[QGIS Commit] r13756 - trunk/qgis/cmake
svn_qgis at osgeo.org
Sun Jun 20 13:09:21 EDT 2010
Author: wonder
Date: 2010-06-20 17:09:21 +0000 (Sun, 20 Jun 2010)
New Revision: 13756
Added:
trunk/qgis/cmake/COPYING-CMAKE-SCRIPTS
trunk/qgis/cmake/Bison.cmake
trunk/qgis/cmake/FindExpat.cmake
trunk/qgis/cmake/FindGDAL.cmake
trunk/qgis/cmake/FindGEOS.cmake
trunk/qgis/cmake/FindGRASS.cmake
trunk/qgis/cmake/FindIconv.cmake
trunk/qgis/cmake/FindPostgres.cmake
trunk/qgis/cmake/FindProj.cmake
trunk/qgis/cmake/FindQWT.cmake
trunk/qgis/cmake/FindSPATIALITE.cmake
trunk/qgis/cmake/FindSqlite3.cmake
trunk/qgis/cmake/Flex.cmake
trunk/qgis/cmake/PyQt4Macros.cmake
Added copyright notices to CMake modules, BSD license has been set to the modules (typical license for CMake modules).
Modified: trunk/qgis/cmake/Bison.cmake
--- trunk/qgis/cmake/Bison.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/Bison.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,9 @@
+# Macros for Bison
+# Copyright (c) 2007, Martin Dobias <wonder.sk at gmail.com>
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
# use bison for .yy files
# search for bison
Added: trunk/qgis/cmake/COPYING-CMAKE-SCRIPTS
--- trunk/qgis/cmake/COPYING-CMAKE-SCRIPTS (rev 0)
+++ trunk/qgis/cmake/COPYING-CMAKE-SCRIPTS 2010-06-20 17:09:21 UTC (rev 13756)
@@ -0,0 +1,22 @@
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions
+are met:
+1. Redistributions of source code must retain the copyright
+ notice, this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the copyright
+ notice, this list of conditions and the following disclaimer in the
+ documentation and/or other materials provided with the distribution.
+3. The name of the author may not be used to endorse or promote products
+ derived from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Modified: trunk/qgis/cmake/FindExpat.cmake
--- trunk/qgis/cmake/FindExpat.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindExpat.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,4 +1,9 @@
+# Find Expat
# CMake module to search for Expat library
# (library for parsing XML files)
Modified: trunk/qgis/cmake/FindGDAL.cmake
--- trunk/qgis/cmake/FindGDAL.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindGDAL.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,14 +1,20 @@
-## Once run this will define:
-## GDAL_FOUND = system has GDAL lib
-## GDAL_LIBRARY = full path to the library
-## GDAL_INCLUDE_DIR = where to find headers
-## Magnus Homann
+# Find GDAL
+# Copyright (c) 2007, Magnus Homann <magnus at homann dot se>
+# Once run this will define:
+# GDAL_FOUND = system has GDAL lib
+# GDAL_LIBRARY = full path to the library
+# GDAL_INCLUDE_DIR = where to find headers
IF(WIN32)
IF (MINGW)
Modified: trunk/qgis/cmake/FindGEOS.cmake
--- trunk/qgis/cmake/FindGEOS.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindGEOS.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,10 @@
+# Find GEOS
+# Copyright (c) 2008, Mateusz Loskot <mateusz at loskot.net>
+# (based on FindGDAL.cmake by Magnus Homann)
# CMake module to search for GEOS library
# If it's found it sets GEOS_FOUND to TRUE
@@ -5,8 +12,7 @@
# GEOS_INCLUDE_DIR
# GEOS_LIBRARY
-# Mateusz Loskot <mateusz at loskot.net>
-# (based in FindGDAL.cmake by Magnus Homann)
IF(WIN32)
Modified: trunk/qgis/cmake/FindGRASS.cmake
--- trunk/qgis/cmake/FindGRASS.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindGRASS.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,8 @@
+# Find GRASS
# macro that checks for grass installation in specified directory
Modified: trunk/qgis/cmake/FindIconv.cmake
--- trunk/qgis/cmake/FindIconv.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindIconv.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,9 @@
+# Find Iconv
+# Copyright (c) 2009, Juergen E. Fischer <jef at norbit dot de>
# CMake module to search for iconv library
# If it's found it sets ICONV_FOUND to TRUE
Modified: trunk/qgis/cmake/FindPostgres.cmake
--- trunk/qgis/cmake/FindPostgres.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindPostgres.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,4 +1,9 @@
+# Find PostgreSQL
# CMake module to search for PostgreSQL library
# pg_config is searched for in POSTGRES_CONFIG dir,
Modified: trunk/qgis/cmake/FindProj.cmake
--- trunk/qgis/cmake/FindProj.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindProj.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,4 +1,9 @@
+# Find Proj
# CMake module to search for Proj library
# If it's found it sets PROJ_FOUND to TRUE
Modified: trunk/qgis/cmake/FindQWT.cmake
--- trunk/qgis/cmake/FindQWT.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindQWT.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,12 +1,17 @@
-## QWT_FOUND = system has QWT lib
-## QWT_LIBRARY = full path to the QWT library
-## QWT_INCLUDE_DIR = where to find headers
-## Tim Sutton
+# Find Qwt
+# Copyright (c) 2010, Tim Sutton <tim at linfiniti.com>
+# QWT_FOUND = system has QWT lib
+# QWT_LIBRARY = full path to the QWT library
+# QWT_INCLUDE_DIR = where to find headers
#MESSAGE("Searching for QWT")
Modified: trunk/qgis/cmake/FindSPATIALITE.cmake
--- trunk/qgis/cmake/FindSPATIALITE.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindSPATIALITE.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,4 +1,9 @@
+# Find SpatiaLite
+# Copyright (c) 2009, Sandro Furieri <a.furieri at lqt.it>
# CMake module to search for SpatiaLite library
# If it's found it sets SPATIALITE_FOUND to TRUE
Modified: trunk/qgis/cmake/FindSqlite3.cmake
--- trunk/qgis/cmake/FindSqlite3.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/FindSqlite3.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,4 +1,9 @@
+# Find Sqlite3
# CMake module to search for Sqlite3 library
# If it's found it sets SQLITE3_FOUND to TRUE
Modified: trunk/qgis/cmake/Flex.cmake
--- trunk/qgis/cmake/Flex.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/Flex.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,9 @@
+# Macros for Bison
# flex a .ll file
# search flex
Modified: trunk/qgis/cmake/PyQt4Macros.cmake
--- trunk/qgis/cmake/PyQt4Macros.cmake 2010-06-20 15:58:31 UTC (rev 13755)
+++ trunk/qgis/cmake/PyQt4Macros.cmake 2010-06-20 17:09:21 UTC (rev 13756)
@@ -1,3 +1,8 @@
+# Macros for PyQt4
IF(NOT PYUIC4_PROGRAM)
