[QGIS Commit] r13898 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 8 02:39:02 EDT 2010
Author: macho
Date: 2010-07-08 06:39:02 +0000 (Thu, 08 Jul 2010)
New Revision: 13898
   trunk/qgis/i18n/qgis_ja.ts
translation update: ja by yoichi
Modified: trunk/qgis/i18n/qgis_ja.ts
--- trunk/qgis/i18n/qgis_ja.ts	2010-07-07 18:37:02 UTC (rev 13897)
+++ trunk/qgis/i18n/qgis_ja.ts	2010-07-08 06:39:02 UTC (rev 13898)
@@ -627,7 +627,7 @@
     <message>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="26"/>
         <source>Area</source>
-        <translation type="unfinished">領域</translation>
+        <translation>領域</translation>
     </message>
     <message>
         <location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="45"/>
@@ -12458,7 +12458,7 @@
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="99"/>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="283"/>
         <source>Waypoints</source>
-        <translation>通過点</translation>
+        <translation>ウェイポイント</translation>
     </message>
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="100"/>
@@ -12482,22 +12482,22 @@
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="334"/>
         <source>Waypoints from a route</source>
-        <translation type="unfinished"></translation>
+        <translation>ルートをウィイポイントに変換する</translation>
     </message>
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="335"/>
         <source>Waypoints from a track</source>
+        <translation>トラックをウェイポイントに変換する</translation>
     </message>
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="336"/>
         <source>Route from waypoints</source>
+        <translation>ウェイポイントをルートに変換する</translation>
     </message>
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpsplugingui.cpp" line="337"/>
         <source>Track from waypoints</source>
+        <translation>ウェイポイントをトラックに変換する</translation>
     </message>
 </context>
 <context>
@@ -12516,7 +12516,7 @@
         <location filename="../src/plugins/gps_importer/qgsgpspluginguibase.ui" line="74"/>
         <location filename="../src/plugins/gps_importer/qgsgpspluginguibase.ui" line="332"/>
     </message>
     <message>
         <location filename="../src/plugins/gps_importer/qgsgpspluginguibase.ui" line="87"/>
@@ -18730,7 +18730,7 @@
     <message>
         <location filename="../src/ui/qgsnewspatialitelayerdialogbase.ui" line="129"/>
         <source>geometry</source>
-        <translation>ジオメトリ</translation>
+        <translation>geometry</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsnewspatialitelayerdialogbase.ui" line="144"/>
@@ -22026,7 +22026,7 @@
         <source>Unable to open one or more project layers
 Try to find missing layers?</source>
         <translation>これ以上プロジェクトのレイヤを開けません
-使用しないレイヤを探して見てください。</translation>
+使用しないレイヤを探してみますか?</translation>
     </message>
 </context>
 <context>
@@ -25478,7 +25478,7 @@
     <message>
         <location filename="../src/plugins/spit/qgsspit.cpp" line="164"/>
         <source>Shapefiles (*.shp);;All files (*)</source>
-        <translation>Shapeファイル (*.xml);; 全ファイル (*)</translation>
+        <translation>Shapeファイル (*.shp);; 全ファイル (*)</translation>
     </message>
     <message>
         <location filename="../src/plugins/spit/qgsspit.cpp" line="258"/>
@@ -26700,47 +26700,47 @@
 <context>
     <name>QgsVectorLayer</name>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3184"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3185"/>
         <source>ERROR: no provider</source>
         <translation>エラー: プロバイダがありません</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3190"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3191"/>
         <source>ERROR: layer not editable</source>
         <translation>エラー: レイヤは編集不可です</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3273"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3274"/>
         <source>SUCCESS: attribute %1 was added.</source>
         <translation>成功: 属性 %1 を追加しれました。</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3280"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3281"/>
         <source>ERROR: attribute %1 not added</source>
         <translation>エラー: 属性 %1 の追加に失敗しました</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2689"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2690"/>
         <source>No renderer object</source>
         <translation>レンダラーオブジェクトがありません</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2693"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2694"/>
         <source>Classification field not found</source>
         <translation>分類フィールドが見つかりません</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2847"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2848"/>
         <source>renderer failed to save</source>
         <translation>レンダラは保存に失敗しました</translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2854"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2855"/>
         <source>no renderer</source>
         <translation>レンダラがありません</translation>
     </message>
     <message numerus="yes">
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3204"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3205"/>
         <source>SUCCESS: %n attribute(s) deleted.</source>
         <comment>deleted attributes count</comment>
         <translation>
@@ -26748,7 +26748,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3210"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3211"/>
         <source>ERROR: %n attribute(s) not deleted.</source>
         <comment>not deleted attributes count</comment>
         <translation>
@@ -26756,7 +26756,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3226"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3227"/>
         <source>SUCCESS: %n attribute(s) added.</source>
         <comment>added attributes count</comment>
         <translation>
@@ -26764,7 +26764,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3232"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3233"/>
         <source>ERROR: %n new attribute(s) not added</source>
         <comment>not added attributes count</comment>
         <translation>
@@ -26772,7 +26772,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3342"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3343"/>
         <source>SUCCESS: %n attribute value(s) changed.</source>
         <comment>changed attribute values count</comment>
         <translation>
@@ -26780,7 +26780,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3347"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3348"/>
         <source>ERROR: %n attribute value change(s) not applied.</source>
         <comment>not changed attribute values count</comment>
         <translation>
@@ -26788,7 +26788,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3380"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3381"/>
         <source>SUCCESS: %n feature(s) added.</source>
         <comment>added features count</comment>
         <translation>
@@ -26796,7 +26796,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3385"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3386"/>
         <source>ERROR: %n feature(s) not added.</source>
         <comment>not added features count</comment>
         <translation>
@@ -26804,7 +26804,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3398"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3399"/>
         <source>SUCCESS: %n geometries were changed.</source>
         <comment>changed geometries count</comment>
         <translation>
@@ -26812,7 +26812,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3403"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3404"/>
         <source>ERROR: %n geometries not changed.</source>
         <comment>not changed geometries count</comment>
         <translation>
@@ -26820,7 +26820,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3415"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3416"/>
         <source>SUCCESS: %n feature(s) deleted.</source>
         <comment>deleted features count</comment>
         <translation>
@@ -26828,7 +26828,7 @@
         </translation>
     </message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="3425"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="3426"/>
         <source>ERROR: %n feature(s) not deleted.</source>
         <comment>not deleted features count</comment>
         <translation>
@@ -26836,7 +26836,7 @@
         </translation>
     </message>
     <message>
-        <location filename="../src/core/qgsvectorlayer.cpp" line="2683"/>
+        <location filename="../src/core/qgsvectorlayer.cpp" line="2684"/>
         <source>Unknown renderer</source>
         <translation>不明なレンダラ</translation>
     </message>
More information about the QGIS-commit mailing list
