[QGIS Commit] r12823 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jan 23 07:29:03 EST 2010
Author: timlinux
Date: 2010-01-23 07:29:02 -0500 (Sat, 23 Jan 2010)
New Revision: 12823
   trunk/qgis/src/ui/qgslabeldialogbase.ui
Label dialog: Remove the toolbox and use tabs and scroll areas rather
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui	2010-01-23 11:28:44 UTC (rev 12822)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui	2010-01-23 12:29:02 UTC (rev 12823)
@@ -21,853 +21,815 @@
   </property>
   <layout class="QVBoxLayout" name="verticalLayout">
    <item>
-    <widget class="QToolBox" name="toolBox">
+    <widget class="QTabWidget" name="tabWidget">
      <property name="currentIndex">
       <number>0</number>
      </property>
-     <widget class="QWidget" name="page">
-      <property name="geometry">
-       <rect>
-        <x>0</x>
-        <y>0</y>
-        <width>644</width>
-        <height>365</height>
-       </rect>
-      </property>
-      <attribute name="label">
-       <string>Basic label options and placement</string>
+     <widget class="QWidget" name="tab">
+      <attribute name="title">
+       <string>Label Properties</string>
       </attribute>
-      <widget class="QGroupBox" name="groupBox_8">
-        <rect>
-         <x>10</x>
-         <y>0</y>
-         <width>621</width>
-         <height>174</height>
-        </rect>
+      <layout class="QGridLayout" name="gridLayout">
+       <property name="margin">
+        <number>0</number>
        </property>
-       <property name="title">
-        <string>Basic label options</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout_8">
-        <item row="0" column="0">
-         <widget class="QLabel" name="textLabel5">
-          <property name="text">
-           <string>Field containing label</string>
-          </property>
-          <property name="buddy">
-           <cstring>cboLabelField</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="2">
-         <widget class="QComboBox" name="cboLabelField">
-          <property name="sizePolicy">
-           <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
-            <horstretch>1</horstretch>
-            <verstretch>0</verstretch>
-           </sizepolicy>
-          </property>
-         </widget>
-        </item>
-        <item row="1" column="0">
-         <widget class="QLabel" name="textLabel1">
-           <string>Default label</string>
-          </property>
-           <cstring>leDefaultLabel</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="1" column="2">
-         <widget class="QLineEdit" name="leDefaultLabel">
-            <horstretch>2</horstretch>
-           </sizepolicy>
-          </property>
-         </widget>
-        </item>
-        <item row="2" column="0">
-         <widget class="QPushButton" name="btnDefaultFont">
-           <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
-           </sizepolicy>
-          </property>
-           <string>Font</string>
-          </property>
-         </widget>
-        </item>
-        <item row="2" column="1">
-         <widget class="QLabel" name="textLabel5_2_2_3_2">
-           <string>Font size</string>
-          </property>
-          <property name="alignment">
-           <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
-          </property>
-           <cstring>spinFontSize</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="2" column="2">
-         <widget class="QDoubleSpinBox" name="spinFontSize">
-            <horstretch>0</horstretch>
-           </sizepolicy>
-          </property>
-          <property name="minimumSize">
-           <size>
-            <width>50</width>
-            <height>0</height>
-           </size>
-          </property>
-          <property name="decimals">
-           <number>6</number>
-          </property>
-          <property name="maximum">
-           <double>1000000.000000000000000</double>
-          </property>
-          <property name="value">
-           <double>0.000000000000000</double>
-          </property>
-         </widget>
-        </item>
-        <item row="3" column="0">
-         <widget class="QPushButton" name="pbnDefaultFontColor">
-           </sizepolicy>
-          </property>
-           <string>Color</string>
-          </property>
-         </widget>
-        </item>
-        <item row="3" column="1">
-         <widget class="QLabel" name="textLabel1_2_2_2_2_2">
-           <string>Angle (deg)</string>
-          </property>
-           <cstring>spinAngle</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="3" column="2">
-         <widget class="QSpinBox" name="spinAngle">
-          <property name="suffix">
-           <string>°</string>
-          </property>
-           <number>360</number>
-          </property>
-           <number>0</number>
-          </property>
-         </widget>
-        </item>
-        <item row="4" column="0">
-         <widget class="QCheckBox" name="chkUseMultiline">
-           <string>Multiline labels?</string>
-          </property>
-          <property name="checked">
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-       </layout>
-      </widget>
-      <widget class="QGroupBox" name="groupBox_2">
-        <rect>
-         <x>10</x>
-         <y>180</y>
-         <height>106</height>
-        </rect>
-       </property>
-        <string>Placement</string>
-       </property>
-       <layout class="QGridLayout">
-        <property name="margin">
-         <number>11</number>
-        </property>
-         <widget class="QRadioButton" name="radioBelowRight">
-           <string>Below Right</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioRight">
-           <string>Right</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioBelow">
-           <string>Below</string>
-          </property>
-         </widget>
-        </item>
-        <item row="1" column="1">
-         <widget class="QRadioButton" name="radioOver">
-           <string>Over</string>
-          </property>
-           <bool>true</bool>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="1">
-         <widget class="QRadioButton" name="radioAbove">
-           <string>Above</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioLeft">
-           <string>Left</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioBelowLeft">
-           <string>Below Left</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioAboveRight">
-           <string>Above Right</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QRadioButton" name="radioAboveLeft">
-           <string>Above Left</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
-      </widget>
-     </widget>
-     <widget class="QWidget" name="page_2">
-       <rect>
-        <x>0</x>
-        <y>0</y>
-       </rect>
-      </property>
-       <string>Scale dependent rendering, buffer labels, font size units and offset</string>
-      </attribute>
-      <layout class="QVBoxLayout" name="verticalLayout_2">
-       <item>
-        <widget class="QGroupBox" name="chkUseScaleDependentRendering">
-          <string>Use scale dependent rendering</string>
-         </property>
-         <property name="checkable">
+       <item row="0" column="0">
+        <widget class="QScrollArea" name="scrollArea">
+         <property name="widgetResizable">
           <bool>true</bool>
          </property>
+         <widget class="QWidget" name="scrollAreaWidgetContents">
+          <property name="geometry">
+           <rect>
+            <x>0</x>
+            <y>-296</y>
+            <width>621</width>
+            <height>740</height>
+           </rect>
           </property>
-           <widget class="QLabel" name="textLabel1_2_2_1">
-             <string>Maximum</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="textLabel1_1">
-             <string>Minimum</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLineEdit" name="leMinimumScale"/>
-          </item>
-          <item row="0" column="3">
-           <widget class="QLineEdit" name="leMaximumScale"/>
-          </item>
-         </layout>
-        </widget>
-       </item>
-       <item>
-        <widget class="QGroupBox" name="chkUseBuffer">
-         <property name="enabled">
-          <bool>true</bool>
-         </property>
-          <string>Buffer labels</string>
-         </property>
-          <bool>true</bool>
-         </property>
-          <bool>false</bool>
-         </property>
-         <layout class="QGridLayout" name="gridLayout_9">
-           <widget class="QLabel" name="textLabel4_3_2_2">
-             <string>Buffer size</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QDoubleSpinBox" name="spinBufferSize"/>
-          </item>
-           <widget class="QRadioButton" name="radioBufferUnitsPoints">
-             <string>Size is in points</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QRadioButton" name="radioBufferUnitsMap">
-             <string>Size is in map units</string>
-            </property>
-           </widget>
-          </item>
-           <widget class="QLabel" name="textLabel5_2_2_3">
-            </property>
-             <string>Transparency</string>
-            </property>
-            </property>
-           </widget>
-          </item>
-           <widget class="QSpinBox" name="spinBufferTransparency">
-            </property>
-             </sizepolicy>
-            </property>
-             <size>
-              <width>50</width>
-             </size>
-            </property>
-             <string>%</string>
-            </property>
-             <number>100</number>
-            </property>
-            </property>
-           </widget>
-          </item>
-           <widget class="QPushButton" name="pbnDefaultBufferColor_2">
-            </property>
-           </widget>
-          </item>
-         </layout>
-        </widget>
-       </item>
-       <item>
-        <layout class="QHBoxLayout" name="horizontalLayout_2">
-         <item>
-          <widget class="QGroupBox" name="groupBox_3">
-            <string>Font size units</string>
-           </property>
-           <layout class="QGridLayout" name="_2">
-             <widget class="QRadioButton" name="radioFontSizeUnitsPoints">
-               <string>Points</string>
+          <layout class="QGridLayout" name="gridLayout_2">
+            <widget class="QGroupBox" name="groupBox_8">
+             <property name="title">
+              <string>Basic label options</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_8">
+               <widget class="QLabel" name="textLabel5">
+                <property name="text">
+                 <string>Field containing label</string>
+                </property>
+                <property name="buddy">
+                 <cstring>cboLabelField</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="0" column="2">
+               <widget class="QComboBox" name="cboLabelField">
+                <property name="sizePolicy">
+                 <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+                  <horstretch>1</horstretch>
+                  <verstretch>0</verstretch>
+                 </sizepolicy>
+                </property>
+               </widget>
+              </item>
+              <item row="1" column="0">
+               <widget class="QLabel" name="textLabel1">
+                 <string>Default label</string>
+                </property>
+                 <cstring>leDefaultLabel</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="1" column="2">
+               <widget class="QLineEdit" name="leDefaultLabel">
+                  <horstretch>2</horstretch>
+                 </sizepolicy>
+                </property>
+               </widget>
+              </item>
+              <item row="2" column="0">
+               <widget class="QPushButton" name="btnDefaultFont">
+                 <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+                 </sizepolicy>
+                </property>
+                 <string>Font</string>
+                </property>
+               </widget>
+              </item>
+              <item row="2" column="1">
+               <widget class="QLabel" name="textLabel5_2_2_3_2">
+                 <string>Font size</string>
+                </property>
+                <property name="alignment">
+                 <set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignVCenter</set>
+                </property>
+                 <cstring>spinFontSize</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="2" column="2">
+               <widget class="QDoubleSpinBox" name="spinFontSize">
+                  <horstretch>0</horstretch>
+                 </sizepolicy>
+                </property>
+                <property name="minimumSize">
+                 <size>
+                  <width>50</width>
+                  <height>0</height>
+                 </size>
+                </property>
+                <property name="decimals">
+                 <number>6</number>
+                </property>
+                <property name="maximum">
+                 <double>1000000.000000000000000</double>
+                </property>
+                <property name="value">
+                 <double>0.000000000000000</double>
+                </property>
+               </widget>
+              </item>
+              <item row="3" column="0">
+               <widget class="QPushButton" name="pbnDefaultFontColor">
+                 </sizepolicy>
+                </property>
+                 <string>Color</string>
+                </property>
+               </widget>
+              </item>
+              <item row="3" column="1">
+               <widget class="QLabel" name="textLabel1_2_2_2_2_2">
+                 <string>Angle (deg)</string>
+                </property>
+                 <cstring>spinAngle</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="3" column="2">
+               <widget class="QSpinBox" name="spinAngle">
+                <property name="suffix">
+                 <string>°</string>
+                </property>
+                 <number>360</number>
+                </property>
+                </property>
+               </widget>
+              </item>
+              <item row="4" column="0">
+               <widget class="QCheckBox" name="chkUseMultiline">
+                 <string>Multiline labels?</string>
+                </property>
+                <property name="checked">
+                 <bool>true</bool>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="groupBox_2">
+              <string>Placement</string>
+             </property>
+             <layout class="QGridLayout" name="_5">
+               <number>11</number>
               </property>
-             </widget>
-            </item>
-             <widget class="QRadioButton" name="radioFontSizeUnitsMap">
-               <string>Map units</string>
+               <widget class="QRadioButton" name="radioBelowRight">
+                 <string>Below Right</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioRight">
+                 <string>Right</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioBelow">
+                 <string>Below</string>
+                </property>
+               </widget>
+              </item>
+              <item row="1" column="1">
+               <widget class="QRadioButton" name="radioOver">
+                 <string>Over</string>
+                </property>
+                 <bool>true</bool>
+                </property>
+               </widget>
+              </item>
+              <item row="0" column="1">
+               <widget class="QRadioButton" name="radioAbove">
+                 <string>Above</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioLeft">
+                 <string>Left</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioBelowLeft">
+                 <string>Below Left</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioAboveRight">
+                 <string>Above Right</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioAboveLeft">
+                 <string>Above Left</string>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="chkUseScaleDependentRendering">
+              <string>Use scale dependent rendering</string>
+             </property>
+             <property name="checkable">
+              <bool>true</bool>
+             </property>
+             <layout class="QGridLayout" name="_2">
               </property>
-             </widget>
-            </item>
-           </layout>
-          </widget>
-         </item>
-         <item>
-          <widget class="QGroupBox" name="buttonGroup10">
-            <string>Offset units</string>
-           </property>
-           <layout class="QGridLayout" name="gridLayout">
-             <widget class="QLabel" name="textLabel1_2_3_2">
-               <string>X Offset (pts)</string>
-              </property>
-             </widget>
-            </item>
-             <widget class="QDoubleSpinBox" name="spinXOffset">
-              <property name="minimum">
-               <double>-99.000000000000000</double>
-              </property>
-             </widget>
-            </item>
-             <widget class="QRadioButton" name="radioOffsetUnitsPoints">
-              </property>
-             </widget>
-            </item>
-             <widget class="QLabel" name="textLabel1_2_2_2_3">
-               <string>Y Offset (pts)</string>
-              </property>
-             </widget>
-            </item>
-             <widget class="QDoubleSpinBox" name="spinYOffset">
-              </property>
-             </widget>
-            </item>
-             <widget class="QRadioButton" name="radioOffsetUnitsMap">
-              </property>
-             </widget>
-            </item>
-           </layout>
-          </widget>
-         </item>
-        </layout>
+               <widget class="QLabel" name="textLabel1_2_2_1">
+                 <string>Maximum</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QLabel" name="textLabel1_1">
+                 <string>Minimum</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QLineEdit" name="leMinimumScale"/>
+              </item>
+              <item row="0" column="3">
+               <widget class="QLineEdit" name="leMaximumScale"/>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="chkUseBuffer">
+             <property name="enabled">
+              <bool>true</bool>
+             </property>
+              <string>Buffer labels</string>
+             </property>
+              <bool>true</bool>
+             </property>
+              <bool>false</bool>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_9">
+               <widget class="QLabel" name="textLabel4_3_2_2">
+                 <string>Buffer size</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QDoubleSpinBox" name="spinBufferSize"/>
+              </item>
+               <widget class="QRadioButton" name="radioBufferUnitsPoints">
+                 <string>Size is in points</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioBufferUnitsMap">
+                 <string>Size is in map units</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QLabel" name="textLabel5_2_2_3">
+                </property>
+                 <string>Transparency</string>
+                </property>
+                </property>
+               </widget>
+              </item>
+               <widget class="QSpinBox" name="spinBufferTransparency">
+                </property>
+                 </sizepolicy>
+                </property>
+                 <size>
+                  <width>50</width>
+                 </size>
+                </property>
+                 <string>%</string>
+                </property>
+                 <number>100</number>
+                </property>
+                </property>
+               </widget>
+              </item>
+               <widget class="QPushButton" name="pbnDefaultBufferColor_2">
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="groupBox_3">
+              <string>Font size units</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_3">
+               <widget class="QRadioButton" name="radioFontSizeUnitsPoints">
+                 <string>Points</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioFontSizeUnitsMap">
+                 <string>Map units</string>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+           <item row="5" column="0">
+            <widget class="QGroupBox" name="buttonGroup10">
+              <string>Offset units</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_4">
+               <widget class="QRadioButton" name="radioOffsetUnitsPoints">
+                </property>
+               </widget>
+              </item>
+               <widget class="QRadioButton" name="radioOffsetUnitsMap">
+                </property>
+               </widget>
+              </item>
+               <widget class="QDoubleSpinBox" name="spinXOffset">
+                <property name="prefix">
+                 <string>X offset </string>
+                </property>
+                 <string> points</string>
+                </property>
+                <property name="minimum">
+                 <double>-99.000000000000000</double>
+                </property>
+               </widget>
+              </item>
+               <widget class="QDoubleSpinBox" name="spinYOffset">
+                 <string>Y offset </string>
+                </property>
+                </property>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+          </layout>
+         </widget>
+        </widget>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="page_3">
-       <rect>
-        <x>0</x>
-        <y>0</y>
-       </rect>
-      </property>
-       <string>Data defined settings (placement and properties)</string>
+     <widget class="QWidget" name="tab_2">
+       <string>Advanced</string>
       </attribute>
-      <widget class="QGroupBox" name="groupBox_5">
-        <rect>
-         <x>10</x>
-         <y>0</y>
-         <height>84</height>
-        </rect>
+      <layout class="QGridLayout" name="gridLayout_5">
        </property>
-        <string>Data defined placement</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout_4">
-         <widget class="QLabel" name="textLabel1_2_2_2_2_3">
-           </sizepolicy>
+        <widget class="QScrollArea" name="scrollArea_2">
+          <bool>true</bool>
+         </property>
+         <widget class="QWidget" name="scrollAreaWidgetContents_2">
+           <rect>
+            <x>0</x>
+            <y>0</y>
+            <height>684</height>
+           </rect>
           </property>
-          </property>
+          <layout class="QGridLayout" name="gridLayout_7">
+            <widget class="QGroupBox" name="groupBox_5">
+              <string>Data defined placement</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_6">
+               <widget class="QLabel" name="textLabel1_2_2_2_2_3">
+                 </sizepolicy>
+                </property>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboAlignmentField"/>
+              </item>
+               <widget class="QLabel" name="textLabel1_2_2_2_2">
+                 </sizepolicy>
+                </property>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboAngleField"/>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="groupBox">
+              <string>Data defined properties</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_10">
+               <widget class="QLabel" name="lblFont">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Font family</string>
+                </property>
+                 <cstring>cboFontField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboFontField"/>
+              </item>
+               <widget class="QLabel" name="textLabel4">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Bold</string>
+                </property>
+                 <cstring>cboBoldField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboBoldField"/>
+              </item>
+               <widget class="QLabel" name="textLabel4_2_4">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Italic</string>
+                </property>
+                 <cstring>cboItalicField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboItalicField"/>
+              </item>
+               <widget class="QLabel" name="textLabel4_3">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Underline</string>
+                </property>
+                 <cstring>cboUnderlineField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboUnderlineField"/>
+              </item>
+              <item row="6" column="0">
+               <widget class="QLabel" name="textLabel4_3_2">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Size</string>
+                </property>
+                 <cstring>cboFontSizeField</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="6" column="1">
+               <widget class="QComboBox" name="cboFontSizeField"/>
+              </item>
+              <item row="7" column="0">
+               <widget class="QLabel" name="textLabel4_3_2_4">
+                 </sizepolicy>
+                </property>
+                 <string>Size units</string>
+                </property>
+                 <cstring>cboFontSizeTypeField</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="7" column="1">
+               <widget class="QComboBox" name="cboFontSizeTypeField"/>
+              </item>
+              <item row="8" column="0">
+               <widget class="QLabel" name="textLabel4_3_2_5">
+                 </sizepolicy>
+                </property>
+                 <string>&amp;Color</string>
+                </property>
+                 <cstring>cboFontColorField</cstring>
+                </property>
+               </widget>
+              </item>
+              <item row="8" column="1">
+               <widget class="QComboBox" name="cboFontColorField"/>
+              </item>
+              <item row="4" column="1">
+               <widget class="QComboBox" name="cboStrikeOutField"/>
+              </item>
+               <widget class="QLabel" name="label">
+                 <string>Strikeout</string>
+                </property>
+               </widget>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="groupBox_6">
+              <string>Data defined buffer</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_11">
+               <widget class="QLabel" name="textLabel1_3_2_2_2">
+                </property>
+                 </sizepolicy>
+                </property>
+                 <size>
+                  <width>70</width>
+                 </size>
+                </property>
+                 <string>Transparency:</string>
+                </property>
+                 <cstring>cboBufferTransparencyField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboBufferTransparencyField">
+                </property>
+               </widget>
+              </item>
+               <widget class="QLabel" name="textLabel4_3_2_2_2">
+                 </sizepolicy>
+                </property>
+                 <string>Size:</string>
+                </property>
+                 <cstring>cboBufferSizeField</cstring>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboBufferSizeField"/>
+              </item>
+             </layout>
+            </widget>
+           </item>
+            <widget class="QGroupBox" name="groupBox_7">
+              <string>Data defined position</string>
+             </property>
+             <layout class="QGridLayout" name="gridLayout_12">
+               <widget class="QLabel" name="textLabel1_2">
+                 </sizepolicy>
+                </property>
+                 <string>X Coordinate</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboXCoordinateField"/>
+              </item>
+               <widget class="QLabel" name="textLabel1_2_2">
+                 </sizepolicy>
+                </property>
+                 <string>Y Coordinate</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboYCoordinateField"/>
+              </item>
+               <widget class="QLabel" name="textLabel1_2_3">
+                 </sizepolicy>
+                </property>
+                 <string>X Offset (pts)</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboXOffsetField"/>
+              </item>
+               <widget class="QLabel" name="textLabel1_2_2_2">
+                 </sizepolicy>
+                </property>
+                 <string>Y Offset (pts)</string>
+                </property>
+               </widget>
+              </item>
+               <widget class="QComboBox" name="cboYOffsetField"/>
+              </item>
+             </layout>
+            </widget>
+           </item>
+          </layout>
          </widget>
-        </item>
-         <widget class="QComboBox" name="cboAlignmentField"/>
-        </item>
-         <widget class="QLabel" name="textLabel1_2_2_2_2">
-           </sizepolicy>
-          </property>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboAngleField"/>
-        </item>
-       </layout>
-      </widget>
-      <widget class="QGroupBox" name="groupBox">
-        <rect>
-         <x>10</x>
-         <y>90</y>
-         <height>246</height>
-        </rect>
-       </property>
-        <string>Data defined properties</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout_3">
-         <widget class="QLabel" name="lblFont">
-           </sizepolicy>
-          </property>
-           <string>&amp;Font family</string>
-          </property>
-           <cstring>cboFontField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboFontField"/>
-        </item>
-         <widget class="QLabel" name="textLabel4">
-           </sizepolicy>
-          </property>
-           <string>&amp;Bold</string>
-          </property>
-           <cstring>cboBoldField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboBoldField"/>
-        </item>
-         <widget class="QLabel" name="textLabel4_2_4">
-           </sizepolicy>
-          </property>
-           <string>&amp;Italic</string>
-          </property>
-           <cstring>cboItalicField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboItalicField"/>
-        </item>
-         <widget class="QLabel" name="textLabel4_3">
-           </sizepolicy>
-          </property>
-           <string>&amp;Underline</string>
-          </property>
-           <cstring>cboUnderlineField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboUnderlineField"/>
-        </item>
-        <item row="6" column="0">
-         <widget class="QLabel" name="textLabel4_3_2">
-           </sizepolicy>
-          </property>
-           <string>&amp;Size</string>
-          </property>
-           <cstring>cboFontSizeField</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="6" column="1">
-         <widget class="QComboBox" name="cboFontSizeField"/>
-        </item>
-        <item row="7" column="0">
-         <widget class="QLabel" name="textLabel4_3_2_4">
-           </sizepolicy>
-          </property>
-           <string>Size units</string>
-          </property>
-           <cstring>cboFontSizeTypeField</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="7" column="1">
-         <widget class="QComboBox" name="cboFontSizeTypeField"/>
-        </item>
-        <item row="8" column="0">
-         <widget class="QLabel" name="textLabel4_3_2_5">
-           </sizepolicy>
-          </property>
-           <string>&amp;Color</string>
-          </property>
-           <cstring>cboFontColorField</cstring>
-          </property>
-         </widget>
-        </item>
-        <item row="8" column="1">
-         <widget class="QComboBox" name="cboFontColorField"/>
-        </item>
-        <item row="4" column="1">
-         <widget class="QComboBox" name="cboStrikeOutField"/>
-        </item>
-         <widget class="QLabel" name="label">
-           <string>Strikeout</string>
-          </property>
-         </widget>
-        </item>
-       </layout>
-      </widget>
+        </widget>
+       </item>
+      </layout>
      </widget>
-     <widget class="QWidget" name="page_4">
-       <rect>
-        <x>0</x>
-        <y>0</y>
-       </rect>
-      </property>
-       <string>Data defined settings: buffer and position</string>
-      </attribute>
-      <widget class="QGroupBox" name="groupBox_6">
-        <rect>
-         <x>10</x>
-         <y>0</y>
-        </rect>
-       </property>
-        <string>Data defined buffer</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout_5">
-         <widget class="QLabel" name="textLabel1_3_2_2_2">
-          </property>
-           </sizepolicy>
-          </property>
-           <size>
-            <width>70</width>
-           </size>
-          </property>
-           <string>Transparency:</string>
-          </property>
-           <cstring>cboBufferTransparencyField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboBufferTransparencyField">
-          </property>
-         </widget>
-        </item>
-         <widget class="QLabel" name="textLabel4_3_2_2_2">
-           </sizepolicy>
-          </property>
-           <string>Size:</string>
-          </property>
-           <cstring>cboBufferSizeField</cstring>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboBufferSizeField"/>
-        </item>
-       </layout>
-      </widget>
-      <widget class="QGroupBox" name="groupBox_7">
-        <rect>
-         <x>10</x>
-         <y>90</y>
-         <height>138</height>
-        </rect>
-       </property>
-        <string>Data defined position</string>
-       </property>
-       <layout class="QGridLayout" name="gridLayout_6">
-         <widget class="QLabel" name="textLabel1_2">
-           </sizepolicy>
-          </property>
-           <string>X Coordinate</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboXCoordinateField"/>
-        </item>
-         <widget class="QLabel" name="textLabel1_2_2">
-           </sizepolicy>
-          </property>
-           <string>Y Coordinate</string>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboYCoordinateField"/>
-        </item>
-         <widget class="QLabel" name="textLabel1_2_3">
-           </sizepolicy>
-          </property>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboXOffsetField"/>
-        </item>
-         <widget class="QLabel" name="textLabel1_2_2_2">
-           </sizepolicy>
-          </property>
-          </property>
-         </widget>
-        </item>
-         <widget class="QComboBox" name="cboYOffsetField"/>
-        </item>
-       </layout>
-      </widget>
-     </widget>
     </widget>
    </item>
    <item>
@@ -904,47 +866,6 @@
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11"/>
- <tabstops>
-  <tabstop>cboLabelField</tabstop>
-  <tabstop>leDefaultLabel</tabstop>
-  <tabstop>btnDefaultFont</tabstop>
-  <tabstop>spinFontSize</tabstop>
-  <tabstop>pbnDefaultFontColor</tabstop>
-  <tabstop>spinAngle</tabstop>
-  <tabstop>chkUseMultiline</tabstop>
-  <tabstop>radioAboveLeft</tabstop>
-  <tabstop>radioAbove</tabstop>
-  <tabstop>radioAboveRight</tabstop>
-  <tabstop>radioLeft</tabstop>
-  <tabstop>radioOver</tabstop>
-  <tabstop>radioRight</tabstop>
-  <tabstop>radioBelowLeft</tabstop>
-  <tabstop>radioBelow</tabstop>
-  <tabstop>radioBelowRight</tabstop>
-  <tabstop>leMinimumScale</tabstop>
-  <tabstop>leMaximumScale</tabstop>
-  <tabstop>pbnDefaultBufferColor_2</tabstop>
-  <tabstop>spinBufferSize</tabstop>
-  <tabstop>radioBufferUnitsPoints</tabstop>
-  <tabstop>radioBufferUnitsMap</tabstop>
-  <tabstop>spinBufferTransparency</tabstop>
-  <tabstop>cboAlignmentField</tabstop>
-  <tabstop>cboAngleField</tabstop>
-  <tabstop>cboFontField</tabstop>
-  <tabstop>cboBoldField</tabstop>
-  <tabstop>cboItalicField</tabstop>
-  <tabstop>cboUnderlineField</tabstop>
-  <tabstop>cboFontSizeField</tabstop>
-  <tabstop>cboFontSizeTypeField</tabstop>
-  <tabstop>cboStrikeOutField</tabstop>
-  <tabstop>cboFontColorField</tabstop>
-  <tabstop>cboBufferTransparencyField</tabstop>
-  <tabstop>cboBufferSizeField</tabstop>
-  <tabstop>cboXCoordinateField</tabstop>
-  <tabstop>cboYCoordinateField</tabstop>
-  <tabstop>cboXOffsetField</tabstop>
-  <tabstop>cboYOffsetField</tabstop>
- </tabstops>
  <resources/>
  <connections/>
 </ui>
More information about the QGIS-commit mailing list
