[QGIS Commit] r13780 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Tue Jun 22 09:18:48 EDT 2010
Author: aghisla
Date: 2010-06-22 13:18:48 +0000 (Tue, 22 Jun 2010)
New Revision: 13780
docs/trunk/english_us/user_guide/foreword.tex
Cleaned up list of new features in Tethys.
Modified: docs/trunk/english_us/user_guide/foreword.tex
--- docs/trunk/english_us/user_guide/foreword.tex 2010-06-22 13:18:32 UTC (rev 13779)
+++ docs/trunk/english_us/user_guide/foreword.tex 2010-06-22 13:18:48 UTC (rev 13780)
@@ -169,22 +169,37 @@
These are the most relevant additions and improvements:
\begin{itemize}[label=--]
- \item TODO(anne): rearrange the list on ManualTasks wikipage!
+% \item TODO(anne): rearrange the list on ManualTasks wikipage!
\item added context help to dialogs
\item show classification attribute above the classes in legend %(new symbology, enable via Options..)
\item measure angle tool
% composer attr tables ?
\item GPS tracker widget
+ \item Spatial Query plugin
+ \item GDAL Tools plugin
+ \item Google Earth plugin
+ \item moved Labeling-ng plugin to core
% composer table select display attribs (r12709) ?
+ \item added "Drag and drop support" for composer legend model
+ \item show labels from labeling plugin also in map composer (though not scaled correctly)
% Added vertical line to simple marker symbol layer ?
% Added rotation for ellipse, cross and line markers ?
- \item new Oracle raster connection dialog
- \item added scroll area, 'select all' and 'clear' buttons to attribute dialog
- \item show labels from labeling plugin also in map composer (though not scaled correctly)
+% \item added scroll area, 'select all' and 'clear' buttons to attribute dialog
\item update georeferencer from gislab SVN, which adds GCP table with errors, new user interface
\item Georeferencer: support custom projection strings.
-% Georeferencer: Implement resampling with user-specified target resolution
+ \item Georeferencer: Implement resampling with user-specified target resolution (enhancement request \#2447)
\item BBOX option for WFS
- \item Join attributes tool now supports both dbf and csv files.
+ \item join attributes tool now supports both dbf and csv files % table join rulez!
\item show feature count in attribute table title
+ \item console runnable also outside QGIS
+ \item added more geometry validity checks
+ \item removed limitation on maximum no of selectable features
+ \item GDAL-GRASS driver no more necessary, new requirement: exceptions support for GRASS
+ \item projection search improvements
+ \item add GDAL compatible CRSes (without +towgs84 parameters) for Polish epsg: 2172-2180, 3120, 3328-3335 and 4179 as epsg+40000
+ \item change map unit in project dialog when user selects a new CRS
+ \item new Oracle raster connection dialog
+ \item implementation of the "Add New Spatialite Layer/Database" feature
+ \item allow creation of multiple layers in Spatialite creation dialog
\end{itemize}
