[QGIS Commit] r13028 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 8 16:23:50 EST 2010
Author: cfarmer
Date: 2010-03-08 16:23:50 -0500 (Mon, 08 Mar 2010)
New Revision: 13028
   trunk/qgis/python/plugins/fTools/tools/doVisual.py
   trunk/qgis/python/plugins/fTools/tools/frmVisual.ui
Basic statistics tool should no longer crash with PostGIS layers. Also adds support for varchar, char, and text fields (PostGIS layers). Should fix #2510
Modified: trunk/qgis/python/plugins/fTools/tools/doVisual.py
--- trunk/qgis/python/plugins/fTools/tools/doVisual.py	2010-03-08 20:38:40 UTC (rev 13027)
+++ trunk/qgis/python/plugins/fTools/tools/doVisual.py	2010-03-08 21:23:50 UTC (rev 13028)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-
 from PyQt4.QtCore import *
 from PyQt4.QtGui import *
 from qgis.core import *
@@ -17,7 +18,7 @@
     self.cancel_close = self.buttonBox_2.button( QDialogButtonBox.Close )
     self.progressBar.setValue( 0 )
     self.partProgressBar.setValue( 0 )
-    self.partProgressBar.setEnabled( False )
+    self.partProgressBar.setVisible( False )
   def keyPressEvent( self, e ):
@@ -27,11 +28,11 @@
       selection = self.lstUnique.selectedItems()
       items = QString()
       if self.myFunction in ( 1, 2 ):
-	for rec in range( self.tblUnique.rowCount() ):
-	  items.append( self.tblUnique.item( rec, 0 ).text() + "\n" )
+        for rec in range( self.tblUnique.rowCount() ):
+          items.append( self.tblUnique.item( rec, 0 ).text() + "\n" )
       else:
-	  items.append( self.tblUnique.item( rec, 0 ).text() + ":" + self.tblUnique.item( rec, 1 ).text() + "\n" )
+          items.append( self.tblUnique.item( rec, 0 ).text() + ":" + self.tblUnique.item( rec, 1 ).text() + "\n" )
       if not items.isEmpty():
         clip_board = QApplication.clipboard()
         clip_board.setText( items )
@@ -125,26 +126,25 @@
   def runFinishedFromThread( self, output ):
     self.testThread.stop()
     result = output[ 0 ]
     numRows = len( result )
     self.tblUnique.setRowCount( numRows )
       self.tblUnique.setColumnCount( 1 )
       for rec in range( numRows ):
-	item = QTableWidgetItem( result[ rec ] )
-	self.tblUnique.setItem( rec, 0, item )
+        item = QTableWidgetItem( result[ rec ] )
+        self.tblUnique.setItem( rec, 0, item )
     else:
       self.tblUnique.setColumnCount( 2 )
-	tmp = result[ rec ].split( ":" )
-	item = QTableWidgetItem( tmp[ 0 ] )
-	item = QTableWidgetItem( tmp[ 1 ] )
-	self.tblUnique.setItem( rec, 1, item )
-	self.tblUnique.setHorizontalHeaderLabels( [ self.tr("Parameter"), self.tr("Value") ] )
-	self.tblUnique.horizontalHeader().setResizeMode( 1, QHeaderView.ResizeToContents )
-	self.tblUnique.horizontalHeader().show()
+        tmp = result[ rec ].split( ":" )
+        item = QTableWidgetItem( tmp[ 0 ] )
+        item = QTableWidgetItem( tmp[ 1 ] )
+        self.tblUnique.setItem( rec, 1, item )
+      self.tblUnique.setHorizontalHeaderLabels( [ self.tr("Parameter"), self.tr("Value") ] )
+      self.tblUnique.horizontalHeader().setResizeMode( 1, QHeaderView.ResizeToContents )
+      self.tblUnique.horizontalHeader().show()
     self.tblUnique.horizontalHeader().setResizeMode( 0, QHeaderView.Stretch )
     self.tblUnique.resizeRowsToContents()
@@ -162,11 +162,11 @@
   def runPartStatusFromThread( self, status ):
     self.partProgressBar.setValue( status )
     if status >= self.part_max:
   def runPartRangeFromThread( self, range_vals ):
     self.part_max = range_vals[ 1 ]
-    self.partProgressBar.setEnabled( True )
+    self.partProgressBar.setVisible( True )
     self.partProgressBar.setRange( range_vals[ 0 ], range_vals[ 1 ] )
 class visualThread( QThread ):
@@ -230,7 +230,8 @@
     first = True
     nElement = 0
     # determine selected field type
-    if ftools_utils.getFieldType( vlayer, myField ) == 'String':
+    if ftools_utils.getFieldType( vlayer, myField ) in (
+    'String', 'varchar', 'char', 'text'):
       fillVal = 0
       emptyVal = 0
       if self.mySelection: # only selected features
@@ -260,6 +261,7 @@
         nFeat = vprovider.featureCount()
         self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
         self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
+        vprovider.select( allAttrs )
         while vprovider.nextFeature( feat ):
           atMap = feat.attributeMap()
           lenVal = float( len( atMap[ index ].toString() ) )
@@ -290,14 +292,16 @@
       lstStats.append( self.tr( "N:" ) + unicode( nVal ) )
       return ( lstStats, [] )
     else: # numeric field
-      stdVal = 0
-      cvVal = 0
-      rangeVal = 0
-      medianVal = 0
+      stdVal = 0.00
+      cvVal = 0.00
+      rangeVal = 0.00
+      medianVal = 0.00
+      maxVal = 0.00
+      minVal = 0.00
         selection = vlayer.selectedFeatures()
         nFeat = vlayer.selectedFeatureCount()
-	uniqueVal = ftools_utils.getUniqueValuesCount( vlayer, index, True )
+        uniqueVal = ftools_utils.getUniqueValuesCount( vlayer, index, True )
         for f in selection:
@@ -316,9 +320,10 @@
           self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
       else: # there is no selection, process the whole layer
-	uniqueVal = ftools_utils.getUniqueValuesCount( vlayer, index, False )
+        uniqueVal = ftools_utils.getUniqueValuesCount( vlayer, index, False )
           value = float( atMap[ index ].toDouble()[ 0 ] )
@@ -343,12 +348,12 @@
           stdVal = math.sqrt( stdVal / nVal )
           cvVal = stdVal / meanVal
       if nVal > 1:
-	  lstVal = values
-	  lstVal.sort()
-	  if ( nVal % 2 ) == 0:
-	    medianVal = 0.5 * ( lstVal[ int( ( nVal - 1 ) / 2 ) ] + lstVal[ int( ( nVal ) / 2 ) ] )
-	  else:
-	    medianVal = lstVal[ int( ( nVal + 1 ) / 2 ) ]
+        lstVal = values
+        lstVal.sort()
+        if ( nVal % 2 ) == 0:
+            medianVal = 0.5 * ( lstVal[ int( ( nVal - 1 ) / 2 ) ] + lstVal[ int( ( nVal ) / 2 ) ] )
+        else:
+            medianVal = lstVal[ int( ( nVal + 1 ) / 2 ) ]
       lstStats = []
       lstStats.append( self.tr( "Mean:" ) + unicode( meanVal ) )
       lstStats.append( self.tr( "StdDev:" ) + unicode( stdVal ) )
@@ -411,6 +416,7 @@
     nElement = 0
       geom = QgsGeometry( feat.geometry() )
       nElement += 1
Modified: trunk/qgis/python/plugins/fTools/tools/frmVisual.ui
--- trunk/qgis/python/plugins/fTools/tools/frmVisual.ui	2010-03-08 20:38:40 UTC (rev 13027)
+++ trunk/qgis/python/plugins/fTools/tools/frmVisual.ui	2010-03-08 21:23:50 UTC (rev 13028)
@@ -34,6 +34,17 @@
      </item>
     </layout>
    </item>
+   <item row="3" column="0">
+    <layout class="QVBoxLayout" name="verticalLayout">
+     <item>
+      <widget class="QCheckBox" name="useSelected">
+       <property name="text">
+        <string>Use only selected features</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
    <item row="4" column="0" colspan="2">
     <layout class="QVBoxLayout">
      <item>
@@ -114,16 +125,15 @@
      </item>
     </layout>
    </item>
-   <item row="3" column="0">
-    <layout class="QVBoxLayout" name="verticalLayout">
-     <item>
-      <widget class="QCheckBox" name="useSelected">
-       <property name="text">
-        <string>Use only selected features</string>
-       </property>
-      </widget>
-     </item>
-    </layout>
+   <item row="9" column="0">
+    <widget class="QProgressBar" name="progressBar">
+     <property name="value">
+      <number>24</number>
+     </property>
+     <property name="alignment">
+      <set>Qt::AlignCenter</set>
+     </property>
+    </widget>
    </item>
    <item row="8" column="1" rowspan="2">
     <widget class="QDialogButtonBox" name="buttonBox_2">
@@ -135,27 +145,11 @@
      </property>
     </widget>
    </item>
-   <item row="9" column="0">
-    <widget class="QProgressBar" name="progressBar">
-     <property name="value">
-      <number>24</number>
-     </property>
-     <property name="alignment">
-      <set>Qt::AlignCenter</set>
-     </property>
-    </widget>
-   </item>
    <item row="8" column="0">
     <widget class="QProgressBar" name="partProgressBar">
-     <property name="enabled">
-      <bool>false</bool>
-     </property>
       <number>24</number>
      </property>
-     </property>
     </widget>
    </item>
   </layout>
More information about the QGIS-commit mailing list
