[QGIS Commit] r13969 - docs/trunk/english_us/coding-compilation_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jul 27 06:23:35 EDT 2010
Author: dassau
Date: 2010-07-27 10:23:35 +0000 (Tue, 27 Jul 2010)
New Revision: 13969
Added:
   docs/trunk/english_us/coding-compilation_guide/floatflt.sty
   docs/trunk/english_us/coding-compilation_guide/coding.tex
   docs/trunk/english_us/coding-compilation_guide/install.tex
   docs/trunk/english_us/coding-compilation_guide/qgis_style.sty
   docs/trunk/english_us/coding-compilation_guide/title.tex
updates from current INSTALL.t2t and CODING.t2t
Modified: docs/trunk/english_us/coding-compilation_guide/coding.tex
--- docs/trunk/english_us/coding-compilation_guide/coding.tex	2010-07-27 07:56:31 UTC (rev 13968)
+++ docs/trunk/english_us/coding-compilation_guide/coding.tex	2010-07-27 10:23:35 UTC (rev 13969)
@@ -4,16 +4,19 @@
 % comment out the following line:
 % \updatedisclaimer
+\hypertarget{toc1}{}
 \section{QGIS Coding Standards}
 The following chapters provide coding information for QGIS Version \CURRENT.
 This document corresponds almost to a \LaTeX~ conversion of the CODING.t2t
-file coming with the QGIS sources from March, 21th 2010.
+file coming with the QGIS sources from July, 27th 2010.
 These standards should be followed by all QGIS developers.
-\subsubsection{Classes}
-\minisec{Names}
+\hypertarget{toc2}{}
+\subsection{Classes}
+\hypertarget{toc3}{}
+\subsubsection{Names}
 Class in QGIS begin with Qgs and are formed using mixed case.
 \begin{verbatim}
@@ -23,7 +26,8 @@
   QgsRasterLayer
 \end{verbatim}
-\minisec{Members}
+\hypertarget{toc4}{}
+\subsubsection{Members}
 Class member names begin with a lower case \textit{m} and are formed using mixed
 case.
@@ -35,9 +39,10 @@
 All class members should be private.
 \textbf{Public class members are STRONGLY discouraged}
-\minisec{Accessor Functions}
+\hypertarget{toc5}{}
+\subsubsection{Accessor Functions}
 Class member values should be obtained through accesssor functions. The
-unction should be named without a \textit{get} prefix. Accessor functions for the
+function should be named without a \textit{get} prefix. Accessor functions for the
 two private members above would be:
 \begin{verbatim}
@@ -45,7 +50,8 @@
   currentExtent()
 \end{verbatim}
-\minisec{Functions}
+\hypertarget{toc6}{}
+\subsubsection{Functions}
 Function names begin with a lowercase letter and are formed using mixed case.
 The function name should convey something about the purpose of the function.
@@ -54,8 +60,10 @@
   setUserOptions()
 \end{verbatim}
-\subsubsection{Qt Designer}
-\minisec{Generated Classes}
+\hypertarget{toc7}{}
+\subsection{Qt Designer}
+\hypertarget{toc8}{}
+\subsubsection{Generated Classes}
 QGIS classes that are generated from Qt Designer (ui) files should have a
 \textit{Base} suffix. This identifies the class as a generated base class.
@@ -64,7 +72,8 @@
   QgsPluginMangerBase
   QgsUserOptionsBase
 \end{verbatim}
-\minisec{Dialogs}
+\hypertarget{toc9}{}
+\subsubsection{Dialogs}
 All dialogs should implement the following:
  * Tooltip help for all toolbar icons and other relevant widgets
  * WhatsThis help for \textbf{all} widgets on the dialog
@@ -72,8 +81,10 @@
    that directs the user to the appropriate help page by launching their web
    browser
-\subsubsection{C++ Files}
-\minisec{Names}
+\hypertarget{toc10}{}
+\subsection{C++ Files}
+\hypertarget{toc11}{}
 C++ implementation and header files should be have a .cpp and .h extension
 respectively.  Filename should be all lowercase and, in the case of classes,
 match the class name.
@@ -89,7 +100,8 @@
 and implemented in its own file. This makes it much easier for newcomers to
 identify where the code is relating to specific class.
-\minisec{Standard Header and License}
+\hypertarget{toc12}{}
+\subsubsection{Standard Header and License}
 Each source file should contain a header section patterned after the following
 example:
@@ -110,8 +122,9 @@
 \end{verbatim}
-\minisec{SVN Keyword}
-Each source file should contain the \$Id\$ keyword. This will be expanded by CVS
+\hypertarget{toc13}{}
+\subsubsection{SVN Keyword}
+Each source file should contain the \$Id\$ keyword. This will be expanded by SVN
 to contain useful information about the file, revision, last committer, and
 date/time of last checkin.
@@ -122,7 +135,14 @@
   /* $Id$ */
 \end{verbatim}
-\subsubsection{Variable Names}
+You also need to set
+svn propset svn:keywords "Id"
+for the new files.
+\hypertarget{toc14}{}
+\subsection{Variable Names}
 Variable names begin with a lower case letter and are formed using mixed case.
 \begin{verbatim}
@@ -131,7 +151,8 @@
   currentExtent
 \end{verbatim}
-\subsubsection{Enumerated Types}
+\hypertarget{toc15}{}
+\subsection{Enumerated Types}
 Enumerated types should be named in CamelCase with a leading capital e.g.:
 \begin{verbatim}
@@ -147,28 +168,33 @@
 Do not use generic type names that will conflict with other types. e.g. use
 "UnkownUnit" rather than "Unknown"
-\subsubsection{Global Constants}
+\hypertarget{toc16}{}
+\subsection{Global Constants}
 Global constants should be written in upper case underscore separated e.g.:
 \begin{verbatim}
 const long GEOCRS_ID = 3344;
 \end{verbatim}
-\subsubsection{Editing}
+\hypertarget{toc17}{}
+\subsection{Editing}
 Any text editor/IDE can be used to edit QGIS code, providing the following
 requirements are met.
-\minisec{Tabs}
+\hypertarget{toc18}{}
+\subsubsection{Tabs}
 Set your editor to emulate tabs with spaces. Tab spacing should be set to 2
 spaces.
-\minisec{Indentation}
+\hypertarget{toc19}{}
+\subsubsection{Indentation}
 Source code should be indented to improve readability. There is a .indent.pro
 file in the QGIS src directory that contains the switches to be used when
 indenting code using the GNU indent program. If you don't use GNU indent, you
 should emulate these settings.
-\minisec{Braces}
+\hypertarget{toc20}{}
+\subsubsection{Braces}
 Braces should start on the line following the expression:
 \begin{verbatim}
@@ -183,7 +209,8 @@
 \end{verbatim}
-\subsubsection{API Compatibility}
+\hypertarget{toc21}{}
+\subsection{API Compatibility}
 From QGIS 1.0 we will provide a stable, backwards compatible API. This will
 provide a stable basis for people to develop against, knowing their code will
 work against any of the 1.x QGIS releases (although recompiling may be
@@ -208,11 +235,13 @@
 \end{verbatim}
-\subsubsection{Coding Style}
+\hypertarget{toc22}{}
+\subsection{Coding Style}
 Here are described some programming hints and tips that will hopefully reduce
 errors, development time, and maintenance.
-\minisec{Where-ever Possible Generalize Code}
+\hypertarget{toc23}{}
+\subsubsection{Where-ever Possible Generalize Code}
 \begin{verbatim}
 If you are cut-n-pasting code, or otherwise writing the same thing more than
 once, consider consolidating the code into a single function.
@@ -224,7 +253,8 @@
   * make it more difficult for multiple copies to evolve differences over time,
     thus making it harder to understand and maintain for others
-\minisec{Prefer Having Constants First in Predicates}
+\hypertarget{toc24}{}
+\subsubsection{Prefer Having Constants First in Predicates}
 Prefer to put constants first in predicates.
 \begin{verbatim}
@@ -236,7 +266,8 @@
 generate an error if you accidentally use "=" instead of "==" for comparisons
 since constants inherently cannot be assigned values.
-\minisec{Whitespace Can Be Your Friend}
+\hypertarget{toc25}{}
+\subsubsection{Whitespace Can Be Your Friend}
 Adding spaces between operators, statements, and functions makes it easier for
 humans to parse code.
@@ -252,7 +283,8 @@
 if ( ! a && b )
 \end{verbatim}
-\minisec{Add Trailing Identifying Comments}
+\hypertarget{toc26}{}
+\subsubsection{Add Trailing Identifying Comments}
 Adding comments at the end of function, struct and class implementations makes
 it easier to find them later.
@@ -272,7 +304,8 @@
 } // foo::bar()
 \end{verbatim}
-\minisec{Use Braces Even for Single Line Statements}
+\hypertarget{toc27}{}
+\subsubsection{Use Braces Even for Single Line Statements}
 Using braces for code in if/then blocks or similar code structures even for
 single line statements means that adding another statement is less likely to
 generate broken code.
@@ -303,28 +336,34 @@
 \end{verbatim}
-\minisec{Book recommendations}
+\hypertarget{toc28}{}
+\subsubsection{Book recommendations}
 \begin{itemize}
-\item \url{Effective C++}{http://www.awprofessional.com/title/0321334876}, Scott Meyers
-\item \url{More Effective C++}{http://www.awprofessional.com/bookstore/product.asp?isbn=020163371X\&rl=1}, Scott Meyers
-\item \url{Effective STL}{http://www.awprofessional.com/title/0201749629}, Scott Meyers
-\item \url{Design Patterns}{http://www.awprofessional.com/title/0201634988}, GoF
+\item \htmladdnormallink{Effective C++}{http://www.awprofessional.com/title/0321334876}, Scott Meyers
+\item \htmladdnormallink{More Effective C++}{http://www.awprofessional.com/bookstore/product.asp?isbn=020163371X\&rl=1}, Scott Meyers
+\item \htmladdnormallink{Effective STL}{http://www.awprofessional.com/title/0201749629}, Scott Meyers
+\item \htmladdnormallink{Design Patterns}{http://www.awprofessional.com/title/0201634988}, GoF
 \end{itemize}
-You should also really read this article from Qt Quarterly on
-\htmladdnormallink{http://doc.trolltech.com/qq/qq13-apis.html designing Qt style}{APIs}
-\subsection{SVN Access}
+You should also really read this article from Qt Quarterly on \\
+\url{http://doc.trolltech.com/qq/qq13-apis.html}
+\hypertarget{toc29}{}
+\section{SVN Access}
 This page describes how to get started using the QGIS Subversion repository
-\subsubsection{Accessing the Repository}
+\hypertarget{toc30}{}
+\subsection{Accessing the Repository}
 To check out QGIS HEAD:
 \begin{verbatim}
   svn --username [your user name] co https://svn.osgeo.org/qgis/trunk/qgis
 \end{verbatim}
-\subsubsection{Anonymous Access}
+\hypertarget{toc31}{}
+\subsection{Anonymous Access}
 You can use the following commands to perform an anonymous checkout from the
 QGIS Subversion repository.  Note we recommend checking out the trunk (unless
 you are a developer or really HAVE to have the latest changes and don't mind
@@ -346,10 +385,10 @@
   svn co https://svn.osgeo.org/qgis/trunk/qgis qgis_trunk
 \end{verbatim}
-/!$\backslash$ \textbf{Note:} If you are behind a proxy server, edit your \~{}/subversion/servers
+\textbf{Note:} If you are behind a proxy server, edit your \~{}/subversion/servers
 file to specify your proxy settings first!
-/!$\backslash$ \textbf{Note:} In QGIS we keep our most stable code in the version 1\_0 branch.
+\textbf{Note:} In QGIS we keep our most stable code in the version 1\_0 branch.
 Trunk contains code for the so called 'unstable' release series. Periodically
 we will tag a release off trunk, and then continue stabilisation and selective
 incorporation of new features into trunk.
@@ -357,7 +396,8 @@
 See the INSTALL file in the source tree for specific instructions on building
 development versions.
-\subsubsection{QGIS documentation sources}
+\hypertarget{toc32}{}
+\subsection{QGIS documentation sources}
 If you're interested in checking out Quantum GIS documentation sources:
 \begin{verbatim}
@@ -366,16 +406,20 @@
 You can also take a look at DocumentationWritersCorner for more information.
-\subsubsection{SVN Documentation}
+\hypertarget{toc33}{}
+\subsection{SVN Documentation}
 The repository is organized as follows:
 \htmladdnormallink{http://wiki.qgis.org/images/repo.png}{http://wiki.qgis.org/images/repo.png}
-See the Subversion book \htmladdnormallink{http://svnbook.red-bean.com}{http://svnbook.red-bean.com} for information on becoming
-a SVN master.
+See the Subversion book
+\htmladdnormallink{http://svnbook.red-bean.com}{http://svnbook.red-bean.com}
+for information on becoming a SVN master.
-\subsubsection{Development in branches}
-\minisec{Purpose}
+\hypertarget{toc34}{}
+\subsection{Development in branches}
+\hypertarget{toc35}{}
+\subsubsection{Purpose}
 The complexity of the QGIS source code has increased considerably during the
 last years. Therefore it is hard to anticipate the side effects that the
 addition of a feature will have. In the past, the QGIS project had very long
@@ -386,7 +430,8 @@
 This section describes the procedure for branching and merging in the QGIS
 project.
-\minisec{Procedure}
+\hypertarget{toc36}{}
+\subsubsection{Procedure}
 \begin{itemize}
 \item \textbf{Initial announcement on mailing list:}
 Before starting, make an announcement on the developer mailing list to see if
@@ -418,7 +463,8 @@
 \end{itemize}
-\minisec{Creating a branch}
+\hypertarget{toc37}{}
+\subsubsection{Creating a branch}
 We prefer that new feature developments happen out of trunk so that trunk
 remains in a stable state. To create a branch use the following command:
@@ -428,25 +474,26 @@
 svn commit -m "New feature branch"
 \end{verbatim}
-\minisec{Merge regularly from trunk to branch}
+\hypertarget{toc38}{}
+\subsubsection{Merge regularly from trunk to branch}
 When working in a branch you should regularly merge trunk into it so that your
 branch does not diverge more than necessary. In the top level dir of your
 branch, first type \texttt{`svn info`} to determine the revision numbers of your
 branch which will produce output something like this:
 \begin{verbatim}
-timlinux at timlinux-desktop:~/dev/cpp/qgis_raster_transparency_branch$ svn info
+timlinux at timlinux-desktop:~/dev/cpp/qgis_raster_transparency_branch svn info
 Caminho: .
 URL: https://svn.osgeo.org/qgis/branches/raster_transparency_branch
-Raiz do Repositrio: https://svn.osgeo.org/qgis
-UUID do repositrio: c8812cc2-4d05-0410-92ff-de0c093fc19c
-Reviso: 6546
-Tipo de N: diretrio
+Raiz do Repositorio: https://svn.osgeo.org/qgis
+UUID do repositorio: c8812cc2-4d05-0410-92ff-de0c093fc19c
+Revisao: 6546
+Tipo de No: diretorio
 Agendado: normal
-Autor da ltima Mudana: timlinux
-Reviso da ltima Mudana: 6495
-Data da ltima Mudana: 2007-02-02 09:29:47 -0200 (Sex, 02 Fev 2007)
-Propriedades da ltima Mudana: 2007-01-09 11:32:55 -0200 (Ter, 09 Jan 2007)
+Autor da Ultima Mudanca: timlinux
+Revisao da Ultima Mudanca: 6495
+Data da Ultima Mudanca: 2007-02-02 09:29:47 -0200 (Sex, 02 Fev 2007)
+Propriedades da Ultima Mudanca: 2007-01-09 11:32:55 -0200 (Ter, 09 Jan 2007)
 \end{verbatim}
 The second revision number shows the revision number of the start revision of
@@ -465,11 +512,13 @@
 svn commit -m "Merged upstream changes from trunk to my branch"
 \end{verbatim}
-\subsubsection{Submitting Patches}
+\hypertarget{toc39}{}
+\subsection{Submitting Patches}
 There are a few guidelines that will help you to get your patches into QGIS
 easily, and help us deal with the patches that are sent to use easily.
-\minisec{Patch file naming}
+\hypertarget{toc40}{}
+\subsubsection{Patch file naming}
 If the patch is a fix for a specific bug, please name the file with the bug
 number in it e.g.  \textbf{bug777fix.diff}, and attach it to the original bug report
 in trac (\htmladdnormallink{https://trac.osgeo.org/qgis/}{https://trac.osgeo.org/qgis/}).
@@ -477,7 +526,8 @@
 If the bug is an enhancement or new feature, its usually a good idea to create
 a ticket in trac (\htmladdnormallink{https://trac.osgeo.org/qgis/}{https://trac.osgeo.org/qgis/}) first and then attach you
-\minisec{Create your patch in the top level QGIS source dir}
+\hypertarget{toc41}{}
+\subsubsection{Create your patch in the top level QGIS source dir}
 This makes it easier for us to apply the patches since we don't need to
 navigate to a specific place in the source tree to apply the patch. Also when I
 receive patches I usually evaluate them using kompare, and having the patch
@@ -490,7 +540,8 @@
 svn diff src/ui/somefile.ui src/app/somefile2.cpp > bug872fix.diff
 \end{verbatim}
-\minisec{Including non version controlled files in your patch}
+\hypertarget{toc42}{}
+\subsubsection{Including non version controlled files in your patch}
 If your improvements include new files that don't yet exist in the repository,
 you should indicate to svn that they need to be added before generating your
 patch e.g.
@@ -501,7 +552,8 @@
 svn diff > bug7887fix.diff
 \end{verbatim}
-\minisec{Getting your patch noticed}
+\hypertarget{toc43}{}
+\subsubsection{Getting your patch noticed}
 QGIS developers are busy folk. We do scan the incoming patches on bug reports
 but sometimes we miss things.  Don't be offended or alarmed. Try to identify a
 developer to help you - using the ["Project Organigram"] and contact them
@@ -509,13 +561,15 @@
 can escalate your query to one of the Project Steering Committee members
 (contact details also available on the ["Project Organigram"]).
-\minisec{Due Diligence}
+\hypertarget{toc44}{}
+\subsubsection{Due Diligence}
 QGIS is licensed under the GPL. You should make every effort to ensure you only
 submit patches which are unencumbered by conflicting intellectual property
 rights. Also do not submit code that you are not happy to have made available
 under the GPL.
-\subsubsection{Obtaining SVN Write Access}
+\hypertarget{toc45}{}
+\subsection{Obtaining SVN Write Access}
 Write access to QGIS source tree is by invitation. Typically when a person
 submits several (there is no fixed number here) substantial patches that
 demonstrate basic competance and understanding of C++ and QGIS coding
@@ -528,7 +582,8 @@
 substantial patches that demonstrate their understanding of modifying the code
 base without breaking things, etc.
-\minisec{Procedure once you have access}
+\hypertarget{toc46}{}
+\subsubsection{Procedure once you have access}
 Checkout the sources:
 \begin{verbatim}
@@ -576,7 +631,7 @@
 svn commit src/pluguns/grass/modules/foo.xml
 \end{verbatim}
-Your editor (as defined in \$EDITOR environment variable) will appear and you
+Your editor (as defined in EDITOR environment variable) will appear and you
 should make a comment at the top of the file (above the area that says 'don't
 change this'. Put a descriptive comment and rather do several small commits if
 the changes across a number of files are unrelated. Conversely we prefer you to
@@ -587,14 +642,16 @@
 trac account.
-\subsection{Unit Testing}
+\hypertarget{toc47}{}
+\section{Unit Testing}
 As of November 2007 we require all new features going into trunk to be
 accompanied with a unit test. Initially we have limited this requirement to
 \textbf{qgis\_core}, and we will extend this requirement to other parts of the code base
 once people are familiar with the procedures for unit testing explained in the
 sections that follow.
-\subsubsection{The QGIS testing framework  - an overview}
+\hypertarget{toc48}{}
+\subsection{The QGIS testing framework  - an overview}
 Unit testing is carried out using a combination of QTestLib (the Qt testing
 library) and CTest (a framework for compiling and running tests as part of the
 CMake build process).  Lets take an overview of the process before I delve into
@@ -645,7 +702,8 @@
 already done much of the configuration for you in CMake and other places in the
 source tree so all you need to do are the easy bits - writing unit tests!
-\subsubsection{Creating a unit test}
+\hypertarget{toc49}{}
+\subsection{Creating a unit test}
 Creating a unit test is easy - typically you will do this by just creating a
 single .cpp file (not .h file is used) and implement all your test methods as
 public methods that return void. I'll use a simple test class for
@@ -679,6 +737,9 @@
 #include <QtTest>
 \end{verbatim}
+\textbf{Note} that we use the new style Qt4 includes - i.e. QtTest is included not
+qttest.h
 Beyond that you just continue implementing your class as per normal, pulling
 in whatever headers you may need:
@@ -837,14 +898,10 @@
 #endif
   //create some objects that will be used in all tests...
-  std::cout << "Prefix  PATH: " << QgsApplication::prefixPath().toLocal8Bit().data()
-  << std::endl;
-  std::cout << "Plugin  PATH: " << QgsApplication::pluginPath().toLocal8Bit().data()
-  << std::endl;
-  std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data()
-  << std::endl;
-  std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data()
-  << std::endl;
+  std::cout << "Prefix  PATH: " << QgsApplication::prefixPath().toLocal8Bit().data() << std::endl;
+  std::cout << "Plugin  PATH: " << QgsApplication::pluginPath().toLocal8Bit().data() << std::endl;
+  std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data() << std::endl;
+  std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data() << std::endl;
   //create a raster layer that will be used in all tests...
   QString myFileName (TEST_DATA_DIR); //defined in CmakeLists.txt
@@ -941,7 +998,8 @@
 line is the include for the MOC generated sources. You should replace
 'testqgsrasterlayer' with the name of your class in lower case.
-\subsubsection{Adding your unit test to CMakeLists.txt}
+\hypertarget{toc50}{}
+\subsection{Adding your unit test to CMakeLists.txt}
 Adding your unit test to the build system is simply a matter of editing the
 CMakeLists.txt in the test directory, cloning one of the existing test blocks,
 and then replacing your test class name into it.  For example:
@@ -951,7 +1009,8 @@
 ADD_QGIS_TEST(rasterlayertest testqgsrasterlayer.cpp)
 \end{verbatim}
-\subsubsection{The ADD\_QGIS\_TEST macro explained}
+\hypertarget{toc51}{}
+\subsection{The ADD\_QGIS\_TEST macro explained}
 I'll run through these lines briefly to explain what they do, but if you are
 not interested, just do the step explained in the above section and section.
@@ -1064,7 +1123,8 @@
 suite of tests and you want to run each executeable in turn, and better yet
 integrate running tests into the build process, the \textbf{CTest} is what we use.
-\subsubsection{Building your unit test}
+\hypertarget{toc52}{}
+\subsection{Building your unit test}
 To build the unit test you need only to make sure that ENABLE\_TESTS=true in the
 cmake configuration. There are two ways to do this:
@@ -1074,7 +1134,8 @@
 Other than that, just build QGIS as per normal and the tests should build too.
-\subsubsection{Run your tests}
+\hypertarget{toc53}{}
+\subsection{Run your tests}
 The simplest way to run the tests is as part of your normal build process:
 \begin{verbatim}
@@ -1128,8 +1189,8 @@
   User DB PATH: /Users/tim/.qgis/qgis.db
   QDEBUG : TestQgsApplication::checkTheme() Checking if a theme icon exists:
-  /Users/tim/dev/cpp/qgis/build/tests/src/core/../ \
-  /share/qgis/themes/default//mIconProjectionDisabled.png
+  /Users/tim/dev/cpp/qgis/build/tests/src/core/..//share/qgis/themes/default/
+/mIconProjectionDisabled.png
   FAIL!  : TestQgsApplication::checkTheme() '!myPixmap.isNull()' returned FALSE. ()
   Loc: [/Users/tim/dev/cpp/qgis/tests/src/core/testqgsapplication.cpp(59)]
 PASS   : TestQgsApplication::cleanupTestCase()
@@ -1143,7 +1204,6 @@
   The following tests FAILED:
 1 - qgis_applicationtest (Failed)
   Errors while running CTest
 \end{verbatim}
 Well that concludes this section on writing unit tests in QGIS. We hope you
@@ -1154,7 +1214,8 @@
 progress.
-\subsection{HIG (Human Interface Guidelines)}
+\hypertarget{toc54}{}
+\section{HIG (Human Interface Guidelines)}
 In order for all graphical user interface elements to appear consistant and to
 all the user to instinctively use dialogs, it is important that the following
 guidelines are followed in layout and design of GUIs.
@@ -1170,7 +1231,7 @@
  \item Do not end labels for widgets or group boxes with a colon:
    Adding a colon causes visual noise and does not impart additional meaning,
    so don't use them. An exception to this rule is when you have two labels next
-   to each other e.g.: Label1 \htmladdnormallink{Plugin}{Path:} Label2 [/path/to/plugins]
+   to each other e.g.: Label1 {Plugin}{Path:} Label2 [/path/to/plugins]
  \item Keep harmful actions away from harmless ones:
    If you have actions for 'delete', 'remove' etc, try to impose adequate space
    between the harmful action and innocuous actions so that the users is less
Added: docs/trunk/english_us/coding-compilation_guide/floatflt.sty
--- docs/trunk/english_us/coding-compilation_guide/floatflt.sty	                        (rev 0)
+++ docs/trunk/english_us/coding-compilation_guide/floatflt.sty	2010-07-27 10:23:35 UTC (rev 13969)
@@ -0,0 +1,348 @@
+%% This is file `floatflt.sty',
+%% generated with the docstrip utility.
+%% The original source files were:
+%% floatflt.dtx  (with options: `paketkod')
+%% Copyright (c) 1994-1998 by Mats Dahlgren <matsd at sssk.se>.
+%% All rights reserved.  See the file `floatflt.ins' for information
+%% on how you may (re-)distribute the `floatflt' package files.
+%% You are not allowed to make any changes to this file without
+%% explicit permission from the author.
+\NeedsTeXFormat{LaTeX2e}[1996/12/01]
+\ProvidesPackage{floatflt}[1997/07/16 v. 1.31]
+\newcounter{OptionTest}
+\setcounter{OptionTest}{0}
+\DeclareOption{rflt}{\setcounter{OptionTest}{1}}
+\DeclareOption{lflt}{\setcounter{OptionTest}{2}}
+\DeclareOption{vflt}{\setcounter{OptionTest}{0}}
+\DeclareOption*{\OptionNotUsed}
+\ProcessOptions
+\newbox\figbox
+\newbox\tabbox
+\newbox\pagebox
+\newcount\ffigcount
+\newcount\ftabcount
+\newcount\fftest
+\newcount\hangcount
+\newcount\nosuccesstryfig
+\newcount\nosuccesstrytab
+\newdimen\figgutter   \figgutter=1truepc
+\newdimen\tabgutter   \tabgutter=1truepc
+\newdimen\htdone      \htdone=0pt
+\newdimen\pageht
+\newdimen\startpageht
+\newdimen\tabbredd
+\newdimen\floatfltwidth
+\newdimen\fltitemwidth
+\newif\iftryingfig     \tryingfigfalse
+\newif\iftryingtab     \tryingtabfalse
+\newif\ifdoingfig      \doingfigfalse
+\newif\ifdoingtab      \doingtabfalse
+\newif\iffigprocessing \figprocessingfalse
+\newif\iftabprocessing \tabprocessingfalse
+\newif\ifpageafterfig  \pageafterfigfalse
+\newif\ifpageaftertab  \pageaftertabfalse
+\newif\ifoddpages
+\newif\ifoutput
+\newtoks\outputpretest
+\newenvironment{floatingfigure}[2][v]%
+{\@tfor \@tempa :=#1\do
+         {\if\@tempa r\global\oddpagestrue\fi
+          \if\@tempa l\global\oddpagesfalse\fi
+          \if\@tempa p%
+              \ifodd\c at page\global\oddpagestrue
+                \else\global\oddpagesfalse\fi
+          \fi
+          \if\@tempa v%
+             \ifnum\theOptionTest=0
+             \else
+                  \ifodd\theOptionTest\global\oddpagestrue
+             \fi
+          \fi
+ \expandafter\ifx\csname oldoutput\endcsname\relax% ref. TeXbook Ex.7.7
+    \PackageError{floatflt}{The `floatflt' package is not initialized}
+     {Try to reinstall the `floatflt' package.\MessageBreak
+      Type `x' to quit or <Return> to try to go on.}\@@end\fi
+ \global\everypar={\tryfig\oldeverypar}% must be set globally!
+ \global\advance\ffigcount by 1
+ \iffigprocessing
+    {\count0=\ffigcount\advance\count0 by -1
+     \PackageWarningNoLine{floatflt}{Floating figures \the\count0\space%
+       \space and \the\ffigcount\space colliding}%
+ \fi
+ \iftabprocessing \PackageWarningNoLine{floatflt}{Floating figure %
+   \the\ffigcount\space and floating table \the\ftabcount\space colliding}
+ \fi
+ \def\@captype{figure}
+ \global\setlength{\floatfltwidth}{#2}
+ \global\figprocessingtrue
+ \global\setbox\figbox=\vbox\bgroup% begin of figbox
+                               \hrule height 0pt width #2 depth 0pt%
+                               \hsize=#2%
+\egroup
+\figinsert\par%
+\newenvironment{floatingtable}[2][v]%
+          \if\@tempa p%
+          \fi
+          \if\@tempa v%
+             \ifnum \theOptionTest=0
+             \else
+             \fi
+          \fi
+\expandafter\ifx\csname oldoutput\endcsname\relax% ref. TeXbook Ex.7.7
+\global\setbox\tabbox=\vbox\bgroup\hrule height 0pt width 0pt depth 0pt%
+   \hsize=0pt\egroup
+ \global\everypar={\trytab\oldeverypar}
+ \global\advance\ftabcount by 1
+ \iftabprocessing
+    {\count0=\ftabcount\advance\count0 by -1
+     \PackageWarningNoLine{floatflt}{Floating tables \the\count0\space%
+            \space and \the\ftabcount \space colliding}%
+ \fi
+ \iftabprocessing \PackageWarningNoLine{floatflt}{Floating table %
+   \the\ffigcount\space and floating figure \the\ftabcount\space colliding}
+ \fi
+ \settowidth{\tabbredd}{#2}
+ \global\setlength{\floatfltwidth}{\tabbredd}
+ \def\@captype{table}
+ \global\tabprocessingtrue
+ \global\setbox\tabbox=\vbox\bgroup% begin of tabbox
+                              \hrule height 0pt width\tabbredd depth 0pt%
+                               \hsize=\tabbredd
+\noindent\ifnum\ftabcount >1\ifoddpages\else\hspace*{-12pt}\fi\fi%
+#2\vspace{0.2\baselineskip}%
+\egroup% end of \tabbox
+\tabinsert\par%
+\AtBeginDocument{%
+\edef\oldoutput{\the\output}%
+\output={\the\outputpretest%
+           \ifoutput\oldoutput\fi}
+\outputpretest={\outputtrue}
+\edef\oldeverypar{\the\everypar}
+\def\dofigtest{%
+   \ifnum\outputpenalty=-10005
+     \setbox\pagebox=\vbox{\unvbox255}%
+     \global\pageht=\ht\pagebox
+     \global\outputfalse
+     \unvbox\pagebox
+   \else
+     \global\outputtrue
+     \ifdoingfig
+         \global\pageafterfigtrue
+     \fi
+   \fi}%
+\def\dotabtest{%
+     \unvbox\pagebox
+   \else
+     \ifdoingtab
+         \global\pageaftertabtrue
+     \fi
+   \fi}%
+\def\tryfig{%
+      \iftryingfig
+       {\everypar={\relax}\setbox0=\lastbox%
+       \parindent=\wd0 \parskip=0pt \par%
+       \penalty-10005 \leavevmode}%
+       \dimen0=\vsize%
+       \advance\dimen0 by -\pageht%
+       \advance\dimen0 by -2\baselineskip%
+       \ifdim\dimen0>\ht\figbox%
+         \dimen0=0.3\baselineskip
+         \vrule depth \dimen0 width 0pt
+         \vadjust{\kern -\dimen0%
+         \vtop to \dimen0{%
+             \baselineskip=\dimen0%
+             \vss \vbox to 1ex{%
+             \ifoddpages%
+               \hbox to \hsize{\hss\copy\figbox}%
+             \else% leftsetting
+               \hbox to \hsize{\copy\figbox\hss}%
+             \fi% \ifodd\count0
+             \vss}\null}}%
+       \global\tryingfigfalse%
+       \global\doingfigtrue
+       \global\startpageht=\pageht
+       \global\htdone=0pt
+       \dohangf
+       \ifnum\nosuccesstryfig>0%
+         \typeout{floatflt Message: Flt. fig. \the\ffigcount\space set on page
+             \the\count0, shifted \the\nosuccesstryfig\space par(s) forward.}%
+       \else
+         \typeout{Package floatflt Message: Floating figure \the\ffigcount
+              \space set on page \the\count0}%
+       \fi
+     \else
+       \global\advance\nosuccesstryfig by 1
+     \fi
+     \else%
+     \ifdoingfig
+    \global\htdone=\pageht
+    \global\advance\htdone by -\startpageht
+    \ifpageafterfig
+      \global\doingfigfalse
+    \else
+      \dimen0=\ht\figbox%
+      \advance\dimen0 by 0.5\baselineskip%
+      \ifdim\htdone<\dimen0%
+         \dohangf
+      \else
+      \fi
+    \fi
+    \ifdoingfig\relax\else\global\figprocessingfalse\fi
+  \else
+    \global\outputpretest={\outputtrue}%
+  \fi
+\fi
+\def\trytab{%
+      \iftryingtab%
+       \dimen0=\vsize%
+       \ifdim\dimen0>\ht\tabbox%
+              \ifoddpages%
+               \hbox to \hsize{\hss\copy\tabbox}%
+               \hbox to \hsize{\copy\tabbox\hss}%
+             \vss}\null}}%
+       \global\tryingtabfalse%
+       \global\doingtabtrue
+       \dohangt
+       \ifnum\nosuccesstrytab>0%
+         \typeout{floatflt Message: Flt. tab. \the\ftabcount\space set on page
+             \the\count0, shifted \the\nosuccesstrytab\space par(s) forward.}%
+       \else
+         \typeout{Package floatflt Message: Floating table \the\ftabcount\space
+                  set on page \the\count0}%
+       \fi
+     \else
+       \global\advance\nosuccesstrytab by 1
+     \fi
+     \else
+     \ifdoingtab
+    \ifpageaftertab
+      \global\doingtabfalse
+    \else
+      \dimen0=\ht\tabbox%
+         \dohangt
+      \else
+      \fi
+    \fi
+    \ifdoingtab\relax\else\global\tabprocessingfalse\fi
+  \else
+  \fi
+\fi
+\def\figinsert{%
+   \global\nosuccesstryfig=0%
+   \global\outputpretest={\dofigtest}%
+   \global\tryingfigtrue \global\doingfigfalse%
+   \global\pageafterfigfalse}%
+\def\tabinsert{%
+   \global\nosuccesstrytab=0%
+   \global\outputpretest={\dotabtest}%
+   \global\tryingtabtrue \global\doingtabfalse%
+   \global\pageaftertabfalse}%
+\def\dohangf{%
+   \advance\dimen0 by -\htdone%
+   \advance\dimen0 by 1.49\baselineskip%
+   \hangcount=\dimen0%
+   \divide\hangcount by \baselineskip%
+   \dimen0=\wd\figbox%
+   \advance\dimen0 by \figgutter%
+   \ifoddpages%
+     \global\hangafter=-\hangcount% placing right
+     \global\hangindent=-\dimen0%
+   \else% \ifleftsetting
+     \global\hangafter=-\hangcount% placing left
+     \global\hangindent=\dimen0%
+   \fi
+\def\dohangt{%
+   \dimen0=\wd\tabbox%
+   \advance\dimen0 by \tabgutter%
+   \ifoddpages%
+   \fi
+\newcommand{\fltitem}[2][0pt]{\setlength{\fltitemwidth}{\linewidth}%
+  \addtolength{\fltitemwidth}{-\floatfltwidth}%
+  \addtolength{\fltitemwidth}{-0.5em}%
+  \item \parbox[t]{\fltitemwidth}{#2}\\[#1]}
+\newcommand{\fltditem}[3][0pt]{\setlength{\fltitemwidth}{\linewidth}%
+  \item[#2] \parbox[t]{\fltitemwidth}{#3}\\[#1]}
+\endinput
+%% End of file `floatflt.sty'.
Modified: docs/trunk/english_us/coding-compilation_guide/install.tex
--- docs/trunk/english_us/coding-compilation_guide/install.tex	2010-07-27 07:56:31 UTC (rev 13968)
+++ docs/trunk/english_us/coding-compilation_guide/install.tex	2010-07-27 10:23:35 UTC (rev 13969)
@@ -2,30 +2,32 @@
 \section{Installation Guide}\label{label_install}
-% when the revision of a section has been finalized,
+% when the revision of a subsection has been finalized,
 % \updatedisclaimer
 The following chapters provide build and installation information for QGIS
 Version \CURRENT. This document corresponds almost to a \LaTeX~ conversion of
-the INSTALL.t2t file coming with the QGIS sources from November, 27th 2009.
+the INSTALL.t2t file coming with the QGIS sources from July, 27th 2010.
 A current version is also available at the wiki, see:
 \url{http://www.qgis.org/wiki/Installation_Guide}
 \subsection{General Build Notes}
 Since version 0.8.1 QGIS no longer uses the autotools for building. QGIS, like a
 number of major projects (eg. KDE 4.0), now uses CMake (\htmladdnormallink{http://www.cmake.org}{http://www.cmake.org})
 for building from source. The configure script in this directory simply checks
 for the existence of cmake and provides some clues to build QGIS.
 \subsubsection{An overview of the dependencies required for building}
 '''Required build deps:'''
-* CMake $>$= 2.4.3
+* CMake $>$= 2.6.0
 * Flex, Bison
 '''Required runtime deps:'''
-* Qt $>$= 4.3.0
+* Qt $>$= 4.4.0
 * Proj $>$= 4.4.x
 * GEOS $>$= 3.0
 * Sqlite3 $>$= 3.0.0
@@ -44,21 +46,23 @@
 * for gps plugin - gpsbabel
 \subsection{Building under windows using msys}
 \textbf{Note:} For a detailed account of building all the dependencies yourself you
 can visit Marco Pasetti's website here:
-\htmladdnormallink{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}
+\url{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}
 Read on to use the simplified approach with pre-built libraries...
 \subsubsection{MSYS:}
 MSYS provides a unix style build environment under windows. We have created a
 zip archive that contains just about all dependencies.
 Get this:
-\htmladdnormallink{http://download.osgeo.org/qgis/win32/msys.zip}{http://download.osgeo.org/qgis/win32/msys.zip}
+\url{http://download.osgeo.org/qgis/win32/msys.zip}
 and unpack to c:$\backslash$msys
@@ -66,6 +70,7 @@
 our pre-made one, detailed instructions are provided elsewhere in this
 document.
 \subsubsection{Qt4.3}
 Download qt4.3 opensource precompiled edition exe and install (including the
 download and install of mingw) from here:
@@ -99,32 +104,36 @@
 c:\Qt\4.3.0 make
 \end{verbatim}
 \subsubsection{Flex and Bison}
-*** Note I think this section can be removed as it should be installed int the
+*** Note I think this subsection can be removed as it should be installed int the
 msys image already. TS
 Get Flex
-\htmladdnormallink{http://sourceforge.net/project/showfiles.php?group\_id=23617\&package\_id=16424}{http://sourceforge.net/project/showfiles.php?group\_id=23617\&package\_id=16424}
+\url{http://sourceforge.net/project/showfiles.php?group\_id=23617\&package\_id=16424}
 (the zip bin) and extract it into c:$\backslash$msys$\backslash$mingw$\backslash$bin
 \subsubsection{Python stuff: (optional)}
-Follow this section in case you would like to use Python bindings for QGIS.  To
+Follow this subsection in case you would like to use Python bindings for QGIS.  To
 be able to compile bindings, you need to compile SIP and PyQt4 from sources as
 their installer doesn't include some development files which are necessary.
 \minisec{Download and install Python - use Windows installer}
 (It doesn't matter to what folder you'll install it)
-\htmladdnormallink{http://python.org/download/}{http://python.org/download/}
+\url{http://python.org/download/}
 \minisec{Download SIP and PyQt4 sources}
-\htmladdnormallink{http://www.riverbankcomputing.com/software/sip/download}{http://www.riverbankcomputing.com/software/sip/download}
+\url{http://www.riverbankcomputing.com/software/sip/download}
+\url{http://www.riverbankcomputing.com/software/pyqt/download}
-\htmladdnormallink{http://www.riverbankcomputing.com/software/pyqt/download}{http://www.riverbankcomputing.com/software/pyqt/download}
 Extract each of the above zip files in a temporary directory. Make sure
 to get versions that match your current Qt installed version.
 \minisec{Compile SIP}
 \begin{verbatim}
 c:\Qt\4.3.0\bin\qtvars.bat
@@ -133,6 +142,7 @@
 make install
 \end{verbatim}
 \minisec{Compile PyQt}
 \begin{verbatim}
@@ -141,21 +151,25 @@
 make install
 \end{verbatim}
 \minisec{Final python notes}
-/!$\backslash$ You can delete the directories with unpacked SIP and PyQt4 sources after a
+You can delete the directories with unpacked SIP and PyQt4 sources after a
 successfull install, they're not needed anymore.
 \subsubsection{Subversion:}
 In order to check out QGIS sources from the repository, you need Subversion
 client. This installer should work fine:
 \htmladdnormallink{http://subversion.tigris.org/files/documents/15/36797/svn-1.4.3-setup.exe}{http://subversion.tigris.org/files/documents/15/36797/svn-1.4.3-setup.exe}
 \subsubsection{CMake:}
 CMake is build system used by Quantum GIS. Download it from here:
 \htmladdnormallink{http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe}{http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe}
 \subsubsection{QGIS:}
 Start a cmd.exe window ( Start -$>$ Run -$>$ cmd.exe ) Create development
 directory and move into it
@@ -176,6 +190,7 @@
  svn co https://svn.osgeo.org/qgis/branches/Release-0_8_0 qgis0.8
 \end{verbatim}
 \subsubsection{Compiling:}
 As a background read the generic building with CMake notes at the end of
 this document.
@@ -197,12 +212,13 @@
 cd build
 \end{verbatim}
 \subsubsection{Configuration}
 \begin{verbatim}
 cmakesetup ..
 \end{verbatim}
-/!$\backslash$ NOTE: You must include the '..' above.
+NOTE: You must include the '..' above.
 Click 'Configure' button.  When asked, you should choose 'MinGW Makefiles'
 as generator.
@@ -219,18 +235,20 @@
 When configuration is done, click 'OK' to exit the setup utility.
 \subsubsection{Compilation and installation}
 \begin{verbatim}
  make make install
 \end{verbatim}
-\minisec{Run qgis.exe from the directory where it's installed (CMAKE\_INSTALL\_PREFIX)}
+\subsubsection{Run qgis.exe from the directory where it's installed (CMAKE\_INSTALL\_PREFIX)}
 Make sure to copy all .dll:s needed to the same directory as the qgis.exe
 binary is installed to, if not already done so, otherwise QGIS will complain
 about missing libraries when started.
 The best way to do this is to download both the QGIS current release installer
-package from \htmladdnormallink{http://qgis.org/uploadfiles/testbuilds/}{http://qgis.org/uploadfiles/testbuilds/} and install it. Now copy
+package from \url{http://qgis.org/uploadfiles/testbuilds/} and install it. Now copy
 the installation dir from C:$\backslash$Program Files$\backslash$Quantum GIS into c:$\backslash$Program
 Files$\backslash$qgis-0.8.1 (or whatever the current version is. The name should strictly
 match the version no.) After making this copy you can uninstall the release
@@ -242,19 +260,21 @@
 c:$\backslash$msys$\backslash$local$\backslash$bin and c:$\backslash$msys$\backslash$local$\backslash$lib directories, so the DLLs will be
 used from that place.
 \subsubsection{Create the installation package: (optional)}
-Downlad and install NSIS from (\htmladdnormallink{http://nsis.sourceforge.net/Main\_Page}{http://nsis.sourceforge.net/Main\_Page})
+Downlad and install NSIS from (\url{http://nsis.sourceforge.net/Main\_Page})
 Now using windows explorer, enter the win\_build directory in your QGIS source
 tree. Read the READMEfile there and follow the instructions. Next right click
 on qgis.nsi and choose the option 'Compile NSIS Script'.
 \subsection{Building on Mac OSX using frameworks and cmake or Xcode}
 In this approach I will try to avoid as much as possible building dependencies
 from source and rather use frameworks wherever possible.
-The base system here is Mac OS X 10.4 (\underline{Tiger}) and below. Included are a few notes
+The base system here is Mac OS X 10.4 (\underline{Tiger}). Included are a few notes
 for building on Mac OS X 10.5 (\underline{Leopard}) and 10.6 (\underline{Snow Leopard}).
 \underline{Snow Leopard note:} A cmake/qt/sip bug currently exists where a 32-bit
@@ -262,6 +282,7 @@
 is currently lacking for 32-bit builds using cmake in Snow Leopard. See the Xcode
 build method to if you require python support.
 \subsubsection{Install Xcode}
 I recommend to get the latest Xcode dmg from the Apple XDC Web site
 (http:/developer.apple.com). The Mac system install disks come with a copy of
@@ -277,8 +298,9 @@
 sudo ln -s /usr/local/ local
 \end{verbatim}
 \subsubsection{Install Qt4 from .dmg}
-You need a minimum of Qt-4.3.0. I suggest getting the latest.
+You need a minimum of Qt-4.4.0. I suggest getting the latest.
 \underline{Snow Leopard note:} If you are building on Snow Leopard, you will need to
 decide between 32-bit support in the older, Qt Carbon branch, or 64-bit
@@ -295,7 +317,7 @@
 Once downloaded open the dmg and run the installer. Note you need admin
 privileges to install.
-\underline{Qt 4.4+ note:} Starting in Qt 4.4 (?) libQtCLucene was added, and in 4.5
+\underline{Qt note:} Starting in Qt 4.4, libQtCLucene was added, and in 4.5
 libQtUiTools was added, both in /usr/lib.  When using a system SDK (which will
 happen in the Xcode build), these libraries will not be found.  To fix this problem,
 add symlinks to /usr/local:
@@ -309,13 +331,14 @@
 may need some help by adding '-L/usr/local/lib' to CMAKE\_SHARED\_LINKER\_FLAGS,
 CMAKE\_MODULE\_LINKER\_FLAGS and CMAKE\_EXE\_LINKER\_FLAGS in the cmake build.
 \subsubsection{Install development frameworks for QGIS dependencies}
 Download William Kyngesburye's excellent GDAL Complete package that includes
 PROJ, GEOS, GDAL, SQLite3, and image libraries, as frameworks.  There is also
 a GSL framework.
 \begin{verbatim}
-http://www.kyngchaos.com/wiki/software:frameworks
+http://www.kyngchaos.com/wiki/software/frameworks
 \end{verbatim}
 Once downloaded, open and install the frameworks.
@@ -326,15 +349,16 @@
 It's available here:
 \begin{verbatim}
-http://www.kyngchaos.com/wiki/software:postgres
+http://www.kyngchaos.com/wiki/software/postgres
 \end{verbatim}
 Also available is a GRASS application:
 \begin{verbatim}
-http://www.kyngchaos.com/wiki/software:grass
+http://www.kyngchaos.com/wiki/software/grass
 \end{verbatim}
 \minisec{Additional Dependencies : General compatibility note}
 There are some additional dependencies that, at the time of writing, are not
 provided as frameworks or installers so we will need to build these from source.
@@ -344,6 +368,10 @@
 default system architecture, which is 64-bit, according to instructions for
 individual dependency packages.
+Stable release versions are preferred.  Beta and other development versions may
+have problems and you are on your own with those.
 \minisec{Additional Dependencies : Expat}
 \underline{Snow Leopard note:} Snow Leopard includes a usable expat, so this step is
 not necessary on Snow Leopard.
@@ -362,12 +390,7 @@
 sudo make install
 \end{verbatim}
-\underline{Leopard note:} To compile for 64bit, substitute the standard configure line with:
-\begin{verbatim}
-./configure CFLAGS="-Os -arch x86_64"
-\end{verbatim}
 \minisec{Additional Dependencies : Python}
 \underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard include a usable
 Python 2.5 and 2.6, respectively. So there is no need to install Python on
@@ -381,6 +404,7 @@
 Python 3 is a major change, and may have compatibility issues, so try it at your own risk.
 \minisec{Additional Dependencies : SIP}
 Retrieve the python bindings toolkit SIP from
@@ -404,8 +428,8 @@
 basic configure above:
 \begin{verbatim}
-python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin \
--e /usr/local/include -v /usr/local/share/sip
+python configure.py -n -d /Library/Python/2.5/site-packages -b /usr/local/bin \
+-e /usr/local/include -v /usr/local/share/sip -s MacOSX10.5.sdk
 \end{verbatim}
 \underline{Snow Leopard notes}
@@ -416,17 +440,18 @@
 'arch' command, 'python' does not). If you are using 32-bit Qt (Qt Carbon):
 \begin{verbatim}
-python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin
--e /usr/local/include -v /usr/local/share/sip --arch=i386
+python2.6 configure.py -n -d /Library/Python/2.6/site-packages -b /usr/local/bin \
+-e /usr/local/include -v /usr/local/share/sip --arch=i386 -s MacOSX10.6.sdk
 \end{verbatim}
 For 64-bit Qt (Qt Cocoa), use this configure line:
 \begin{verbatim}
--e /usr/local/include -v /usr/local/share/sip --arch=x86_64
+-e /usr/local/include -v /usr/local/share/sip --arch=x86_64 -s MacOSX10.6.sdk
 \end{verbatim}
 \minisec{Additional Dependencies : PyQt}
 Retrieve the python bindings toolkit for Qt from
@@ -438,12 +463,11 @@
 and (this installs by default into the Python framework, and is appropriate only for python.org Python installs):
 \begin{verbatim}
-export QTDIR=/Developer/Applications/Qt
 python configure.py
 yes
 \end{verbatim}
-There is a problem with the configuration that needs to be fixed now (it affect PyQwt compilation later).  Edit pyqtconfig.py and change the qt\_dir line to:
+There is a problem with the configuration that needs to be fixed now (it affects PyQwt compilation later).  Edit pyqtconfig.py and change the qt\_dir line to:
 \begin{verbatim}
     'qt_dir': '/usr',
@@ -479,15 +503,18 @@
 \begin{verbatim}
-python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
+python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin \
+--use-arch i386
 \end{verbatim}
 \begin{verbatim}
-python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch x86_64
+--use-arch x86_64
 \end{verbatim}
 \minisec{Additional Dependencies : Qwt/PyQwt}
 The GPS tracking feature uses Qwt.  Some popular 3rd-party plugins use PyQwt.
 You can take care of both with the PyQwt source from:
@@ -496,14 +523,25 @@
 http://pyqwt.sourceforge.net/
 \end{verbatim}
-Double-click the tarball to unpack it.
+Double-click the tarball to unpack it.  The following assumes PyQwt v5.2.0 (comes with Qwt 5.2.1).
 Now, first edit qwtconfig.pri in the qwt-5.2 subdir and change some settings so
-you don't get a bloated debug static library (too bad they are configurable from
+you don't get a bloated debug static library (too bad they are not configurable from
 qmake).  Scroll down to the 'release/debug mode' block.  Edit the last 'CONFIG +='
-line, within an 'else' block, and change 'debug' to 'release'.  Also uncomment
-(remove \# prefix) the line 'CONFIG += QwtDll'.
+line, within an 'else' block, and change 'debug' to 'release'.  Like so:
+\begin{verbatim}
+    else {
+        CONFIG           += release     # release/debug
+\end{verbatim}
+Also uncomment (remove \# prefix) the line 'CONFIG += QwtDll'.  Like so:
+\begin{verbatim}
+CONFIG           += QwtDll
+\end{verbatim}
 Save and close.
 Now, cd into the qwt-5.2 subdir in a Terminal.  Type these commands to build and install:
@@ -529,6 +567,13 @@
 Make sure to use the qwt install path from the Qwt build above.
+Finally, if you run into problems with the library not being properly linked after you build qgis, you may need to fix that as follows and then rebuild qgis (this is not needed when bundling all Qt/PyQt related components, which is recommended, and default in the Xcode build):
+\begin{verbatim}
+sudo install_name_tool -id /usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib \
+/usr/local/qwt-5.2.1-svn/lib/libqwt.5.dylib
+\end{verbatim}
 \underline{Snow Leopard note}
 If using Qt Carbon, you need to specify which architectures to build, otherwise
@@ -541,17 +586,18 @@
 --extra-lib-dirs=/usr/local/qwt-5.2.1-svn/lib --extra-libs=qwt
 \end{verbatim}
 \minisec{Additional Dependencies : Bison}
 \underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard include Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
-The version of bison available by default on Mac OS X 10.4 and older is too old so you need to
+The version of bison available by default on Mac OS X 10.4 is too old so you need to
 get a more recent one on your system. Download at least version 2.3 from:
 \begin{verbatim}
 ftp.gnu.org/gnu/bison/
 \end{verbatim}
-Now build and install it to a prefix of /usr/local.\&\#65533; Double-click the source
+Now build and install it to a prefix of /usr/local. Double-click the source
 tarball to unpack it, then cd to the source folder and:
 \begin{verbatim}
@@ -560,7 +606,10 @@
 sudo make install
 \end{verbatim}
 \subsubsection{Install CMake for OSX}
+(Only needed for a cmake build.)
 Get the latest source release from here:
 \begin{verbatim}
@@ -578,11 +627,12 @@
 sudo make install
 \end{verbatim}
 \subsubsection{Install subversion for OSX}
 \underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard (Xcode 3+)
 include SVN, so this step can be skipped on Leopard and Snow Leopard.
-The [\htmladdnormallink{http://sourceforge.net/projects/macsvn/MacSVN}{http://sourceforge.net/projects/macsvn/MacSVN}] project has a downloadable
+The [\url{http://sourceforge.net/projects/macsvn/MacSVN}] project has a downloadable
 build of svn. If you are a GUI inclined person you may want to grab their gui
 client too. Get the command line client here:
@@ -593,7 +643,7 @@
 Once downloaded open the zip file and run the installer.
 You also need to install BerkleyDB available from the same
-\htmladdnormallink{http://sourceforge.net/projects/macsvn/}{website}. At the time of writing the
+\url{http://sourceforge.net/projects/macsvn/}. At the time of writing the
 file was here:
 \begin{verbatim}
@@ -621,6 +671,7 @@
 Now close and reopen your shell to get the updated vars.
 \subsubsection{Check out QGIS from SVN}
 Now we are going to check out the sources for QGIS. First we will create a
 directory for working in (or some folder of your choice):
@@ -659,6 +710,7 @@
 I suggest you press 'p' to accept the key permanently.
 \subsubsection{Configure the build}
 There are 2 different methods to build QGIS: the traditional CMake method,
 and the new Xcode project (starting with QGIS 1.1). The Xcode project has
@@ -666,6 +718,7 @@
 stated in a user configuration file. The CMake build handles optional features,
 and some bundling steps are available with scripts in the mac directory.
 \minisec{Configure the CMake build}
 CMake supports out of source build so we will create a 'build' dir for the
 build process. OS X uses \$\{HOME\}/Applications as a standard user app folder (it gives it the system app folder icon).
@@ -712,9 +765,13 @@
 \end{verbatim}
-\underline{Snow Leopard note:} To handle the appropriate version of Qt (32-bit or 64-bit), you will need to invoke cmake based on which version of Qt you installed.  Also, SIP/PyQt detection will fail for 32bit because Python runs 64bit.
+\underline{Snow Leopard note:} To handle the appropriate version of Qt
+(32-bit or 64-bit), you will need to invoke cmake based on which version
+of Qt you installed.  Also, SIP/PyQt detection will fail for 32bit because
+Python runs 64bit.
-For 32-bit Qt (Carbon) with GRASS-6.4, create a 32bit python script and add arch flags to the configuration:
+For 32-bit Qt (Carbon) with GRASS-6.4, create a 32bit python script and add
+arch flags to the configuration:
 \begin{verbatim}
 sudo cat >/usr/local/bin/python32 <<EOF
@@ -744,6 +801,7 @@
 \end{verbatim}
 \minisec{Configure the Xcode build}
 In the mac/xcode folder in the source, duplicate the 'qgis\_user-template.xcconfig'
 file and name it 'qgis\_user.xcconfig'. A default build will use the KyngChaos
@@ -757,7 +815,9 @@
 other dependency libraries to create a self-contained package. The KyngChaos
 frameworks and GRASS application are not bundled.
 \subsubsection{Building}
 \minisec{Building with Cmake}
 Now we can start the build process:
@@ -777,6 +837,7 @@
 sudo make install
 \end{verbatim}
 \minisec{Building with Xcode}
 Open the Xcode project file in the mac/xcode directory. Select 'Release' build
 configuration and select the 'Full Qgis' target, then build. If you use ccache,
@@ -794,7 +855,9 @@
 qgis\_user.xcconfig. Copy this to whereever you like.
 \subsection{Building on GNU/Linux}
 \subsubsection{Building QGIS with Qt4.x}
 \textbf{Requires:} Ubuntu Hardy / Debian derived distro
@@ -812,6 +875,7 @@
 in use for a while, you may need to just skip those steps which are irrelevant
 to you.
 \subsubsection{Prepare apt}
 The packages qgis depends on to build are available in the "universe" component
 of Ubuntu. This is not activated by default, so you need to activate it:
@@ -828,6 +892,7 @@
 sudo apt-get update
 \end{verbatim}
 \subsubsection{Install Qt4}
 \begin{verbatim}
 sudo apt-get install libqt4-core libqt4-debug  \
@@ -835,7 +900,7 @@
 qt4-dev-tools qt4-doc qt4-qtconfig uim-qt gcc libapt-pkg-perl resolvconf
 \end{verbatim}
-/!$\backslash$ \textbf{*A Special Note:*} If you are following this set of instructions on
+\textbf{*A Special Note:*} If you are following this set of instructions on
 a system where you already have Qt3 development tools installed, there will
 be a conflict between Qt3 tools and Qt4 tools. For example, qmake will
 point to the Qt3 version not the Qt4. Ubuntu Qt4 and Qt3 packages are
@@ -871,6 +936,7 @@
 Use the simple command line dialog that appears after running each of the
 above commands to select the Qt4 version of the relevant applications.
 \subsubsection{Install additional software dependencies required by QGIS}
 \begin{verbatim}
 sudo apt-get install gdal-bin libgdal1-dev libgeos-dev proj \
@@ -880,9 +946,9 @@
 python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
 \end{verbatim}
-/!$\backslash$ Debian users should use libgdal-dev above rather
+Debian users should use libgdal-dev above rather
-/!$\backslash$ \textbf{*Note:*} For python language bindings SIP $>$= 4.5 and PyQt4 $>$= 4.1 is required! Some stable GNU/Linux
+\textbf{*Note:*} For python language bindings SIP $>$= 4.5 and PyQt4 $>$= 4.1 is required! Some stable GNU/Linux
 distributions (e.g. Debian or SuSE) only provide SIP $<$ 4.5 and PyQt4 $<$ 4.1. To include support for python
 language bindings you may need to build and install those packages from source.
@@ -892,9 +958,10 @@
 sudo apt-get install cmake
 \end{verbatim}
 \subsubsection{GRASS Specific Steps}
 /!$\backslash$ \textbf{*Note:*} If you don't need to build with GRASS support,  you can
-skip this section.
+skip this subsection.
 Now you can install grass from dapper:
@@ -902,6 +969,7 @@
 sudo apt-get install grass libgrass-dev
 \end{verbatim}
 \subsubsection{Setup ccache (Optional)}
 You should also setup ccache to speed up compile times:
@@ -911,6 +979,7 @@
 sudo ln -s /usr/bin/ccache g++
 \end{verbatim}
 \subsubsection{Prepare your development environment}
 As a convention I do all my development work in \$HOME/dev/$<$language$>$, so in
 this case we will create a work environment for C++ development work like
@@ -923,6 +992,7 @@
 This directory path will be assumed for all instructions that follow.
 \subsubsection{Check out the QGIS Source Code}
 There are two ways the source can be checked out. Use the anonymous method
 if you do not have edit privaleges for the QGIS source repository, or use
@@ -959,8 +1029,9 @@
      accept (t)emporarily or accept (p)ermanently?
 \end{verbatim}
 \subsubsection{Starting the compile}
-/!$\backslash$ \textbf{*Note:*} The next section describes howto build debian packages
+/!$\backslash$ \textbf{*Note:*} The next subsection describes howto build debian packages
 I compile my development version of QGIS into my \~{}/apps directory to avoid
 conflicts with Ubuntu packages that may be under /usr. This way for example
@@ -1000,6 +1071,7 @@
 It may take a little while to build depending on your platform.
 \subsubsection{Building Debian packages}
 Instead of creating a personal installation as in the previous step you can
 also create debian package.  This is done from the qgis root directory, where
@@ -1011,6 +1083,12 @@
 apt-get install build-essential
 \end{verbatim}
+First you need to create an changelog entry for your distribution. For example for Ubuntu Lucid:
+\begin{verbatim}
+dch -l ~lucid  --force-distribution --distribution lucid "lucid build"
+\end{verbatim}
 The QGIS packages will be created with:
 \begin{verbatim}
@@ -1024,7 +1102,7 @@
 using \texttt{dpkg -r libqgis1-dev}.  Otherwise \texttt{dpkg-buildpackage} will complain about a
 build conflict.
-The the packages are created in the parent directory (ie. one level up).
+The packages are created in the parent directory (ie. one level up).
 Install them using dpkg.  E.g.:
 \begin{verbatim}
@@ -1036,6 +1114,7 @@
 	../python-qgis_1.0preview16_amd64.deb
 \end{verbatim}
 \subsubsection{Running QGIS}
 Now you can try to run QGIS:
@@ -1046,12 +1125,14 @@
 If all has worked properly the QGIS application should start up and appear
 on your screen.
 \subsubsection{A practical case: Building QGIS and GRASS from source on Ubuntu with ECW and MrSID formats support}
 The following procedure has been tested on Ubuntu 8.04, 8.10 and 9.04 32bit. If you want
 to use different versions of the software (gdal, grass, qgis), just make the
 necessary adjustments to the following code. This guide assumes that you don't have
 installed any previous version of gdal, grass and qgis.
+\hypertarget{toc55}{}
 \minisec{Step 1: install base packages}
 First you need to install the necessary packages required to download the source
 code and compile it. Open the terminal and issue the following command:
@@ -1060,6 +1141,7 @@
 sudo apt-get install build-essential g++ subversion
 \end{verbatim}
+\hypertarget{toc56}{}
 \minisec{Step 2: compile and install the ecw libraries}
 Go to the ERDAS web site \htmladdnormallink{http://www.erdas.com/}{http://www.erdas.com/} and follow the links
 "'''products --$>$ ECW JPEG2000 Codec SDK --$>$ downloads'''"
@@ -1098,14 +1180,16 @@
 cd ..
 \end{verbatim}
+\hypertarget{toc57}{}
 \minisec{Step 3: download the MrSID binaries}
-Go to the LIZARDTECH web site \htmladdnormallink{http://www.lizardtech.com/}{http://www.lizardtech.com/} and follow the links
+Go to the LIZARDTECH web site \url{http://www.lizardtech.com/} and follow the links
 "'''download --$>$ Developer SDKs'''",
 then download the "'''GeoExpress SDK for Linux (x86) - gcc 4.1 32-bit'''"
 (you'll need to make a registration and accept a license).
 Uncompress the downloaded file. The resulting directory name should be similar to "Geo\_DSDK-7.0.0.2167"
+\hypertarget{toc58}{}
 \minisec{Step 4: compile and install the gdal libraries}
 Download the latest gdal source code
@@ -1180,6 +1264,7 @@
 cd ..
 \end{verbatim}
+\hypertarget{toc59}{}
 \minisec{Step 5: compile and install GRASS}
 Before downloading and compile GRASS source code you need to install a few
 other libraries and programs. We can do this trough apt
@@ -1189,9 +1274,10 @@
 debhelper dpatch libtiff4-dev tcl8.4-dev tk8.4-dev fftw-dev xlibmesa-gl-dev \
 libfreetype6-dev autoconf2.13 autotools-dev libgdal1-dev proj libjpeg62-dev \
 libpng12-dev libpq-dev unixodbc-dev doxygen fakeroot cmake python-dev \
-python-qt4-common python-qt4-dev python-sip4 python2.5-dev sip4 libglew1.5-dev libxmu6 \
-libqt4-dev libgsl0-dev python-qt4 swig python-wxversion python-wxgtk2.8 \
-libwxgtk2.8-0 libwxbase2.8-0 tcl8.4-dev tk8.4-dev tk8.4 libfftw3-dev libfftw3-3
+python-qt4-common python-qt4-dev python-sip4 python2.5-dev sip4 \
+libglew1.5-dev libxmu6 libqt4-dev libgsl0-dev python-qt4 swig python-wxversion \
+python-wxgtk2.8 libwxgtk2.8-0 libwxbase2.8-0 tcl8.4-dev tk8.4-dev tk8.4 \
+libfftw3-dev libfftw3-3
 \end{verbatim}
 At this point we can get the GRASS source code: you may want to download it
@@ -1233,12 +1319,14 @@
 grass64 -wxpython
 \end{verbatim}
+\hypertarget{toc60}{}
 \minisec{Step 6: compile and install QGIS}
 As for GRASS you can obtain the QGIS source code from different sources,
 for instance from svn or just by downloading one of the source code arquives available
-at \htmladdnormallink{http://www.qgis.org/download/sources.html}{http://www.qgis.org/download/sources.html}
+at \url{http://www.qgis.org/download/sources.html}
-For example download the QGIS 1.1.0 source code here \htmladdnormallink{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}
+For example download the QGIS 1.1.0 source code here \\
+\url{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}
 uncompress the arquive and enter the newly created folder
@@ -1287,8 +1375,11 @@
 \end{verbatim}
+\hypertarget{toc61}{}
 \subsection{Creation of MSYS environment for compilation of Quantum GIS}
+\hypertarget{toc62}{}
 \subsubsection{Initial setup}
+\hypertarget{toc63}{}
 \minisec{MSYS}
 This is the environment that supplies many utilities from UNIX world in Windows and is needed
 by many dependencies to be able to compile.
@@ -1296,44 +1387,48 @@
 Download from here:
 	\begin{quotation}
-\htmladdnormallink{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}
+\url{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}
 	\end{quotation}
 Install to \texttt{c:$\backslash$msys}
 All stuff we're going to compile is going to get to this directory (resp. its subdirs).
+\hypertarget{toc64}{}
 \minisec{MinGW}
 Download from here:
 	\begin{quotation}
-\htmladdnormallink{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}
+\url{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}
 	\end{quotation}
 Install to \texttt{c:$\backslash$msys$\backslash$mingw}
 It suffices to download and install only \texttt{g++} and \texttt{mingw-make} components.
+\hypertarget{toc65}{}
 \minisec{Flex and Bison}
 Flex and Bison are tools for generation of parsers, they're needed for GRASS and also QGIS compilation.
 Download the following packages:
 	\begin{quotation}
-\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}
+\url{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}
 	\end{quotation}
 	\begin{quotation}
-\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}
+\url{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}
 	\end{quotation}
 	\begin{quotation}
-\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}
+\url{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}
 	\end{quotation}
 Unpack them all to \texttt{c:$\backslash$msys$\backslash$local}
+\hypertarget{toc66}{}
 \subsubsection{Installing dependencies}
+\hypertarget{toc67}{}
 \minisec{Getting ready}
 Paul Kelly did a great job and prepared a package of precompiled libraries for GRASS.
 The package currently includes:
@@ -1352,17 +1447,18 @@
 It's available for download here:
 	\begin{quotation}
-\htmladdnormallink{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}
+\url{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}
 	\end{quotation}
 Moreover he also left the notes how to compile it (for those interested):
 	\begin{quotation}
-\htmladdnormallink{http://www.stjohnspoint.co.uk/grass/README.extralibs}{http://www.stjohnspoint.co.uk/grass/README.extralibs}
+\url{http://www.stjohnspoint.co.uk/grass/README.extralibs}
 	\end{quotation}
 Unpack the whole package to \texttt{c:$\backslash$msys$\backslash$local}
+\hypertarget{toc68}{}
 \minisec{GRASS}
 Grab sources from CVS or use a weekly snapshot, see:
@@ -1377,8 +1473,9 @@
 \begin{verbatim}
 export PATH="/usr/local/bin:/usr/local/lib:$PATH"
-./configure --prefix=/usr/local --bindir=/usr/local --with-includes=/usr/local/include \
---with-libs=/usr/local/lib --with-cxx --without-jpeg --without-tiff --with-postgres=yes \
+./configure --prefix=/usr/local --bindir=/usr/local \
+--with-includes=/usr/local/include --with-libs=/usr/local/lib \
+--with-cxx --without-jpeg --without-tiff --with-postgres=yes \
 --with-postgres-includes=/local/pgsql/include --with-pgsql-libs=/local/pgsql/lib \
 --with-opengl=windows --with-fftw --with-freetype \
 --with-freetype-includes=/mingw/include/freetype2 --without-x --without-tcltk \
@@ -1392,15 +1489,16 @@
 By the way, these pages might be useful:
 \begin{itemize}
-\item \htmladdnormallink{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}
-\item \htmladdnormallink{http://geni.ath.cx/grass.html}{http://geni.ath.cx/grass.html}
+\item \url{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}
+\item \url{http://geni.ath.cx/grass.html}
 \end{itemize}
+\hypertarget{toc69}{}
 \minisec{GEOS}
 Download the sources:
 	\begin{quotation}
-\htmladdnormallink{http://geos.refractions.net/geos-2.2.3.tar.bz2}{http://geos.refractions.net/geos-2.2.3.tar.bz2}
+\url{http://geos.refractions.net/geos-2.2.3.tar.bz2}
 	\end{quotation}
 Unpack to e.g. \texttt{c:$\backslash$msys$\backslash$local$\backslash$src}
@@ -1425,6 +1523,7 @@
 make install
 \end{verbatim}
+\hypertarget{toc70}{}
 \minisec{SQLITE}
 You can use precompiled DLL, no need to compile from source:
@@ -1444,6 +1543,7 @@
 and copy sqlite3.h to \texttt{c:$\backslash$msys$\backslash$local$\backslash$include}
+\hypertarget{toc71}{}
 \minisec{GSL}
 Download sources:
@@ -1461,11 +1561,12 @@
 make install
 \end{verbatim}
+\hypertarget{toc72}{}
 \minisec{EXPAT}
 Download sources:
 	\begin{quotation}
-\htmladdnormallink{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}
+\url{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}
 	\end{quotation}
 Unpack to \texttt{c:$\backslash$msys$\backslash$local$\backslash$src}
@@ -1478,35 +1579,40 @@
 make install
 \end{verbatim}
+\hypertarget{toc73}{}
 \minisec{POSTGRES}
 We're going to use precompiled binaries. Use the link below for download:
 	\begin{quotation}
-\url{http://wwwmaster.postgresql.org/download/}
+\url{http://wwwmaster.postgresql.org/download/mirrors-ftp}
 	\end{quotation}
 copy contents of pgsql directory from the archive to \texttt{c:$\backslash$msys$\backslash$local}
+\hypertarget{toc74}{}
 \subsubsection{Cleanup}
 We're done with preparation of MSYS environment. Now you can delete all stuff in \texttt{c:$\backslash$msys$\backslash$local$\backslash$src} - it takes quite a lot
 of space and it's not necessary at all.
+\hypertarget{toc75}{}
 \subsection{Building with MS Visual Studio}
-/!$\backslash$ This section describes a process where you build all dependencies yourself. See the section
+This subsection describes a process where you build all dependencies yourself. See the subsection
 after this for a simpler procedure where we have all the dependencies you need pre-packaged
 and we focus just on getting Visual Studio Express set up and building QGIS.
 Note that this does not currently include GRASS or Python plugins.
+\hypertarget{toc76}{}
 \subsubsection{Setup Visual Studio}
-This section describes the setup required to allow Visual Studio to be used to build QGIS.
+This subsection describes the setup required to allow Visual Studio to be used to build QGIS.
+\hypertarget{toc77}{}
 \minisec{Express Edition}
 The free Express Edition lacks the platform SDK which contains headers and so on that are needed when building QGIS. The platform SDK can be installed as described here:
 	\begin{quotation}
-\htmladdnormallink{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}
+\url{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}
 	\end{quotation}
 Once this is done, you will need to edit the $<$vsinstalldir$>$$\backslash$Common7$\backslash$Tools$\backslash$vsvars file as follows:
@@ -1517,33 +1623,37 @@
 You will also need to perform the edits described here to remove the need for a library that Visual Studio Express lacks:
 	\begin{quotation}
-\htmladdnormallink{http://www.codeproject.com/wtl/WTLExpress.asp}{http://www.codeproject.com/wtl/WTLExpress.asp}
+\url{http://www.codeproject.com/wtl/WTLExpress.asp}
 	\end{quotation}
+\hypertarget{toc78}{}
 \minisec{All Editions}
 You will need stdint.h and unistd.h. unistd.h comes with GnuWin32 version of flex \& bison binaries (see later). stdint.h can be found here:
 	\begin{quotation}
-\htmladdnormallink{http://www.azillionmonkeys.com/qed/pstdint.h}{http://www.azillionmonkeys.com/qed/pstdint.h}.
+\url{http://www.azillionmonkeys.com/qed/pstdint.h}.
 	\end{quotation}
 Copy both of these to $<$vsinstalldir$>$$\backslash$VC$\backslash$include.
+\hypertarget{toc79}{}
 \subsubsection{Download/Install Dependencies}
-This section describes the downloading and installation of the various QGIS dependencies.
+This subsection describes the downloading and installation of the various QGIS dependencies.
+\hypertarget{toc80}{}
 Download the following packages and run the installers:
 	\begin{quotation}
-\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/flex.php}{http://gnuwin32.sourceforge.net/downlinks/flex.php}
+\url{http://gnuwin32.sourceforge.net/downlinks/flex.php}
 	\end{quotation}
 	\begin{quotation}
-\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison.php}{http://gnuwin32.sourceforge.net/downlinks/bison.php}
+\url{http://gnuwin32.sourceforge.net/downlinks/bison.php}
 	\end{quotation}
+\hypertarget{toc81}{}
 \minisec{To include  PostgreSQL support in Qt}
 If you want to build Qt with PostgreSQL support you need to download
 PostgreSQL, install it and create a library you can later link with Qt.
@@ -1586,13 +1696,15 @@
 That's almost it.  You only need to the include and lib path to INCLUDE and LIB
 in vcvars.bat respectively.
+\hypertarget{toc82}{}
 \minisec{Qt}
 Build Qt following the instructions here:
 	\begin{quotation}
-\htmladdnormallink{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}
+\url{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}
 	\end{quotation}
+\hypertarget{toc83}{}
 \minisec{Proj.4}
 Get proj.4 source from here:
@@ -1622,6 +1734,7 @@
 This can also be added to a batch file.
+\hypertarget{toc84}{}
 \minisec{GSL}
 Get gsl source from here:
@@ -1630,8 +1743,9 @@
 	\end{quotation}
 Build using the gsl.sln file
+\hypertarget{toc85}{}
 \minisec{GEOS}
-Get geos from svn (svn checkout \htmladdnormallink{http://svn.refractions.net/geos/trunk}{http://svn.refractions.net/geos/trunk} geos).
+Get geos from svn (svn checkout \url{http://svn.refractions.net/geos/trunk} geos).
 Edit geos$\backslash$source$\backslash$makefile.vc as follows:
 Uncomment lines 333 and 334 to allow the copying of version.h.vc to version.h.
@@ -1663,8 +1777,9 @@
+\hypertarget{toc86}{}
 \minisec{GDAL}
-Get gdal from svn (svn checkout \htmladdnormallink{https://svn.osgeo.org/gdal/branches/1.4/gdal}{https://svn.osgeo.org/gdal/branches/1.4/gdal} gdal).
+Get gdal from svn (svn checkout \url{https://svn.osgeo.org/gdal/branches/1.4/gdal} gdal).
 Edit nmake.opt to suit, it's pretty well commented.
@@ -1680,66 +1795,60 @@
 nmake -f makefile.vc devinstall
 \end{verbatim}
+\hypertarget{toc87}{}
 \minisec{PostGIS}
 Get PostGIS and the Windows version of PostgreSQL from here:
 	\begin{quotation}
-\htmladdnormallink{http://postgis.refractions.net/download/}{http://postgis.refractions.net/download/}
+\url{http://postgis.refractions.net/download/}
 	\end{quotation}
 Note the warning about not installing the version of PostGIS that comes with the PostgreSQL installer. Simply run the installers.
+\hypertarget{toc88}{}
 \minisec{Expat}
 Get expat from here:
 	\begin{quotation}
-\htmladdnormallink{http://sourceforge.net/project/showfiles.php?group\_id=10127}{http://sourceforge.net/project/showfiles.php?group\_id=10127}
+\url{http://sourceforge.net/project/showfiles.php?group\_id=10127}
 	\end{quotation}
 You'll need expat-win32bin-2.0.1.exe.
 Simply run the executable to install expat.
+\hypertarget{toc89}{}
 \minisec{CMake}
 Get CMake from here:
 	\begin{quotation}
-\htmladdnormallink{http://www.cmake.org/HTML/Download.html}{http://www.cmake.org/HTML/Download.html}
+\url{http://www.cmake.org/HTML/Download.html}
 	\end{quotation}
 You'll need cmake-$<$version$>$-win32-x86.exe. Simply run this to install CMake.
+\hypertarget{toc90}{}
 \subsubsection{Building QGIS with CMAKE}
 Get QGIS source from svn (svn co \htmladdnormallink{https://svn.osgeo.org/qgis/trunk/qgis}{https://svn.osgeo.org/qgis/trunk/qgis} qgis).
 Create a 'Build' directory in the top level QGIS directory. This will be where all the build output will be generated.
-Run Start out{$>$All Programs}$>$CMake--$>$CMake.
+Run Start$>$All Programs$>$CMake--$>$CMake.
-In the 'Where is the source code:' box, browse to the top level QGIS directory.
-In the 'Where to build the binaries:' box, browse to the 'Build' directory you created in the top level QGIS directory.
+In the 'Where is the source code:' box, browse to the top level QGIS directory. In the 'Where to build the binaries:' box, browse to the 'Build' directory you created in the top level QGIS directory.
 Fill in the various *\_INCLUDE\_DIR and *\_LIBRARY entries in the 'Cache Values' list.
 Click the Configure button. You will be prompted for the type of makefile that will be generated. Select Visual Studio 8 2005 and click OK.
 All being well, configuration should complete without errors. If there are errors, it is usually due to an incorrect path to a header or library directory. Failed items will be shown in red in the list.
 Once configuration completes without error, click OK to generate the solution and project files.
 With Visual Studio 2005, open the qgis.sln file that will have been created in the Build directory you created earlier.
+Build the ALL\_BUILD project. This will build all the QGIS binaries along with all the plugins. Install QGIS by building the INSTALL project. By default this will install to c:$\backslash$Program Files$\backslash$qgis$<$version$>$ (this can be changed by changing the CMAKE\_INSTALL\_PREFIX variable in CMake).
+You will also either need to add all the dependency dlls to the QGIS install directory or add their respective directories to your PATH.
-Build the ALL\_BUILD project. This will build all the QGIS binaries along with all the plugins.
- Install QGIS by building the INSTALL project. By default this will install to c:$\backslash$Program Files$\backslash$qgis$<$version$>$ (this can be changed by changing the CMAKE\_INSTALL\_PREFIX variable in CMake).
- You will also either need to add all the dependency dlls to the QGIS install directory or add their respective directories to your PATH.
+\hypertarget{toc91}{}
 \subsection{Building under Windows using MSVC Express}
-/!$\backslash$ This section of the document is in draft form and is not ready to be used
+This subsection of the document is in draft form and is not ready to be used
 yet.
 Tim Sutton, 2007
+\hypertarget{toc92}{}
 \subsubsection{System preparation}
 I started with a clean XP install with Service Pack 2 and all patches applied.
 I have already compiled all the dependencies you need for gdal, expat etc,
@@ -1760,8 +1869,9 @@
  * Compile QGIS
  * Create setup.exe installer for QGIS
+\hypertarget{toc93}{}
 \subsubsection{Install the libraries archive}
-Half of the point of this section of the MSVC setup procedure is to make
+Half of the point of this subsection of the MSVC setup procedure is to make
 things as simple as possible for you. To that end I have prepared an
 archive that includes all dependencies needed to build QGIS except Qt
 (which we will build further down). Fetch the archive from:
@@ -1787,6 +1897,7 @@
 should adjust any instructions that follow if you plan to do things
 differently.
+\hypertarget{toc94}{}
 \subsubsection{Install Visual Studio Express 2005}
 First thing we need to get is MSVC Express from here:
@@ -1812,6 +1923,7 @@
 It will need to download around 90mb of installation files and reports
 that the install will consume 554mb of disk space.
+\hypertarget{toc95}{}
 \subsubsection{Install Microsoft Platform SDK2}
 Go to this page:
@@ -1883,9 +1995,9 @@
 Debuggin Tools for Windows                      (Yes)
 \end{verbatim}
-/!$\backslash$ Note that you can always come back later to add extra bits if you like.
+Note that you can always come back later to add extra bits if you like.
-/!$\backslash$ Note that installing the SDK requires validation with the
+Note that installing the SDK requires validation with the
 Microsoft Genuine Advantage application. Some people have a philosophical
 objection to installing this software on their computers. If you are one
 of them you should probably consider using the MINGW build instructions
@@ -1945,6 +2057,7 @@
 The notes go on to show how to build a mswin32 application which you can try if you like -
 I'm not going to recover that here.
+\hypertarget{toc96}{}
 \subsubsection{Edit your vsvars}
 Backup your vsvars32.bat file in
@@ -1970,24 +2083,26 @@
 @rem
 @set DevEnvDir=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE
- at set PATH=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE;C:\Program \
-Files\Microsoft Visual Studio 8\VC\BIN;C:\Program Files\Microsoft Visual \
-Studio 8\Common7\Tools;C:\Program Files\Microsoft Visual Studio \
-8\SDK\v2.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;C:\Program \
+ at set PATH=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE;C:\Program
+Files\Microsoft Visual Studio 8\VC\BIN;C:\Program Files\Microsoft Visual
+Studio 8\Common7\Tools;C:\Program Files\Microsoft Visual Studio
+8\SDK\v2.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;C:\Program
 Files\Microsoft Visual Studio 8\VC\VCPackages;%PATH%
 @rem added by Tim
- at set PATH=C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\Bin;%PATH%
+ at set PATH=C:\Program Files\Microsoft Platform SDK for Windows Server
+2003 R2\Bin;%PATH%
 @set INCLUDE=C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE;%INCLUDE%
 @rem added by Tim
- at set INCLUDE=C:\Program Files\Microsoft Platform SDK for Windows Server \
+ at set INCLUDE=C:\Program Files\Microsoft Platform SDK for Windows Server
 2003 R2\Include;%INCLUDE%
 2003 R2\Include\mfc;%INCLUDE%
 @set INCLUDE=%INCLUDE%;C:\dev\cpp\qgislibs-release\include\postgresql
- at set LIB=C:\Program Files\Microsoft Visual Studio 8\VC\LIB;C:\Program \
+ at set LIB=C:\Program Files\Microsoft Visual Studio 8\VC\LIB;C:\Program
 Files\Microsoft Visual Studio 8\SDK\v2.0\lib;%LIB%
 @rem added by Tim
- at set LIB=C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\Lib;%LIB%
+ at set LIB=C:\Program Files\Microsoft Platform SDK for Windows Server
+2003 R2\Lib;%LIB%
 @set LIB=%LIB%;C:\dev\cpp\qgislibs-release\lib
 @set LIBPATH=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
@@ -2005,6 +2120,7 @@
 \end{verbatim}
+\hypertarget{toc97}{}
 \subsubsection{Environment Variables}
 Right click on 'My computer' then select the 'Advanced' tab. Click environment variables and
 create or augment the following '''System''' variables (if they don't already exist):
@@ -2013,21 +2129,21 @@
 Variable Name:     Value:
 EDITOR             vim
-INCLUDE            C:\Program Files\Microsoft Platform SDK for Windows Server \
-                   2003 R2\Include\.
-LIB                C:\Program Files\Microsoft Platform SDK for Windows Server \
-                   2003 R2\Lib\.
+INCLUDE            C:\Program Files\Microsoft Platform SDK for Windows Server
+2003 R2\Include\.
+LIB                C:\Program Files\Microsoft Platform SDK for Windows Server
+2003 R2\Lib\.
 LIB_DIR            C:\dev\cpp\qgislibs-release
 PATH               C:\Program Files\CMake 2.4\bin;
                    %SystemRoot%\system32;
                    %SystemRoot%;
                    %SystemRoot%\System32\Wbem;
-                   C:\Program Files\Microsoft Platform SDK for Windows Server \
-                   2003 R2\Bin\.;
-                   2003 R2\Bin\WinNT\;
-                   C:\Program Files\svn\bin;C:\Program Files\Microsoft Visual \
-                   Studio 8\VC\bin;
+                   C:\Program Files\Microsoft Platform SDK for Windows Server
+2003 R2\Bin\.;
+2003 R2\Bin\WinNT\;
+                   C:\Program Files\svn\bin;C:\Program Files\Microsoft Visual
+Studio 8\VC\bin;
                    "c:\Program Files\Microsoft Visual Studio 8\Common7\Tools";
                    c:\Qt\4.3.2\bin;
@@ -2036,6 +2152,7 @@
 SVN_SSH            "C:\\Program Files\\PuTTY\\plink.exe"
 \end{verbatim}
+\hypertarget{toc98}{}
 \subsubsection{Building Qt4.3.2}
 You need a minimum of Qt 4.3.2 here since this is the first version to officially
 support building the open source version of Qt for windows under MSVC.
@@ -2052,6 +2169,7 @@
 c:\Qt\4.x.x\
 \end{verbatim}
+\hypertarget{toc99}{}
 \minisec{Compile Qt}
 Open the Visual Studio C++ command line and cd to c:$\backslash$Qt$\backslash$4.x.x where you
 extracted the source and enter:
@@ -2065,11 +2183,12 @@
 Add -qt-sql-odbc -qt-sql-psql to the configure line if your want odbc and
 PostgreSQL support build into Qt.
-/!$\backslash$ Note: For me in some cases I got a build error on qscreenshot.pro. If you
+Note: For me in some cases I got a build error on qscreenshot.pro. If you
 are only interested in having the libraries needed for building Qt apps, you
 can probably ignore that. Just check in c:$\backslash$Qt$\backslash$4.3.2$\backslash$bin to check all dlls and
 helper apps (assistant etc) have been made.
+\hypertarget{toc100}{}
 \minisec{Configure Visual C++ to use Qt}
 After building configure the Visual Studio Express IDE to use Qt:
@@ -2107,7 +2226,8 @@
 QString = t=<d->data, su>, size=<d->size, i>
 \end{verbatim}
-to AutoExp.DAT in C:$\backslash$Program Files$\backslash$Microsoft Visual Studio 8$\backslash$Common7$\backslash$Packages$\backslash$Debugger before
+to AutoExp.DAT in C:$\backslash$Program Files$\backslash$Microsoft Visual
+Studio 8$\backslash$Common7$\backslash$Packages$\backslash$Debugger before
 \begin{verbatim}
 [Visualizer]
@@ -2118,11 +2238,13 @@
 feel free to add some - I just needed QString and took the first hit in google
 I could find.
+\hypertarget{toc101}{}
 \subsubsection{Install Python}
 Download \htmladdnormallink{http://python.org/ftp/python/2.5.1/python-2.5.1.msi}{http://python.org/ftp/python/2.5.1/python-2.5.1.msi} and install it.
+\hypertarget{toc102}{}
 \subsubsection{Install SIP}
-Download \htmladdnormallink{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip}{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip} and extract it
+Download \url{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip} and extract it
 into your c:$\backslash$dev$\backslash$cpp directory.
 From a Visual C++ command line cd to the directory where you extract SIP and run:
@@ -2132,6 +2254,7 @@
 nmake install
 \end{verbatim}
+\hypertarget{toc103}{}
 \subsubsection{Install PyQt4}
 Download \htmladdnormallink{http://www.riverbankcomputing.com/Downloads/PyQt4/GPL/PyQt-win-gpl-4.3.1.zip}{http://www.riverbankcomputing.com/Downloads/PyQt4/GPL/PyQt-win-gpl-4.3.1.zip} and extract it
@@ -2143,6 +2266,7 @@
 nmake install
 \end{verbatim}
+\hypertarget{toc104}{}
 \subsubsection{Install CMake}
 Download and install cmake 2.4.7 or better, making sure to enable the
 option
@@ -2151,6 +2275,7 @@
 Update path for all users
 \end{verbatim}
+\hypertarget{toc105}{}
 \subsubsection{Install Subversion}
 You '''must''' install the command line version if you want the CMake svn scripts to work.
 Its a bit tricky to find the correct version on the subversion download site as they have
@@ -2172,6 +2297,7 @@
 To your path.
+\hypertarget{toc106}{}
 \subsubsection{Initial SVN Check out}
 Open a cmd.exe window and do:
@@ -2199,9 +2325,10 @@
 Press 'p' to accept and the svn checkout will commence.
+\hypertarget{toc107}{}
 \subsubsection{Create Makefiles using cmakesetup.exe}
 I wont be giving a detailed description of the build process, because
-the process is explained in the first section (where you manually build
+the process is explained in the first subsection (where you manually build
 all dependencies) of the windows build notes in this document. Just skip
 past the parts where you need to build GDAL etc, since this simplified
 install process does all the dependency provisioning for you.
@@ -2239,9 +2366,12 @@
 Once the build completes right click on INSTALL in the solution browser and
 choose build. This will by default install qgis into c:$\backslash$program files$\backslash$qgisX.X.X.
+\hypertarget{toc108}{}
 \subsubsection{Running and packaging}
 To run QGIS you need to at the minimum copy the dlls from c:$\backslash$dev$\backslash$cpp$\backslash$qgislibs-release$\backslash$bin
 into the c:$\backslash$program files$\backslash$qgisX.X.X directory.
Modified: docs/trunk/english_us/coding-compilation_guide/qgis_style.sty
--- docs/trunk/english_us/coding-compilation_guide/qgis_style.sty	2010-07-27 07:56:31 UTC (rev 13968)
+++ docs/trunk/english_us/coding-compilation_guide/qgis_style.sty	2010-07-27 10:23:35 UTC (rev 13969)
@@ -173,8 +173,8 @@
 \usepackage{xspace}
 %Macros QGIS Versions
-\def\CURRENT{1.4\xspace}
-\def\OLD{1.3\xspace}
+\def\CURRENT{1.5\xspace}
+\def\OLD{1.4\xspace}
 \def\VERYOLD{1.0\xspace}
 % add disclaimer about the revision status of a section
Modified: docs/trunk/english_us/coding-compilation_guide/title.tex
--- docs/trunk/english_us/coding-compilation_guide/title.tex	2010-07-27 07:56:31 UTC (rev 13968)
+++ docs/trunk/english_us/coding-compilation_guide/title.tex	2010-07-27 10:23:35 UTC (rev 13969)
@@ -15,7 +15,7 @@
 \Large{Coding and Compilation Guide} \\
 \vspace{0.5cm}
 %\includegraphics[clip=true, scale=0.4]{splash}
-\Large{Version ~\CURRENT \textsl{'Enceladus'}}
+\Large{Version ~\CURRENT \textsl{'Thethys'}}
 \end{center}
 \end{titlepage}
More information about the QGIS-commit mailing list
