[QGIS Commit] r13658 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org
Sat Jun 5 07:47:26 EDT 2010
Author: mhugent
Date: 2010-06-05 07:47:25 -0400 (Sat, 05 Jun 2010)
New Revision: 13658
trunk/qgis/src/core/composer/qgscomposermap.cpp
Added code to fix bug #2755 also for Qt<4.6
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-06-05 03:01:36 UTC (rev 13657)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-06-05 11:47:25 UTC (rev 13658)
@@ -1415,8 +1415,9 @@
return;
+ QGraphicsItem* currentItem = 0;
- QGraphicsItem* currentItem = 0;
+#if QT_VERSION >= 0x40600 //Qt 4.6 provides the items in visibility order
for ( int i = itemList.size() - 1; i >= 0; --i )
currentItem = itemList.at( i );
@@ -1427,6 +1428,42 @@
drawCanvasItem( currentItem, painter, itemStyle );
+#else //Qt <4.6 provides the items in random order
+ QMultiMap<int, QGraphicsItem*> topLevelItems;
+ QMultiMap<QGraphicsItem*, QGraphicsItem*> childItems; //QMultiMap<parentItem, childItem>
+ for ( int i = 0; i < itemList.size(); ++i )
+ currentItem = itemList.at( i );
+ //don't draw mapcanvasmap (has z value -10)
+ if ( !currentItem || currentItem->zValue() == -10 )
+ continue;
+ if ( currentItem->parentItem() )
+ childItems.insert( currentItem->parentItem(), currentItem );
+ else
+ topLevelItems.insert( currentItem->zValue(), currentItem );
+ QMultiMap<int, QGraphicsItem*>::iterator topLevelIt = topLevelItems.begin();
+ for ( ; topLevelIt != topLevelItems.end(); ++topLevelIt )
+ drawCanvasItem( topLevelIt.value(), painter, itemStyle );
+ //Draw children. They probably should be sorted according to z-order, but we don't do it because this code is only
+ //there for backward compatibility. And currently, having several embedded children is not used in QGIS
+ QMap<QGraphicsItem*, QGraphicsItem*>::iterator childIt = childItems.find( topLevelIt.value() );
+ while ( childIt != childItems.end() && childIt.key() == topLevelIt.value() )
+ drawCanvasItem( childIt.value(), painter, itemStyle );
+ ++childIt;
+#endif
void QgsComposerMap::drawCanvasItem( QGraphicsItem* item, QPainter* painter, const QStyleOptionGraphicsItem* itemStyle )
