[QGIS Commit] r12786 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jan 16 16:09:23 EST 2010
Author: kyngchaos
Date: 2010-01-16 16:09:22 -0500 (Sat, 16 Jan 2010)
New Revision: 12786
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
   trunk/qgis/mac/xcode/ReadMe.rtf
   trunk/qgis/mac/xcode/qgis_settings.xcconfig
   trunk/qgis/mac/xcode/qgis_user-template.xcconfig
missed sip include dir
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-01-16 20:20:34 UTC (rev 12785)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-01-16 21:09:22 UTC (rev 12786)
@@ -16228,6 +16228,7 @@
 					../../src/core,
 					../../src/core/spatialindex,
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GEOS_INC)",
 				LIBRARY_SEARCH_PATHS = "$(QGIS_BUILD_PATH)/MacOS/$(QGIS_LIB_SUBDIR)";
@@ -16260,6 +16261,7 @@
 					../../src/core,
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GEOS_INC)",
@@ -16296,6 +16298,7 @@
 					../../src/core/symbology,
 					"../../src/core/symbology-ng",
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GDAL_INC)",
 					"$(GEOS_INC)",
@@ -16334,6 +16337,7 @@
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GDAL_INC)",
 					"$(GEOS_INC)",
@@ -16375,6 +16379,7 @@
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GDAL_INC)",
 					"$(GEOS_INC)",
@@ -16416,6 +16421,7 @@
 					"$(PYTHON_INC)",
+					"$(SIP_INC)",
 					"$(GDAL_INC)",
 					"$(GEOS_INC)",
Modified: trunk/qgis/mac/xcode/ReadMe.rtf
--- trunk/qgis/mac/xcode/ReadMe.rtf	2010-01-16 20:20:34 UTC (rev 12785)
+++ trunk/qgis/mac/xcode/ReadMe.rtf	2010-01-16 21:09:22 UTC (rev 12786)
@@ -215,14 +215,25 @@
 \f1\fs20 /Library/Frameworks
 \f0\fs24  install.  But the system Python has a user location for Python modules, and programs should be installed elsewhere, like /usr/local/bin (follow the Qgis install instructions for SIP/PyQt).\
-PYQT_SIP_DIR and PYQT_SIP_FLAGS are set for a system SIP/PyQt install as described in INSTALL.  They should be adjusted for other configurations.  These can be found by starting Python (the desired Python for the Qgis build) in a Terminal, then:\
+\pard\tx720\tx1440\tx2160\tx2880\tx3600\tx4320\tx5040\tx5760\tx6480\tx7200\tx7920\tx8640\ql\qnatural\pardirnatural
+\f1\fs20 \cf0 SIP_INC
+\f0\fs24 ,
+\f1\fs20 PYQT_SIP_DIR
+\f0\fs24  and
+\f1\fs20 PYQT_SIP_FLAGS
+\f0\fs24  are set for a system SIP/PyQt install as described in INSTALL.  They should be adjusted for other configurations.  These can be found by starting Python (the desired Python for the Qgis build) in a Terminal, then:\
-\f1\fs20 \cf0 	import PyQt4.pyqtconfig\
+\f1\fs20 \cf0 	import sipconfig\
+	sipconfig.Configuration().sip_inc_dir\
+\cf0 	import PyQt4.pyqtconfig\
 	PyQt4.pyqtconfig.Configuration().pyqt_sip_dir\
-	PyQt4.pyqtconfig.Configuration().pyqt_sip_flags\
+\cf0 	PyQt4.pyqtconfig.Configuration().pyqt_sip_flags\
 \f0\fs24 \cf0 \
 SIP/PyQt utility programs are found with the
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-01-16 20:20:34 UTC (rev 12785)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-01-16 21:09:22 UTC (rev 12786)
@@ -42,6 +42,8 @@
 SIP = $(PYTHON_USRBIN)/sip
 PYUIC4 = $(PYTHON_USRBIN)/pyuic4
 PYRCC4 = $(PYTHON_USRBIN)/pyrcc4
+// from sipconfig.py
+SIP_INC = /usr/local/include
 // from pyqtconfig.py
 PYQT_SIP_DIR = /usr/local/share/sip/PyQt4
 PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_4_5_0 -x Py_v3 -g
Modified: trunk/qgis/mac/xcode/qgis_user-template.xcconfig
--- trunk/qgis/mac/xcode/qgis_user-template.xcconfig	2010-01-16 20:20:34 UTC (rev 12785)
+++ trunk/qgis/mac/xcode/qgis_user-template.xcconfig	2010-01-16 21:09:22 UTC (rev 12786)
@@ -27,6 +27,7 @@
 //QT_PLUGINS_DIR = /Developer/Applications/Qt/plugins
 //QTBIN = /Developer/Tools/Qt // bin dir
+//SIP_INC = /usr/local/include
 //PYQT_SIP_DIR = /usr/local/share/sip/PyQt4
 //PYQT_SIP_FLAGS = -x VendorID -t WS_MACX -x PyQt_NoPrintRangeBug -t Qt_4_5_0 -x Py_v3 -g
 //BISON = /usr/bin/bison // Tiger requires user-installed bison 2.3
More information about the QGIS-commit mailing list
