[QGIS Commit] r13931 - in branches/threading-branch/src: core providers/delimitedtext providers/gpx providers/grass providers/memory providers/ogr providers/osm providers/postgres providers/spatialite providers/wfs
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Jul 18 11:07:07 EDT 2010
Author: wonder
Date: 2010-07-18 15:07:07 +0000 (Sun, 18 Jul 2010)
New Revision: 13931
   branches/threading-branch/src/core/qgsvectordataprovider.cpp
   branches/threading-branch/src/core/qgsvectordataprovider.h
   branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
   branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.h
   branches/threading-branch/src/providers/gpx/qgsgpxprovider.cpp
   branches/threading-branch/src/providers/gpx/qgsgpxprovider.h
   branches/threading-branch/src/providers/grass/qgsgrassprovider.cpp
   branches/threading-branch/src/providers/grass/qgsgrassprovider.h
   branches/threading-branch/src/providers/memory/qgsmemoryprovider.cpp
   branches/threading-branch/src/providers/memory/qgsmemoryprovider.h
   branches/threading-branch/src/providers/ogr/qgsogrprovider.cpp
   branches/threading-branch/src/providers/ogr/qgsogrprovider.h
   branches/threading-branch/src/providers/osm/osmprovider.cpp
   branches/threading-branch/src/providers/osm/osmprovider.h
   branches/threading-branch/src/providers/postgres/qgspostgresprovider.cpp
   branches/threading-branch/src/providers/postgres/qgspostgresprovider.h
   branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.cpp
   branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.h
   branches/threading-branch/src/providers/wfs/qgswfsprovider.cpp
   branches/threading-branch/src/providers/wfs/qgswfsprovider.h
Moved implementation of old provider API to QgsVectorDataProvider. Providers now only implement getFeatures() request.
Modified: branches/threading-branch/src/core/qgsvectordataprovider.cpp
--- branches/threading-branch/src/core/qgsvectordataprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/core/qgsvectordataprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -20,6 +20,10 @@
 #include <cfloat> // for DBL_MAX
 #include <climits>
+#include <QApplication>
+#include <QThread>
 #include "qgsvectordataprovider.h"
 #include "qgsfeature.h"
 #include "qgsfield.h"
@@ -162,6 +166,55 @@
   return QgsFeatureIterator();
+void QgsVectorDataProvider::select( QgsAttributeList fetchAttributes,
+                                    QgsRectangle rect,
+                                    bool fetchGeometry,
+                                    bool useIntersect )
+  if ( !isValid() )
+    QgsDebugMsg( "Read attempt on an invalid data source" );
+    return;
+  if (qApp->thread() != QThread::currentThread())
+    QgsDebugMsg("accessing old provider API from non-gui thread! (IGNORING)");
+    return;
+  mOldApiIter = getFeatures( fetchAttributes, rect, fetchGeometry, useIntersect );
+bool QgsVectorDataProvider::nextFeature( QgsFeature& feature )
+  if ( !isValid() )
+    return false;
+  if ( mOldApiIter.isClosed() )
+    QgsDebugMsg( "nextFeature() without select()" );
+    return false;
+  if (mOldApiIter.nextFeature(feature))
+    return true;
+  else
+    mOldApiIter.close(); // make sure to unlock the layer
+    return false;
+void QgsVectorDataProvider::rewind()
+  mOldApiIter.rewind();
 bool QgsVectorDataProvider::featureAtId( int featureId,
     QgsFeature& feature,
     bool fetchGeometry,
@@ -453,12 +506,12 @@
   QgsFeature f;
   QgsAttributeList keys;
   keys.append( index );
-  select( keys, QgsRectangle(), false );
+  QgsFeatureIterator fi = getFeatures( keys, QgsRectangle(), false );
   QSet<QString> set;
   values.clear();
-  while ( nextFeature( f ) )
+  while ( fi.nextFeature( f ) )
     if ( !set.contains( f.attributeMap()[index].toString() ) )
@@ -490,9 +543,9 @@
   QgsFeature f;
   QgsAttributeList keys = mCacheMinValues.keys();
     QgsAttributeMap attrMap = f.attributeMap();
     for ( QgsAttributeList::const_iterator it = keys.begin(); it != keys.end(); ++it )
Modified: branches/threading-branch/src/core/qgsvectordataprovider.h
--- branches/threading-branch/src/core/qgsvectordataprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/core/qgsvectordataprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -178,11 +178,12 @@
      * @param fetchGeometry true if the feature geometry should be fetched
      * @param useIntersect true if an accurate intersection test should be used,
      *                     false if a test based on bounding box is sufficient
+     * @deprecated do not use nor implement in providers, use getFeatures() instead
     virtual void select( QgsAttributeList fetchAttributes = QgsAttributeList(),
                          QgsRectangle rect = QgsRectangle(),
                          bool fetchGeometry = true,
-                         bool useIntersect = false ) = 0;
+                         bool useIntersect = false );
      * This function does nothing useful, it's kept only for compatibility.
@@ -193,6 +194,12 @@
      * Start iterating over features of the vector data provider.
      * For new code, consider using this method instead of select/nextFeature combo.
+     * @param fetchAttributes list of attributes which should be fetched
+     * @param rect spatial filter
+     * @param fetchGeometry true if the feature geometry should be fetched
+     * @param useIntersect true if an accurate intersection test should be used,
+     *                     false if a test based on bounding box is sufficient
+     * @return iterator instance for retrieval of features
      * @note Added in v1.6
     virtual QgsFeatureIterator getFeatures( QgsAttributeList fetchAttributes = QgsAttributeList(),
@@ -220,8 +227,9 @@
      * Get the next feature resulting from a select operation.
      * @param feature feature which will receive data from the provider
      * @return true when there was a feature to fetch, false when end was hit
-    virtual bool nextFeature( QgsFeature& feature ) = 0;
+    virtual bool nextFeature( QgsFeature& feature );
      * Get feature type.
@@ -255,8 +263,9 @@
     virtual QString dataComment() const;
-    /** Restart reading features from previous select operation */
-    virtual void rewind() = 0;
+    /** Restart reading features from previous select operation
+     @deprecated do not use nor implement in providers, use getFeatures() instead */
+    virtual void rewind();
      * Returns the minimum value of an attribute
@@ -462,6 +471,8 @@
     /**The names of the providers native types*/
     QList< NativeType > mNativeTypes;
+    QgsFeatureIterator mOldApiIter;
   private:
     /** old notation **/
     QMap<QString, QVariant::Type> mOldTypeList;
Modified: branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
--- branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -315,6 +315,8 @@
 QgsDelimitedTextProvider::~QgsDelimitedTextProvider()
   mFile->close();
   delete mFile;
   delete mStream;
@@ -335,34 +337,6 @@
-bool QgsDelimitedTextProvider::nextFeature( QgsFeature& feature )
-  if (mOldApiIter.nextFeature(feature))
-    return true;
-  else
-    mOldApiIter.close(); // make sure to unlock the layer
-    return false;
-void QgsDelimitedTextProvider::select( QgsAttributeList fetchAttributes,
-                                       QgsRectangle rect,
-                                       bool fetchGeometry,
-                                       bool useIntersect )
-  mOldApiIter = getFeatures(fetchAttributes, rect, fetchGeometry, useIntersect);
-void QgsDelimitedTextProvider::rewind()
-  mOldApiIter.rewind();
 void QgsDelimitedTextProvider::showInvalidLinesErrors()
   // TODO: this should be modified to only set an error string that can be read from provider
Modified: branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.h
--- branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/delimitedtext/qgsdelimitedtextprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -58,28 +58,17 @@
     virtual QString storageType() const;
-    /** Select features based on a bounding rectangle. Features can be retrieved with calls to nextFeature.
-     *  @param fetchAttributes list of attributes which should be fetched
-     *  @param rect spatial filter
-     *  @param fetchGeometry true if the feature geometry should be fetched
-     *  @param useIntersect true if an accurate intersection test should be used,
+     * Start iterating over features of the vector data provider.
+     * For new code, consider using this method instead of select/nextFeature combo.
+     * @note Added in v1.6
-    virtual void select( QgsAttributeList fetchAttributes = QgsAttributeList(),
-                         QgsRectangle rect = QgsRectangle(),
-                         bool fetchGeometry = true,
-                         bool useIntersect = false );
-     * Get the next feature resulting from a select operation.
-     * @param feature feature which will receive data from the provider
-     * @return true when there was a feature to fetch, false when end was hit
-     * mFile should be open with the file pointer at the record of the next
-     * feature, or EOF.  The feature found on the current line is parsed.
-    virtual bool nextFeature( QgsFeature& feature );
@@ -108,9 +97,6 @@
     virtual const QgsFieldMap & fields() const;
-    virtual void rewind();
     /** Returns a bitmask containing the supported capabilities
         Note, some capabilities may change depending on whether
         a spatial filter is active on this provider, so it may
@@ -200,7 +186,6 @@
     void showInvalidLinesErrors();
     friend class QgsDelimitedTextFeatureIterator;
-    QgsFeatureIterator mOldApiIter;
     QMutex mStreamMutex;
Modified: branches/threading-branch/src/providers/gpx/qgsgpxprovider.cpp
--- branches/threading-branch/src/providers/gpx/qgsgpxprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/gpx/qgsgpxprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -108,6 +108,8 @@
 QgsGPXProvider::~QgsGPXProvider()
   QgsGPSData::releaseData( mFileName );
@@ -132,33 +134,7 @@
   return QgsFeatureIterator( new QgsGPXFeatureIterator(this, fetchAttributes, rect, fetchGeometry, useIntersect) );
-bool QgsGPXProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
-void QgsGPXProvider::select( QgsAttributeList fetchAttributes,
-  mOldApiIter = getFeatures( fetchAttributes, rect, fetchGeometry, useIntersect );
-void QgsGPXProvider::rewind()
 // Return the extent of the layer
 QgsRectangle QgsGPXProvider::extent()
Modified: branches/threading-branch/src/providers/gpx/qgsgpxprovider.h
--- branches/threading-branch/src/providers/gpx/qgsgpxprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/gpx/qgsgpxprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -52,25 +52,17 @@
@@ -98,9 +90,6 @@
      * Adds a list of features
      * @return true in case of success and false in case of failure
@@ -176,7 +165,6 @@
     long mNumberFeatures;
     friend class QgsGPXFeatureIterator;
     QMutex mDataMutex;
Modified: branches/threading-branch/src/providers/grass/qgsgrassprovider.cpp
--- branches/threading-branch/src/providers/grass/qgsgrassprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/grass/qgsgrassprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -241,6 +241,9 @@
 QgsGrassProvider::~QgsGrassProvider()
   QgsDebugMsg( "entered." );
   closeLayer( mLayerId );
@@ -258,32 +261,7 @@
   return QgsFeatureIterator( new QgsGrassFeatureIterator(this, fetchAttributes, rect, fetchGeometry, useIntersect) );
-void QgsGrassProvider::select( QgsAttributeList fetchAttributes,
-bool QgsGrassProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
-void QgsGrassProvider::rewind()
 QgsRectangle QgsGrassProvider::extent()
   BOUND_BOX box;
Modified: branches/threading-branch/src/providers/grass/qgsgrassprovider.h
--- branches/threading-branch/src/providers/grass/qgsgrassprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/grass/qgsgrassprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -126,28 +126,17 @@
-     * @note This function works only until first edit operation! (category index used)
@@ -184,9 +173,6 @@
     // ! Key (category) field index
     int keyField();
-    void rewind();
     /** Returns the minimum value of an attributs
      *  @param index the index of the attribute */
     QVariant minimumValue( int index );
@@ -549,7 +535,6 @@
     bool    mValid;                // !UPDATE!
     long    mNumberFeatures;       // !UPDATE!
     friend class QgsGrassFeatureIterator;
     QMutex mMapMutex;
Modified: branches/threading-branch/src/providers/memory/qgsmemoryprovider.cpp
--- branches/threading-branch/src/providers/memory/qgsmemoryprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/memory/qgsmemoryprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -57,6 +57,8 @@
 QgsMemoryProvider::~QgsMemoryProvider()
   delete mSpatialIndex;
@@ -73,18 +75,7 @@
   return QgsFeatureIterator( new QgsMemoryFeatureIterator(this, fetchAttributes, rect, fetchGeometry, useIntersect) );
-bool QgsMemoryProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
 bool QgsMemoryProvider::featureAtId( int featureId,
                                      bool fetchGeometry,
@@ -104,20 +95,6 @@
-void QgsMemoryProvider::select( QgsAttributeList fetchAttributes,
-void QgsMemoryProvider::rewind()
 QgsRectangle QgsMemoryProvider::extent()
   return mExtent;
Modified: branches/threading-branch/src/providers/memory/qgsmemoryprovider.h
--- branches/threading-branch/src/providers/memory/qgsmemoryprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/memory/qgsmemoryprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -37,28 +37,18 @@
-     *                     false if a test based on bounding box is sufficient
@@ -100,10 +90,7 @@
@@ -204,7 +191,6 @@
     QgsSpatialIndex* mSpatialIndex;
     friend class QgsMemoryFeatureIterator;
     QMutex mDataMutex;
Modified: branches/threading-branch/src/providers/ogr/qgsogrprovider.cpp
--- branches/threading-branch/src/providers/ogr/qgsogrprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/ogr/qgsogrprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -197,6 +197,8 @@
 QgsOgrProvider::~QgsOgrProvider()
   if ( ogrLayer != ogrOrigLayer )
     OGR_DS_ReleaseResultSet( ogrDataSource, ogrLayer );
@@ -466,32 +468,7 @@
   return true;
-bool QgsOgrProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
-#include <QThread>
-void QgsOgrProvider::select( QgsAttributeList fetchAttributes, QgsRectangle rect, bool fetchGeometry, bool useIntersect )
-  if (qApp->thread() != QThread::currentThread())
-    QgsDebugMsg("accessing old provider API from non-gui thread! (IGNORING)");
-    return;
-  //if (mOldApiIter != QgsFeatureIterator())
 unsigned char * QgsOgrProvider::getGeometryPointer( OGRFeatureH fet )
   OGRGeometryH geom = OGR_F_GetGeometryRef( fet );
@@ -632,14 +609,7 @@
   return mAttributeFields;
-void QgsOgrProvider::rewind()
-  // the iterator is closed everyt
-  //mOldApiIter = getFeatures( fetchAttributes, rect, fetchGeometry, useIntersect );
 //TODO - add sanity check for shape file layers, to include cheking to
 //       see if the .shp, .dbf, .shx files are all present and the layer
 //       actually has features
Modified: branches/threading-branch/src/providers/ogr/qgsogrprovider.h
--- branches/threading-branch/src/providers/ogr/qgsogrprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/ogr/qgsogrprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -62,26 +62,17 @@
@@ -141,9 +132,6 @@
     virtual QgsRectangle extent();
     /**Writes a list of features to the file*/
     virtual bool addFeatures( QgsFeatureList & flist );
@@ -290,7 +278,6 @@
     int geomType;
     long featuresCounted;
     friend class QgsOgrFeatureIterator;
     /**Adds one feature*/
Modified: branches/threading-branch/src/providers/osm/osmprovider.cpp
--- branches/threading-branch/src/providers/osm/osmprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/osm/osmprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -327,6 +327,8 @@
 QgsOSMDataProvider::~QgsOSMDataProvider()
   // finalize all created sqlite3 statements
   sqlite3_finalize( mTagsStmt );
   sqlite3_finalize( mCustomTagsStmt );
@@ -454,32 +456,6 @@
-void QgsOSMDataProvider::select( QgsAttributeList fetchAttributes,
-bool QgsOSMDataProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
-void QgsOSMDataProvider::rewind()
 bool QgsOSMDataProvider::featureAtId( int featureId,
                                       bool fetchGeometry,
Modified: branches/threading-branch/src/providers/osm/osmprovider.h
--- branches/threading-branch/src/providers/osm/osmprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/osm/osmprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -94,7 +94,6 @@
     QgsFieldMap mAttributeFields;
     friend class QgsOSMFeatureIterator;
     mutable QMutex mDatabaseMutex;
@@ -119,25 +118,18 @@
-    /** Select features based on a bounding rectangle. Features can be retrieved with calls to getNextFeature.
@@ -180,11 +172,6 @@
-     * Restart reading features from previous select operation.
      * Changes attribute values of existing features.
      * @param attr_map a map containing changed attributes
Modified: branches/threading-branch/src/providers/postgres/qgspostgresprovider.cpp
--- branches/threading-branch/src/providers/postgres/qgspostgresprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/postgres/qgspostgresprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -524,30 +524,6 @@
-void QgsPostgresProvider::select( QgsAttributeList fetchAttributes, QgsRectangle rect, bool fetchGeometry, bool useIntersect )
-  if (!mOldApiIter.isClosed())
-bool QgsPostgresProvider::nextFeature( QgsFeature& feature )
-  if ( !valid )
-    QgsDebugMsg( "Read attempt on an invalid postgresql data source" );
-    return false;
-  if ( mOldApiIter.isClosed() )
-    QgsDebugMsg( "nextFeature() without select()" );
-    return false;
-  return mOldApiIter.nextFeature( feature );
 QString QgsPostgresProvider::whereClause( int featureId ) const
   QString whereClause;
@@ -659,11 +635,6 @@
   return mDataComment;
-void QgsPostgresProvider::rewind()
 /** @todo XXX Perhaps this should be promoted to QgsDataProvider? */
 QString QgsPostgresProvider::endianString()
Modified: branches/threading-branch/src/providers/postgres/qgspostgresprovider.h
--- branches/threading-branch/src/providers/postgres/qgspostgresprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/postgres/qgspostgresprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -73,25 +73,17 @@
     virtual QgsCoordinateReferenceSystem crs();
@@ -176,11 +168,6 @@
-    /** Reset the layer - for a PostgreSQL layer, this means clearing the PQresult
-     * pointer, setting it to 0 and reloading the field list
-    void rewind();
     /** Returns the minimum value of an attribute
@@ -373,7 +360,6 @@
     QgsFieldMap attributeFields;
     QString mDataComment;
     friend class QgsPostgresFeatureIterator;
     //! Data source URI struct for this layer
Modified: branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.cpp
--- branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -391,44 +391,10 @@
                                                        bool fetchGeometry,
                                                        bool useIntersect )
-  if ( !valid )
-    QgsDebugMsg( "Read attempt on an invalid SpatiaLite data source" );
-    return QgsFeatureIterator();
   return QgsFeatureIterator( new QgsSpatiaLiteFeatureIterator(this, fetchAttributes, rect, fetchGeometry, useIntersect) );
-void QgsSpatiaLiteProvider::select( QgsAttributeList fetchAttributes, QgsRectangle rect, bool fetchGeometry, bool useIntersect )
-bool QgsSpatiaLiteProvider::nextFeature( QgsFeature & feature )
-  if ( !valid )
-    return false;
-    return true;
-  else
-    return false;
-void QgsSpatiaLiteProvider::rewind()
 QgsRectangle QgsSpatiaLiteProvider::extent()
   return layerExtent;
Modified: branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.h
--- branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/spatialite/qgsspatialiteprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -85,23 +85,17 @@
     virtual bool supportsSubsetString() { return true; }
-                         QgsRectangle rect = QgsRectangle(), bool fetchGeometry = true, bool useIntersect = false );
-    virtual bool nextFeature( QgsFeature & feature );
@@ -150,9 +144,6 @@
-    /** Reset the layer */
-    void rewind();
@@ -411,7 +402,6 @@
     SqliteHandles *handle;
     friend class QgsSpatiaLiteFeatureIterator;
     QMutex mHandleMutex;
Modified: branches/threading-branch/src/providers/wfs/qgswfsprovider.cpp
--- branches/threading-branch/src/providers/wfs/qgswfsprovider.cpp	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/wfs/qgswfsprovider.cpp	2010-07-18 15:07:07 UTC (rev 13931)
@@ -103,42 +103,11 @@
                                                 bool fetchGeometry,
                                                 bool useIntersect )
-  if ( !mValid )
-    QgsDebugMsg( "Read attempt on an invalid WFS layer" );
   return QgsFeatureIterator( new QgsWFSFeatureIterator(this, fetchAttributes, rect, fetchGeometry, useIntersect) );
-void QgsWFSProvider::select( QgsAttributeList fetchAttributes,
-bool QgsWFSProvider::nextFeature( QgsFeature& feature )
-    return true;
-  else
-    return false;
-void QgsWFSProvider::rewind()
 int QgsWFSProvider::getFeature( const QString& uri )
   QString geometryAttribute;
Modified: branches/threading-branch/src/providers/wfs/qgswfsprovider.h
--- branches/threading-branch/src/providers/wfs/qgswfsprovider.h	2010-07-18 12:06:52 UTC (rev 13930)
+++ branches/threading-branch/src/providers/wfs/qgswfsprovider.h	2010-07-18 15:07:07 UTC (rev 13931)
@@ -48,25 +48,17 @@
     /* Inherited from QgsVectorDataProvider */
@@ -76,7 +68,6 @@
     long featureCount() const;
     uint fieldCount() const;
-    void rewind();
@@ -126,7 +117,6 @@
     bool mValid;
     friend class QgsWFSFeatureIterator;
     QMutex mDataMutex;
More information about the QGIS-commit mailing list
