[QGIS Commit] r13927 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jul 17 17:34:31 EDT 2010
Author: kyngchaos
Date: 2010-07-17 21:34:31 +0000 (Sat, 17 Jul 2010)
New Revision: 13927
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
   trunk/qgis/mac/xcode/qgis_settings.xcconfig
version bump (r13926);
context help update (r13924);
fix path to user bundle script
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-07-17 20:53:40 UTC (rev 13926)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2010-07-17 21:34:31 UTC (rev 13927)
@@ -1008,6 +1008,7 @@
 		7256F5360F41C5EF0022BE1F /* qgis_help.db in Copy - resources */ = {isa = PBXBuildFile; fileRef = 7209ED830F39E5D9003DC336 /* qgis_help.db */; };
 		7256F5370F41C5EF0022BE1F /* srs.db in Copy - resources */ = {isa = PBXBuildFile; fileRef = 7209ED840F39E5D9003DC336 /* srs.db */; };
 		7261A9B51195BB69006BD962 /* qgsresidualplotitem.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 7261A9B31195BB3F006BD962 /* qgsresidualplotitem.cpp */; };
+		7261EF9911F2589500E4C6E2 /* QgsWMSSourceSelect-pl_PL in Copy - context_help */ = {isa = PBXBuildFile; fileRef = 7261EF9811F2588100E4C6E2 /* QgsWMSSourceSelect-pl_PL */; };
 		7262ED830F7A750F00498385 /* qgsspatialitefilterproxymodel.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 7262ED7E0F7A74B700498385 /* qgsspatialitefilterproxymodel.cpp */; };
 		7262ED840F7A750F00498385 /* qgsspatialitetablemodel.cpp in Sources */ = {isa = PBXBuildFile; fileRef = 7262ED820F7A74B700498385 /* qgsspatialitetablemodel.cpp */; };
 		7262ED970F7A770300498385 /* libqgis_core.dylib in Frameworks */ = {isa = PBXBuildFile; fileRef = 7209F1D20F39E760003DC336 /* libqgis_core.dylib */; };
@@ -3375,6 +3376,7 @@
 				721D950211CE911900714113 /* QgsWMSSourceSelect-en_US in Copy - context_help */,
 				721D950311CE911900714113 /* QgsWMSSourceSelect-it_IT in Copy - context_help */,
 				721D950411CE911900714113 /* QgsWMSSourceSelect-ja_JP in Copy - context_help */,
+				7261EF9911F2589500E4C6E2 /* QgsWMSSourceSelect-pl_PL in Copy - context_help */,
 				721D950511CE911900714113 /* QgsWMSSourceSelect-pt_BR in Copy - context_help */,
 				721D950611CE911900714113 /* QgsWMSSourceSelect-ru_RU in Copy - context_help */,
 				721D950711CE911900714113 /* QgsWMSSourceSelect-sk_SK in Copy - context_help */,
@@ -6110,6 +6112,7 @@
 		725B4FF00F936E3300084072 /* qgsmaptip.sip */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = qgsmaptip.sip; path = ../../python/gui/qgsmaptip.sip; sourceTree = SOURCE_ROOT; };
 		7261A9B31195BB3F006BD962 /* qgsresidualplotitem.cpp */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.cpp.cpp; name = qgsresidualplotitem.cpp; path = ../../src/plugins/georeferencer/qgsresidualplotitem.cpp; sourceTree = SOURCE_ROOT; };
 		7261A9B41195BB3F006BD962 /* qgsresidualplotitem.h */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = sourcecode.c.h; name = qgsresidualplotitem.h; path = ../../src/plugins/georeferencer/qgsresidualplotitem.h; sourceTree = SOURCE_ROOT; };
+		7261EF9811F2588100E4C6E2 /* QgsWMSSourceSelect-pl_PL */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = "QgsWMSSourceSelect-pl_PL"; path = "../../resources/context_help/QgsWMSSourceSelect-pl_PL"; sourceTree = SOURCE_ROOT; };
 		72624BCF10E30376006F0A26 /* qgssearchstring.sip */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = qgssearchstring.sip; path = ../../python/core/qgssearchstring.sip; sourceTree = SOURCE_ROOT; };
 		72624BD010E30376006F0A26 /* qgssearchtreenode.sip */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text; name = qgssearchtreenode.sip; path = ../../python/core/qgssearchtreenode.sip; sourceTree = SOURCE_ROOT; };
 		72624BF510E30437006F0A26 /* OsmTags.py */ = {isa = PBXFileReference; fileEncoding = 4; lastKnownFileType = text.script.python; name = OsmTags.py; path = ../../python/plugins/osm/OsmTags.py; sourceTree = SOURCE_ROOT; };
@@ -12254,6 +12257,7 @@
 				721D944811CE90DF00714113 /* QgsWMSSourceSelect-en_US */,
 				721D944911CE90DF00714113 /* QgsWMSSourceSelect-it_IT */,
 				721D944A11CE90DF00714113 /* QgsWMSSourceSelect-ja_JP */,
+				7261EF9811F2588100E4C6E2 /* QgsWMSSourceSelect-pl_PL */,
 				721D944B11CE90DF00714113 /* QgsWMSSourceSelect-pt_BR */,
 				721D944C11CE90DF00714113 /* QgsWMSSourceSelect-ru_RU */,
 				721D944D11CE90DF00714113 /* QgsWMSSourceSelect-sk_SK */,
@@ -15117,7 +15121,7 @@
 			runOnlyForDeploymentPostprocessing = 0;
 			shellPath = /bin/sh;
-			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\techo \"Copying libpq...\"\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executab
 le_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDAL_PREFIX/lib/libgdal.dylib\" ] ; then\n\techo \"Copying GDAL...\"\n\tditto -X $QARCHS \"$GDAL_PREFIX/lib/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tditto -X $QARCHS \"$PYSITE/osgeo\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tfor p in gdal gdalconst gdalnumeric ogr osr\n\tdo\n\t\tditto -X $QARCHS \"$PYSITE/$p.py\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/\"\n\tdone\n\tfor p in $GDAL_PROGS\n\tdo\n\t\tif [ -e \"$GDAL_PREFIX/bin/$p\" ] ; then\n\t\t\tditto -X $QARCHS \"$GDAL_PREFIX/bin/$p\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\t\tfi\n\tdone\n\tglib=`otool -L \"$GDAL_PREFIX/lib/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_pa
 th/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJ_PREFIX/lib/libproj.dylib\" ] ; then\n\techo \"Copying PROJ...\"\n\tditto -X $QARCHS \"$PROJ_PREFIX/lib/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJ_PREFIX/lib/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\techo \"Copying GEOS...\"\n\tditto -X $QARCHS \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -
 d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite & SpatiaLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\techo \"Copying Sqlite3...\"\n\tditto -X $QARCHS \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tif [ -f \"$SQLITEROOT/libspatialite.dylib\" ] ; the
 n\n\t\tditto -X $QARCHS \"$SQLITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\t\tslib=`otool -L \"$SQLITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tfi\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\techo \"Copying GSL...\"\n\tditto -X $QARCHS \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tditto -X $QARCHS \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E
 -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"Updating bundled library paths...\"\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\techo \"install_name
 _tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\\\"\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR\"\n# clean out pyc\nfind python -name *.pyc -print0 | xargs -0 rm -f\n# python binary modules\npymodlist=`find -x python -name *.so`\nfor p in $pymodlist\ndo\n\techo \"install_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \\\"$p\\\"\"\n\tinstall_name_tool $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG \"$p\"\ndone\n\n# change bundled progs from above bundling\n# will get error on qgis_help.app\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\nbinlist=`ls`\nfor p in $binlist\ndo\n\techo \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\\\"\"\n\tinst
 all_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\"\ndone\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
+			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\nmkdir -p \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"\n\nQGISPYDIR=\"$QGIS_BUILD_PATH/MacOS/$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\techo \"Copying libpq...\"\n\tditto -X $QARCHS \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executab
 all_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR/$p\"\ndone\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\ncd \"$PROJECT_DIR\"\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
 			showEnvVarsInLog = 0;
 		7268C04D118294F2001BC9C4 /* Script - ui */ = {
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-07-17 20:53:40 UTC (rev 13926)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig	2010-07-17 21:34:31 UTC (rev 13927)
@@ -15,12 +15,12 @@
 // major-minor-patch must be integers for Mac OS X
-QGIS_RELEASE_NAME = Tethys
+QGIS_RELEASE_NAME = Trunk
 QGIS_VERSION_MAJOR = 1
-QGIS_VERSION_MINOR = 5
+QGIS_VERSION_MINOR = 6
 QGIS_VERSION_PATCH = 0
 QGIS_VERSION_FULL = $(QGIS_VERSION_MAJOR).$(QGIS_VERSION_MINOR).$(QGIS_VERSION_PATCH)-$(QGIS_RELEASE_NAME)
-QGIS_VERSION_INT = 10500
+QGIS_VERSION_INT = 10600
 // Qt and other support
More information about the QGIS-commit mailing list
