[QGIS Commit] r13725 - in trunk/qgis:
python/plugins/GdalTools/tools src/app
svn_qgis at osgeo.org
Sun Jun 13 14:27:55 EDT 2010
Author: brushtyler
Date: 2010-06-13 18:27:55 +0000 (Sun, 13 Jun 2010)
New Revision: 13725
trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py
trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
trunk/qgis/src/app/qgisapp.cpp
applied patch to show GDAL version in about dialog, to fix #2804
Modified: trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py
--- trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py 2010-06-13 08:43:01 UTC (rev 13724)
+++ trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py 2010-06-13 18:27:55 UTC (rev 13725)
@@ -603,33 +603,27 @@
# class which allows to create version objects and compare them
class Version:
def __init__(self, ver):
- self.vers = (0, 0, 0)
+ self.vers = ('0', '0', '0')
if isinstance(ver, Version):
self.vers = ver.vers
elif isinstance(ver, tuple) or isinstance(ver, list):
- self.vers = tuple(ver)
+ self.vers = map(str, ver)
elif isinstance(ver, str) or isinstance(ver, QString):
self.vers = self.string2vers(ver)
@staticmethod
def string2vers(string):
- vers = [0, 0, 0]
+ vers = ['0', '0', '0']
nums = str(string).split(".")
if len(nums) > 0:
- n = QString(nums[0]).remove( QRegExp( "[^0-9].*$" ) )
- if not n.isEmpty():
- vers[0] = int(n)
+ vers[0] = nums[0]
if len(nums) > 1:
- n = QString(nums[1]).remove( QRegExp( "[^0-9].*$" ) )
- vers[1] = int(n)
+ vers[1] = nums[1]
if len(nums) > 2:
- n = QString(nums[2]).remove( QRegExp( "[^0-9].*$" ) )
- vers[2] = int(n)
+ vers[2] = nums[2]
return (vers[0], vers[1], vers[2])
Modified: trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
--- trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2010-06-13 08:43:01 UTC (rev 13724)
+++ trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2010-06-13 18:27:55 UTC (rev 13725)
@@ -7,6 +7,7 @@
from ui_dialogAbout import Ui_GdalToolsAboutDialog as Ui_Dialog
from GdalTools import version
+from GdalTools_utils import GdalConfig
class GdalToolsAboutDialog(QDialog, Ui_Dialog):
@@ -17,7 +18,7 @@
QObject.connect(self.btnWeb, SIGNAL("clicked()"), self.openWebsite)
- self.lblVersion.setText( version() )
+ self.lblVersion.setText( version() + self.tr( "\n(using GDAL v. %1)" ).arg( str( GdalConfig.version() ) ) )
self.textEdit.setText(self.getText())
def getText(self):
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-06-13 08:43:01 UTC (rev 13724)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-06-13 18:27:55 UTC (rev 13725)
@@ -2390,6 +2390,9 @@
QString versionString = tr( "You are using QGIS version %1 built against code revision %2." )
.arg( QGis::QGIS_VERSION )
.arg( QGis::QGIS_SVN_VERSION );
+ versionString += tr( "\nThis copy of QGIS has been built with GDAL/OGR %1." ).arg( GDAL_RELEASE_NAME );
#ifdef HAVE_POSTGRESQL
versionString += tr( "\nThis copy of QGIS has been built with PostgreSQL support (%1)." ).arg( PG_VERSION );
#else
