[QGIS Commit] r12793 - trunk/qgis/src/core/raster
svn_qgis at osgeo.org
Mon Jan 18 15:24:51 EST 2010
Author: ersts
Date: 2010-01-18 15:24:49 -0500 (Mon, 18 Jan 2010)
New Revision: 12793
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
-Patch for slowdown or segfault when zooming very far into rasters.
-Closes ticket #2268
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2010-01-18 18:08:52 UTC (rev 12792)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2010-01-18 20:24:49 UTC (rev 12793)
@@ -1533,6 +1533,15 @@
myRasterViewPort->drawableAreaXDim = static_cast<int>( fabs(( myRasterViewPort->clippedWidth / theQgsMapToPixel.mapUnitsPerPixel() * mGeoTransform[1] ) ) + 0.5 );
myRasterViewPort->drawableAreaYDim = static_cast<int>( fabs(( myRasterViewPort->clippedHeight / theQgsMapToPixel.mapUnitsPerPixel() * mGeoTransform[5] ) ) + 0.5 );
+ //the drawable area can start to get very very large when you get down displaying 2x2 or smaller, this is becasue
+ //theQgsMapToPixel.mapUnitsPerPixel() is less then 1,
+ //so we will just get the pixel data and then render these special cases differently in paintImageToCanvas()
+ if( 2 >= myRasterViewPort->clippedWidth && 2 >= myRasterViewPort->clippedHeight )
+ myRasterViewPort->drawableAreaXDim = myRasterViewPort->clippedWidth;
+ myRasterViewPort->drawableAreaYDim = myRasterViewPort->clippedHeight;
QgsDebugMsg( QString( "mapUnitsPerPixel = %1" ).arg( theQgsMapToPixel.mapUnitsPerPixel() ) );
QgsDebugMsg( QString( "mWidth = %1" ).arg( mWidth ) );
QgsDebugMsg( QString( "mHeight = %1" ).arg( mHeight ) );
@@ -5064,6 +5073,8 @@
QgsDebugMsg( "painting image to canvas from "
+ QString::number( paintXoffset ) + ", " + QString::number( paintYoffset )
+ " to "
@@ -5072,11 +5083,107 @@
+ QString::number( static_cast<int>( theRasterViewPort->topLeftPoint.y() + 0.5 ) )
- theQPainter->drawImage( static_cast<int>( theRasterViewPort->topLeftPoint.x() + 0.5 ),
- static_cast<int>( theRasterViewPort->topLeftPoint.y() + 0.5 ),
- *theImage,
- paintXoffset,
- paintYoffset );
+ //Catch special rendering cases
+ //INSTANCE: 1x1
+ if( 1 == theRasterViewPort->clippedWidth && 1 == theRasterViewPort->clippedHeight )
+ QColor myColor( theImage->pixel( 0, 0 ) );
+ myColor.setAlpha( qAlpha( theImage->pixel( 0, 0 ) ) );
+ theQPainter->fillRect( static_cast<int>( theRasterViewPort->topLeftPoint.x() + 0.5 ),
+ static_cast<int>( theRasterViewPort->topLeftPoint.y() + 0.5 ),
+ static_cast<int>( theRasterViewPort->bottomRightPoint.x() ),
+ static_cast<int>( theRasterViewPort->bottomRightPoint.y() ),
+ QBrush( myColor ) );
+ //1x2, 2x1 or 2x2
+ else if( 2 >= theRasterViewPort->clippedWidth && 2 >= theRasterViewPort->clippedHeight )
+ int myPixelBoundaryX = 0;
+ int myPixelBoundaryY = 0;
+ if( theQgsMapToPixel ) {
+ myPixelBoundaryX = static_cast<int>( theRasterViewPort->topLeftPoint.x() + 0.5 ) + static_cast<int>( fabs ( mGeoTransform[1] / theQgsMapToPixel->mapUnitsPerPixel() ) ) - paintXoffset;
+ myPixelBoundaryY = static_cast<int>( theRasterViewPort->topLeftPoint.y() + 0.5 ) + static_cast<int>( fabs(mGeoTransform[5] / theQgsMapToPixel->mapUnitsPerPixel() )) - paintYoffset;
+ //INSTANCE: 1x2
+ if( 1 == theRasterViewPort->clippedWidth ) {
+ static_cast<int>( myPixelBoundaryY ),
+ myColor = QColor( theImage->pixel( 0, 1) );
+ myColor.setAlpha( qAlpha( theImage->pixel( 0, 1 ) ) );
+ else {
+ //INSTANCE: 2x1
+ if( 1 == theRasterViewPort->clippedHeight )
+ myColor.setAlpha( qAlpha( theImage->pixel( 0,0 ) ) );
+ static_cast<int>( myPixelBoundaryX ),
+ myColor = QColor( theImage->pixel( 1, 0 ) );
+ myColor.setAlpha( qAlpha( theImage->pixel( 1, 0 ) ) );
+ theQPainter->fillRect( static_cast<int>( myPixelBoundaryX ),
+ //INSTANCE: 2x2
+ else
+ static_cast<int>(myPixelBoundaryX ),
+ myColor = QColor( theImage->pixel( 0, 1 ) );
+ myColor = QColor( theImage->pixel( 1, 1 ) );
+ myColor.setAlpha( qAlpha( theImage->pixel( 1, 1 ) ) );
+ // INSTANCE: > 2x2, so just use the image filled by GDAL
+ else {
+ theQPainter->drawImage( static_cast<int>( theRasterViewPort->topLeftPoint.x() + 0.5 ),
+ *theImage,
+ paintXoffset,
+ paintYoffset );
QString QgsRasterLayer::projectionWkt()
