[QGIS Commit] r13867 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 1 17:23:20 EDT 2010
Author: macho
Date: 2010-07-01 21:23:20 +0000 (Thu, 01 Jul 2010)
New Revision: 13867
   trunk/qgis/i18n/qgis_ja.ts
translation update: ja by yoichi
Modified: trunk/qgis/i18n/qgis_ja.ts
--- trunk/qgis/i18n/qgis_ja.ts	2010-07-01 21:17:04 UTC (rev 13866)
+++ trunk/qgis/i18n/qgis_ja.ts	2010-07-01 21:23:20 UTC (rev 13867)
@@ -624,7 +624,7 @@
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="32"/>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="45"/>
         <source>buttonGroup</source>
-        <translation type="unfinished"></translation>
+        <translation>ボタングループ</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="42"/>
@@ -669,7 +669,7 @@
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="122"/>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="152"/>
         <source>buttonGroup_2</source>
+        <translation>ボタングループ_2</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="171"/>
@@ -4775,7 +4775,7 @@
         <translation>ルールに基づいた</translation>
     </message>
     <message numerus="yes">
-        <location filename="../src/app/qgsmaptoolcapture.cpp" line="233"/>
+        <location filename="../src/app/qgsmaptoolcapture.cpp" line="238"/>
         <location filename="../src/app/qgsmaptoolnodetool.cpp" line="977"/>
         <source>%n geometry error(s) found.</source>
         <comment>number of geometry errors</comment>
@@ -6293,7 +6293,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2642"/>
         <source>%1 doesn&apos;t have any layers</source>
+        <translation>%1にはレイヤがありません</translation>
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="3197"/>
@@ -12074,7 +12074,7 @@
     <message>
         <location filename="../src/app/gps/qgsgpsinformationwidget.cpp" line="600"/>
         <source>Cannot edit the vector layer. Use &apos;Toggle Editing&apos; to make it editable.</source>
+        <translation>そのベクタレイヤは編集できません.&apos;編集モード変更&apos;をクリックすると編集可能にできます.</translation>
     </message>
     <message>
         <location filename="../src/app/gps/qgsgpsinformationwidget.cpp" line="609"/>
@@ -17444,7 +17444,7 @@
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="73"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdfeature.cpp" line="84"/>
@@ -17532,7 +17532,7 @@
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="53"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdisland.cpp" line="63"/>
@@ -17608,7 +17608,7 @@
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="51"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptooladdring.cpp" line="66"/>
@@ -17810,7 +17810,7 @@
     <message>
         <location filename="../src/app/qgsmaptoolmovefeature.cpp" line="66"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolmovefeature.cpp" line="157"/>
@@ -17865,7 +17865,7 @@
     <message>
         <location filename="../src/app/qgsmaptoolreshape.cpp" line="50"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolreshape.cpp" line="65"/>
@@ -17978,7 +17978,7 @@
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="50"/>
     </message>
     <message>
         <location filename="../src/app/qgsmaptoolsplitfeatures.cpp" line="78"/>
@@ -20939,11 +20939,11 @@
     </message>
     <message>
         <source>Plugin Installer update uninstalled. Plugin Installer will now close and revert to its primary version. You can find it in the Plugins menu and continue operation.</source>
+        <translation>プラグインインストーラのアップデートでアンインストールされました.プラグインインストーラは終了して最初のバージョンに戻ります.プラグインメニューからプラグインインストーラを選択して処理を続けられます.</translation>
     </message>
     <message>
         <source>Plugin Installer update uninstalled. Please restart QGIS in order to load its primary version.</source>
+        <translation>プラグインインストーラのアップデートでアンインストールされました.プラグインインストーラの最初のバージョンをロードするためにQGISを再起動してください.</translation>
     </message>
     <message>
         <source>Plugin uninstalled successfully</source>
@@ -22725,7 +22725,7 @@
     <message>
         <location filename="../src/core/raster/qgsrasterlayer.cpp" line="468"/>
         <source>This raster file has no bands and is invalid as a raster layer.</source>
+        <translation>このラスタファイルはバンドを持ちません,よってラスタレイヤとしては不正です.</translation>
     </message>
     <message>
         <location filename="../src/core/raster/qgsrasterlayer.cpp" line="2667"/>
More information about the QGIS-commit mailing list
