=\"$q.framework/Versions/$QT_FWVER/$q\"\n\t# app\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/Qgis\"\n\t# qgis_help\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/qgis_help\"\n\t# libs\n\tfor ql in $qgliblist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\tdone\n\t# plugins\n\tfor qp in $pluglist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\tdone\n\t# qt fw\n\tfor qf in $QTLISTQG\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\tdone\n\t# qt plugs\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t# PyQt\n\tif [ \"$PYSITE\" ] ; then\n\t\tfor pq in $PYQTLIST\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\tdone\n\t\tfor pg in $qgpylist\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/qgis/$pg\"\n\t\tdone\n\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\tfor pw in _iqt Qwt\n\t\t\tdo\n\t\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\tdone\n\t\tfi\n\tfi\ndone\n";
+ shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"/Library/Frameworks/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto $QARCHS \"/Library/Frameworks/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tfi\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls *.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tqq=\"$q.framework/Versions/$QT_FWVER/$q\"\n\t# app\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/Qgis\"\n\t# qgis_help qt linking done with symlinks\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t# libs\n\tfor ql in $qgliblist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\tdone\n\t# plugins\n\tfor qp in $pluglist\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\tdone\n\t# qt fw\n\tfor qf in $QTLISTQG\n\tdo\n\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\tdone\n\t# qt plugs\n\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t# PyQt\n\tif [ \"$PYSITE\" ] ; then\n\t\tfor pq in $PYQTLIST\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\tdone\n\t\tfor pg in $qgpylist\n\t\tdo\n\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/qgis/$pg\"\n\t\tdone\n\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\tfor pw in _iqt Qwt\n\t\t\tdo\n\t\t\t\tinstall_name_tool -change $qq @executable_path/$QGIS_FW_SUBDIR/$qq \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\tdone\n\t\tfi\n\tfi\ndone\n";
72FB0B4B0FFD680F0052360B /* Script - ui */ = {
@@ -15509,6 +15509,11 @@
target = 721597EA1052B46D003D1610 /* qgis_analysis */;
targetProxy = 721598601052D6B4003D1610 /* PBXContainerItemProxy */;
+ 7217CEA410FE32330064D760 /* PBXTargetDependency */ = {
+ isa = PBXTargetDependency;
+ target = 729BBEFE0F40770B001BCB63 /* qgis_help app */;
+ targetProxy = 7217CEA310FE32330064D760 /* PBXContainerItemProxy */;
7223B7A60F96AA6C00D905B4 /* PBXTargetDependency */ = {
target = 7223B77E0F96A96500D905B4 /* oracleplugin */;
@@ -15519,11 +15524,6 @@
target = 7225EF1710B2265A00D23EA2 /* labelingplugin */;
targetProxy = 7225EF2F10B2273D00D23EA2 /* PBXContainerItemProxy */;
- 7249EBF310E7C0E200708435 /* PBXTargetDependency */ = {
- isa = PBXTargetDependency;
- target = 7249EBD610E7BBEA00708435 /* qgis_help */;
- targetProxy = 7249EBF210E7C0E200708435 /* PBXContainerItemProxy */;
7256F1900F411B110022BE1F /* PBXTargetDependency */ = {
target = 72A07D140F3BD625004FC2A4 /* delimitedtextprovider */;
