[QGIS Commit] r13748 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jun 18 08:26:01 EDT 2010
Author: pcav
Date: 2010-06-18 12:26:01 +0000 (Fri, 18 Jun 2010)
New Revision: 13748
   trunk/qgis/i18n/qgis_it.ts
More GUI IT translations
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts	2010-06-18 08:45:40 UTC (rev 13747)
+++ trunk/qgis/i18n/qgis_it.ts	2010-06-18 12:26:01 UTC (rev 13748)
@@ -8533,7 +8533,7 @@
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="722"/>
         <source>&lt;p&gt;The SVG export function in Qgis has several problems due to bugs and deficiencies in the </source>
-        <translation>&lt;p&gt;La funziona di esportazione SVG in Qgis ha diversi problemi causati da bug e limitazioni</translation>
+        <translation>&lt;p&gt;La funziona di esportazione SVG in Qgis ha diversi problemi causati da bug e limitazioni </translation>
     </message>
     <message>
         <location filename="../src/app/composer/qgscomposer.cpp" line="617"/>
@@ -9106,7 +9106,7 @@
     <message>
         <location filename="../src/ui/qgscomposerlegendwidgetbase.ui" line="88"/>
         <source>Group Font...</source>
-        <translation type="unfinished"></translation>
+        <translation>Carattere del gruppo...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposerlegendwidgetbase.ui" line="95"/>
@@ -9888,7 +9888,7 @@
     <message>
         <location filename="../src/ui/qgscomposertablewidgetbase.ui" line="101"/>
         <source>Maximum columns</source>
-        <translation>Massimo colonne</translation>
+        <translation>N massimo righe</translation>
     </message>
     <message>
         <location filename="../src/ui/qgscomposertablewidgetbase.ui" line="118"/>
@@ -10284,7 +10284,7 @@
         <location filename="../src/app/qgsconfigureshortcutsdialog.cpp" line="76"/>
         <location filename="../src/app/qgsconfigureshortcutsdialog.cpp" line="128"/>
         <source>XML file (*.xml);; All files (*)</source>
+        <translation>file XML (*.xml *.XML)</translation>
     </message>
     <message>
         <location filename="../src/app/qgsconfigureshortcutsdialog.cpp" line="90"/>
@@ -11285,12 +11285,12 @@
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="14"/>
         <source>Dialog</source>
+        <translation>Finestra di dialogo</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="22"/>
         <source>Search method</source>
-        <translation type="unfinished">Modalità di ricerca</translation>
+        <translation>Modalità di ricerca</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="30"/>
@@ -11320,32 +11320,32 @@
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="78"/>
         <source>Number of candidates</source>
-        <translation type="unfinished">Numero di candidati</translation>
+        <translation>Numero di candidati</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="84"/>
         <source>Point</source>
-        <translation type="unfinished">Punto</translation>
+        <translation>Punto</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="104"/>
         <source>Line</source>
-        <translation type="unfinished">Linea</translation>
+        <translation>Linea</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="124"/>
         <source>Polygon</source>
-        <translation type="unfinished">Poligono</translation>
+        <translation>Poligono</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="178"/>
         <source>Show all labels (i.e. including colliding labels)</source>
-        <translation type="unfinished">Mostra tutte le etichette (incluse quelle che collidono)</translation>
+        <translation>Mostra tutte le etichette (incluse quelle che collidono)</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsengineconfigdialog.ui" line="185"/>
         <source>Show label candidates (for debugging)</source>
-        <translation type="unfinished">Mostra le etichette possibili (per debugging)</translation>
+        <translation>Mostra le etichette possibili (per debugging)</translation>
     </message>
 </context>
 <context>
@@ -11581,13 +11581,13 @@
         <location filename="../src/plugins/georeferencer/qgsgcplistmodel.cpp" line="112"/>
         <location filename="../src/plugins/georeferencer/qgsgcplistmodel.cpp" line="164"/>
         <source>map units</source>
-        <translation type="unfinished">unità mappa</translation>
+        <translation>unità mappa</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgsgcplistmodel.cpp" line="116"/>
         <location filename="../src/plugins/georeferencer/qgsgcplistmodel.cpp" line="152"/>
         <source>pixels</source>
-        <translation type="unfinished">pixel</translation>
+        <translation>pixel</translation>
     </message>
 </context>
 <context>
@@ -12463,17 +12463,17 @@
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="60"/>
         <source>Residual units</source>
+        <translation>Unità dei residui</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="66"/>
         <source>Pixels</source>
+        <translation>Pixel</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="73"/>
         <source>Use map units if possible</source>
+        <translation>Usa le unità di mappa se possibile</translation>
     </message>
 </context>
 <context>
@@ -12645,7 +12645,7 @@
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="133"/>
         <source>Georeferencer</source>
-        <translation type="unfinished">Georeferenziatore</translation>
+        <translation>Georeferenziatore</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefplugingui.cpp" line="1095"/>
@@ -24627,7 +24627,6 @@
         <comment>selected geometries</comment>
             <numerusform></numerusform>
-            <numerusform></numerusform>
         </translation>
     </message>
     <message>
@@ -27174,7 +27173,6 @@
         <comment>selected layer count</comment>
         </translation>
     </message>
     <message>
@@ -27295,12 +27293,12 @@
     <message>
         <location filename="../src/ui/qgswmssourceselectbase.ui" line="208"/>
         <source>Ignore GetMap URL</source>
+        <translation>Ignora GetMap URL</translation>
     </message>
     <message>
         <location filename="../src/ui/qgswmssourceselectbase.ui" line="218"/>
         <source>Ignore GetFeatureInfo URL</source>
+        <translation>Ignora GetFeatureInfo URL</translation>
     </message>
     <message>
         <location filename="../src/ui/qgswmssourceselectbase.ui" line="231"/>
@@ -27560,7 +27558,7 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2475"/>
         <source>Selected Layers:</source>
+        <translation>Layer selezionati:</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2488"/>
@@ -27642,7 +27640,7 @@
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2232"/>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2242"/>
         <source>Available in CRS</source>
-        <translation type="unfinished">Disponibile in CRS</translation>
+        <translation>Disponibile in CRS</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2253"/>
@@ -27657,12 +27655,12 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2534"/>
         <source>Styles</source>
-        <translation type="unfinished">Stili</translation>
+        <translation>Stili</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2542"/>
         <source>CRS</source>
-        <translation type="unfinished">CRS</translation>
+        <translation>CRS</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2549"/>
@@ -27687,12 +27685,12 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2600"/>
         <source>Errors</source>
+        <translation>Errori</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2673"/>
         <source>Layer cannot be queried in plain text.</source>
+        <translation>Il layer non può essere interrogato come testo.</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2679"/>
@@ -27702,7 +27700,7 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2723"/>
         <source>identify request redirected.</source>
+        <translation>richiesta di identificazione rediretta.</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="964"/>
@@ -27718,7 +27716,6 @@
         <comment>tile request count</comment>
         </translation>
     </message>
     <message numerus="yes">
@@ -27728,7 +27725,6 @@
         <comment>tile cache hits</comment>
         </translation>
     </message>
@@ -27738,7 +27734,6 @@
         <comment>tile cache missed</comment>
         </translation>
     </message>
@@ -27746,9 +27741,9 @@
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="783"/>
         <source>, %n errors.</source>
         <comment>errors</comment>
+        <translation>
+            <numerusform>, %n errore.</numerusform>
+            <numerusform>, %n errori.</numerusform>
         </translation>
     </message>
     <message>
@@ -27772,7 +27767,7 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="899"/>
         <source>Capabilities request redirected.</source>
-        <translation type="unfinished">Richiesta capabilities reindirizzata.</translation>
+        <translation>Richiesta capabilities reindirizzata.</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="918"/>
@@ -27782,7 +27777,7 @@
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="923"/>
         <source>Download of capabilities failed: %1</source>
-        <translation type="unfinished">Download di capabilities non riuscito: %1</translation>
+        <translation>Download di capabilities non riuscito: %1</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="935"/>
@@ -27824,14 +27819,13 @@
         <comment>crs</comment>
         </translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2303"/>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2329"/>
         <source>Server Properties</source>
+        <translation>Proprietà del server</translation>
     </message>
     <message>
         <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2307"/>
@@ -28230,7 +28224,7 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_linedecoration.ui" line="22"/>
         <source>Color</source>
-        <translation type="unfinished">Colore</translation>
+        <translation>Colore</translation>
     </message>
     <message>
         <source>Color:</source>
@@ -28252,17 +28246,17 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_markerline.ui" line="22"/>
         <source>Marker</source>
+        <translation>Marcatore</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_markerline.ui" line="52"/>
         <source>Marker interval</source>
+        <translation>Intervallo marcatore</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_markerline.ui" line="66"/>
         <source>Line offset</source>
+        <translation>Offset linea</translation>
     </message>
     <message>
         <source>Marker:</source>
@@ -28305,12 +28299,12 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_svgfill.ui" line="22"/>
         <source>Texture width</source>
+        <translation>Larghezza della texture</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_svgfill.ui" line="40"/>
         <source>Outline</source>
+        <translation>Contorno esterno</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_svgfill.ui" line="47"/>
@@ -28333,32 +28327,32 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="22"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="52"/>
         <source>Fill style</source>
+        <translation>Stile riempimento</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="62"/>
         <source>Border color</source>
+        <translation>Colore del bordo</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="76"/>
         <source>Border style</source>
+        <translation>Stile del bordo</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="86"/>
         <source>Border width</source>
+        <translation>Larghezza bordo</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplefill.ui" line="103"/>
         <source>Offset X,Y</source>
+        <translation>Offset X,Y</translation>
     </message>
     <message>
@@ -28401,32 +28395,32 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="22"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="58"/>
         <source>Pen width</source>
+        <translation>Larghezza penna</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="87"/>
         <source>Offset</source>
-        <translation type="unfinished">Offset</translation>
+        <translation>Offset</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="110"/>
         <source>Pen style</source>
+        <translation>Stile penna</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="151"/>
         <source>Join style</source>
+        <translation>Stile unione</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simpleline.ui" line="177"/>
         <source>Cap style</source>
+        <translation>Stile testa</translation>
     </message>
     <message>
@@ -28474,27 +28468,27 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="22"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="52"/>
         <source>Fill color</source>
+        <translation>Colore di riempimento</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="66"/>
         <source>Size</source>
-        <translation type="unfinished">Dimensione</translation>
+        <translation>Dimensione</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="73"/>
         <source>Angle</source>
-        <translation type="unfinished">Angolo</translation>
+        <translation>Angolo</translation>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="93"/>
     </message>
     <message>
         <source>Border color:</source>
@@ -28533,22 +28527,22 @@
     <message>
         <location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="28"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="48"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="98"/>
     </message>
     <message>
         <location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="126"/>
         <source>SVG Image</source>
+        <translation>Immagine SVG</translation>
     </message>
     <message>
         <source>Size:</source>
More information about the QGIS-commit mailing list
