[QGIS Commit] r13787 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Jun 23 07:49:29 EDT 2010
Author: aghisla
Date: 2010-06-23 11:49:29 +0000 (Wed, 23 Jun 2010)
New Revision: 13787
docs/trunk/english_us/user_guide/features_at_a_glance.tex
Reordered subsections in Features at a glance/QGIS GUI, to match numbering in GUI screenshot.
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-06-23 11:28:05 UTC (rev 13786)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-06-23 11:49:29 UTC (rev 13787)
@@ -129,29 +129,11 @@
\end{tabular}
These six components of the QGIS interface are described in more detail in
-the following sections.
+the following sections. Two more sections present keyboard shortcuts and
+context help.
-\subsection{Keyboard shortcuts}\label{shortcuts}
-\index{Keyboard shortcuts}
+% \newpage
-QGIS provides default keyboard shortcuts for many features. You find them in
-Section \ref{label_menubar} below. Additionally the menu option \mainmenuopt{Settings} >
-\dropmenuopt{Configure Shortcuts} allows to change the default keyboard
-shortcuts and to add new keyboard shortcuts to QGIS features.
-\begin{figure}[ht]
- \centering
- \includegraphics[clip=true, width=8cm]{shortcuts}
- \caption{Define shortcut options \nixcaption (KDE)} \label{fig:shortcuts}
-\end{figure}
-Configuration is very simple. Just select a feature from the list and click
-on \button{Change}, \button{Set none} or \button{Set default}. Once you have
-found your configuration, you can save it as XML file and load it to another
-QGIS installation.
-\newpage
\subsection{Menu Bar}\label{label_menubar}
\index{menus}
@@ -710,6 +692,25 @@
units are set to what the project projection specifies, e.g. '+units=m'.
\end{Tip}
+\subsection{Keyboard shortcuts}\label{shortcuts}
+\index{Keyboard shortcuts}
+QGIS provides default keyboard shortcuts for many features. You find them in
+Section \ref{label_menubar} below. Additionally the menu option \mainmenuopt{Settings} >
+\dropmenuopt{Configure Shortcuts} allows to change the default keyboard
+shortcuts and to add new keyboard shortcuts to QGIS features.
+\begin{figure}[ht]
+ \centering
+ \includegraphics[clip=true, width=8cm]{shortcuts}
+ \caption{Define shortcut options \nixcaption (KDE)} \label{fig:shortcuts}
+\end{figure}
+Configuration is very simple. Just select a feature from the list and click
+on \button{Change}, \button{Set none} or \button{Set default}. Once you have
+found your configuration, you can save it as XML file and load it to another
+QGIS installation.
\section{Rendering}\label{subsec:redraw_events}\index{rendering}
By default, QGIS renders all visible layers whenever the map canvas must be
