[QGIS Commit] r12762 - trunk/qgis/src/core/symbology-ng
svn_qgis at osgeo.org
Thu Jan 14 13:33:25 EST 2010
Author: wonder
Date: 2010-01-14 13:33:24 -0500 (Thu, 14 Jan 2010)
New Revision: 12762
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.cpp
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h
Refactored output unit encoding/decoding to their own functions
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.cpp 2010-01-14 18:20:34 UTC (rev 12761)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.cpp 2010-01-14 18:33:24 UTC (rev 12762)
@@ -148,6 +148,34 @@
return QPointF( lst[0].toDouble(), lst[1].toDouble() );
+QString QgsSymbolLayerV2Utils::encodeOutputUnit( QgsSymbolV2::OutputUnit unit )
+ switch ( unit )
+ case QgsSymbolV2::MM:
+ return "MM";
+ case QgsSymbolV2::MapUnit:
+ return "MapUnit";
+ default:
+ return "MM";
+QgsSymbolV2::OutputUnit QgsSymbolLayerV2Utils::decodeOutputUnit( QString str )
+ if ( str == "MM" )
+ return QgsSymbolV2::MM;
+ else if ( str == "MapUnit" )
+ return QgsSymbolV2::MapUnit;
+ // milimeters are default
QIcon QgsSymbolLayerV2Utils::symbolPreviewIcon( QgsSymbolV2* symbol, QSize size )
return QIcon( symbolPreviewPixmap( symbol, size ) );
@@ -343,7 +371,6 @@
QString symbolType = element.attribute( "type" );
- QString unitString = element.attribute( "outputUnit", "MM" );
QgsSymbolV2* symbol = 0;
if ( symbolType == "line" )
@@ -358,14 +385,8 @@
return NULL;
- if ( unitString == "MM" )
- symbol->setOutputUnit( QgsSymbolV2::MM );
- else
- symbol->setOutputUnit( QgsSymbolV2::MapUnit );
+ symbol->setOutputUnit( decodeOutputUnit( element.attribute( "outputUnit" ) ) );
return symbol;
@@ -409,12 +430,7 @@
QDomElement symEl = doc.createElement( "symbol" );
symEl.setAttribute( "type", _nameForSymbolType( symbol->type() ) );
symEl.setAttribute( "name", name );
- QString unitString = "MM";
- if ( symbol->outputUnit() == QgsSymbolV2::MapUnit )
- unitString = "MapUnit";
- symEl.setAttribute( "outputUnit", unitString );
+ symEl.setAttribute( "outputUnit", encodeOutputUnit( symbol->outputUnit() ) );
QgsDebugMsg( "num layers " + QString::number( symbol->symbolLayerCount() ) );
for ( int i = 0; i < symbol->symbolLayerCount(); i++ )
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h 2010-01-14 18:20:34 UTC (rev 12761)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2utils.h 2010-01-14 18:33:24 UTC (rev 12762)
@@ -44,6 +44,9 @@
static QString encodePoint( QPointF point );
static QPointF decodePoint( QString str );
+ static QString encodeOutputUnit( QgsSymbolV2::OutputUnit unit );
+ static QgsSymbolV2::OutputUnit decodeOutputUnit( QString str );
static QIcon symbolPreviewIcon( QgsSymbolV2* symbol, QSize size );
static QIcon symbolLayerPreviewIcon( QgsSymbolLayerV2* layer, QgsSymbolV2::OutputUnit u, QSize size );
static QIcon colorRampPreviewIcon( QgsVectorColorRampV2* ramp, QSize size );
