[QGIS Commit] r13626 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Wed Jun 2 06:52:41 EDT 2010
Author: mhugent
Date: 2010-06-02 06:52:41 -0400 (Wed, 02 Jun 2010)
New Revision: 13626
trunk/qgis/src/plugins/georeferencer/qgsgcplistmodel.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.h
show residuals in pixel for non-linear transformations
Modified: trunk/qgis/src/plugins/georeferencer/qgsgcplistmodel.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgcplistmodel.cpp 2010-06-02 10:47:00 UTC (rev 13625)
+++ trunk/qgis/src/plugins/georeferencer/qgsgcplistmodel.cpp 2010-06-02 10:52:41 UTC (rev 13626)
@@ -92,15 +92,23 @@
vector<QgsPoint> mapCoords, pixelCoords;
mGCPList->createGCPVectors( mapCoords, pixelCoords );
- // TODO: the parameters should probable be updated externally (by user interaction)
- bTransformUpdated = mGeorefTransform->updateParametersFromGCPs( mapCoords, pixelCoords );
// // Setup table header
QStringList itemLabels;
QString unitType;
QSettings s;
- if ( s.value( "/Plugin-GeoReferencer/Config/ResidualUnits" ) == "mapUnits" )
+ bool mapUnitsPossible = false;
+ if ( mGeorefTransform )
+ bTransformUpdated = mGeorefTransform->updateParametersFromGCPs( mapCoords, pixelCoords );
+ mapUnitsPossible = mGeorefTransform->providesAccurateInverseTransformation();
+ if ( s.value( "/Plugin-GeoReferencer/Config/ResidualUnits" ) == "mapUnits" && mapUnitsPossible )
unitType = tr( "map units" );
else
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-06-02 10:47:00 UTC (rev 13625)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui 2010-06-02 10:52:41 UTC (rev 13626)
@@ -70,7 +70,7 @@
<item row="1" column="0">
<widget class="QRadioButton" name="mMapUnitsButton">
<property name="text">
- <string>Map units</string>
+ <string>Use map units if possible</string>
</property>
</widget>
</item>
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-06-02 10:47:00 UTC (rev 13625)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-06-02 10:52:41 UTC (rev 13626)
@@ -1344,7 +1344,7 @@
QString residualUnits;
QSettings s;
+ if ( s.value( "/Plugin-GeoReferencer/Config/ResidualUnits" ) == "mapUnits" && mGeorefTransform.providesAccurateInverseTransformation() )
residualUnits = tr( "map units" );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp 2010-06-02 10:47:00 UTC (rev 13625)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.cpp 2010-06-02 10:52:41 UTC (rev 13626)
@@ -150,6 +150,13 @@
+bool QgsGeorefTransform::providesAccurateInverseTransformation() const
+ return ( mTransformParametrisation == Linear \
+ || mTransformParametrisation == Helmert \
+ || mTransformParametrisation == PolynomialOrder1 );
bool QgsGeorefTransform::parametersInitialized() const
return mParametersInitialized;
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.h 2010-06-02 10:47:00 UTC (rev 13625)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftransform.h 2010-06-02 10:52:41 UTC (rev 13626)
@@ -82,6 +82,9 @@
//! \brief The transform parametrisation currently in use.
TransformParametrisation transformParametrisation() const;
+ /**True for linear, Helmert, first order polynomial*/
+ bool providesAccurateInverseTransformation() const;
//! \returns whether the parameters of this transform have been initialised by \ref updateParametersFromGCPs
bool parametersInitialized() const;
