[QGIS Commit] r13025 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 8 15:19:04 EST 2010
Author: cfarmer
Date: 2010-03-08 15:19:04 -0500 (Mon, 08 Mar 2010)
New Revision: 13025
   trunk/qgis/python/plugins/fTools/tools/doDefineProj.py
Adding projection information (prj-file) no longer throws an error if folder has cyrillics. Fixes #2501.
Modified: trunk/qgis/python/plugins/fTools/tools/doDefineProj.py
--- trunk/qgis/python/plugins/fTools/tools/doDefineProj.py	2010-03-08 19:57:34 UTC (rev 13024)
+++ trunk/qgis/python/plugins/fTools/tools/doDefineProj.py	2010-03-08 20:19:04 UTC (rev 13025)
@@ -4,137 +4,121 @@
 from qgis.core import *
 from qgis.gui import *
+import ftools_utils
 from ui_frmReProject import Ui_Dialog
 class Dialog(QDialog, Ui_Dialog):
-	def __init__(self, iface):
-		QDialog.__init__(self)
-		self.iface = iface
-		self.setupUi(self)
-		self.toolOut.setEnabled(False)
-		self.toolOut.setVisible(False)
-		self.outShape.setEnabled(False)
-		self.outShape.setVisible(False)
-		self.label_2.setVisible(False)
-		self.label_2.setEnabled(False)
-		self.setWindowTitle(self.tr("Define current projection"))
-		QObject.connect(self.btnProjection, SIGNAL("clicked()"), self.outProjFile)
-		QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.updateProj1)
-		QObject.connect(self.cmbLayer, SIGNAL("currentIndexChanged(QString)"), self.updateProj2)
-		# populate layer list
-		self.progressBar.setValue(0)
-		mapCanvas = self.iface.mapCanvas()
-		for i in range(mapCanvas.layerCount()):
-			layer = mapCanvas.layer(i)
-			if layer.type() == layer.VectorLayer:
-				self.inShape.addItem(layer.name())
-				self.cmbLayer.addItem(layer.name())
+    def __init__(self, iface):
+        QDialog.__init__(self)
+        self.iface = iface
+        self.setupUi(self)
+        self.toolOut.setEnabled(False)
+        self.toolOut.setVisible(False)
+        self.outShape.setEnabled(False)
+        self.outShape.setVisible(False)
+        self.label_2.setVisible(False)
+        self.label_2.setEnabled(False)
+        self.setWindowTitle(self.tr("Define current projection"))
+        QObject.connect(self.btnProjection, SIGNAL("clicked()"), self.outProjFile)
+        QObject.connect(self.inShape, SIGNAL("currentIndexChanged(QString)"), self.updateProj1)
+        QObject.connect(self.cmbLayer, SIGNAL("currentIndexChanged(QString)"), self.updateProj2)
+        # populate layer list
+        self.progressBar.setValue(0)
+        mapCanvas = self.iface.mapCanvas()
+        layers = ftools_utils.getLayerNames([QGis.Point, QGis.Line, QGis.Polygon])
+        self.inShape.addItems(layers)
+        self.cmbLayer.addItems(layers)
-	def updateProj1(self, layerName):
-		tempLayer = self.getVectorLayerByName(layerName)
-		crs = tempLayer.dataProvider().crs().toProj4()
-		self.inRef.insert(unicode(crs))
+    def updateProj1(self, layerName):
+        tempLayer = ftools_utils.getVectorLayerByName(layerName)
+        crs = tempLayer.dataProvider().crs().toProj4()
+        self.inRef.insert(unicode(crs))
-	def updateProj2(self, layerName):
-		self.outRef.insert(unicode(crs))
+    def updateProj2(self, layerName):
+        self.outRef.insert(unicode(crs))
-	def accept(self):
-		if self.inShape.currentText() == "":
-			QMessageBox.information(self, self.tr("Define current projection"), self.tr("No input shapefile specified"))
-		elif self.txtProjection.text() == "" and self.rdoProjection.isChecked():
-			QMessageBox.information(self, self.tr("Define current projection"), self.tr("Please specify spatial reference system"))
-		elif self.cmbLayer.currentText() == "" and self.rdoLayer.isChecked():
-		else:
-			self.progressBar.setValue(5)
-			inName = self.inShape.currentText()
-			self.progressBar.setValue(10)
-			vLayer = self.getVectorLayerByName(inName)
-			self.progressBar.setValue(30)
-			if vLayer == "Error":
-				QMessageBox.information(self, self.tr("Define current projection"), self.tr("Cannot define projection for PostGIS data...yet!"))
-			else:
-				srsDefine = QgsCoordinateReferenceSystem()
-				if self.rdoProjection.isChecked():
-					outProj = self.txtProjection.text()
-					srsDefine.createFromProj4(outProj)
-				else:
-					destLayer = self.getVectorLayerByName(self.cmbLayer.currentText())
-					srsDefine = destLayer.srs()
-				if srsDefine == vLayer.srs():
-					QMessageBox.information(self, self.tr("Define current projection"), self.tr("Identical output spatial reference system chosen"))
-				else:
-					provider = vLayer.dataProvider()
-					self.progressBar.setValue(35)
-					inPath = provider.dataSourceUri()
-					inPath = inPath.remove( QRegExp( "\|.*" ) )
-					self.progressBar.setValue(40)
-					if inPath.endsWith(".shp"):
-						inPath = inPath.left(inPath.length() - 4)
-					self.progressBar.setValue(55)
-					if not srsDefine.isValid():
-						QMessageBox.information(self, self.tr("Define current projection"), self.tr("Output spatial reference system is not valid"))
-					else:
-						self.progressBar.setValue(60)
-						outputWkt = srsDefine.toWkt()
-						self.progressBar.setValue(65)
-						outputPrj = open(inPath + ".prj", "w")
-						self.progressBar.setValue(70)
-						outputPrj.write(outputWkt)
-						self.progressBar.setValue(75)
-						outputPrj.close()
-						mLayer = self.getMapLayerByName(inName)
-						self.progressBar.setValue(90)
-						if not mLayer.isValid():
-							QMessageBox.information(self, self.tr("Define current projection"), self.tr("Unable to dynamically define projection.\nPlease reload layer manually for projection definition to take effect."))
-						else:
-							self.progressBar.setValue(95)
-							mLayer.setCrs(srsDefine)
-							self.progressBar.setValue(100)
-							QMessageBox.information(self, self.tr("Define current projection"), self.tr("Defined Projection For:\n%1.shp").arg( inPath ) )
+    def accept(self):
+        if self.inShape.currentText() == "":
+            QMessageBox.information(self, self.tr("Define current projection"), self.tr("No input shapefile specified"))
+        elif self.txtProjection.text() == "" and self.rdoProjection.isChecked():
+            QMessageBox.information(self, self.tr("Define current projection"), self.tr("Please specify spatial reference system"))
+        elif self.cmbLayer.currentText() == "" and self.rdoLayer.isChecked():
+        else:
+            self.progressBar.setValue(5)
+            inName = self.inShape.currentText()
+            self.progressBar.setValue(10)
+            vLayer = ftools_utils.getVectorLayerByName(inName)
+            self.progressBar.setValue(30)
+            if vLayer == "Error":
+                QMessageBox.information(self, self.tr("Define current projection"), self.tr("Cannot define projection for PostGIS data...yet!"))
+            else:
+                srsDefine = QgsCoordinateReferenceSystem()
+                if self.rdoProjection.isChecked():
+                    outProj = self.txtProjection.text()
+                    srsDefine.createFromProj4(outProj)
+                else:
+                    destLayer = self.getVectorLayerByName(self.cmbLayer.currentText())
+                    srsDefine = destLayer.srs()
+                if srsDefine == vLayer.srs():
+                    QMessageBox.information(self, self.tr("Define current projection"), self.tr("Identical output spatial reference system chosen"))
+                else:
+                    provider = vLayer.dataProvider()
+                    self.progressBar.setValue(35)
+                    inPath = provider.dataSourceUri()
+                    inPath = inPath.remove( QRegExp( "\|.*" ) )
+                    self.progressBar.setValue(40)
+                    if inPath.endsWith(".shp"):
+                        inPath = inPath.left(inPath.length() - 4)
+                    self.progressBar.setValue(55)
+                    if not srsDefine.isValid():
+                        QMessageBox.information(self, self.tr("Define current projection"), self.tr("Output spatial reference system is not valid"))
+                    else:
+                        self.progressBar.setValue(60)
+                        outputWkt = srsDefine.toWkt()
+                        self.progressBar.setValue(65)
+                        outputPrj = open(unicode("%s.prj" % inPath), "w")
+                        self.progressBar.setValue(70)
+                        outputPrj.write(outputWkt)
+                        self.progressBar.setValue(75)
+                        outputPrj.close()
+                        #mLayer = self.getMapLayerByName(inName)
+                        #self.progressBar.setValue(90)
+                        #if not mLayer.isValid():
+                            #QMessageBox.information(self, self.tr("Define current projection"), self.tr("Unable to dynamically define projection.\nPlease reload layer manually for projection definition to take effect."))
+                        #else:
+                        self.progressBar.setValue(95)
+                        vLayer.setCrs(srsDefine)
+                        self.progressBar.setValue(100)
+                        QMessageBox.information(self, self.tr("Define current projection"), self.tr("Defined Projection For:\n%1.shp").arg( inPath ) )
-	def outProjFile(self):
-		format = QString( "<h2>%1</h2>%2 <br/> %3" )
-		header = QString( "Define layer CRS:" )
-		sentence1 = self.tr( "Please select the projection system that defines the current layer." )
-		sentence2 = self.tr( "Layer CRS information will be updated to the selected CRS." )
-		self.projSelect = QgsGenericProjectionSelector(self, Qt.Widget)
-		self.projSelect.setMessage( format.arg( header ).arg( sentence1 ).arg( sentence2 ))
-		if self.projSelect.exec_():
-			projString = self.projSelect.selectedProj4String()
-			if projString == "":
-				QMessageBox.information(self, self.tr("Export to new projection"), self.tr("No Valid CRS selected"))
-				return
-			else:
-				self.txtProjection.clear()
-				self.txtProjection.insert(projString)
-		else:
-			return
+    def outProjFile(self):
+        format = QString( "<h2>%1</h2>%2 <br/> %3" )
+        header = QString( "Define layer CRS:" )
+        sentence1 = self.tr( "Please select the projection system that defines the current layer." )
+        sentence2 = self.tr( "Layer CRS information will be updated to the selected CRS." )
+        self.projSelect = QgsGenericProjectionSelector(self, Qt.Widget)
+        self.projSelect.setMessage( format.arg( header ).arg( sentence1 ).arg( sentence2 ))
+        if self.projSelect.exec_():
+            projString = self.projSelect.selectedProj4String()
+            if projString == "":
+                QMessageBox.information(self, self.tr("Export to new projection"), self.tr("No Valid CRS selected"))
+                return
+            else:
+                self.txtProjection.clear()
+                self.txtProjection.insert(projString)
+        else:
+            return
-# Gets vector layer by layername in canvas
-	def getVectorLayerByName(self, myName):
-		mc = self.iface.mapCanvas()
-		nLayers = mc.layerCount()
-		for l in range(nLayers):
-			layer = mc.layer(l)
-			if layer.name() == unicode(myName,'latin1'):
-				if unicode(layer.dataProvider().name()) == "postgres":
-					return "Error"
-				else:
-					vlayer = QgsVectorLayer(unicode(layer.source()),  unicode(myName),  unicode(layer.dataProvider().name()))
-					if vlayer.isValid():
-						return vlayer
 #Gets map layer by layername in canvas
 #Return: QgsMapLayer
-	def getMapLayerByName(self,myName):
-				return layer
+    def getMapLayerByName(self,myName):
+        mc = self.iface.mapCanvas()
+        nLayers = mc.layerCount()
+        for l in range(nLayers):
+            layer = mc.layer(l)
+            if layer.name() == unicode(myName):
+                return layer
More information about the QGIS-commit mailing list
