[QGIS Commit] r12842 - in docs/trunk/english_us/user_guide: . images
svn_qgis at osgeo.org
Thu Jan 28 09:15:18 EST 2010
Author: dassau
Date: 2010-01-28 09:15:18 -0500 (Thu, 28 Jan 2010)
New Revision: 12842
Added:
docs/trunk/english_us/user_guide/images/mActionAddArrow.png
docs/trunk/english_us/user_guide/images/mActionAddBasicShape.png
docs/trunk/english_us/user_guide/images/mActionAddImage.png
docs/trunk/english_us/user_guide/images/mActionArrowDown.png
docs/trunk/english_us/user_guide/images/mActionArrowUp.png
docs/trunk/english_us/user_guide/images/mActionCalculateField.png
docs/trunk/english_us/user_guide/images/mActionComposerManager.png
docs/trunk/english_us/user_guide/images/mActionDeselectAll.png
docs/trunk/english_us/user_guide/images/mActionFromSelectedFeature.png
docs/trunk/english_us/user_guide/images/mActionNewComposer.png
docs/trunk/english_us/user_guide/images/mActionRemoveSelectedFeature.png
docs/trunk/english_us/user_guide/images/mActionRotatePointSymbols.png
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/images/Makefile
docs/trunk/english_us/user_guide/images/mActionSaveMapAsImage.png
started to update features at a glance section
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-01-28 11:49:44 UTC (rev 12841)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-01-28 14:15:18 UTC (rev 12842)
@@ -39,7 +39,7 @@
\small
\begin{verbatim}
qgis --help
-Quantum GIS - 1.3.0-Mimas 'Mimas' (exported)
+Quantum GIS - 1.4.0-Enceladus 'Enceladus' (exported)
Quantum GIS (QGIS) is a viewer for spatial data sets, including
raster and vector data.
Usage: qgis [options] [FILES]
@@ -87,8 +87,8 @@
to change your language, you can specify a language code. For example:
\usertext{---lang=it}
starts QGIS in italian localization. A list of currently supported
-languages with language code is provided at
-\url{http://wiki.qgis.org/qgiswiki/TranslatorsCorner}
+languages with language code and status is provided at
+\url{http://www.qgis.org/wiki/GUI_Translation_Progress}
\minisec{Command line option \usertext{---project}}
Starting QGIS with an existing project file is also possible. Just
@@ -138,14 +138,16 @@
The menu bar provides access to various QGIS features using a standard
hierarchical menu. The top-level menus and a summary of some of the
-menu options are listed below, together with the icons of the corresponding
-tools as they appear on the toolbar, as well as keyboard shortcuts.\footnote{Keyboard shortcuts can
-now be configured manually (shortcuts presented in this section are the defaults), using the Configure
+menu options are listed below, together with the icons of the corresponding
+tools as they appear on the toolbar, as well as keyboard
+shortcuts.\footnote{Keyboard shortcuts can now be configured manually
+(shortcuts presented in this section are the defaults), using the Configure
Shortcuts tool under Settings Menu.}
Although most menu options have a corresponding tool and vice-versa,
the menus are not organized quite like the toolbars.
The toolbar containing the tool is listed after each menu option as a checkbox
-entry. For more information about tools and toolbars, see Section \ref{label_toolbars}.
+entry. For more information about tools and toolbars, see Section
+\ref{label_toolbars}.
\begin{tabbing}
\hspace{5.5cm}\=\hspace{3cm}\=\hspace{3.5cm}\= \kill
@@ -178,10 +180,17 @@
\dropmenuopttwo{mActionSaveMapAsImage}{Save as Image}
\> see Section \ref{sec:output} \\
-\dropmenuopttwo{mActionFilePrint}{Print Composer}
- \> \keystroke{Ctrl+P}
+\dropmenuopttwo{mActionNewComposer}{New Print Composer}
+ \> \keystroke{Ctrl+P}
+ \> see Section \ref{label_printcomposer}
+ \> \dropmenucheck{File} \\
+\dropmenuopttwo{mActionComposerManager}{Composer manager}
+\dropmenuopt{Print Composers}
+ \> see Section \ref{label_printcomposer} \\
\dropmenuopttwo{mActionFileExit}{Exit}
\> \keystroke{Ctrl+Q} \\
\end{tabbing}
@@ -191,12 +200,12 @@
\hspace{4.5cm}\=\hspace{3cm}\=\hspace{3.5cm}\= \kill
\dropmenuopttwo{mActionUndo}{Undo}
\> \keystroke{Ctrl+Z}
- \> see Section \ref{sec:edit_existing_layer}
- \> \dropmenucheck{Digitizing} \\
+ \> see Section \ref{sec:advanced_edit}
+ \> \dropmenucheck{Advanced Digitizing} \\
\dropmenuopttwo{mActionRedo}{Redo}
\> \keystroke{Ctrl+Shift+Z}
\dropmenuopttwo{mActionEditCut}{Cut Features}
\> \keystroke{Ctrl+X}
@@ -209,40 +218,75 @@
\> \keystroke{Ctrl+V}
+\dropmenuopttwo{mActionEditPaste}{Move Feature}
+ \> see Section \ref{sec:edit_existing_layer}
+ \> \dropmenucheck{Digitizing} \\
+\dropmenuopttwo{mActionDeleteSelected}{Delete Selected}
+\dropmenuopttwo{mActionSimplify}{Simplify Feature}
+\dropmenuopttwo{mActionAddRing}{Add Ring}
+\dropmenuopttwo{mActionAddIsland}{Add Part}
+\dropmenuopttwo{mActionDeleteRing}{Delete Ring}
+\dropmenuopttwo{mActionDeletePart}{Delete Part}
+\dropmenuopttwo{mActionReshape}{Reshape Features}
+\dropmenuopttwo{mActionSplitFeatures}{Split Features}
+\dropmenuopttwo{mActionMergeFeatures}{Merge selected Features}
+\dropmenuopttwo{mActionNodeTool}{Node Tool}
+\dropmenuopttwo{mActionRotatePointSymbols}{Rotate Point Symbols}
+\end{tabbing}
+After activating the \toolbtntwo{mActionToggleEditing}{toogle editing} mode
+for a layer, you will find another capture feature icon in the
+\mainmenuopt{Edit} menu depending on the layer type (point, line or
+polygon). \\
+\begin{tabbing}
+\hspace{4.5cm}\=\hspace{3cm}\=\hspace{3.5cm}\= \kill
\dropmenuopttwo{mActionCapturePoint}{Capture Point}
- \> \keystroke{.}
\dropmenuopttwo{mActionCaptureLine}{Capture Line}
- \> \keystroke{/}
\dropmenuopttwo{mActionCapturePolygon}{Capture Polygon}
- \> \keystroke{Ctrl+/}
-And Other Edit Menu Items
-%\dropmenuopt{Move Feature}
-% \> \> \dropmenucheck{Edit} \\
-%\dropmenuopt{Split Features}
-%\dropmenuopt{Delete Selected}
-%\dropmenuopt{Add Vertex}
-%\dropmenuopt{Move Vertex}
-%\dropmenuopt{Delete Vertex}
-%\dropmenuopt{Add Ring}\footnote{New since v0.9}
-% \> \dropmenucheck{Edit} \\
-%\dropmenuopt{Add Island} \footnotemark[\value{footnote}]
\end{tabbing}
@@ -261,6 +305,9 @@
\dropmenuopttwo{mActionSelect}{Select Features}
\> \> \dropmenucheck{Attributes} \\
+\dropmenuopttwo{mActionDeselectAll}{Deselect Features}
+ \> \> \dropmenucheck{Attributes} \\
\dropmenuopttwo{mActionIdentify}{Identify Features}
\> \keystroke{I}
@@ -312,27 +359,27 @@
see Section \ref{sec:create shape}
\> \dropmenucheck{Manage Layers} \\
-\dropmenuopttwo{mActionAddNonDbLayer}{Add a Vector Layer}
+\dropmenuopttwo{mActionAddNonDbLayer}{Add Vector Layer}
\> \keystroke{V}
see Section \ref{label_workingvector}
-\dropmenuopttwo{mActionAddRasterLayer}{Add a Raster Layer}
+\dropmenuopttwo{mActionAddRasterLayer}{Add Raster Layer}
\> \keystroke{R}
see Section \ref{label_raster}
-\dropmenuopttwo{mActionAddLayer}{Add a PostGIS Layer}
+\dropmenuopttwo{mActionAddLayer}{Add PostGIS Layer}
\> \keystroke{D}
see Section \ref{label_postgis}
-\dropmenuopttwo{mActionAddSpatiaLiteLayer}{Add a SpatiaLite Layer}
+\dropmenuopttwo{mActionAddSpatiaLiteLayer}{Add SpatiaLite Layer}
\> \keystroke{L}
see Section \ref{label_spatialite}
-\dropmenuopttwo{mActionAddWmsLayer}{Add a WMS Layer}
+\dropmenuopttwo{mActionAddWmsLayer}{Add WMS Layer}
\> \keystroke{W}
see Section \ref{sec:ogc-wms}
@@ -397,6 +444,10 @@
\dropmenuopttwo{mActionCustomProjection}{Custom CRS}
\> \> see Section \ref{sec:customprojections}
+\dropmenuopt{Style Manager}
\dropmenuopttwo{mActionOptions}{Configure shortcuts}
Modified: docs/trunk/english_us/user_guide/images/Makefile
--- docs/trunk/english_us/user_guide/images/Makefile 2010-01-28 11:49:44 UTC (rev 12841)
+++ docs/trunk/english_us/user_guide/images/Makefile 2010-01-28 14:15:18 UTC (rev 12842)
@@ -37,11 +37,13 @@
mActionCheckQgisVersion.eps\
mActionCollapseTree.eps\
mActionContextHelp.eps\
+ mActionComposerManager.eps\
mActionCopySelected.eps\
mActionCustomProjection.eps\
mActionDeleteAttribute.eps\
mActionDeleteSelected.eps\
mActionDeleteVertex.eps\
+ mActionDeselectAll.eps\
mActionDraw.eps\
mActionEditCopy.eps\
mActionEditCut.eps\
@@ -69,6 +71,7 @@
mActionMoveFeature.eps\
mActionMoveVertex.eps\
mActionNewAttribute.eps\
+ mActionNewComposer.eps\
mActionNewBookmark.eps\
mActionNewFolder.eps\
mActionNewVectorLayer.eps\
@@ -82,6 +85,7 @@
mActionReshape.eps\
mActionRemoveAllFromOverview.eps\
mActionRemoveLayer.eps\
+ mActionRotatePointSymbols.eps\
mActionSaveAsSVG.eps\
mActionSaveMapAsImage.eps\
mActionScaleBar.eps\
Added: docs/trunk/english_us/user_guide/images/mActionAddArrow.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/images/mActionAddArrow.png
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/images/mActionAddBasicShape.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionAddBasicShape.png
Added: docs/trunk/english_us/user_guide/images/mActionAddImage.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionAddImage.png
Added: docs/trunk/english_us/user_guide/images/mActionArrowDown.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionArrowDown.png
Added: docs/trunk/english_us/user_guide/images/mActionArrowUp.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionArrowUp.png
Added: docs/trunk/english_us/user_guide/images/mActionCalculateField.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionCalculateField.png
Added: docs/trunk/english_us/user_guide/images/mActionComposerManager.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionComposerManager.png
Added: docs/trunk/english_us/user_guide/images/mActionDeselectAll.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionDeselectAll.png
Added: docs/trunk/english_us/user_guide/images/mActionFromSelectedFeature.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionFromSelectedFeature.png
Added: docs/trunk/english_us/user_guide/images/mActionNewComposer.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionNewComposer.png
Added: docs/trunk/english_us/user_guide/images/mActionRemoveSelectedFeature.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionRemoveSelectedFeature.png
Added: docs/trunk/english_us/user_guide/images/mActionRotatePointSymbols.png
Property changes on: docs/trunk/english_us/user_guide/images/mActionRotatePointSymbols.png
Modified: docs/trunk/english_us/user_guide/images/mActionSaveMapAsImage.png
