[QGIS Commit] r13011 - trunk/qgis/src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 6 08:49:57 EST 2010
Author: macho
Date: 2010-03-06 08:49:55 -0500 (Sat, 06 Mar 2010)
New Revision: 13011
   trunk/qgis/src/ui/qgsabout.ui
just optical changes in the aboutbox (bug?fixes)
Modified: trunk/qgis/src/ui/qgsabout.ui
--- trunk/qgis/src/ui/qgsabout.ui	2010-03-05 18:23:04 UTC (rev 13010)
+++ trunk/qgis/src/ui/qgsabout.ui	2010-03-06 13:49:55 UTC (rev 13011)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsAbout</class>
- <widget class="QDialog" name="QgsAbout" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsAbout">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,75 +10,75 @@
     <height>416</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>About Quantum GIS</string>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QTabWidget" name="tabWidget" >
-     <property name="currentIndex" >
-      <number>0</number>
+  <layout class="QGridLayout">
+   <item row="0" column="0">
+    <widget class="QTabWidget" name="tabWidget">
+     <property name="currentIndex">
+      <number>4</number>
      </property>
-     <widget class="QWidget" name="Widget2" >
-      <attribute name="title" >
+     <widget class="QWidget" name="Widget2">
+      <attribute name="title">
        <string>About</string>
       </attribute>
-        <layout class="QHBoxLayout" >
+        <layout class="QHBoxLayout">
          <item>
-          <widget class="QLabel" name="qgisIcon" >
-           <property name="maximumSize" >
+          <widget class="QLabel" name="qgisIcon">
+           <property name="maximumSize">
             <size>
              <width>60</width>
              <height>60</height>
             </size>
            </property>
-           <property name="pixmap" >
-            <pixmap resource="../../images/images.qrc" >:/images/icons/qgis-icon-60x60.png</pixmap>
+           <property name="pixmap">
+            <pixmap resource="../../images/images.qrc">:/images/icons/qgis-icon-60x60.png</pixmap>
            </property>
-           <property name="scaledContents" >
+           <property name="scaledContents">
             <bool>false</bool>
            </property>
           </widget>
          </item>
          <item>
-          <widget class="QLabel" name="TextLabel4" >
-           <property name="text" >
-            <string>&lt;html>&lt;head>&lt;meta name="qrichtext" content="1" />&lt;style type="text/css">
+          <widget class="QLabel" name="TextLabel4">
+           <property name="text">
+            <string>&lt;html&gt;&lt;head&gt;&lt;meta name=&quot;qrichtext&quot; content=&quot;1&quot; /&gt;&lt;style type=&quot;text/css&quot;&gt;
 p, li { white-space: pre-wrap; }
-&lt;/style>&lt;/head>&lt;body style=" font-family:'Lucida Grande'; font-size:13pt; font-weight:400; font-style:normal;">
-&lt;p style=" margin-top:16px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-size:x-large; font-weight:600;">&lt;span style=" font-size:x-large;">Quantum GIS (QGIS)&lt;/span>&lt;/p>&lt;/body>&lt;/html></string>
+&lt;/style&gt;&lt;/head&gt;&lt;body style=&quot; font-family:'Lucida Grande'; font-size:13pt; font-weight:400; font-style:normal;&quot;&gt;
+&lt;p style=&quot; margin-top:16px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-size:x-large; font-weight:600;&quot;&gt;&lt;span style=&quot; font-size:x-large;&quot;&gt;Quantum GIS (QGIS)&lt;/span&gt;&lt;/p&gt;&lt;/body&gt;&lt;/html&gt;</string>
            </property>
-           <property name="alignment" >
+           <property name="alignment">
             <set>Qt::AlignCenter</set>
            </property>
           </widget>
          </item>
         </layout>
        </item>
-       <item row="1" column="0" >
-        <widget class="QLabel" name="lblVersion" >
+       <item row="1" column="0">
+        <widget class="QLabel" name="lblVersion">
           <string>Version</string>
          </property>
          </property>
-         <property name="wordWrap" >
+         <property name="wordWrap">
           <bool>true</bool>
          </property>
         </widget>
        </item>
-       <item row="2" column="0" >
+       <item row="2" column="0">
         <spacer>
-         <property name="orientation" >
+         <property name="orientation">
           <enum>Qt::Vertical</enum>
          </property>
-         <property name="sizeHint" >
+         <property name="sizeHint" stdset="0">
           <size>
            <width>20</width>
            <height>21</height>
@@ -85,35 +86,35 @@
          </property>
         </spacer>
        </item>
-       <item row="3" column="0" >
-        <widget class="QLabel" name="label" >
+       <item row="3" column="0">
+        <widget class="QLabel" name="label">
           <string>Quantum GIS is licensed under the GNU General Public License</string>
          </property>
          </property>
           <bool>true</bool>
          </property>
         </widget>
        </item>
-       <item row="4" column="0" >
-        <widget class="QLabel" name="label_2" >
+       <item row="4" column="0">
+        <widget class="QLabel" name="label_2">
           <string>http://www.gnu.org/licenses</string>
          </property>
          </property>
         </widget>
        </item>
-       <item row="5" column="0" >
+       <item row="5" column="0">
         <spacer>
          </property>
           <size>
            <width>20</width>
            <height>40</height>
@@ -121,24 +122,24 @@
          </property>
         </spacer>
        </item>
-       <item row="6" column="0" >
+       <item row="6" column="0">
          <item>
-          <widget class="QPushButton" name="btnQgisHome" >
+          <widget class="QPushButton" name="btnQgisHome">
             <string>QGIS Home Page</string>
            </property>
-           <property name="flat" >
+           <property name="flat">
             <bool>false</bool>
            </property>
           </widget>
          </item>
          <item>
-          <widget class="QPushButton" name="btnQgisUser" >
+          <widget class="QPushButton" name="btnQgisUser">
             <string>Join our user mailing list</string>
            </property>
             <bool>false</bool>
            </property>
           </widget>
@@ -147,112 +148,108 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="Widget3" >
+     <widget class="QWidget" name="Widget3">
        <string>What's New</string>
       </attribute>
-        <widget class="QTextEdit" name="txtWhatsNew" >
-         <property name="focusPolicy" >
+        <widget class="QTextEdit" name="txtWhatsNew">
+         <property name="focusPolicy">
           <enum>Qt::NoFocus</enum>
          </property>
-         <property name="acceptDrops" >
+         <property name="acceptDrops">
           <bool>false</bool>
          </property>
-         <property name="lineWidth" >
+         <property name="lineWidth">
           <number>2</number>
          </property>
-         <property name="readOnly" >
+         <property name="readOnly">
           <bool>true</bool>
          </property>
         </widget>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="TabPage" >
+     <widget class="QWidget" name="TabPage">
        <string>Providers</string>
       </attribute>
-        <widget class="QTextBrowser" name="txtProviders" />
+        <widget class="QTextBrowser" name="txtProviders"/>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tab" >
+     <widget class="QWidget" name="tab">
        <string>Developers</string>
       </attribute>
-        <widget class="QListWidget" name="lstDevelopers" >
-         <property name="alternatingRowColors" >
+        <widget class="QListWidget" name="lstDevelopers">
+         <property name="alternatingRowColors">
           <bool>true</bool>
          </property>
-         <property name="isWrapping" stdset="0" >
+         <property name="isWrapping" stdset="0">
           <bool>false</bool>
          </property>
         </widget>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tab_5" >
+     <widget class="QWidget" name="tab_5">
        <string>Contributors</string>
       </attribute>
-      <widget class="QListWidget" name="lstContributors" >
-        <rect>
-         <x>0</x>
-         <y>0</y>
-         <width>713</width>
-         <height>314</height>
-        </rect>
-       </property>
-        <bool>true</bool>
-       </property>
-      </widget>
+      <layout class="QGridLayout" name="gridLayout">
+        <widget class="QListWidget" name="lstContributors">
+          <bool>true</bool>
+         </property>
+        </widget>
+       </item>
+      </layout>
      </widget>
-     <widget class="QWidget" name="tab_3" >
+     <widget class="QWidget" name="tab_3">
        <string>Translators</string>
       </attribute>
-        <widget class="QTextBrowser" name="txtTranslators" />
+        <widget class="QTextBrowser" name="txtTranslators"/>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tab_2" >
+     <widget class="QWidget" name="tab_2">
        <string>Sponsors</string>
       </attribute>
-        <widget class="QTextBrowser" name="txtSponsors" >
-         <property name="openExternalLinks" >
+        <widget class="QTextBrowser" name="txtSponsors">
+         <property name="openExternalLinks">
           <bool>true</bool>
          </property>
-         <property name="openLinks" >
+         <property name="openLinks">
           <bool>true</bool>
          </property>
         </widget>
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tab_4" >
+     <widget class="QWidget" name="tab_4">
        <string>Donors</string>
       </attribute>
-        <widget class="QTextBrowser" name="txtDonors" >
+        <widget class="QTextBrowser" name="txtDonors">
           <bool>true</bool>
          </property>
           <bool>true</bool>
          </property>
         </widget>
@@ -261,16 +258,16 @@
      </widget>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="standardButtons" >
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="standardButtons">
       <set>QDialogButtonBox::Close</set>
      </property>
     </widget>
    </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <tabstops>
   <tabstop>tabWidget</tabstop>
   <tabstop>btnQgisHome</tabstop>
@@ -284,7 +281,7 @@
   <tabstop>lstContributors</tabstop>
  </tabstops>
  <resources>
-  <include location="../../images/images.qrc" />
+  <include location="../../images/images.qrc"/>
  </resources>
  <connections>
   <connection>
@@ -293,11 +290,11 @@
    <receiver>QgsAbout</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>719</x>
      <y>386</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>674</x>
      <y>414</y>
     </hint>
More information about the QGIS-commit mailing list
