[QGIS Commit] r13664 - in trunk/qgis/ms-windows: . osgeo4w
svn_qgis at osgeo.org
Sat Jun 5 16:38:16 EDT 2010
Author: jef
Date: 2010-06-05 16:38:15 -0400 (Sat, 05 Jun 2010)
New Revision: 13664
Added:
trunk/qgis/ms-windows/osgeo4w/creatensis.pl
trunk/qgis/ms-windows/QGIS-Installer.nsi
add script to build nsis standalone installer from OSGeo4W packages
Modified: trunk/qgis/ms-windows/QGIS-Installer.nsi
--- trunk/qgis/ms-windows/QGIS-Installer.nsi 2010-06-05 18:15:46 UTC (rev 13663)
+++ trunk/qgis/ms-windows/QGIS-Installer.nsi 2010-06-05 20:38:15 UTC (rev 13664)
@@ -3,14 +3,14 @@
;Quantum GIS Installer for Windows
;Written by Marco Pasetti
;Mail to: marco.pasetti at alice.it
+;Extended for creatensis.pl by Jürgen E. Fischer <jef at norbit.de>
;Select if you are building a "Development Version" or a "Release Version" of the Quantum GIS Installer
;Change the INSTALLER_TYPE variable to Release or Development
-!define INSTALLER_TYPE "Release-NoGrass"
;Version variables
@@ -43,13 +43,10 @@
-;define the QGIS Base Name
-!define RELEASE_QGIS_BASE "Quantum GIS Enceladus"
-!define DEV_QGIS_BASE "Quantum GIS Unstable Dev"
;Set the installer variables, depending on the selected version to build
!if ${INSTALLER_TYPE} == "Release"
+ !define RELEASE_QGIS_BASE "Quantum GIS Enceladus"
!define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
!define VERSION_NAME "${RELEASE_VERSION_NAME}"
!define COMPLETE_NAME "${RELEASE_QGIS_BASE} ${RELEASE_VERSION_NUMBER} ${RELEASE_VERSION_NAME}"
@@ -74,6 +71,7 @@
!define INSTALLER_DISPLAYED_NAME "${COMPLETE_NAME}"
!define PACKAGE_FOLDER ".\QGIS-Release-Package-No-Grass"
!else if ${INSTALLER_TYPE} == "Development"
+ !define DEV_QGIS_BASE "Quantum GIS Unstable Dev"
!define VERSION_NUMBER "${DEV_VERSION_NUMBER}"
!define VERSION_NAME "${DEV_VERSION_NAME}"
!define COMPLETE_NAME "${DEV_QGIS_BASE} ${DEV_VERSION_NUMBER} ${DEV_VERSION_NAME}"
@@ -85,6 +83,12 @@
!define CHECK_INSTALL_NAME "${DEV_QGIS_BASE}"
!define INSTALLER_DISPLAYED_NAME "${DISPLAYED_NAME}"
!define PACKAGE_FOLDER ".\QGIS-Dev-Package"
+!else if ${INSTALLER_TYPE} == "OSGeo4W"
+ !define COMPLETE_NAME "${QGIS_BASE} ${VERSION_NUMBER} ${VERSION_NAME}"
+ !define CHECK_INSTALL_NAME "${QGIS_BASE}"
+ !define INSTALLER_DISPLAYED_NAME "${DISPLAYED_NAME}"
+ !addplugindir osgeo4w/untgz
!endif
@@ -352,6 +356,10 @@
File .\Installer-Files\QGIS_Web.ico
SetOutPath "$INSTALL_DIR"
File .\Installer-Files\QGIS-WebSite.url
+!if ${INSTALLER_TYPE} == "OSGeo4W"
+ File .\Installer-Files\postinstall.bat
+ File .\Installer-Files\preremove.bat
+!endif
;add Quantum GIS files
@@ -394,23 +402,39 @@
;Create the Desktop Shortcut
SetShellVarContext current
+ CreateShortCut "$DESKTOP\${QGIS_BASE}.lnk" "$INSTALL_DIR\bin\nircmd.exe" 'exec hide "$INSTALL_DIR\bin\qgis-dev.bat"' \
+ "$INSTALL_DIR\icons\QGIS.ico" "" SW_SHOWNORMAL "" "Launch ${COMPLETE_NAME}"
+!else
CreateShortCut "$DESKTOP\${QGIS_BASE}.lnk" "$INSTALL_DIR\bin\qgis.exe" ""\
+!endif
;Create the Windows Start Menu Shortcuts
SetShellVarContext all
CreateDirectory "$SMPROGRAMS\${QGIS_BASE}"
+ CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\${QGIS_BASE}.lnk" "$INSTALL_DIR\bin\nircmd.exe" 'exec hide "$INSTALL_DIR\bin\qgis-dev.bat"' \
+!else
CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\${QGIS_BASE}.lnk" "$INSTALL_DIR\bin\qgis.exe" ""\
+!endif
CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\Quantum GIS Web Site.lnk" "$INSTALL_DIR\QGIS-WebSite.url" ""\
"$INSTALL_DIR\icons\QGIS_Web.ico" "" SW_SHOWNORMAL "" "Visit the Quantum GIS Web Site"
CreateShortCut "$SMPROGRAMS\${QGIS_BASE}\Uninstall ${QGIS_BASE}.lnk" "$INSTALL_DIR\Uninstall-QGIS.exe" ""\
"$INSTALL_DIR\Uninstall-QGIS.exe" "" SW_SHOWNORMAL "" "Uninstall ${COMPLETE_NAME}"
+ GetFullPathName /SHORT $0 $INSTALL_DIR
+ System::Call 'Kernel32::SetEnvironmentVariableA(t, t) i("OSGEO4W_ROOT", "$0").r0'
+ System::Call 'Kernel32::SetEnvironmentVariableA(t, t) i("OSGEO4W_STARTMENU", "$SMPROGRAMS\${QGIS_BASE}").r0'
+ ReadEnvStr $0 COMSPEC
+ nsExec::ExecToLog '"$0" /c "$INSTALL_DIR\postinstall.bat"'
SectionEnd
Function DownloadDataSet
@@ -524,6 +548,31 @@
Section "Uninstall"
+ GetFullPathName /SHORT $0 $INSTDIR
+ nsExec::ExecToLog '"$0" /c "$INSTALL_DIR\preremove.bat"'
+ Delete "$INSTDIR\Uninstall-QGIS.exe"
+ Delete "$INSTDIR\postinstall.bat.done"
+ Delete "$INSTDIR\postinstall.bat"
+ Delete "$INSTDIR\postinstall.log"
+ Delete "$INSTDIR\preremove.bat.done"
+ Delete "$INSTDIR\preremove.bat"
+ Delete "$INSTDIR\preremove.log"
+ RMDir /r "$INSTDIR\bin"
+ RMDir /r "$INSTDIR\apps"
+ RMDir /r "$INSTDIR\etc"
+ RMDir /r "$INSTDIR\include"
+ RMDir /r "$INSTDIR\lib"
+ RMDir /r "$INSTDIR\share"
+ RMDir /r "$INSTDIR\icons"
+!else
;remove files
@@ -563,6 +612,7 @@
RMDir /r "$INSTDIR\themes"
RMDir /r "$INSTDIR\proj"
RMDir /r "$INSTDIR\epsg_csv"
+!endif
;if empty, remove the install folder
RMDir "$INSTDIR"
@@ -578,7 +628,6 @@
;remove the Registry Entries
DeleteRegKey HKLM "Software\${QGIS_BASE}"
DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${QGIS_BASE}"
SectionEnd
Added: trunk/qgis/ms-windows/osgeo4w/creatensis.pl
--- trunk/qgis/ms-windows/osgeo4w/creatensis.pl (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/creatensis.pl 2010-06-05 20:38:15 UTC (rev 13664)
@@ -0,0 +1,212 @@
+#!/usr/bin/perl
+# creates a NSIS installer from OSGeo4W packages
+# note: works also on Unix
+# Copyright (C) 2010 Jürgen E. Fischer <jef at norbit.de>
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# Download OSGeo4W packages
+mkdir "packages", 0755 unless -d "packages";
+chdir "packages";
+my $root = "http://download.osgeo.org/osgeo4w";
+system "wget -q -c http://nsis.sourceforge.net/mediawiki/images/9/9d/Untgz.zip" unless -f "Untgz.zip";
+system "wget -q -c http://www.nirsoft.net/utils/nircmd.zip" unless -f "nircmd.zip";
+my %dep;
+my %file;
+system "wget -q -c $root/setup.ini";
+open F, "setup.ini" || die "setup.ini not found";
+while(<F>) {
+ chop;
+ if(/^@ (\S+)/) {
+ $package = $1;
+ } elsif( /^requires: (.*)$/ ) {
+ @{$dep{$package}} = split / /, $1;
+ } elsif( /^install:\s+(\S+)\s+/) {
+ $file{$package} = $1 unless exists $file{$package};
+close F;
+my %pkgs;
+sub getDeps {
+ my ($pkg) = @_;
+ return if exists $pkgs{$pkg};
+ $pkgs{$pkg} = 1;
+ foreach my $p ( @{ $dep{$pkg} } ) {
+ getDeps($p);
+getDeps("qgis-dev");
+if(-f "../addons/bin/NCSEcw.dll") {
+ print "Enabling ECW support...\n";
+ getDeps("gdal16-ecw")
+if(-f "../addons/bin/lti_dsdk_dll.dll") {
+ print "Enabling MrSID support...\n";
+ getDeps("gdal16-mrsid")
+delete $pkgs{"qgis-dev"};
+foreach my $p ( keys %pkgs ) {
+ $f = "$root/$file{$p}";
+ $f =~ s/\/\.\//\//g;
+ my($file) = $f =~ /([^\/]+)$/;
+ next if -f $file;
+ print "Downloading $file [$f]...\n";
+ system "wget -q -c $f";
+chdir "..";
+# Unpack them
+# Add nircmd
+# Add addons
+system "rm -rf unpacked" if -d "unpacked" && !grep(/^-k$/, @ARGV);
+unless(-d "unpacked") {
+ mkdir "unpacked", 0755;
+ for my $p (<packages/*.tar.bz2>) {
+ print "Unpacking $p...\n";
+ system "tar -C unpacked -xjf $p";
+ chdir "unpacked";
+ mkdir "bin", 0755;
+ mkdir "apps", 0755;
+ mkdir "apps/nircmd", 0755;
+ system "cd apps/nircmd; unzip ../../../packages/nircmd.zip && mv nircmd.exe ../../bin";
+ system "tar -C ../addons -cf . | tar -xf -" if -d "../addons";
+ chdir "..";
+# Create postinstall.bat
+unless(-f "../Installer-Files/postinstall.bat") {
+ open F, ">../Installer-Files/postinstall.bat";
+ print F "\@echo off\r\n";
+ print F "del postinstall.log>>postinstall.log\r\n";
+ print F "echo OSGEO4W_ROOT=%OSGEO4W_ROOT%>>postinstall.log 2>&1\r\n";
+ print F "echo OSGEO4W_STARTMENU=%OSGEO4W_STARTMENU%>>postinstall.log 2>&1\r\n";
+ print F "set OSGEO4W_ROOT_MSYS=%OSGEO4W_ROOT:\\=/%\r\n";
+ print F "if \"%OSGEO4W_ROOT_MSYS:~1,1%\"==\":\" set OSGEO4W_ROOT_MSYS=/%OSGEO4W_ROOT_MSYS:~0,1%/%OSGEO4W_ROOT_MSYS:~3%\r\n";
+ print F "echo OSGEO4W_ROOT_MSYS=%OSGEO4W_ROOT_MSYS%>>postinstall.log 2>&1\r\n";
+ print F "PATH %OSGEO4W_ROOT%\\bin;%PATH%>>postinstall.log 2>&1\r\n";
+ print F "cd %OSGEO4W_ROOT%>>postinstall.log 2>&1\r\n";
+ chdir "unpacked";
+ for my $p (<etc/postinstall/*.bat>) {
+ $p =~ s/\//\\/g;
+ my($dir,$file) = $p =~ /^(.+)\\([^\\]+)$/;
+ print F "echo Running postinstall $file...\r\n";
+ print F "%COMSPEC% /c $p>>postinstall.log 2>&1\r\n";
+ print F "ren $p $file.done>>postinstall.log 2>&1\r\n";
+ chdir "..";
+ print F "ren postinstall.bat postinstall.bat.done\r\n";
+ close F;
+unless(-f "../Installer-Files/preremove.bat") {
+ open F, ">../Installer-Files/preremove.bat";
+ print F "del preremove.log>>preremove.log\r\n";
+ print F "echo OSGEO4W_ROOT=%OSGEO4W_ROOT%>>preremove.log 2>&1\r\n";
+ print F "echo OSGEO4W_STARTMENU=%OSGEO4W_STARTMENU%>>preremove.log 2>&1\r\n";
+ print F "echo OSGEO4W_ROOT_MSYS=%OSGEO4W_ROOT_MSYS%>>preremove.log 2>&1\r\n";
+ print F "PATH %OSGEO4W_ROOT%\\bin;%PATH%>>preremove.log 2>&1\r\n";
+ print F "cd %OSGEO4W_ROOT%>>preremove.log 2>&1\r\n";
+ chdir "unpacked";
+ for my $p (<etc/preremove/*.bat>) {
+ $p =~ s/\//\\/g;
+ print F "echo Running preremove $file...\r\n";
+ print F "%COMSPEC% /c $p>>preremove.log 2>&1\r\n";
+ print F "ren $p $file.done>>preremove.log 2>&1\r\n";
+ chdir "..";
+ print F "ren preremove.bat preremove.bat.done\r\n";
+ close F;
+my($major, $minor, $patch, $release, $revision);
+open F, "../../CMakeLists.txt";
+while(<F>) {
+ print;
+ if(/SET\(CPACK_PACKAGE_VERSION_MAJOR "(\d+)"\)/) {
+ $major = $1;
+ } elsif(/SET\(CPACK_PACKAGE_VERSION_MINOR "(\d+)"\)/) {
+ $minor = $1;
+ } elsif(/SET\(CPACK_PACKAGE_VERSION_PATCH "(\d+)"\)/) {
+ $patch = $1;
+ } elsif(/SET\(RELEASE_NAME "(.+)"\)/) {
+ $release = $1;
+close F;
+open F, "svnversion|";
+$revision = <F>;
+$revision =~ s/\D+$//g;
+close F;
+chdir "..";
+my $cmd = "makensis";
+$cmd .= " -DVERSION_NUMBER='$major.$minor.$patch'";
+$cmd .= " -DVERSION_NAME='$release'";
+$cmd .= " -DSVN_REVISION='$revision'";
+$cmd .= " -DQGIS_BASE='Quantum GIS $release'";
+$cmd .= " -DINSTALLER_NAME='QGIS-OSGeo4W-$major.$minor.$patch-$revision-Setup.exe'";
+$cmd .= " -DDISPLAYED_NAME='Quantum GIS OSGeo4W ($release)'";
+$cmd .= " -DBINARY_REVISION=1";
+$cmd .= " -DINSTALLER_TYPE=OSGeo4W";
+$cmd .= " -DPACKAGE_FOLDER=osgeo4w/unpacked";
+$cmd .= " QGIS-Installer.nsi";
+system $cmd;
Property changes on: trunk/qgis/ms-windows/osgeo4w/creatensis.pl
___________________________________________________________________
Added: svn:executable
