[QGIS Commit] r12773 - in trunk/qgis/src/ui: . symbollayer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jan 15 20:05:44 EST 2010
Author: wonder
Date: 2010-01-15 20:05:44 -0500 (Fri, 15 Jan 2010)
New Revision: 12773
   trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui
   trunk/qgis/src/ui/symbollayer/widget_markerline.ui
   trunk/qgis/src/ui/symbollayer/widget_simplefill.ui
   trunk/qgis/src/ui/symbollayer/widget_simpleline.ui
   trunk/qgis/src/ui/symbollayer/widget_simplemarker.ui
   trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui
Increased precision of spin boxes for size/width to 2 decimals
Modified: trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui
--- trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/qgssymbolv2selectordialogbase.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -105,7 +105,7 @@
            <item row="1" column="1">
             <widget class="QDoubleSpinBox" name="spinSize">
              <property name="decimals">
-              <number>1</number>
+              <number>2</number>
              </property>
              <property name="value">
               <double>1.000000000000000</double>
@@ -166,7 +166,7 @@
             <widget class="QDoubleSpinBox" name="spinWidth">
              </property>
Modified: trunk/qgis/src/ui/symbollayer/widget_markerline.ui
--- trunk/qgis/src/ui/symbollayer/widget_markerline.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/symbollayer/widget_markerline.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -70,7 +70,7 @@
      <item row="3" column="1">
       <widget class="QDoubleSpinBox" name="spinOffset">
        </property>
        <property name="minimum">
         <double>-100000.000000000000000</double>
@@ -83,7 +83,7 @@
       <widget class="QDoubleSpinBox" name="spinInterval">
        </property>
        <property name="maximum">
         <double>100000.000000000000000</double>
Modified: trunk/qgis/src/ui/symbollayer/widget_simplefill.ui
--- trunk/qgis/src/ui/symbollayer/widget_simplefill.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/symbollayer/widget_simplefill.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -90,7 +90,7 @@
      <item row="4" column="1">
       <widget class="QDoubleSpinBox" name="spinBorderWidth">
        </property>
Modified: trunk/qgis/src/ui/symbollayer/widget_simpleline.ui
--- trunk/qgis/src/ui/symbollayer/widget_simpleline.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/symbollayer/widget_simpleline.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -82,7 +82,7 @@
         <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
        </property>
        </property>
@@ -104,7 +104,7 @@
        </property>
        </property>
Modified: trunk/qgis/src/ui/symbollayer/widget_simplemarker.ui
--- trunk/qgis/src/ui/symbollayer/widget_simplemarker.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/symbollayer/widget_simplemarker.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -99,7 +99,7 @@
        <item>
         <widget class="QDoubleSpinBox" name="spinOffsetX">
          </property>
           <double>-100.000000000000000</double>
@@ -109,7 +109,7 @@
        <item>
         <widget class="QDoubleSpinBox" name="spinOffsetY">
          </property>
@@ -121,7 +121,7 @@
      <item row="2" column="1">
        </property>
Modified: trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui
--- trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui	2010-01-16 00:59:47 UTC (rev 12772)
+++ trunk/qgis/src/ui/symbollayer/widget_svgmarker.ui	2010-01-16 01:05:44 UTC (rev 12773)
@@ -67,7 +67,7 @@
        <item>
          </property>
@@ -80,7 +80,7 @@
        <item>
          </property>
@@ -108,7 +108,7 @@
         </sizepolicy>
        </property>
        </property>
More information about the QGIS-commit mailing list
